Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/81225?usp=email )
Change subject: amdfwtool: Move the address of tables to the context ......................................................................
Instead of being local variables. This can be easier to find all the tables anywhere.
TEST=Identical test on all AMD SOC platform
Change-Id: I98b7d01e32c75b4f13e23d496cd3de3da900678d Signed-off-by: Zheng Bao fishbaozi@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/81225 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M util/amdfwtool/amdfwtool.c M util/amdfwtool/amdfwtool.h 2 files changed, 92 insertions(+), 62 deletions(-)
diff --git a/util/amdfwtool/amdfwtool.c b/util/amdfwtool/amdfwtool.c index ef97010..aedd326 100644 --- a/util/amdfwtool/amdfwtool.c +++ b/util/amdfwtool/amdfwtool.c @@ -813,6 +813,30 @@ } }
+static void dump_image_addresses(context *ctx) +{ + printf("romsig offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->amd_romsig_ptr)); + printf("PSP L1 offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->pspdir)); + if (ctx->pspdir2 != NULL) + printf("PSP L2(A) offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->pspdir2)); + if (ctx->ish_a_dir != NULL) + printf("ISHA offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->ish_a_dir)); + if (ctx->ish_b_dir != NULL) + printf("ISHB offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->ish_b_dir)); + if (ctx->pspdir2_b != NULL) + printf("PSP L2B offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->pspdir2_b)); + if (ctx->biosdir != NULL) + printf("BHD offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->biosdir)); + if (ctx->biosdir2 != NULL) + printf("BHD L2(A) offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->biosdir2)); + if (ctx->biosdir2_b != NULL) + printf("BHD L2B offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->biosdir2_b)); + if (ctx->psp_combo_dir != NULL) + printf("PSP combo offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->psp_combo_dir)); + if (ctx->bhd_combo_dir != NULL) + printf("BHD combo offset:%lx\n", BUFF_TO_RUN(*ctx, ctx->bhd_combo_dir)); +} + static void integrate_psp_ab(context *ctx, psp_directory_table *pspdir, psp_directory_table *pspdir2, ish_directory_table *ish, amd_fw_type ab, enum platform soc_id) @@ -871,7 +895,6 @@ uint64_t addr; uint32_t current_table_save; bool recovery_ab = cb_config->recovery_ab; - ish_directory_table *ish_a_dir = NULL, *ish_b_dir = NULL; bool use_only_a = (cb_config->soc_id == PLATFORM_PHOENIX); /* TODO: b:285390041 */
/* This function can create a primary table, a secondary table, or a @@ -999,19 +1022,19 @@
if (recovery_ab && (pspdir2 != NULL)) { if (cb_config->need_ish) { /* Need ISH */ - ish_a_dir = new_ish_dir(ctx); + ctx->ish_a_dir = new_ish_dir(ctx); if (pspdir2_b != NULL) - ish_b_dir = new_ish_dir(ctx); + ctx->ish_b_dir = new_ish_dir(ctx); } pspdir->header.num_entries = count; - integrate_psp_ab(ctx, pspdir, pspdir2, ish_a_dir, + integrate_psp_ab(ctx, pspdir, pspdir2, ctx->ish_a_dir, AMD_FW_RECOVERYAB_A, cb_config->soc_id); if (pspdir2_b != NULL) - integrate_psp_ab(ctx, pspdir, pspdir2_b, ish_b_dir, + integrate_psp_ab(ctx, pspdir, pspdir2_b, ctx->ish_b_dir, use_only_a ? AMD_FW_RECOVERYAB_A : AMD_FW_RECOVERYAB_B, cb_config->soc_id); else - integrate_psp_ab(ctx, pspdir, pspdir2, ish_a_dir, + integrate_psp_ab(ctx, pspdir, pspdir2, ctx->ish_a_dir, use_only_a ? AMD_FW_RECOVERYAB_A : AMD_FW_RECOVERYAB_B, cb_config->soc_id);
