Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16212
commit c16df31ef73aaeefd3d79dbcdafc131d3a1d9a2b Author: Aaron Durbin adurbin@chromium.org Date: Fri Aug 12 15:50:16 2016 -0500
drivers/spi: move cbfs_spi.c location
The common boot device spi implementation is very much specific to SPI flash. As such it should be moved into that subdirectory. It's still a high-level option but it correctly depends on BOOT_DEVICE_SPI_FLASH. Additionally that allows the auto-selection of SPI_FLASH by a platform selecting COMMON_CBFS_SPI_WRAPPER which allows for culling of SPI_FLASH selections everywhere.
BUG=chrome-os-partner:56151
Change-Id: Ia2ccfdc9e1a4348cd91b381f9712d8853b7d2a79 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/Kconfig | 8 ----- src/drivers/spi/Kconfig | 8 +++++ src/drivers/spi/Makefile.inc | 4 +++ src/drivers/spi/cbfs_spi.c | 80 ++++++++++++++++++++++++++++++++++++++++++++ src/lib/Makefile.inc | 5 --- src/lib/cbfs_spi.c | 80 -------------------------------------------- 6 files changed, 92 insertions(+), 93 deletions(-)
diff --git a/src/Kconfig b/src/Kconfig index f7a924f..fd98cc8 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -35,14 +35,6 @@ config CBFS_PREFIX Select the prefix to all files put into the image. It's "fallback" by default, "normal" is a common alternative.
-config COMMON_CBFS_SPI_WRAPPER - bool - default n - depends on SPI_FLASH - depends on !ARCH_X86 - help - Use common wrapper to interface CBFS to SPI bootrom. - choice prompt "Compiler to use" default COMPILER_GCC diff --git a/src/drivers/spi/Kconfig b/src/drivers/spi/Kconfig index b0187fd..030fa6c 100644 --- a/src/drivers/spi/Kconfig +++ b/src/drivers/spi/Kconfig @@ -13,6 +13,14 @@ ## GNU General Public License for more details. ##
+config COMMON_CBFS_SPI_WRAPPER + bool + default n + depends on !ARCH_X86 + depends on BOOT_DEVICE_SPI_FLASH + help + Use common wrapper to interface CBFS to SPI bootrom. + config SPI_FLASH bool default y if BOOT_DEVICE_SPI_FLASH diff --git a/src/drivers/spi/Makefile.inc b/src/drivers/spi/Makefile.inc index 6b4182e..e976059 100644 --- a/src/drivers/spi/Makefile.inc +++ b/src/drivers/spi/Makefile.inc @@ -8,6 +8,7 @@ smm-$(CONFIG_DEBUG_SMI) += spiconsole.c endif
ifeq ($(CONFIG_COMMON_CBFS_SPI_WRAPPER),y) +bootblock-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c bootblock-y += spi_flash.c bootblock-$(CONFIG_SPI_FLASH_EON) += eon.c bootblock-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.c @@ -18,6 +19,7 @@ bootblock-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.c bootblock-$(CONFIG_SPI_FLASH_WINBOND) += winbond.c bootblock-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.c
+romstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c romstage-$(CONFIG_SPI_FLASH) += spi_flash.c romstage-$(CONFIG_SPI_FLASH_EON) += eon.c romstage-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.c @@ -28,6 +30,7 @@ romstage-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.c romstage-$(CONFIG_SPI_FLASH_WINBOND) += winbond.c romstage-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.c
+verstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c verstage-$(CONFIG_SPI_FLASH) += spi_flash.c verstage-$(CONFIG_SPI_FLASH_EON) += eon.c verstage-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.c @@ -40,6 +43,7 @@ verstage-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.c
endif
+ramstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c ramstage-$(CONFIG_SPI_FLASH) += spi_flash.c
# drivers diff --git a/src/drivers/spi/cbfs_spi.c b/src/drivers/spi/cbfs_spi.c new file mode 100644 index 0000000..bbe9125 --- /dev/null +++ b/src/drivers/spi/cbfs_spi.c @@ -0,0 +1,80 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* + * This file provides a common CBFS wrapper for SPI storage. SPI driver + * context is expanded with the buffer descriptor used to store data read from + * SPI. + */ + +#include <boot_device.h> +#include <spi_flash.h> +#include <symbols.h> +#include <cbmem.h> + +static struct spi_flash *spi_flash_info; + +static ssize_t spi_readat(const struct region_device *rd, void *b, + size_t offset, size_t size) +{ + if (spi_flash_info->read(spi_flash_info, offset, size, b)) + return -1; + return size; +} + +static const struct region_device_ops spi_ops = { + .mmap = mmap_helper_rdev_mmap, + .munmap = mmap_helper_rdev_munmap, + .readat = spi_readat, +}; + +static struct