Attention is currently required from: Arthur Heymans, Leah Rowe, Michael Büchler, Máté Kukri, Nicholas Chin, Nico Huber, Paul Menzel, ilikenwf, nat ✨.
Hello Arthur Heymans, Martin L Roth, Michael Büchler, Nicholas Chin, Nico Huber, Patrick Rudolph, Paul Menzel, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/55232?usp=email
to look at the new patch set (#34).
The following approvals got outdated and were removed: Code-Review+1 by Paul Menzel, Code-Review+2 by Nicholas Chin, Verified+1 by build bot (Jenkins)
Change subject: mb/dell: Add OptiPlex 7020/9020 port ......................................................................
The OptiPlex 7020 and 9020 use physically identical motherboards.
WARNING: PWM fan control doesn't work via the EC and the fan runs at a fixed speed. There is likely more EC init to reverse engineer.
Each model comes in the following form factors: - 7020: SFF, MT - 9020: USFF (not currently supported), SFF, MT
(7020 SFF) Boots Linux and Windows 10: - Tested with an i3-4160 and i5-4460 - DRAM init works using the MRC (4G, 4G+4G) - iGPU init works using libgfxinit (VGA, 2x DP) - PCIe 16x: tested, ok - PCIe 4x: tested, ok - All USB2 and USB3 ports work - SMSC SCH5555 Super I/O: serial works, PS/2 untested - Audio: back and front output works, internal speaker works, mic inputs untested - Ethernet: tested, works
(9020 MT) - Tested by Michael Büchler (thanks for the overridetree)
Change-Id: Ie7c7089f443aef9890711c4412209bceb1f1e96a Signed-off-by: Mate Kukri kukri.mate@gmail.com --- A src/mainboard/dell/optiplex_9020/Kconfig A src/mainboard/dell/optiplex_9020/Kconfig.name A src/mainboard/dell/optiplex_9020/Makefile.mk A src/mainboard/dell/optiplex_9020/acpi/ec.asl A src/mainboard/dell/optiplex_9020/acpi/platform.asl A src/mainboard/dell/optiplex_9020/acpi/superio.asl A src/mainboard/dell/optiplex_9020/board_info.txt A src/mainboard/dell/optiplex_9020/bootblock.c A src/mainboard/dell/optiplex_9020/cmos.default A src/mainboard/dell/optiplex_9020/cmos.layout A src/mainboard/dell/optiplex_9020/data.vbt A src/mainboard/dell/optiplex_9020/devicetree.cb A src/mainboard/dell/optiplex_9020/dsdt.asl A src/mainboard/dell/optiplex_9020/gma-mainboard.ads A src/mainboard/dell/optiplex_9020/gpio.c A src/mainboard/dell/optiplex_9020/hda_verb.c A src/mainboard/dell/optiplex_9020/mainboard.c A src/mainboard/dell/optiplex_9020/overridetree_mt.cb A src/mainboard/dell/optiplex_9020/romstage.c 19 files changed, 698 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/55232/34
