Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6226
commit c252aa0f492b75d0004d208a40cea4ec07afe4df Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Wed Jul 9 05:22:32 2014 +1000
Fix romstage dev type, 'device_t' -> 'pci_devfn_t' in get_sbdn()
Unfortunately coreboot has to deal with ROMCC's short comings which has lead to a little bit of confusion due to typedefs. Essentially, coreboot defines four typedefs:
* 'typedef struct device * device_t' in ramstage not in SIMPLE_DEVICE mode * 'typedef u32 device_t' in romstage or when SIMPLE_DEVICE is defined * 'typedef u32 pnp_devfn_t' * 'typedef u32 pci_devfn_t'
Some early functions make use of 'device_t' over 'pci_devfn_t' and since the C type-checker does not enforce typedefs to the same type 'u32' these are never noticed. Fix these so that 'device_t' does not conflict in romstage for later work. We later plan to have 'pnp_devfn_t' and 'pci_devfn_t' as the only variants of 'u32' and 'device_t' to be a struct pointer type exclusively.
Change-Id: Ied3940d9b2ec119ca4b75b955305add59edbbb18 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/mainboard/asus/a8v-e_deluxe/romstage.c | 2 +- src/mainboard/asus/a8v-e_se/romstage.c | 2 +- src/mainboard/asus/k8v-x/romstage.c | 2 +- src/mainboard/asus/m2v-mx_se/romstage.c | 2 +- src/mainboard/asus/m2v/romstage.c | 2 +- src/southbridge/amd/cimx/sb700/early.c | 2 +- src/southbridge/amd/cimx/sb800/early.c | 2 +- src/southbridge/amd/sb600/early_setup.c | 2 +- src/southbridge/amd/sb700/early_setup.c | 2 +- src/southbridge/broadcom/bcm5785/early_setup.c | 2 +- src/southbridge/nvidia/mcp55/early_ctrl.c | 2 +- src/southbridge/sis/sis966/early_ctrl.c | 2 +- 12 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/src/mainboard/asus/a8v-e_deluxe/romstage.c b/src/mainboard/asus/a8v-e_deluxe/romstage.c index 1dea57b..9604816 100644 --- a/src/mainboard/asus/a8v-e_deluxe/romstage.c +++ b/src/mainboard/asus/a8v-e_deluxe/romstage.c @@ -90,7 +90,7 @@ void soft_reset(void)
unsigned int get_sbdn(unsigned bus) { - device_t dev; + pci_devfn_t dev;
dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_VT8237R_LPC), bus); diff --git a/src/mainboard/asus/a8v-e_se/romstage.c b/src/mainboard/asus/a8v-e_se/romstage.c index abe5f84..1261293 100644 --- a/src/mainboard/asus/a8v-e_se/romstage.c +++ b/src/mainboard/asus/a8v-e_se/romstage.c @@ -90,7 +90,7 @@ void soft_reset(void)
dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_VT8237R_LPC), bus); diff --git a/src/mainboard/asus/k8v-x/romstage.c b/src/mainboard/asus/k8v-x/romstage.c index 4d6bd60..e4b9c6b 100644 --- a/src/mainboard/asus/k8v-x/romstage.c +++ b/src/mainboard/asus/k8v-x/romstage.c @@ -88,7 +88,7 @@ void soft_reset(void)
dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_VT8237R_LPC), bus); diff --git a/src/mainboard/asus/m2v-mx_se/romstage.c b/src/mainboard/asus/m2v-mx_se/romstage.c index d374828..6e113c0 100644 --- a/src/mainboard/asus/m2v-mx_se/romstage.c +++ b/src/mainboard/asus/m2v-mx_se/romstage.c @@ -107,7 +107,7 @@ void soft_reset(void)
dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_VT8237R_LPC), bus); diff --git a/src/mainboard/asus/m2v/romstage.c b/src/mainboard/asus/m2v/romstage.c index a2c6a03..94b1251 100644 --- a/src/mainboard/asus/m2v/romstage.c +++ b/src/mainboard/asus/m2v/romstage.c @@ -91,7 +91,7 @@ void soft_reset(void)
dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_VT8237R_LPC), bus); diff --git a/src/southbridge/amd/cimx/sb700/early.c b/src/southbridge/amd/cimx/sb700/early.c index 6dc4ff4..fd9d26b 100644 --- a/src/southbridge/amd/cimx/sb700/early.c +++ b/src/southbridge/amd/cimx/sb700/early.c @@ -34,7 +34,7 @@ */ u32 get_sbdn(u32 bus) { - device_t dev; + pci_devfn_t dev;
printk(BIOS_SPEW, "SB700 - Early.c - %s - Start.\n", __func__); dev = pci_locate_device_on_bus( diff --git a/src/southbridge/amd/cimx/sb800/early.c b/src/southbridge/amd/cimx/sb800/early.c index 40648ed..0341567 100644 --- a/src/southbridge/amd/cimx/sb800/early.c +++ b/src/southbridge/amd/cimx/sb800/early.c @@ -33,7 +33,7 @@ */ u32 get_sbdn(u32 bus) { - device_t dev; + pci_devfn_t dev;
printk(BIOS_DEBUG, "SB800 - %s - %s - Start.\n", __FILE__, __func__); //dev = PCI_DEV(bus, 0x14, 0); diff --git a/src/southbridge/amd/sb600/early_setup.c b/src/southbridge/amd/sb600/early_setup.c index b6611f6..6797399 100644 --- a/src/southbridge/amd/sb600/early_setup.c +++ b/src/southbridge/amd/sb600/early_setup.c @@ -106,7 +106,7 @@ static void sb600_lpc_init(void) /* what is its usage? */ static u32 get_sbdn(u32 bus) { - device_t dev; + pci_devfn_t dev;
/* Find the device. */ dev = pci_locate_device_on_bus(PCI_ID(0x1002, 0x4385), bus); diff --git a/src/southbridge/amd/sb700/early_setup.c b/src/southbridge/amd/sb700/early_setup.c index b7a5e77..7208146 100644 --- a/src/southbridge/amd/sb700/early_setup.c +++ b/src/southbridge/amd/sb700/early_setup.c @@ -221,7 +221,7 @@ void sb7xx_51xx_disable_wideio(u8 wio_index) /* what is its usage? */ u32 __attribute__ ((weak)) get_sbdn(u32 bus) { - device_t dev; + pci_devfn_t dev;
/* Find the device. */ dev = pci_locate_device_on_bus(PCI_ID(0x1002, 0x4385), bus); diff --git a/src/southbridge/broadcom/bcm5785/early_setup.c b/src/southbridge/broadcom/bcm5785/early_setup.c index 9dee295..0a69e5e 100644 --- a/src/southbridge/broadcom/bcm5785/early_setup.c +++ b/src/southbridge/broadcom/bcm5785/early_setup.c @@ -69,7 +69,7 @@ static void bcm5785_enable_wdt_port_cf9(void)
unsigned get_sbdn(unsigned bus) { - device_t dev; + pci_devfn_t dev;
/* Find the device. * There can only be one bcm5785 on a hypertransport chain/bus. diff --git a/src/southbridge/nvidia/mcp55/early_ctrl.c b/src/southbridge/nvidia/mcp55/early_ctrl.c index 92f9d03..865c023 100644 --- a/src/southbridge/nvidia/mcp55/early_ctrl.c +++ b/src/southbridge/nvidia/mcp55/early_ctrl.c @@ -24,7 +24,7 @@
static unsigned get_sbdn(unsigned bus) { - device_t dev; + pci_devfn_t dev;
/* Find the device. */ dev = pci_locate_device_on_bus(PCI_ID(PCI_VENDOR_ID_NVIDIA, diff --git a/src/southbridge/sis/sis966/early_ctrl.c b/src/southbridge/sis/sis966/early_ctrl.c index 3695023..4b3a228 100644 --- a/src/southbridge/sis/sis966/early_ctrl.c +++ b/src/southbridge/sis/sis966/early_ctrl.c @@ -23,7 +23,7 @@
