Attention is currently required from: Andrey Petrov. Hello build bot (Jenkins), Werner Zeh, Andrey Petrov,
https://review.coreboot.org/c/coreboot/+/63546
Change subject: intel/common/block: Provide RAPL and min clock ratio switches in common ......................................................................
There are two APL specific config switches for RAPL and min. cpu clock (APL_SKIP_SET_POWER_LIMITS, APL_SET_MIN_CLOCK_RATIO). This switches could be used in future in other CPU platforms. Move them to common code instead of having them just for one SOC.
Test: Make sure that the clock ratio (MSR 0x198) and the RAPL settings (MSR0x610) do not change with this patch applied on mc_apl{1,4,5} mainboard.
Change-Id: I3d63d1b9b6c96586a3c20bf8c1d8001b1d7c4bed Signed-off-by: Uwe Poeche uwe.poeche@siemens.com --- M src/mainboard/siemens/mc_apl1/variants/mc_apl1/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl3/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig M src/soc/intel/apollolake/Kconfig M src/soc/intel/apollolake/chip.c M src/soc/intel/apollolake/cpu.c M src/soc/intel/common/block/cpu/Kconfig 9 files changed, 26 insertions(+), 27 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/46/63546/4
