Shelley Chen has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35907 )
Change subject: mb/google/hatch/variants/helios: Modify touchscreen power on sequence ......................................................................
The previous values do not affect the touchscreen function. But, the previous values cause the power leakage in S0ix.
from b/142368161:
1. Modify GPP_D: The specification define T1 >= 10ms. We change it to 12ms for a safety and low impact value in our mind. Enable pin as GPP_D9 is define to be AVDD in specification. Set it to 10ms to make it to be the final one to pull low during power off sequence .
2. Add GPP_C4: If we set stop_off_delay_ms to be 1. The true T4 we got will be 300us . Set stop_off_delay_ms to be 2 . True T4 will be 500us . So we change it to 5 to be a low impact value in our mind according to the true T4 value we got .
BUG=b:142368161 BRANCH=Master TEST=emerge-hatch coreboot chromeos-bootimage ./util/abuild/abuild -p none -t google/hatch -x -a
Signed-off-by: YenLu Chen kane_chen@pegatron.corp-partner.google.com Change-Id: I86c920ff1d5c0b510adde8a37f60003072d5f4e7 Reviewed-on: https://review.coreboot.org/c/coreboot/+/35907 Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Shelley Chen shchen@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/hatch/variants/helios/overridetree.cb 1 file changed, 6 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Shelley Chen: Looks good to me, approved
diff --git a/src/mainboard/google/hatch/variants/helios/overridetree.cb b/src/mainboard/google/hatch/variants/helios/overridetree.cb index 262ae8d..04bf6c1 100644 --- a/src/mainboard/google/hatch/variants/helios/overridetree.cb +++ b/src/mainboard/google/hatch/variants/helios/overridetree.cb @@ -107,9 +107,13 @@ register "generic.reset_off_delay_ms" = "1" register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D9)" - register "generic.enable_delay_ms" = "10" - register "generic.enable_off_delay_ms" = "1" + register "generic.enable_delay_ms" = "12" + register "generic.enable_off_delay_ms" = "10" register "generic.has_power_resource" = "1" + register "generic.stop_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C4)" + register "generic.stop_delay_ms" = "15" + register "generic.stop_off_delay_ms" = "5" register "hid_desc_reg_offset" = "0x01" device i2c 5d on end end
