Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17629
commit 7a003c72fac3fb1d8c086f65db5517dace1d80c2 Author: Lin Huang hl@rock-chips.com Date: Tue Nov 15 11:40:58 2016 +0800
rockchip/rk3399: sdram: use register to calculate sdram sizes
We may support different sdram side on one board in future, so we need to calculate sdram sizes from sdram drvier.
BRANCH=None BUG=None TEST=boot kevin
Change-Id: I43e8f164ecdb768c051464b4dbc7d890df8055d0 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 3c4d8b3cb647b2f9cebc416c298817c16d49330e Original-Change-Id: I95d5ef34de9d79ebca3600dc7a4b9e14449606ff Original-Signed-off-by: Lin Huang hl@rock-chips.com Original-Reviewed-on: https://chromium-review.googlesource.com/411600 Original-Reviewed-by: Julius Werner jwerner@chromium.org --- src/mainboard/google/gru/Kconfig | 4 ---- src/mainboard/google/gru/romstage.c | 6 ++---- src/soc/rockchip/rk3399/sdram.c | 38 ++++++++++++++++++++++++++++++++++++- src/soc/rockchip/rk3399/soc.c | 4 ++-- 4 files changed, 41 insertions(+), 11 deletions(-)
diff --git a/src/mainboard/google/gru/Kconfig b/src/mainboard/google/gru/Kconfig index 57b1762..f07bc82 100644 --- a/src/mainboard/google/gru/Kconfig +++ b/src/mainboard/google/gru/Kconfig @@ -60,10 +60,6 @@ config MAINBOARD_VENDOR string default "Google"
-config DRAM_SIZE_MB - int - default 4096 - config EC_GOOGLE_CHROMEEC_SPI_BUS hex default 0x5 diff --git a/src/mainboard/google/gru/romstage.c b/src/mainboard/google/gru/romstage.c index 55ed79a..7f84a2a 100644 --- a/src/mainboard/google/gru/romstage.c +++ b/src/mainboard/google/gru/romstage.c @@ -33,9 +33,6 @@
#include "pwm_regulator.h"
-static const uint64_t dram_size = - (uint64_t)min((uint64_t)CONFIG_DRAM_SIZE_MB * MiB, MAX_DRAM_ADDRESS); - static void init_dvs_outputs(void) { pwm_regulator_configure(PWM_REGULATOR_GPU, 900); @@ -66,7 +63,8 @@ void main(void)
sdram_init(get_sdram_config());
- mmu_config_range((void *)0, (uintptr_t)dram_size, CACHED_MEM); + mmu_config_range((void *)0, (uintptr_t)sdram_size_mb() * MiB, + CACHED_MEM); mmu_config_range(_dma_coherent, _dma_coherent_size, UNCACHED_MEM); cbmem_initialize_empty(); run_ramstage(); diff --git a/src/soc/rockchip/rk3399/sdram.c b/src/soc/rockchip/rk3399/sdram.c index 4ea31dd..5bbf89f 100644 --- a/src/soc/rockchip/rk3399/sdram.c +++ b/src/soc/rockchip/rk3399/sdram.c @@ -1031,5 +1031,41 @@ void sdram_init(const struct rk3399_sdram_params *sdram_params)
size_t sdram_size_mb(void) { - return CONFIG_DRAM_SIZE_MB; + u32 rank, col, bk, cs0_row, cs1_row, bw, row_3_4; + size_t chipsize_mb = 0; + static size_t size_mb = 0; + u32 ch; + + if (!size_mb) { + u32 sys_reg = read32(&rk3399_pmugrf->os_reg2); + u32 ch_num = SYS_REG_DEC_NUM_CH(sys_reg); + + for (ch = 0; ch < ch_num; ch++) { + rank = SYS_REG_DEC_RANK(sys_reg, ch); + col = SYS_REG_DEC_COL(sys_reg, ch); + bk = SYS_REG_DEC_BK(sys_reg, ch); + cs0_row = SYS_REG_DEC_CS0_ROW(sys_reg, ch); + cs1_row = SYS_REG_DEC_CS1_ROW(sys_reg, ch); + bw = SYS_REG_DEC_BW(sys_reg, ch); + row_3_4 = SYS_REG_DEC_ROW_3_4(sys_reg, ch); + + chipsize_mb = (1 << (cs0_row + col + bk + bw - 20)); + + if (rank > 1) + chipsize_mb += chipsize_mb >> + (cs0_row - cs1_row); + if (row_3_4) + chipsize_mb = chipsize_mb * 3 / 4; + size_mb += chipsize_mb; + } + + /* + * we use the 0x00000000~0xf7ffffff space + * since 0xf8000000~0xffffffff is soc register space + * so we reserve it + */ + size_mb = MIN(size_mb, 0xf8000000/MiB); + } + + return size_mb; } diff --git a/src/soc/rockchip/rk3399/soc.c b/src/soc/rockchip/rk3399/soc.c index e34ca09..4418a27 100644 --- a/src/soc/rockchip/rk3399/soc.c +++ b/src/soc/rockchip/rk3399/soc.c @@ -20,6 +20,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <soc/display.h> +#include <soc/sdram.h> #include <stddef.h> #include <stdlib.h> #include <string.h> @@ -27,8 +28,7 @@
static void soc_read_resources(device_t dev) { - ram_resource(dev, 0, (uintptr_t)_dram / KiB, - min(CONFIG_DRAM_SIZE_MB * KiB, MAX_DRAM_ADDRESS / KiB)); + ram_resource(dev, 0, (uintptr_t)_dram / KiB, sdram_size_mb() * KiB); }
static void soc_init(device_t dev)
