Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/26133 )
Change subject: soc/intel/common/block: Move cse common functions into block/cse ......................................................................
This patch cleans soc/intel/{cnl, icl, tgl} by moving common soc code into common/block/cse.
Supported SoC can select existing HECI_DISABLE_USING_SMM option to select common cse code block to make heci function disable using sideband interface during SMM mode at preboot envionment.
BUG=b:78109109 TEST=Able to make HECI disable in SMM mode successfully without any hang or errors in CNL, ICL and TGL platform.
Change-Id: I22a4cc05d3967c7653d2abe2c829b4876516d179 Signed-off-by: Subrata Banik subrata.banik@intel.com Signed-off-by: Maulik V Vaghela maulik.v.vaghela@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/26133 Reviewed-by: V Sowmya v.sowmya@intel.com Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/cannonlake/smihandler.c M src/soc/intel/common/block/cse/Kconfig M src/soc/intel/common/block/cse/Makefile.inc A src/soc/intel/common/block/cse/disable_heci.c M src/soc/intel/common/block/include/intelblocks/cse.h M src/soc/intel/icelake/smihandler.c M src/soc/intel/tigerlake/smihandler.c 7 files changed, 76 insertions(+), 117 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved V Sowmya: Looks good to me, approved
diff --git a/src/soc/intel/cannonlake/smihandler.c b/src/soc/intel/cannonlake/smihandler.c index 550c92d..4be7897 100644 --- a/src/soc/intel/cannonlake/smihandler.c +++ b/src/soc/intel/cannonlake/smihandler.c @@ -18,49 +18,11 @@ #include <console/console.h> #include <device/pci_def.h> #include <intelblocks/cse.h> -#include <intelblocks/p2sb.h> -#include <intelblocks/pcr.h> #include <intelblocks/smihandler.h> #include <soc/soc_chip.h> #include <soc/pci_devs.h> -#include <soc/pcr_ids.h> #include <soc/pm.h>
-#define CSME0_FBE 0xf -#define CSME0_BAR 0x0 -#define CSME0_FID 0xb0 - -static void pch_disable_heci(void) -{ - struct pcr_sbi_msg msg = { - .pid = PID_CSME0, - .offset = 0, - .opcode = PCR_WRITE, - .is_posted = false, - .fast_byte_enable = CSME0_FBE, - .bar = CSME0_BAR, - .fid = CSME0_FID - }; - /* Bit 0: Set to make HECI#1 Function disable */ - uint32_t data32 = 1; - uint8_t response; - int status; - - /* unhide p2sb device */ - p2sb_unhide(); - - /* Send SBI command to make HECI#1 function disable */ - status = pcr_execute_sideband_msg(&msg, &data32, &response); - if (status && response) - printk(BIOS_ERR, "Fail to make CSME function disable\n"); - - /* Ensure to Lock SBI interface after this command */ - p2sb_disable_sideband_access(); - - /* hide p2sb device */ - p2sb_hide(); -} - /* * Specific SOC SMI handler during ramstage finalize phase * @@ -75,7 +37,7 @@ config = config_of_soc();
if (!config->HeciEnabled && CONFIG(HECI_DISABLE_USING_SMM)) - pch_disable_heci(); + heci_disable(); }
const smi_handler_t southbridge_smi[SMI_STS_BITS] = { diff --git a/src/soc/intel/common/block/cse/Kconfig b/src/soc/intel/common/block/cse/Kconfig index 321d34c..15de0b0 100644 --- a/src/soc/intel/common/block/cse/Kconfig +++ b/src/soc/intel/common/block/cse/Kconfig @@ -4,3 +4,11 @@ help Driver for communication with Converged Security Engine (CSE) over Host Embedded Controller Interface (HECI) + +config SOC_INTEL_COMMON_BLOCK_HECI_DISABLE_IN_SMM + bool + default y if HECI_DISABLE_USING_SMM + select SOC_INTEL_COMMON_BLOCK_P2SB + help + Use this config to include common CSE block to make HECI function + disable in SMM mode diff --git a/src/soc/intel/common/block/cse/Makefile.inc b/src/soc/intel/common/block/cse/Makefile.inc index 376f00f..90f76d5 100644 --- a/src/soc/intel/common/block/cse/Makefile.inc +++ b/src/soc/intel/common/block/cse/Makefile.inc @@ -1,3 +1,4 @@ bootblock-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CSE) += cse.c romstage-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CSE) += cse.c ramstage-$(CONFIG_SOC_INTEL_COMMON_BLOCK_CSE) += cse.c +smm-$(CONFIG_SOC_INTEL_COMMON_BLOCK_HECI_DISABLE_IN_SMM) += disable_heci.c diff --git a/src/soc/intel/common/block/cse/disable_heci.c b/src/soc/intel/common/block/cse/disable_heci.c new file mode 100644 index 0000000..f560a37 --- /dev/null +++ b/src/soc/intel/common/block/cse/disable_heci.c @@ -0,0 +1,62 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2020 Intel Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <commonlib/helpers.h> +#include <console/console.