Attention is currently required from: Jason Glenesk, Furquan Shaikh, Martin Roth, Marshall Dawson, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Martin Roth, Marshall Dawson, Paul Menzel, Karthik Ramasubramanian, Felix Held,
https://review.coreboot.org/c/coreboot/+/55987
Change subject: soc/amd/common/block/cpu: Cache the uCode to avoid multiple SPI reads ......................................................................
We are currently reading the uCode for each CPU. This is unnecessary since the uCode never changes.
BUG=b:177909625 TEST=Boot guybrush and see "microcode: being updated to patch id" for each CPU. I no longer see CBFS access for each CPU. This drops device initialization time by 32 ms.
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I98b9d4ce8290a1f08063176809e903e671663208 --- M src/soc/amd/common/block/cpu/update_microcode.c 1 file changed, 20 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/55987/2
