Ronald G. Minnich (rminnich@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17132
commit ca3c5cb1bc2f5a809d5bbdb4bd3673208e3368ca Author: Ronald G. Minnich rminnich@gmail.com Date: Tue Oct 25 19:11:07 2016 -0700
riscv: add the lowrisc/nexys4ddr mainboard
This was tested at the coreboot meeting in Berlin.
The uart programming may still not be right but when used with the lowrisc bitstream for the board we were able to load and start linux, although it does not yet get far due to PTE version issues with lowrisc.
Change-Id: Ia1de1a92762631c9d7bb3d41b04f95296144caa3 Signed-off-by: Ronald G. Minnich rminnich@gmail.com --- src/mainboard/lowrisc/Kconfig | 16 ++++ src/mainboard/lowrisc/Kconfig.name | 2 + src/mainboard/lowrisc/nexys4ddr/Kconfig | 38 +++++++++ src/mainboard/lowrisc/nexys4ddr/Kconfig.name | 2 + src/mainboard/lowrisc/nexys4ddr/Makefile.inc | 28 +++++++ src/mainboard/lowrisc/nexys4ddr/board_info.txt | 3 + src/mainboard/lowrisc/nexys4ddr/devicetree.cb | 20 +++++ src/mainboard/lowrisc/nexys4ddr/mainboard.c | 36 +++++++++ src/mainboard/lowrisc/nexys4ddr/memlayout.ld | 31 ++++++++ src/mainboard/lowrisc/nexys4ddr/rom_media.c | 30 +++++++ src/mainboard/lowrisc/nexys4ddr/romstage.c | 23 ++++++ src/mainboard/lowrisc/nexys4ddr/uart.c | 40 ++++++++++ src/mainboard/lowrisc/nexys4ddr/util.c | 103 +++++++++++++++++++++++++ 13 files changed, 372 insertions(+)
diff --git a/src/mainboard/lowrisc/Kconfig b/src/mainboard/lowrisc/Kconfig new file mode 100644 index 0000000..ba0fbe7 --- /dev/null +++ b/src/mainboard/lowrisc/Kconfig @@ -0,0 +1,16 @@ +if VENDOR_LOWRISC + +choice + prompt "Mainboard model" + +source "src/mainboard/lowrisc/*/Kconfig.name" + +endchoice + +source "src/mainboard/lowrisc/*/Kconfig" + +config MAINBOARD_VENDOR + string + default "lowrisc" + +endif # VENDOR_LOWRISC diff --git a/src/mainboard/lowrisc/Kconfig.name b/src/mainboard/lowrisc/Kconfig.name new file mode 100644 index 0000000..4c992fc --- /dev/null +++ b/src/mainboard/lowrisc/Kconfig.name @@ -0,0 +1,2 @@ +config VENDOR_LOWRISC + bool "lowrisc" diff --git a/src/mainboard/lowrisc/nexys4ddr/Kconfig b/src/mainboard/lowrisc/nexys4ddr/Kconfig new file mode 100644 index 0000000..f0a3637 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/Kconfig @@ -0,0 +1,38 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Google Inc. +## +## This software is licensed under the terms of the GNU General Public +## License version 2, as published by the Free Software Foundation, and +## may be copied, distributed, and modified under those terms. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. + +if BOARD_LOWRISC_NEXYS4DDR + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select SOC_LOWRISC_LOWRISC + select BOARD_ROMSIZE_KB_4096 + select DRIVERS_UART_8250MEM + select BOOT_DEVICE_NOT_SPI_FLASH + select UART_OVERRIDE_REFCLK + select UART_OVERRIDE_INPUT_CLOCK_DIVIDER + +config MAINBOARD_DIR + string + default lowrisc/nexys4ddr + +config MAINBOARD_PART_NUMBER + string + default "LOWRISC NEXYS4DDR" + +config MAX_CPUS + int + default 1 + +endif # BOARD_LOWRISC_NEXYS4DDR diff --git a/src/mainboard/lowrisc/nexys4ddr/Kconfig.name b/src/mainboard/lowrisc/nexys4ddr/Kconfig.name new file mode 100644 index 0000000..f99b3cc --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_LOWRISC_NEXYS4DDR + bool "nexys4ddr" diff --git a/src/mainboard/lowrisc/nexys4ddr/Makefile.inc b/src/mainboard/lowrisc/nexys4ddr/Makefile.inc new file mode 100644 index 0000000..69519b1 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/Makefile.inc @@ -0,0 +1,28 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Google Inc. +## +## This software is licensed under the terms of the GNU General Public +## License version 2, as published by the Free Software Foundation, and +## may be copied, distributed, and modified under those terms. