Attention is currently required from: Felix Held, Fred Reitberger, Zheng Bao.
Hello Felix Held, Fred Reitberger, Zheng Bao, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81255?usp=email
Change subject: amdfwtool: Set the table size only for FWs ......................................................................
The entry in the table has two categaries, file and pointer. For the pointer, it does not take space. The ISH, PSP level 2, BIOS table are all the pointer type. So only integration function packs FWs which increase the table size.
The fill_dir_header can take the parameter count as 0, such PSP level 1 only with ISH-A and ISH-B. It doesn't have any file type enties.
Change-Id: I5dfbbb55912c8e37243c351427a8df89c12e5da8 Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M util/amdfwtool/amdfwtool.c 1 file changed, 17 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/55/81255/2
