Attention is currently required from: Sean Rhodes, Benjamin Doron, Christian Walter, Maximilian Brune, Lean Sheng Tan.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/74122 )
Change subject: [WIP] mb/prodrive/atlas: Put options in CFR cbtable ......................................................................
Patch Set 3:
(5 comments)
File src/mainboard/prodrive/atlas/cfr.c:
https://review.coreboot.org/c/coreboot/+/74122/comment/bd5291ac_457aaeaf PS1, Line 14: struct sm_enum_value pwr_after_g3_values[] = { : { "Power on (S0)", 0 }, : { "Power off (S5)", 1 }, : SM_ENUM_VALUE_END, : };
The string<->enum are still mismatched?
*facepalm*
Done
https://review.coreboot.org/c/coreboot/+/74122/comment/65125d18_72a9700e PS2, Line 123: .ui_helptext = "Specify what to do when power is re-applied " : "after a power loss. This option has no effect " : "on systems without a RTC battery.", /* TODO: check */ :
Will try
Done
https://review.coreboot.org/c/coreboot/+/74122/comment/dfff5a73_708d1d7e PS3, Line 77: .opt_name = "DONOTSTOREME_sn", /* TODO: Make optional? */
Name still needed so that the value can be read.
Done
https://review.coreboot.org/c/coreboot/+/74122/comment/8540c6b9_e699123d PS3, Line 79: .flags = CFR_OPTFLAG_READONLY,
Add another flag to indicate an option is volatile.
Done
https://review.coreboot.org/c/coreboot/+/74122/comment/022bdc54_0d67f523 PS3, Line 92: .ui_name = "", /* Empty UI name */
Define new tag for text fields (i.e. […]
Done