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <intelblocks/cse.h> +#include <intelblocks/p2sb.h> +#include <intelblocks/pcr.h> +#include <soc/pci_devs.h> +#include <soc/pcr_ids.h> +#include <string.h> + +#define CSME0_FBE 0xf +#define CSME0_BAR 0x0 +#define CSME0_FID 0xb0 + +/* Disable HECI using Sideband interface communication */ +void heci_disable(void) +{ + struct pcr_sbi_msg msg = { + .pid = PID_CSME0, + .offset = 0, + .opcode = PCR_WRITE, + .is_posted = false, + .fast_byte_enable = CSME0_FBE, + .bar = CSME0_BAR, + .fid = CSME0_FID + }; + /* Bit 0: Set to make HECI#1 Function disable */ + uint32_t data32 = 1; + uint8_t response; + int status; + + /* unhide p2sb device */ + p2sb_unhide(); + + /* Send SBI command to make HECI#1 function disable */ + status = pcr_execute_sideband_msg(&msg, &data32, &response); + if (status || response) + printk(BIOS_ERR, "Fail to make CSME function disable\n"); + + /* Ensure to Lock SBI interface after this command */ + p2sb_disable_sideband_access(); + + /* hide p2sb device */ + p2sb_hide(); +} diff --git a/src/soc/intel/common/block/include/intelblocks/cse.h b/src/soc/intel/common/block/include/intelblocks/cse.h index c597a3f..59ddc5b 100644 --- a/src/soc/intel/common/block/include/intelblocks/cse.h +++ b/src/soc/intel/common/block/include/intelblocks/cse.h @@ -97,6 +97,8 @@ * Returns 0 on failure and 1 on success. */ int heci_reset(void); +/* Disable HECI using Sideband interface communication */ +void heci_disable(void);
/* Reads config value from a specified offset in the CSE PCI Config space. */ uint32_t me_read_config32(int offset); diff --git a/src/soc/intel/icelake/smihandler.c b/src/soc/intel/icelake/smihandler.c index 5228f5d..6be7b70 100644 --- a/src/soc/intel/icelake/smihandler.c +++ b/src/soc/intel/icelake/smihandler.c @@ -16,49 +16,11 @@ #include <console/console.h> #include <device/pci_def.h> #include <intelblocks/cse.h> -#include <intelblocks/p2sb.h> -#include <intelblocks/pcr.h> #include <intelblocks/smihandler.h> #include <soc/soc_chip.h> #include <soc/pci_devs.h> -#include <soc/pcr_ids.h> #include <soc/pm.h>
-#define CSME0_FBE 0xf -#define CSME0_BAR 0x0 -#define CSME0_FID 0xb0 - -static void pch_disable_heci(void) -{ - struct pcr_sbi_msg msg = { - .pid = PID_CSME0, - .offset = 0, - .opcode = PCR_WRITE, - .is_posted = false, - .fast_byte_enable = CSME0_FBE, - .bar = CSME0_BAR, - .fid = CSME0_FID - }; - /* Bit 0: Set to make HECI#1 Function disable */ - uint32_t data32 = 1; - uint8_t response; - int status; - - /* unhide p2sb device */ - p2sb_unhide(); - - /* Send SBI command to make HECI#1 function disable */ - status = pcr_execute_sideband_msg(&msg, &data32, &response); - if (status && response) - printk(BIOS_ERR, "Fail to make CSME function disable\n"); - - /* Ensure to Lock SBI interface after this command */ - p2sb_disable_sideband_access(); - - /* hide p2sb device */ - p2sb_hide(); -} - /* * Specific SOC SMI handler during ramstage finalize phase * @@ -73,7 +35,7 @@ config = config_of_soc();
const smi_handler_t southbridge_smi[SMI_STS_BITS] = { diff --git a/src/soc/intel/tigerlake/smihandler.c b/src/soc/intel/tigerlake/smihandler.c index 68954eb..0e8d345 100644 --- a/src/soc/intel/tigerlake/smihandler.c +++ b/src/soc/intel/tigerlake/smihandler.c @@ -16,49 +16,11 @@ #include <console/console.h> #include <device/pci_def.h> #include <intelblocks/cse.h> -#include <intelblocks/p2sb.h> -#include <intelblocks/pcr.h> #include <intelblocks/smihandler.h> #include <soc/soc_chip.h> #include <soc/pci_devs.h> -#include <soc/pcr_ids.h> #include <soc/pm.h>
