Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17915
commit 9566ef36133b471deb1a843fa68fb689257ca500 Author: Arthur Heymans arthur@aheymans.xyz Date: Sun Dec 18 16:03:52 2016 +0100
nb/intel/haswell: Hook up libgfxinit
Change-Id: I55e2d99b3f9929703f34d268f4490f3c5c2c766f Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/northbridge/intel/haswell/gma.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/src/northbridge/intel/haswell/gma.c b/src/northbridge/intel/haswell/gma.c index 04fa6da..a0616c2 100644 --- a/src/northbridge/intel/haswell/gma.c +++ b/src/northbridge/intel/haswell/gma.c @@ -459,8 +459,13 @@ static void gma_func0_init(struct device *dev) #if IS_ENABLED(CONFIG_CHROMEOS) init_fb = display_init_required(); #endif - lightup_ok = panel_lightup(&dp, init_fb); - gfx_set_init_done(1); + if (IS_ENABLED(CONFIG_MAINBOARD_USE_LIBGFXINIT)) { + gma_gfxinit(gtt_res->base, (u32)dp.graphics, + dp.physbase, &lightup_ok); + } else + lightup_ok = panel_lightup(&dp, init_fb); + + gfx_set_init_done(1); #endif if (! lightup_ok) { printk(BIOS_SPEW, "FUI did not run; using VBIOS\n");
