Nico Huber has uploaded this change for review. ( https://review.coreboot.org/27062
Change subject: gma: Turn constants depending on Config.CPU* into functions ......................................................................
To reduce elaboration time dependencies, turn constants at package level into functions. This will allow us to use the same code for configurations with constant and non-constant `GMA.Config.CPU*`.
Change-Id: I0522f5c63c63080bf9633f3d1b6019f35e52d226 Signed-off-by: Nico Huber nico.h@gmx.de --- M common/hw-gfx-gma-pch-fdi.adb M common/hw-gfx-gma-pch-vga.adb M common/hw-gfx-gma-pch.ads M common/ironlake/hw-gfx-gma-connectors-fdi.adb M common/ironlake/hw-gfx-gma-pch-hdmi.adb 5 files changed, 49 insertions(+), 39 deletions(-)
git pull ssh://review.coreboot.org:29418/libgfxinit refs/changes/62/27062/1
diff --git a/common/hw-gfx-gma-pch-fdi.adb b/common/hw-gfx-gma-pch-fdi.adb index 0217639..1d2361c 100644 --- a/common/hw-gfx-gma-pch-fdi.adb +++ b/common/hw-gfx-gma-pch-fdi.adb @@ -30,15 +30,18 @@ FDI_RX_CTL_RAWCLK_TO_PCDCLK_SEL_RAWCLK : constant := 0 * 2 ** 4; FDI_RX_CTL_RAWCLK_TO_PCDCLK_SEL_PCDCLK : constant := 1 * 2 ** 4;
- TP_SHIFT : constant := (if Config.Has_Original_ILK_Trans then 28 else 8); - FDI_RX_CTL_TRAINING_PATTERN_MASK : constant := 3 * 2 ** TP_SHIFT; + function TP_SHIFT return Natural is + (if Config.Has_Original_ILK_Trans then 28 else 8);
- type TP_Array is array (Training_Pattern) of Word32; - FDI_RX_CTL_TRAINING_PATTERN : constant TP_Array := - (TP_1 => 0 * 2 ** TP_SHIFT, - TP_2 => 1 * 2 ** TP_SHIFT, - TP_Idle => 2 * 2 ** TP_SHIFT, - TP_None => 3 * 2 ** TP_SHIFT); + function FDI_RX_CTL_TRAINING_PATTERN_MASK + return Word32 is (Shift_Left (3, TP_SHIFT)); + + function FDI_RX_CTL_TRAINING_PATTERN (TP : Training_Pattern) return Word32 is + (case TP is + when TP_1 => Shift_Left (0, TP_SHIFT), + when TP_2 => Shift_Left (1, TP_SHIFT), + when TP_Idle => Shift_Left (2, TP_SHIFT), + when TP_None => Shift_Left (3, TP_SHIFT));
function FDI_RX_CTL_PORT_WIDTH_SEL (Lane_Count : DP_Lane_Count) return Word32 is diff --git a/common/hw-gfx-gma-pch-vga.adb b/common/hw-gfx-gma-pch-vga.adb index f090246..fd82740 100644 --- a/common/hw-gfx-gma-pch-vga.adb +++ b/common/hw-gfx-gma-pch-vga.adb @@ -29,13 +29,13 @@ PCH_ADPA_VSYNC_ACTIVE_HIGH : constant := 1 * 2 ** 4; PCH_ADPA_HSYNC_ACTIVE_HIGH : constant := 1 * 2 ** 3;
- PCH_ADPA_MASK : constant Word32 := - PCH_TRANSCODER_SELECT_MASK or + function PCH_ADPA_MASK return Word32 is + (PCH_TRANSCODER_SELECT_MASK or PCH_ADPA_DAC_ENABLE or PCH_ADPA_VSYNC_DISABLE or PCH_ADPA_HSYNC_DISABLE or PCH_ADPA_VSYNC_ACTIVE_HIGH or - PCH_ADPA_HSYNC_ACTIVE_HIGH; + PCH_ADPA_HSYNC_ACTIVE_HIGH);
diff --git a/common/hw-gfx-gma-pch.ads b/common/hw-gfx-gma-pch.ads index 1e05e90..300e377 100644 --- a/common/hw-gfx-gma-pch.ads +++ b/common/hw-gfx-gma-pch.ads @@ -22,16 +22,16 @@
-- common to all PCH outputs
- PCH_TRANSCODER_SELECT_SHIFT : constant := + function PCH_TRANSCODER_SELECT_SHIFT return Natural is (if Config.Has_Original_ILK_Trans then 30 else 29);
