Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9094
commit ffd510976668a90fa6d94bdefa37b9dab56ea222 Author: Aaron Durbin adurbin@chromium.org Date: Fri Sep 19 17:08:20 2014 -0500
arm64: fix smc bugs in secmon
Two things: 1. Not returning once setting the return state. 2. mempcy(x, y, ARRAY_SIZE(x)) is not memcpy(x, y, sizeof(x))
With these 2 changes arguments and results are being processed correctly.
BUG=chrome-os-partner:32112 BRANCH=None TEST=Built and brought up SMP using PSCI.
Change-Id: If76a207e1a434a4c08faaa535f069d7386481e9e Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 42d540afd4e6ea2b34cf3632ad2c683fcaa063c8 Original-Change-Id: I656b9c11e3bc07cc1664789a600eb88afd639f93 Original-Signed-off-by: Aaron Durbin adurbin@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/218847 Original-Reviewed-by: Furquan Shaikh furquan@chromium.org --- src/arch/arm64/armv8/secmon/smc.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/src/arch/arm64/armv8/secmon/smc.c b/src/arch/arm64/armv8/secmon/smc.c index 3bb52f0..8aa6d41 100644 --- a/src/arch/arm64/armv8/secmon/smc.c +++ b/src/arch/arm64/armv8/secmon/smc.c @@ -84,7 +84,7 @@ int smc_register_range(uint32_t min, uint32_t max, int (*h)(struct smc_call *))
static int smc_cleanup(struct exc_state *state, struct smc_call *smc, int ret) { - memcpy(&state->regs.x, &smc->results, ARRAY_SIZE(smc->results)); + memcpy(&state->regs.x, &smc->results, sizeof(smc->results));
return ret; } @@ -103,15 +103,15 @@ static int smc_handler(struct exc_state *state, uint64_t vector_id) uint32_t esr; struct smc_range *r;
- memcpy(&smc->args, &state->regs.x, ARRAY_SIZE(smc->args)); - memcpy(&smc->results, &state->regs.x, ARRAY_SIZE(smc->results)); + memcpy(&smc->args, &state->regs.x, sizeof(smc->args)); + memcpy(&smc->results, &state->regs.x, sizeof(smc->results));
esr = raw_read_esr_el3(); exception_class = (esr >> 26) & 0x3f;
/* No support for 32-bit SMC calls. */ if (exception_class == EC_SMC32) - smc_return_with_error(state, smc); + return smc_return_with_error(state, smc);
/* Check to ensure this is an SMC from aarch64. */ if (exception_class != EC_SMC64) @@ -119,7 +119,7 @@ static int smc_handler(struct exc_state *state, uint64_t vector_id)
/* Ensure immediate value is 0. */ if ((esr & 0xffff) != 0) - smc_return_with_error(state, smc); + return smc_return_with_error(state, smc);
r = smc_handler_by_function(smc_function_id(smc));
