Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56528 )
Change subject: soc/amd/cezanne/fch: implement and use fch_clk_output_48Mhz ......................................................................
Make sure that the 48MHz clock output that is typically used as a clock source for an I2S audio codec or a Super I/O chip.
TEST=On Guybrush before and after this patch the final state of MISC_CLK_CNTL0 is 0x1006044, so BP_X48M0_OUTPUT_EN is set in both cases.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I38be344a95ccf166c344b2bddcb388fea437a4df Reviewed-on: https://review.coreboot.org/c/coreboot/+/56528 Reviewed-by: Marshall Dawson marshalldawson3rd@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/cezanne/fch.c M src/soc/amd/cezanne/include/soc/southbridge.h 2 files changed, 11 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Marshall Dawson: Looks good to me, approved
diff --git a/src/soc/amd/cezanne/fch.c b/src/soc/amd/cezanne/fch.c index 81fb5d2..f39eeb6 100644 --- a/src/soc/amd/cezanne/fch.c +++ b/src/soc/amd/cezanne/fch.c @@ -73,6 +73,14 @@ return irq_association; }
+static void fch_clk_output_48Mhz(void) +{ + uint32_t ctrl = misc_read32(MISC_CLK_CNTL0); + /* Enable BP_X48M0 Clock Output */ + ctrl |= BP_X48M0_OUTPUT_EN; + misc_write32(MISC_CLK_CNTL0, ctrl); +} + static void fch_init_acpi_ports(void) { u32 reg; @@ -172,6 +180,7 @@ acpi_clear_pm_gpe_status();
gpp_clk_setup(); + fch_clk_output_48Mhz(); }
void fch_final(void *chip_info) diff --git a/src/soc/amd/cezanne/include/soc/southbridge.h b/src/soc/amd/cezanne/include/soc/southbridge.h index 386d3c1..31387b6 100644 --- a/src/soc/amd/cezanne/include/soc/southbridge.h +++ b/src/soc/amd/cezanne/include/soc/southbridge.h @@ -78,6 +78,8 @@ #define GPP_CLK_REQ_EXT(clk_shift) (0x1 << (clk_shift)) #define GPP_CLK_REQ_OFF(clk_shift) (0x0 << (clk_shift))
+#define MISC_CLK_CNTL0 0x40 /* named MISC_CLK_CNTL1 on Picasso */ +#define BP_X48M0_OUTPUT_EN BIT(2) /* 1=En, unlike Hudson, Kern */ #define MISC_I2C0_PAD_CTRL 0xd8 #define MISC_I2C1_PAD_CTRL 0xdc #define MISC_I2C2_PAD_CTRL 0xe0