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. + +bootblock-y += uart.c +bootblock-y += util.c +bootblock-y += rom_media.c +romstage-y += romstage.c +romstage-y += uart.c +romstage-y += util.c +romstage-y += rom_media.c +ramstage-y += uart.c +ramstage-y += util.c +ramstage-y += rom_media.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/lowrisc/nexys4ddr/board_info.txt b/src/mainboard/lowrisc/nexys4ddr/board_info.txt new file mode 100644 index 0000000..a305030 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/board_info.txt @@ -0,0 +1,3 @@ +Board name: lowrisc nexys4ddr +Category: eval +Board URL: https://www.google.com/search?q=Tutorial+for+the+debug+preview+of+lowRISC&am... diff --git a/src/mainboard/lowrisc/nexys4ddr/devicetree.cb b/src/mainboard/lowrisc/nexys4ddr/devicetree.cb new file mode 100644 index 0000000..e857276 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/devicetree.cb @@ -0,0 +1,20 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Google, Inc. +## +## This software is licensed under the terms of the GNU General Public +## License version 2, as published by the Free Software Foundation, and +## may be copied, distributed, and modified under those terms. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. + +chip soc/ucb/riscv + device cpu_cluster 0 on end + chip drivers/generic/generic # I2C0 controller + device i2c 6 on end # Fake component for testing + end +end diff --git a/src/mainboard/lowrisc/nexys4ddr/mainboard.c b/src/mainboard/lowrisc/nexys4ddr/mainboard.c new file mode 100644 index 0000000..8c3ea1a --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/mainboard.c @@ -0,0 +1,36 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Google, Inc. + * + * This software is licensed under the terms of the GNU General Public + * License version 2, as published by the Free Software Foundation, and + * may be copied, distributed, and modified under those terms. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <device/device.h> +#include <cbmem.h> +#include <symbols.h> + +static void mainboard_enable(device_t dev) +{ + /* + * TODO: Get this size from the hardware-supplied configuration string. + */ + const size_t ram_size = 1*GiB; + + if (!dev) + die("No dev0; die\n"); + + ram_resource(dev, 0, (uintptr_t)_dram / KiB, ram_size / KiB); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/lowrisc/nexys4ddr/memlayout.ld b/src/mainboard/lowrisc/nexys4ddr/memlayout.ld new file mode 100644 index 0000000..0348c47 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/memlayout.ld @@ -0,0 +1,31 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2016 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +#define START 0x80000000 + +SECTIONS +{ + DRAM_START(START) + BOOTBLOCK(START, 64K) + STACK(START + 8M, 64K) + ROMSTAGE(START + 8M + 64K, 128K) + PRERAM_CBMEM_CONSOLE(START + 8M + 192k, 8K) + PAGETABLES(START + 8M + 200K, 56K) + RAMSTAGE(START + 8M + 256K, 256K) +} diff --git a/src/mainboard/lowrisc/nexys4ddr/rom_media.c b/src/mainboard/lowrisc/nexys4ddr/rom_media.c new file mode 100644 index 0000000..7d4ed00 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/rom_media.c @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * Copyright 2016 Jonathan Neuschäfer j.neuschaefer@gmx.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#include <boot_device.h> +#include <symbols.h> + +/* + * _dram is the start of RAM. We currently need to load coreboot.rom into + * RAM. The actual "rom" code on the FPGAs is in a block ram. + */ +static const struct mem_region_device boot_dev = + MEM_REGION_DEV_RO_INIT(_dram, CONFIG_ROM_SIZE); + +const struct region_device *boot_device_ro(void) +{ + return &boot_dev.rdev; +} diff --git a/src/mainboard/lowrisc/nexys4ddr/romstage.c b/src/mainboard/lowrisc/nexys4ddr/romstage.c new file mode 100644 index 0000000..1509efb --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/romstage.c @@ -0,0 +1,23 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Google, Inc. + * + * This software is licensed under the terms of the GNU General Public + * License version 2, as published by the Free Software Foundation, and + * may be copied, distributed, and modified under those terms. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <program_loading.h> +#include <console/console.h> + +void main(void) +{ + console_init(); + run_ramstage(); +} diff --git a/src/mainboard/lowrisc/nexys4ddr/uart.c b/src/mainboard/lowrisc/nexys4ddr/uart.c new file mode 100644 index 0000000..e3c233f80 --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/uart.c @@ -0,0 +1,40 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2016 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <types.h> +#include <console/uart.h> +#include <arch/io.h> +#include <boot/coreboot_tables.h> +#include <spike_util.h> + +uintptr_t uart_platform_base(int idx) +{ + return (uintptr_t) 0x42000000; +} + +/* these are currently not quite right but they are here for reference + * and will be fixed when lowrisc gives us a standard clock + * and set of values. */ +// divisor = clk_freq / (16 * Baud) +unsigned int uart_input_clock_divider(void) +{ + return (25 * 1000 * 1000u / (16u * 115200u)) % 0x100; +} + +// System clock 25 MHz, 115200 baud rate +unsigned int uart_platform_refclk(void) +{ + return (25 * 1000 * 1000u / (16u * 115200u)) >> 8; +} diff --git a/src/mainboard/lowrisc/nexys4ddr/util.c b/src/mainboard/lowrisc/nexys4ddr/util.c new file mode 100644 index 0000000..32cdb6d --- /dev/null +++ b/src/mainboard/lowrisc/nexys4ddr/util.c @@ -0,0 +1,103 @@ +/* + * Copyright (c) 2013, The Regents of the University of California (Regents). + * All Rights Reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. Neither the name of the Regents nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT, + * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING + * LOST PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS + * DOCUMENTATION, EVEN IF REGENTS HAS BEEN ADVISED OF THE POSSIBILITY + * OF SUCH DAMAGE. + * + * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT + * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS + * FOR A PARTICULAR PURPOSE. THE SOFTWARE AND ACCOMPANYING + * DOCUMENTATION, IF ANY, PROVIDED HEREUNDER IS PROVIDED "AS + * IS". REGENTS HAS NO OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, + * UPDATES, ENHANCEMENTS, OR MODIFICATIONS. + */ + +#include <arch/barrier.h> +#include <arch/errno.h> +#include <atomic.h> +#include <console/console.h> +#include <spike_util.h> +#include <string.h> +#include <vm.h> + +uintptr_t mcall_query_memory(uintptr_t id, memory_block_info *info) +{ + if (id == 0) { + mprv_write_ulong(&info->base, 2U*GiB); + + /* TODO: Return the correct value */ + mprv_write_ulong(&info->size, 1*GiB); + return 0; + } + + return -1; +} + +uintptr_t mcall_send_ipi(uintptr_t recipient) +{ + die("mcall_send_ipi is currently not implemented"); + return 0; +} + +uintptr_t mcall_clear_ipi(void) +{ + // only clear SSIP if no other events are pending + if (HLS()->device_response_queue_head == NULL) { + clear_csr(mip, MIP_SSIP); + /* Ensure the other hart sees it. */ + mb(); + } + + return atomic_swap(&HLS()->ipi_pending, 0); +} + +uintptr_t mcall_shutdown(void) +{ + die("mcall_shutdown is currently not implemented"); + return 0; +} + +uintptr_t mcall_set_timer(unsigned long long when) +{ + printk(BIOS_DEBUG, "mcall_set_timer is currently not implemented, ignoring\n"); + return 0; +} + +uintptr_t mcall_dev_req(sbi_device_message *m) +{ + die("mcall_dev_req is currently not implemented"); + return 0; +} + +uintptr_t mcall_dev_resp(void) +{ + die("mcall_dev_resp is currently not implemented"); + return 0; +} + +void hls_init(uint32_t hart_id) +{ + memset(HLS(), 0, sizeof(*HLS())); + HLS()->hart_id = hart_id; +} + +uintptr_t mcall_console_putchar(uint8_t ch) +{ + do_putchar(ch); + return 0; +}
