Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52755 )
Change subject: mb/google/dedede/var/boten: Modify DPTF parameters ......................................................................
DPTF parameters from thermal team.
1. Modify TSR1 sensor as charge sensor. 2. Modify P-state parameter
BUG=b:180641150 BRANCH=dedede TEST=build and verified by thermal team.
Change-Id: I43002db61de650d29cd85944a4eaea1b2f99aec4 Signed-off-by: Stanley Wu stanley1.wu@lcfc.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/52755 Reviewed-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/dedede/variants/boten/overridetree.cb 1 file changed, 36 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Sumeet R Pawnikar: Looks good to me, approved
diff --git a/src/mainboard/google/dedede/variants/boten/overridetree.cb b/src/mainboard/google/dedede/variants/boten/overridetree.cb index cfb440e..8c68f7e 100644 --- a/src/mainboard/google/dedede/variants/boten/overridetree.cb +++ b/src/mainboard/google/dedede/variants/boten/overridetree.cb @@ -87,15 +87,48 @@ register "policies.passive" = "{ [0] = DPTF_PASSIVE(CPU, CPU, 90, 10000), [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 80, 60000), - [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 55, 15000),}" + [2] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_1, 75, 15000) + }" + ## Critical Policy register "policies.critical" = "{ [0] = DPTF_CRITICAL(CPU, 105, SHUTDOWN), [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 90, SHUTDOWN), - [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 80, SHUTDOWN),}" + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 90, SHUTDOWN) + }" + + ## Power Limits Control + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 3000, + .max_power = 6000, + .time_window_min = 1 * MSECS_PER_SEC, + .time_window_max = 1 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 20000, + .max_power = 20000, + .time_window_min = 1 * MSECS_PER_SEC, + .time_window_max = 1 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + register "options.tsr[0].desc" = ""Memory"" + register "options.tsr[1].desc" = ""Charger"" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 3000 }, + [1] = { 24, 2000 }, + [2] = { 16, 1500 }, + [3] = { 8, 1000 } + }" + device generic 0 on end end - end + end # SA Thermal device device pci 14.0 on chip drivers/usb/acpi register "desc" = ""Root Hub""