- PCH_TRANSCODER_SELECT_MASK : constant := + function PCH_TRANSCODER_SELECT_MASK return Word32 is (if Config.Has_Original_ILK_Trans then 1 * 2 ** 30 else 3 * 2 ** 29);
- type PCH_TRANSCODER_SELECT_Array is array (FDI_Port_Type) of Word32; - PCH_TRANSCODER_SELECT : constant PCH_TRANSCODER_SELECT_Array := - (FDI_A => 0 * 2 ** PCH_TRANSCODER_SELECT_SHIFT, - FDI_B => 1 * 2 ** PCH_TRANSCODER_SELECT_SHIFT, - FDI_C => 2 * 2 ** PCH_TRANSCODER_SELECT_SHIFT); + function PCH_TRANSCODER_SELECT (Port : FDI_Port_Type) return Word32 is + (case Port is + when FDI_A => Shift_Left (0, PCH_TRANSCODER_SELECT_SHIFT), + when FDI_B => Shift_Left (1, PCH_TRANSCODER_SELECT_SHIFT), + when FDI_C => Shift_Left (2, PCH_TRANSCODER_SELECT_SHIFT));
end HW.GFX.GMA.PCH; diff --git a/common/ironlake/hw-gfx-gma-connectors-fdi.adb b/common/ironlake/hw-gfx-gma-connectors-fdi.adb index 6a41d21..6fd7a1c 100644 --- a/common/ironlake/hw-gfx-gma-connectors-fdi.adb +++ b/common/ironlake/hw-gfx-gma-connectors-fdi.adb @@ -14,6 +14,7 @@
with HW.Time; with HW.GFX.GMA.Config; +with HW.GFX.GMA.DP_Info; with HW.GFX.GMA.PCH.FDI; with HW.GFX.GMA.Registers;
@@ -40,12 +41,18 @@ FDI_TX_CTL_AUTO_TRAIN_ENABLE : constant := 1 * 2 ** 10; FDI_TX_CTL_AUTO_TRAIN_DONE : constant := 1 * 2 ** 1;
- TP_SHIFT : constant := (if Config.Has_Ivy_Bridge_FDI then 8 else 28); - FDI_TX_CTL_TRAINING_PATTERN_MASK : constant := 3 * 2 ** TP_SHIFT; - FDI_TX_CTL_TRAINING_PATTERN_1 : constant := 0 * 2 ** TP_SHIFT; - FDI_TX_CTL_TRAINING_PATTERN_2 : constant := 1 * 2 ** TP_SHIFT; - FDI_TX_CTL_TRAINING_PATTERN_IDLE : constant := 2 * 2 ** TP_SHIFT; - FDI_TX_CTL_TRAINING_PATTERN_NORMAL : constant := 3 * 2 ** TP_SHIFT; + function TP_SHIFT return Natural is + (if Config.Has_Ivy_Bridge_FDI then 8 else 28); + function FDI_TX_CTL_TRAINING_PATTERN_MASK + return Word32 is (Shift_Left (3, TP_SHIFT)); + function FDI_TX_CTL_TRAINING_PATTERN (TP : DP_Info.Training_Pattern) + return Word32 is + (case TP is + when DP_Info.TP_1 => Shift_Left (0, TP_SHIFT), + when DP_Info.TP_2 => Shift_Left (1, TP_SHIFT), + when DP_Info.TP_Idle => Shift_Left (2, TP_SHIFT), + when DP_Info.TP_None => Shift_Left (3, TP_SHIFT), + when others => 0);
subtype FDI_TX_CTL_VP_T is Natural range 0 .. 3; type Vswing_Preemph_Values is array (FDI_TX_CTL_VP_T) of Word32; @@ -88,7 +95,7 @@ Mask_Set => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_VSWING_PREEMPH (VP2 / 2) or FDI_TX_CTL_AUTO_TRAIN_ENABLE or - FDI_TX_CTL_TRAINING_PATTERN_1); + FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Auto_Train (PCH_FDI_Port); @@ -109,7 +116,7 @@ Mask_Unset => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_AUTO_TRAIN_ENABLE or FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_1); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1));
