Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10867
commit 8e04cc0c44d7963915801eb7f5cea3aeee89b1b0 Author: Patrick Georgi pgeorgi@chromium.org Date: Tue Jul 14 17:15:51 2015 +0100
cbtable: describe boot media
This allows finding the currently used CBFS (in case there are several), and avoids the need to define flash size when building the payload.
Change-Id: I4b00159610077761c501507e136407e9ae08c73e Signed-off-by: Aaron Durbin adurbin@chromium.org Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- src/include/boot/coreboot_tables.h | 11 +++++++++++ src/lib/coreboot_table.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/src/include/boot/coreboot_tables.h b/src/include/boot/coreboot_tables.h index c8d5251..3dddde5 100644 --- a/src/include/boot/coreboot_tables.h +++ b/src/include/boot/coreboot_tables.h @@ -297,6 +297,17 @@ struct lb_spi_flash { uint32_t erase_cmd; };
+#define LB_TAG_BOOT_MEDIA_PARAMS 0x0030 +struct lb_boot_media_params { + uint32_t tag; + uint32_t size; + /* offsets are relative to start of boot media */ + uint64_t fmap_offset; + uint64_t cbfs_offset; + uint64_t cbfs_size; + uint64_t boot_media_size; +}; + #define LB_TAG_SERIALNO 0x002a #define MAX_SERIALNO_LENGTH 32
diff --git a/src/lib/coreboot_table.c b/src/lib/coreboot_table.c index f7fb2bb..a41fb29 100644 --- a/src/lib/coreboot_table.c +++ b/src/lib/coreboot_table.c @@ -23,10 +23,12 @@ #include <console/uart.h> #include <ip_checksum.h> #include <boot/coreboot_tables.h> +#include <boot_device.h> #include <string.h> #include <version.h> #include <boardid.h> #include <device/device.h> +#include <fmap.h> #include <stdlib.h> #include <cbfs.h> #include <cbmem.h> @@ -228,6 +230,36 @@ static void lb_board_id(struct lb_header *header) #endif }
+static void lb_boot_media_params(struct lb_header *header) +{ + struct lb_boot_media_params *bmp; + struct cbfs_props props; + const struct region_device *boot_dev; + struct region_device fmrd; + + boot_device_init(); + + if (cbfs_boot_region_properties(&props)) + return; + + boot_dev = boot_device_ro(); + if (boot_dev == NULL) + return; + + bmp = (struct lb_boot_media_params *)lb_new_record(header); + bmp->tag = LB_TAG_BOOT_MEDIA_PARAMS; + bmp->size = sizeof(*bmp); + + bmp->cbfs_offset = props.offset; + bmp->cbfs_size = props.size; + bmp->boot_media_size = region_device_sz(boot_dev); + + bmp->fmap_offset = ~0; + if (find_fmap_directory(&fmrd) == 0) { + bmp->fmap_offset = region_device_offset(&fmrd); + } +} + static void lb_ram_code(struct lb_header *header) { #if IS_ENABLED(CONFIG_RAM_CODE_SUPPORT) @@ -483,6 +515,8 @@ unsigned long write_coreboot_table( lb_ramoops(head); #endif
+ lb_boot_media_params(head); + /* Remember where my valid memory ranges are */ return lb_table_fini(head); }
