Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11942
commit 565ee009c50649258993dc7d50fbdf43fe161038 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Tue Sep 8 16:08:45 2015 -0500
northbridge/amd/amdmct/mct_ddr3: Fix curly brace style violations
Change-Id: Ic27d404a7ed76b58043037e8b66097db6d664501 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdmct/mct_ddr3/mhwlc_d.c | 37 ++++++++------------------- 1 file changed, 10 insertions(+), 27 deletions(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mhwlc_d.c b/src/northbridge/amd/amdmct/mct_ddr3/mhwlc_d.c index c76476b..9f42d54 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mhwlc_d.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mhwlc_d.c @@ -818,28 +818,19 @@ void setWLByteDelay(sDCTStruct *pDCTData, u8 ByteLane, u8 dimm, u8 targetAddr)
tempB = 0; offsetAddr = (u8)(3 * dimm); - if (ByteLane < 2) - { + if (ByteLane < 2) { tempB = (u8)(16 * ByteLane); addr = DRAM_CONT_ADD_DQS_TIMING_CTRL_BL_01; - } - else if (ByteLane <4) - { + } else if (ByteLane <4) { tempB = (u8)(16 * ByteLane); addr = DRAM_CONT_ADD_DQS_TIMING_CTRL_BL_01 + 1; - } - else if (ByteLane <6) - { + } else if (ByteLane <6) { tempB = (u8)(16 * ByteLane); addr = DRAM_CONT_ADD_DQS_TIMING_CTRL_BL_45; - } - else if (ByteLane <8) - { + } else if (ByteLane <8) { tempB = (u8)(16 * ByteLane); addr = DRAM_CONT_ADD_DQS_TIMING_CTRL_BL_45 + 1; - } - else - { + } else { tempB = 0; addr = DRAM_CONT_ADD_DQS_TIMING_CTRL_BL_01 + 2; } @@ -883,19 +874,14 @@ void getWLByteDelay(sDCTStruct *pDCTData, u8 ByteLane, u8 dimm) u32 addr, fine, gross; tempB = 0; index = (u8)(MAX_BYTE_LANES*dimm); - if (ByteLane < 4) - { + if (ByteLane < 4) { tempB = (u8)(8 * ByteLane); addr = DRAM_CONT_ADD_PHASE_REC_CTRL_LOW; - } - else if (ByteLane < 8) - { + } else if (ByteLane < 8) { tempB1 = (u8)(ByteLane - 4); tempB = (u8)(8 * tempB1); addr = DRAM_CONT_ADD_PHASE_REC_CTRL_HIGH; - } - else - { + } else { tempB = 0; addr = DRAM_CONT_ADD_ECC_PHASE_REC_CTRL; } @@ -911,16 +897,13 @@ void getWLByteDelay(sDCTStruct *pDCTData, u8 ByteLane, u8 dimm) /* Adjust seed gross delay overflow (greater than 3): * - Adjust the trained gross delay to the original seed gross delay. */ - if(pDCTData->WLGrossDelay[index+ByteLane] >= 3) - { + if (pDCTData->WLGrossDelay[index+ByteLane] >= 3) { gross += pDCTData->WLGrossDelay[index+ByteLane]; if(pDCTData->WLGrossDelay[index+ByteLane] & 1) gross -= 1; else gross -= 2; - } - else if((pDCTData->WLGrossDelay[index+ByteLane] == 0) && (gross == 3)) - { + } else if ((pDCTData->WLGrossDelay[index+ByteLane] == 0) && (gross == 3)) { /* If seed gross delay is 0 but PRE result gross delay is 3, it is negative. * We will then round the negative number to 0. */
