Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36994 )
Change subject: sb/intel/ibexpeak: Decode more LPC IO ranges ......................................................................
This fixes Thinkpad X201T which uses IO 0x200 for wacom digitizer.
Change-Id: Ie569d567a65010aa5372323f8610a1b8b5d2599d Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/southbridge/intel/ibexpeak/bootblock.c 1 file changed, 15 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/36994/1
diff --git a/src/southbridge/intel/ibexpeak/bootblock.c b/src/southbridge/intel/ibexpeak/bootblock.c index 599e182..c8b1d6e 100644 --- a/src/southbridge/intel/ibexpeak/bootblock.c +++ b/src/southbridge/intel/ibexpeak/bootblock.c @@ -62,15 +62,21 @@ const struct device *dev = pcidev_on_root(0x1f, 0); const struct southbridge_intel_ibexpeak_config *config = NULL;
- /* Add some default decode ranges: - - 0x2e/2f, 0x4e/0x4f - - EC/Mouse/KBC 60/64, 62/66 - - 0x3f8 COMA - If more are needed, update in mainboard_lpc_init hook - */ - pci_write_config16(PCH_LPC_DEV, LPC_EN, - CNF2_LPC_EN | CNF1_LPC_EN | MC_LPC_EN | KBC_LPC_EN | - COMA_LPC_EN); + /* + * Enable some common LPC IO ranges: + * - 0x2e/0x2f, 0x4e/0x4f often SuperIO + * - 0x60/0x64, 0x62/0x66 often KBC/EC + * - 0x3f0-0x3f5/0x3f7 FDD + * - 0x378-0x37f and 0x778-0x77f LPT + * - 0x2f8-0x2ff COMB + * - 0x3f8-0x3ff COMA + * - 0x208-0x20f GAMEH + * - 0x200-0x207 GAMEL + */ + pci_write_config16(PCH_LPC_DEV, LPC_EN, CNF2_LPC_EN | CNF1_LPC_EN + | MC_LPC_EN | KBC_LPC_EN | GAMEH_LPC_EN + | GAMEL_LPC_EN | FDD_LPC_EN | LPT_LPC_EN + | COMB_LPC_EN | COMA_LPC_EN); pci_write_config16(PCH_LPC_DEV, LPC_IO_DEC, 0x10);
/* Clear PWR_FLR */
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36994 )
Patch Set 1: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36994 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/36994/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/36994/1//COMMIT_MSG@9 PS1, Line 9: fixes What is fixed? The Wacom device didn’t work before?
Hello Patrick Rudolph, build bot (Jenkins), Nico Huber,
3b452e0 "nb/intel/nehalem: Move PCH init to sb/intel/ibexpeak" introduced a regression where the GAME_L decode range was not set up, which is used by the WACOM digitizer on the Thinkpad X201T.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/36994/2
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36994 )
Patch Set 2:
Done
Arthur Heymans has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36994 )
Change-Id: Ie569d567a65010aa5372323f8610a1b8b5d2599d Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/36994 Reviewed-by: Nico Huber nico.h@gmx.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/southbridge/intel/ibexpeak/bootblock.c 1 file changed, 15 insertions(+), 9 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved
/* Clear PWR_FLR */