@@ -1511,11 +1534,6 @@ int main(int argc, char **argv) { int retval = 0; - embedded_firmware *amd_romsig; - psp_directory_table *pspdir = NULL; - psp_directory_table *pspdir2 = NULL; - psp_directory_table *pspdir2_b = NULL; - psp_combo_directory *psp_combo_dir = NULL, *bhd_combo_dir = NULL; int combo_index = 0; int targetfd; context ctx = { 0 }; @@ -1551,14 +1569,14 @@ romsig_offset = cb_config.efs_location ? cb_config.efs_location : AMD_ROMSIG_OFFSET; set_current_pointer(&ctx, romsig_offset);
- amd_romsig = BUFF_OFFSET(ctx, romsig_offset); - amd_romsig->signature = EMBEDDED_FW_SIGNATURE; - amd_romsig->imc_entry = 0; - amd_romsig->gec_entry = 0; - amd_romsig->xhci_entry = 0; + ctx.amd_romsig_ptr = BUFF_OFFSET(ctx, romsig_offset); + ctx.amd_romsig_ptr->signature = EMBEDDED_FW_SIGNATURE; + ctx.amd_romsig_ptr->imc_entry = 0; + ctx.amd_romsig_ptr->gec_entry = 0; + ctx.amd_romsig_ptr->xhci_entry = 0;
if (cb_config.soc_id != PLATFORM_UNKNOWN) { - retval = set_efs_table(cb_config.soc_id, &cb_config, amd_romsig); + retval = set_efs_table(cb_config.soc_id, &cb_config, ctx.amd_romsig_ptr); if (retval) { fprintf(stderr, "ERROR: Failed to initialize EFS table!\n"); return retval; @@ -1579,7 +1597,7 @@ else set_current_pointer(&ctx, romsig_offset + sizeof(embedded_firmware));
- integrate_firmwares(&ctx, amd_romsig, amd_fw_table); + integrate_firmwares(&ctx, ctx.amd_romsig_ptr, amd_fw_table);
if (is_initial_alignment_required(cb_config.soc_id)) { /* TODO: Check for older platforms. */ @@ -1596,12 +1614,12 @@ cb_config.soc_id);
if (cb_config.use_combo) { - psp_combo_dir = new_combo_dir(&ctx); + ctx.psp_combo_dir = new_combo_dir(&ctx);
adjust_current_pointer(&ctx, 0, 0x1000U);
if (!cb_config.recovery_ab) - bhd_combo_dir = new_combo_dir(&ctx); + ctx.bhd_combo_dir = new_combo_dir(&ctx); }
combo_index = 0; @@ -1612,6 +1630,14 @@ if (cb_config.use_combo && cb_config.debug) printf("Processing %dth combo entry\n", combo_index);
+ ctx.pspdir = NULL; + ctx.pspdir2 = NULL; + ctx.pspdir2_b = NULL; + ctx.biosdir = NULL; + ctx.biosdir2 = NULL; + ctx.biosdir2_b = NULL; + ctx.ish_a_dir = NULL; + ctx.ish_b_dir = NULL; /* for non-combo image, combo_config[0] == config, and * it already is processed. Actually "combo_index > * 0" is enough. Put both of them here to make sure @@ -1640,14 +1666,14 @@
