Furquan Shaikh (furquan@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14449
commit ed56683650c86797b8b23c89a3cca2d97c080aaa Author: Furquan Shaikh furquan@google.com Date: Thu Apr 21 08:10:02 2016 -0700
soc/intel/apollolake: Flush L1D to L2 only if loaded segment is in CAR
In program_segment_loaded, flush L1D to L2 only if the address of the loaded segment lies in the CAR region. Add an assert to ensure that the loaded segment does not cross CAR boundaries.
Change-Id: Ie43e99299ed82f01518c8a1c1fd2bc64747d0c7b Signed-off-by: Furquan Shaikh furquan@google.com --- src/soc/intel/apollolake/car.c | 25 +++++++++++++++++++++---- 1 file changed, 21 insertions(+), 4 deletions(-)
diff --git a/src/soc/intel/apollolake/car.c b/src/soc/intel/apollolake/car.c index ff4603c..68bcb31 100644 --- a/src/soc/intel/apollolake/car.c +++ b/src/soc/intel/apollolake/car.c @@ -16,6 +16,7 @@ */
#include <arch/cpu.h> +#include <assert.h> #include <program_loading.h> #include <soc/cpu.h>
@@ -31,11 +32,27 @@ static void flush_l1d_to_l2(void) wrmsr(MSR_POWER_MISC, msr); }
+static inline int is_car_addr(uintptr_t addr) +{ + return ((addr >= CONFIG_DCACHE_RAM_BASE) && + (addr < (CONFIG_DCACHE_RAM_BASE + CONFIG_DCACHE_RAM_SIZE))); +} + void platform_segment_loaded(uintptr_t start, size_t size, int flags) { - /* TODO: filter on address to see if L1D flushing required. */ + /* Bail out if this is not the final segment. */ + if (!(flags & SEG_FINAL)) + return; + + char start_car_check = is_car_addr(start); + char end_car_check = is_car_addr(start + size - 1); + + /* Bail out if loaded program segment does not lie in CAR region. */ + if (!start_car_check && !end_car_check) + return; + + /* Loaded program segment should lie entirely within CAR region. */ + assert (start_car_check && end_car_check);
- /* Flush L1D cache to L2 on final segment loaded */ - if (flags & SEG_FINAL) - flush_l1d_to_l2(); + flush_l1d_to_l2(); }