PCH.FDI.Off (PCH_FDI_Port, PCH.FDI.Rx_Off); end loop; @@ -149,7 +156,7 @@ FDI_TX_CTL_TRAINING_PATTERN_MASK, Mask_Set => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_VSWING_PREEMPH (VP2 / 2) or - FDI_TX_CTL_TRAINING_PATTERN_1); + FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_1, Success); @@ -158,7 +165,7 @@ Registers.Unset_And_Set_Mask (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_2); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_2)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_2, Success); @@ -169,7 +176,7 @@ (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_1); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1));
PCH.FDI.Off (PCH_FDI_Port, PCH.FDI.Rx_Off); end loop; @@ -178,7 +185,7 @@ Registers.Unset_And_Set_Mask (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_NORMAL); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_None)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_None, Success); @@ -219,7 +226,7 @@ (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_TRAINING_PATTERN_MASK, Mask_Set => FDI_TX_CTL_FDI_TX_ENABLE or - FDI_TX_CTL_TRAINING_PATTERN_1); + FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_1, Success); @@ -228,7 +235,7 @@ Registers.Unset_And_Set_Mask (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_2); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_2)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_2, Success); @@ -238,7 +245,7 @@ Registers.Unset_And_Set_Mask (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_NORMAL); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_None)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port));
PCH.FDI.Train (PCH_FDI_Port, PCH.FDI.TP_None, Success); @@ -247,7 +254,7 @@ (Register => TX_CTL (Port_Cfg.Port), Mask_Unset => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_1); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1)); PCH.FDI.Off (PCH_FDI_Port, PCH.FDI.Rx_Off);
Registers.Unset_Mask @@ -293,7 +300,7 @@ FDI_TX_CTL_ENHANCED_FRAMING_ENABLE or FDI_TX_CTL_FDI_PLL_ENABLE or Composite_Sel or - FDI_TX_CTL_TRAINING_PATTERN_1); + FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1)); Registers.Posting_Read (TX_CTL (Port_Cfg.Port)); Time.U_Delay (100); end Pre_On; @@ -327,7 +334,7 @@ Mask_Unset => FDI_TX_CTL_FDI_TX_ENABLE or FDI_TX_CTL_AUTO_TRAIN_ENABLE or FDI_TX_CTL_TRAINING_PATTERN_MASK, - Mask_Set => FDI_TX_CTL_TRAINING_PATTERN_1); + Mask_Set => FDI_TX_CTL_TRAINING_PATTERN (DP_Info.TP_1));
diff --git a/common/ironlake/hw-gfx-gma-pch-hdmi.adb b/common/ironlake/hw-gfx-gma-pch-hdmi.adb index e53d85a..aaf7951 100644 --- a/common/ironlake/hw-gfx-gma-pch-hdmi.adb +++ b/common/ironlake/hw-gfx-gma-pch-hdmi.adb @@ -31,13 +31,13 @@ PCH_HDMI_HSYNC_ACTIVE_HIGH : constant := 1 * 2 ** 3; PCH_HDMI_PORT_DETECT : constant := 1 * 2 ** 2;
- PCH_HDMI_MASK : constant Word32 := - PCH_TRANSCODER_SELECT_MASK or + function PCH_HDMI_MASK return Word32 is + (PCH_TRANSCODER_SELECT_MASK or PCH_HDMI_ENABLE or PCH_HDMI_COLOR_FORMAT_MASK or PCH_HDMI_SDVO_ENCODING_MASK or PCH_HDMI_HSYNC_ACTIVE_HIGH or - PCH_HDMI_VSYNC_ACTIVE_HIGH; + PCH_HDMI_VSYNC_ACTIVE_HIGH);
type PCH_HDMI_Array is array (PCH_HDMI_Port) of Registers.Registers_Index; PCH_HDMI : constant PCH_HDMI_Array := PCH_HDMI_Array'