mmap_helper_region_device mdev = + MMAP_HELPER_REGION_INIT(&spi_ops, 0, CONFIG_ROM_SIZE); + +static void switch_to_postram_cache(int unused) +{ + /* + * Call boot_device_init() to ensure spi_flash is initialized before + * backing mdev with postram cache. This prevents the mdev backing from + * being overwritten if spi_flash was not accessed before dram was up. + */ + boot_device_init(); + if (_preram_cbfs_cache != _postram_cbfs_cache) + mmap_helper_device_init(&mdev, _postram_cbfs_cache, + _postram_cbfs_cache_size); +} +ROMSTAGE_CBMEM_INIT_HOOK(switch_to_postram_cache); + +void boot_device_init(void) +{ + int bus = CONFIG_BOOT_DEVICE_SPI_FLASH_BUS; + int cs = 0; + + if (spi_flash_info != NULL) + return; + + spi_flash_info = spi_flash_probe(bus, cs); + + mmap_helper_device_init(&mdev, _cbfs_cache, _cbfs_cache_size); +} + +/* Return the CBFS boot device. */ +const struct region_device *boot_device_ro(void) +{ + if (spi_flash_info == NULL) + return NULL; + + return &mdev.rdev; +} diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 5f708a6..e2cf9ef 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -22,7 +22,6 @@ endif bootblock-y += prog_loaders.c bootblock-y += prog_ops.c bootblock-y += cbfs.c -bootblock-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c bootblock-$(CONFIG_GENERIC_GPIO_LIB) += gpio.c bootblock-y += libgcc.c bootblock-$(CONFIG_GENERIC_UDELAY) += timer.c @@ -49,7 +48,6 @@ verstage-y += memcmp.c verstage-$(CONFIG_COLLECT_TIMESTAMPS) += timestamp.c verstage-y += boot_device.c verstage-$(CONFIG_CONSOLE_CBMEM) += cbmem_console.c -verstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c
ifeq ($(MOCK_TPM),1) libverstage-y += mocked_tlcl.c @@ -73,7 +71,6 @@ $(foreach arch,$(ARCH_SUPPORTED),\ romstage-y += fmap.c romstage-y += delay.c romstage-y += cbfs.c -romstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c romstage-$(CONFIG_COMPRESS_RAMSTAGE) += lzma.c lzmadecode.c romstage-y += libgcc.c romstage-y += memrange.c @@ -117,7 +114,6 @@ ramstage-y += delay.c ramstage-y += fallback_boot.c ramstage-y += compute_ip_checksum.c ramstage-y += cbfs.c -ramstage-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c ramstage-y += lzma.c lzmadecode.c ramstage-y += stack.c ramstage-y += hexstrtobin.c @@ -214,7 +210,6 @@ smm-y += halt.c postcar-y += bootmode.c postcar-y += boot_device.c postcar-y += cbfs.c -postcar-$(CONFIG_COMMON_CBFS_SPI_WRAPPER) += cbfs_spi.c postcar-y += delay.c postcar-y += fmap.c postcar-y += gcc.c diff --git a/src/lib/cbfs_spi.c b/src/lib/cbfs_spi.c deleted file mode 100644 index bbe9125..0000000 --- a/src/lib/cbfs_spi.c +++ /dev/null @@ -1,80 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2014 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* - * This file provides a common CBFS wrapper for SPI storage. SPI driver - * context is expanded with the buffer descriptor used to store data read from - * SPI. - */ - -#include <boot_device.h> -#include <spi_flash.h> -#include <symbols.h> -#include <cbmem.h> - -static struct spi_flash *spi_flash_info; - -static ssize_t spi_readat(const struct region_device *rd, void *b, - size_t offset, size_t size) -{ - if (spi_flash_info->read(spi_flash_info, offset, size, b)) - return -1; - return size; -} - -static const struct region_device_ops spi_ops = { - .mmap = mmap_helper_rdev_mmap, - .munmap = mmap_helper_rdev_munmap, - .readat = spi_readat, -}; - -static struct mmap_helper_region_device mdev = - MMAP_HELPER_REGION_INIT(&spi_ops, 0, CONFIG_ROM_SIZE); - -static void switch_to_postram_cache(int unused) -{ - /* - * Call boot_device_init() to ensure spi_flash is initialized before - * backing mdev with postram cache. This prevents the mdev backing from - * being overwritten if spi_flash was not accessed before dram was up. - */ - boot_device_init(); - if (_preram_cbfs_cache != _postram_cbfs_cache) - mmap_helper_device_init(&mdev, _postram_cbfs_cache, - _postram_cbfs_cache_size); -} -ROMSTAGE_CBMEM_INIT_HOOK(switch_to_postram_cache); - -void boot_device_init(void) -{ - int bus = CONFIG_BOOT_DEVICE_SPI_FLASH_BUS; - int cs = 0; - - if (spi_flash_info != NULL) - return; - - spi_flash_info = spi_flash_probe(bus, cs); - - mmap_helper_device_init(&mdev, _cbfs_cache, _cbfs_cache_size); -} - -/* Return the CBFS boot device. */ -const struct region_device *boot_device_ro(void) -{ - if (spi_flash_info == NULL) - return NULL; - - return &mdev.rdev; -}
