Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/74126 )
Change subject: soc/amd/mendocino: Reinterpret smu_power_and_thm_limit ......................................................................
The FSP will return the TDP in the format 0xX0000, where 'X' is the value we're interested in. For example: 0xF0000 (15W), 0x60000 (6W). Re-interpret the value so the caller just sees the TDP directly, without needing to re-interpret things themselves.
BUG=b:253301653 TEST=Manually verify value is correct
Change-Id: I632e702d986a4ac85605040e09c1afab2bbdc59d Signed-off-by: Tim Van Patten timvp@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/74126 Reviewed-by: Felix Held felix-coreboot@felixheld.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/mendocino/fsp_misc_data_hob.c 1 file changed, 29 insertions(+), 1 deletion(-)
diff --git a/src/soc/amd/mendocino/fsp_misc_data_hob.c b/src/soc/amd/mendocino/fsp_misc_data_hob.c index 103f821..3b51fd8 100644 --- a/src/soc/amd/mendocino/fsp_misc_data_hob.c +++ b/src/soc/amd/mendocino/fsp_misc_data_hob.c @@ -43,7 +43,14 @@ if (get_amd_misc_data_hob(&fsp_misc_data, AMD_MISC_DATA_VERSION) != CB_SUCCESS) return CB_ERR;
- *tdp = fsp_misc_data->smu_power_and_thm_limit; + /* + * The FSP will return the TDP in the format 0xX0000, where 'X' is the value + * we're interested in. For example: 0xF0000 (15W), 0x60000 (6W). Re-interpret + * the value so the caller just sees the TDP. + */ + printk(BIOS_INFO, "fsp_misc_data->smu_power_and_thm_limit = 0x%08X\n", + fsp_misc_data->smu_power_and_thm_limit); + *tdp = fsp_misc_data->smu_power_and_thm_limit >> 16;
return CB_SUCCESS; }
