Attention is currently required from: Bora Guvendik, Anil Kumar K, Subrata Banik, Tim Wawrzynczak, Paul Menzel, Thejaswani Putta. Cliff Huang has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/61354 )
Change subject: drivers/wwan/fm: Add Fibocom 5G WWAN ACPI support ......................................................................
Patch Set 10:
(2 comments)
File src/drivers/wwan/fm/acpi_fm350gl.c:
https://review.coreboot.org/c/coreboot/+/61354/comment/be0184d5_2c6185db PS7, Line 64: /* warm reset */ : acpigen_write_if_lequal_op_int(ARG0_OP, 0); : acpigen_write_sleep(FM350GL_TBTG); : /* cold reset */ : acpigen_write_else(); : acpigen_write_if_lequal_op_int(ARG0_OP, 1);
okay. Let me change to this.
Done
https://review.coreboot.org/c/coreboot/+/61354/comment/b944a79c_e2f3bd54 PS7, Line 52: acpigen_write_method_serialized("FHRF", 1); : /* LOCAL0 = PERST# */ : acpigen_get_tx_gpio(&config->perst_gpio); : acpigen_write_if_lequal_op_int(LOCAL0_OP, 0); : if (wwan_fm350gl_get_rtd3_method_support(config) | ACPI_PCIE_RP_EMIT_L23) : acpigen_emit_namestring(acpi_device_path_join(parent_dev, "DL23")); : /* assert PERST# pin */ : acpigen_enable_tx_gpio(&config->perst_gpio); : acpigen_write_if_end(); /* If */ : acpigen_write_sleep(FM350GL_TR2B); : /* assert RESET# pin */ : acpigen_enable_tx_gpio(&config->reset_gpio); : /* warm reset */ : acpigen_write_if_lequal_op_int(ARG0_OP, 0); : acpigen_write_sleep(FM350GL_TBTG); : /* cold reset */ : acpigen_write_else(); : acpigen_write_if_lequal_op_int(ARG0_OP, 1); : /* disable source clock */ : if (wwan_fm350gl_get_rtd3_method_support(config) | ACPI_PCIE_RP_EMIT_SRCK) : acpigen_emit_namestring(acpi_device_path_join(parent_dev, "SRCK")); : acpigen_emit_byte(ZERO_OP); : acpigen_write_sleep(FM350GL_TB2F); : /* assert FCPO# pin */ : acpigen_enable_tx_gpio(&config->fcpo_gpio); : acpigen_write_sleep(FM350GL_TFDI); : acpigen_write_if_end(); /* If */ : acpigen_pop_len(); /* Else */ : acpigen_write_method_end(); /* Method */ : }
Good. I thought about the same thing, but I decided to follow the existing code. […]
Done