if (cb_config.multi_level) { /* Do 2nd PSP directory followed by 1st */ - pspdir2 = new_psp_dir(&ctx, cb_config.multi_level); - integrate_psp_firmwares(&ctx, pspdir2, NULL, NULL, + ctx.pspdir2 = new_psp_dir(&ctx, cb_config.multi_level); + integrate_psp_firmwares(&ctx, ctx.pspdir2, NULL, NULL, amd_psp_fw_table, PSPL2_COOKIE, &cb_config); if (cb_config.recovery_ab && !cb_config.recovery_ab_single_copy) { /* Create a copy of PSP Directory 2 in the backup slot B. Related biosdir2_b copy will be created later. */ - pspdir2_b = new_psp_dir(&ctx, cb_config.multi_level); - integrate_psp_firmwares(&ctx, pspdir2_b, NULL, NULL, + ctx.pspdir2_b = new_psp_dir(&ctx, cb_config.multi_level); + integrate_psp_firmwares(&ctx, ctx.pspdir2_b, NULL, NULL, amd_psp_fw_table, PSPL2_COOKIE, &cb_config); } else { /* @@ -1658,88 +1684,87 @@ * Related biosdir2_b will be skipped * automatically. */ - pspdir2_b = NULL; /* More explicitly */ + ctx.pspdir2_b = NULL; /* More explicitly */ } - pspdir = new_psp_dir(&ctx, cb_config.multi_level); - integrate_psp_firmwares(&ctx, pspdir, pspdir2, pspdir2_b, + ctx.pspdir = new_psp_dir(&ctx, cb_config.multi_level); + integrate_psp_firmwares(&ctx, ctx.pspdir, ctx.pspdir2, ctx.pspdir2_b, amd_psp_fw_table, PSP_COOKIE, &cb_config); } else { /* flat: PSP 1 cookie and no pointer to 2nd table */ - pspdir = new_psp_dir(&ctx, cb_config.multi_level); - integrate_psp_firmwares(&ctx, pspdir, NULL, NULL, + ctx.pspdir = new_psp_dir(&ctx, cb_config.multi_level); + integrate_psp_firmwares(&ctx, ctx.pspdir, NULL, NULL, amd_psp_fw_table, PSP_COOKIE, &cb_config); }
if (!cb_config.use_combo) { - fill_psp_directory_to_efs(amd_romsig, pspdir, &ctx, &cb_config); + fill_psp_directory_to_efs(ctx.amd_romsig_ptr, ctx.pspdir, &ctx, &cb_config); } else { - fill_psp_directory_to_efs(amd_romsig, psp_combo_dir, &ctx, &cb_config); + fill_psp_directory_to_efs(ctx.amd_romsig_ptr, ctx.psp_combo_dir, &ctx, &cb_config); /* 0 -Compare PSP ID, 1 -Compare chip family ID */ assert_fw_entry(combo_index, MAX_COMBO_ENTRIES, &ctx); - psp_combo_dir->entries[combo_index].id_sel = 0; - psp_combo_dir->entries[combo_index].id = get_psp_id(cb_config.soc_id); - psp_combo_dir->entries[combo_index].lvl2_addr = - BUFF_TO_RUN_MODE(ctx, pspdir, AMD_ADDR_REL_BIOS); + ctx.psp_combo_dir->entries[combo_index].id_sel = 0; + ctx.psp_combo_dir->entries[combo_index].id = get_psp_id(cb_config.soc_id); + ctx.psp_combo_dir->entries[combo_index].lvl2_addr = + BUFF_TO_RUN_MODE(ctx, ctx.pspdir, AMD_ADDR_REL_BIOS);
- fill_dir_header(psp_combo_dir, combo_index + 1, PSP2_COOKIE, &ctx); + fill_dir_header(ctx.psp_combo_dir, combo_index + 1, PSP2_COOKIE, &ctx); }
if (have_bios_tables(amd_bios_table)) { - bios_directory_table *biosdir = NULL; if (cb_config.multi_level) { /* Do 2nd level BIOS directory followed by 1st */ - bios_directory_table *biosdir2 = NULL; - bios_directory_table *biosdir2_b = NULL; + ctx.biosdir2 = new_bios_dir(&ctx, cb_config.multi_level);
- biosdir2 = new_bios_dir(&ctx, cb_config.multi_level); - - integrate_bios_firmwares(&ctx, biosdir2, NULL, + integrate_bios_firmwares(&ctx, ctx.biosdir2, NULL, amd_bios_table, BHDL2_COOKIE, &cb_config); if (cb_config.recovery_ab) { - if (pspdir2_b != NULL) { - biosdir2_b = new_bios_dir(&ctx, + if (ctx.pspdir2_b != NULL) { + ctx.biosdir2_b = new_bios_dir(&ctx, cb_config.multi_level); - integrate_bios_firmwares(&ctx, biosdir2_b, NULL, + integrate_bios_firmwares(&ctx, ctx.biosdir2_b, NULL, amd_bios_table, BHDL2_COOKIE, &cb_config); } - add_psp_firmware_entry(&ctx, pspdir2, biosdir2, + add_psp_firmware_entry(&ctx, ctx.pspdir2, ctx.biosdir2, AMD_FW_BIOS_TABLE, TABLE_ALIGNMENT); - if (pspdir2_b != NULL) - add_psp_firmware_entry(&ctx, pspdir2_b, - biosdir2_b, AMD_FW_BIOS_TABLE, + if (ctx.pspdir2_b != NULL) + add_psp_firmware_entry(&ctx, ctx.pspdir2_b, + ctx.biosdir2_b, AMD_FW_BIOS_TABLE, TABLE_ALIGNMENT); } else { - biosdir = new_bios_dir(&ctx, cb_config.multi_level); - integrate_bios_firmwares(&ctx, biosdir, biosdir2, + ctx.biosdir = new_bios_dir(&ctx, cb_config.multi_level); + integrate_bios_firmwares(&ctx, ctx.biosdir, ctx.biosdir2, amd_bios_table, BHD_COOKIE, &cb_config); } } else { /* flat: BHD1 cookie and no pointer to 2nd table */ - biosdir = new_bios_dir(&ctx, cb_config.multi_level); - integrate_bios_firmwares(&ctx, biosdir, NULL, + ctx.biosdir = new_bios_dir(&ctx, cb_config.multi_level); + integrate_bios_firmwares(&ctx, ctx.biosdir, NULL, amd_bios_table, BHD_COOKIE, &cb_config); } if (!cb_config.use_combo) { - fill_bios_directory_to_efs(amd_romsig, biosdir, + fill_bios_directory_to_efs(ctx.amd_romsig_ptr, ctx.biosdir, &ctx, &cb_config); - } else if (bhd_combo_dir != NULL) { + } else if (ctx.bhd_combo_dir != NULL) { /* In recovery A/B mode, there isn't a BHD combo directory. * Instead, the BIOS tables level 2 are linked by PSP tables. */ - fill_bios_directory_to_efs(amd_romsig, bhd_combo_dir, + fill_bios_directory_to_efs(ctx.amd_romsig_ptr, ctx.bhd_combo_dir, &ctx, &cb_config); assert_fw_entry(combo_index, MAX_COMBO_ENTRIES, &ctx); - bhd_combo_dir->entries[combo_index].id_sel = 0; - bhd_combo_dir->entries[combo_index].id = + ctx.bhd_combo_dir->entries[combo_index].id_sel = 0; + ctx.bhd_combo_dir->entries[combo_index].id = get_psp_id(cb_config.soc_id); - bhd_combo_dir->entries[combo_index].lvl2_addr = - BUFF_TO_RUN_MODE(ctx, biosdir, AMD_ADDR_REL_BIOS); + ctx.bhd_combo_dir->entries[combo_index].lvl2_addr = + BUFF_TO_RUN_MODE(ctx, ctx.biosdir, AMD_ADDR_REL_BIOS);
- fill_dir_header(bhd_combo_dir, combo_index + 1, + fill_dir_header(ctx.bhd_combo_dir, combo_index + 1, BHD2_COOKIE, &ctx); + } } + if (cb_config.debug) + dump_image_addresses(&ctx); } while (cb_config.use_combo && ++combo_index < MAX_COMBO_ENTRIES && cb_config.combo_config[combo_index] != NULL);
@@ -1747,7 +1772,7 @@ if (targetfd >= 0) { uint32_t offset = cb_config.efs_location; uint32_t bytes = cb_config.efs_location == cb_config.body_location ? - ctx.current - offset : sizeof(*amd_romsig); + ctx.current - offset : sizeof(embedded_firmware); uint32_t ret_bytes;
ret_bytes = write_from_buf_to_file(targetfd, BUFF_OFFSET(ctx, offset), bytes); diff --git a/util/amdfwtool/amdfwtool.h b/util/amdfwtool/amdfwtool.h index fdcd6a8..1dc445c 100644 --- a/util/amdfwtool/amdfwtool.h +++ b/util/amdfwtool/amdfwtool.h @@ -452,6 +452,11 @@ uint8_t ins; uint8_t sub; } combo_apcb[MAX_COMBO_ENTRIES], combo_apcb_bk[MAX_COMBO_ENTRIES]; + embedded_firmware *amd_romsig_ptr; + psp_directory_table *pspdir, *pspdir2, *pspdir2_b; + bios_directory_table *biosdir, *biosdir2, *biosdir2_b; + psp_combo_directory *psp_combo_dir, *bhd_combo_dir; + ish_directory_table *ish_a_dir, *ish_b_dir; } context;
uint8_t process_config(FILE *config, amd_cb_config *cb_config);
