Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52510 )
Change subject: mb/asus/am1i-a: Use read_int_option() ......................................................................
Drop "error" (BIOS_DEBUG) messages as well.
Change-Id: I61954f8f893c144bbeba1530a486b389bd855ec6 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/52510 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph siro@das-labor.org --- M src/mainboard/asus/am1i-a/BiosCallOuts.c 1 file changed, 2 insertions(+), 12 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved
diff --git a/src/mainboard/asus/am1i-a/BiosCallOuts.c b/src/mainboard/asus/am1i-a/BiosCallOuts.c index bdaf7a7..e20f4f4 100644 --- a/src/mainboard/asus/am1i-a/BiosCallOuts.c +++ b/src/mainboard/asus/am1i-a/BiosCallOuts.c @@ -87,12 +87,7 @@ FchParams_reset->Mode = 6;
/* Read SATA speed setting from CMOS */ - enum cb_err ret; - ret = get_option(&FchParams_reset->SataSetMaxGen2, "sata_speed"); - if (ret != CB_SUCCESS) { - FchParams_reset->SataSetMaxGen2 = 0; - printk(BIOS_DEBUG, "ERROR: cannot read CMOS setting, falling back to default. Error code: %x\n", (int)ret); - } + FchParams_reset->SataSetMaxGen2 = get_int_option("sata_speed", 0); printk(BIOS_DEBUG, "Force SATA 3Gbps mode = %x\n", FchParams_reset->SataSetMaxGen2); }
@@ -107,12 +102,7 @@ FchParams_env->Hwm.HwmFchtsiAutoPoll = FALSE;/* 1 enable, 0 disable TSI Auto Polling */
/* Read SATA controller mode from CMOS */ - enum cb_err ret; - ret = get_option(&FchParams_env->Sata.SataClass, "sata_mode"); - if (ret != CB_SUCCESS) { - FchParams_env->Sata.SataClass = 0; - printk(BIOS_DEBUG, "ERROR: cannot read CMOS setting, falling back to default. Error code: %x\n", (int)ret); - } + FchParams_env->Sata.SataClass = get_int_option("sata_mode", 0);
switch ((SATA_CLASS)FchParams_env->Sata.SataClass) { case SataLegacyIde:
