Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17101
commit cab0cee19fb751a3dc27cba82c75b0b7a0af065b Author: Patrick Georgi pgeorgi@chromium.org Date: Mon Oct 24 11:54:45 2016 +0200
Rename and move util/gitconfig/rebase.sh
It has nothing to do with git configuration, but is one of our convenience scripts. It also has nothing to do with rebases (except that it can be comfortably used through git rebase --exec)
Change-Id: Icc60c4de486a0027fe2230e93b441e62ba022193 Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- util/gitconfig/rebase.sh | 47 -------------------------------------- util/scripts/cross-repo-cherrypick | 47 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 47 insertions(+), 47 deletions(-)
diff --git a/util/gitconfig/rebase.sh b/util/gitconfig/rebase.sh deleted file mode 100755 index 4b098c1..0000000 --- a/util/gitconfig/rebase.sh +++ /dev/null @@ -1,47 +0,0 @@ -#!/bin/sh - -# rebase.sh - rebase helper script -# -# This program is free software; you can redistribute it and/or modify -# it under the terms of the GNU General Public License as published by -# the Free Software Foundation; version 2 of the License. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# - -# Adapt to your remote branch: -BRANCH="cros/chromeos-2016.05" - -# When pulling in patches from another tree from a gerrit repository, -# do the following at the end of a larger cherry-pick series: -# git remote add ... -# git checkout -b upstreaming -# git cherry-pick ... -# git rebase -i --exec util/gitconfig/rebase.sh master -# Alternatively, you can run util/gitconfig/rebase.sh after every -# individual cherry-pick. - -commit_message() { - git log -n 1 | grep "^ " | cut -c5- -} - -CHID=$( commit_message | grep -i "^Change-Id: I" ) -CID=$( git log -n1 --grep "^$CHID$" --pretty=%H $BRANCH ) -GUID="$(git config user.name) <$(git config user.email)>" - -# TBD: Don't add Original- to empty lines, and possibly make script more -# solid for commits with an unexpected order of meta data lines. - -commit_message | tac | awk '/^$/ { - if (end==0) - print "Original-Commit-Id: '"$CID"'\nSigned-off-by: '"$GUID"'"; - end=1 - }; { - if (end==0) - print "Original-" $0; - else - print $0; - }' | tac | git commit --amend -F - diff --git a/util/scripts/cross-repo-cherrypick b/util/scripts/cross-repo-cherrypick new file mode 100755 index 0000000..4b098c1 --- /dev/null +++ b/util/scripts/cross-repo-cherrypick @@ -0,0 +1,47 @@ +#!/bin/sh + +# rebase.sh - rebase helper script +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +# Adapt to your remote branch: +BRANCH="cros/chromeos-2016.05" + +# When pulling in patches from another tree from a gerrit repository, +# do the following at the end of a larger cherry-pick series: +# git remote add ... +# git checkout -b upstreaming +# git cherry-pick ... +# git rebase -i --exec util/gitconfig/rebase.sh master +# Alternatively, you can run util/gitconfig/rebase.sh after every +# individual cherry-pick. + +commit_message() { + git log -n 1 | grep "^ " | cut -c5- +} + +CHID=$( commit_message | grep -i "^Change-Id: I" ) +CID=$( git log -n1 --grep "^$CHID$" --pretty=%H $BRANCH ) +GUID="$(git config user.name) <$(git config user.email)>" + +# TBD: Don't add Original- to empty lines, and possibly make script more +# solid for commits with an unexpected order of meta data lines. + +commit_message | tac | awk '/^$/ { + if (end==0) + print "Original-Commit-Id: '"$CID"'\nSigned-off-by: '"$GUID"'"; + end=1 + }; { + if (end==0) + print "Original-" $0; + else + print $0; + }' | tac | git commit --amend -F -
