Marc Jones (marc.jones@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8681
commit e56b8da01a4ede1a88e616ada73905546d9d9ffc Author: Furquan Shaikh furquan@google.com Date: Fri Jul 25 14:50:23 2014 -0700
t132: Add TTB_BUFFER to resource reserved
TTB_BUFFER holds the MMU tables. Thus, this memory needs to be preserved while performing a wipe in depthcharge. Hence, marking it as reserved
BUG=None BRANCH=None TEST=Compiles successfully and boots upto depthcharge. Error wiping memory tables is fixed.
Original-Change-Id: Idd5cd0235d50f7b9617df2cead3bf71012e3b630 Original-Signed-off-by: Furquan Shaikh furquan@google.com Original-Reviewed-on: https://chromium-review.googlesource.com/210000 Original-Tested-by: Furquan Shaikh furquan@chromium.org Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Commit-Queue: Aaron Durbin adurbin@chromium.org (cherry picked from commit 670e21ed11f985ca6cfef4f051c71b3c06f9c6ff) Signed-off-by: Marc Jones marc.jones@se-eng.com
Change-Id: Ifcbdd4fdaad0bd4bfe384698b13cc5013317345e --- src/soc/nvidia/tegra132/soc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/src/soc/nvidia/tegra132/soc.c b/src/soc/nvidia/tegra132/soc.c index 3a419bc..f4ef928 100644 --- a/src/soc/nvidia/tegra132/soc.c +++ b/src/soc/nvidia/tegra132/soc.c @@ -38,6 +38,10 @@ static void soc_read_resources(device_t dev) reserved_ram_resource(dev, index++, begin * KiB, size * KiB); }
+ reserved_ram_resource(dev, index++, CONFIG_TTB_BUFFER / KiB, + CONFIG_TTB_SIZE / KiB); + + /* * TODO: Frame buffer needs to handled as a carveout from the below_4G * uintptr_t framebuffer_begin = framebuffer_attributes(&framebuffer_size);
