Youness Alaoui has posted comments on this change. ( https://review.coreboot.org/19849 )
Change subject: console/flashsconsole: Add spi flash console for debugging ......................................................................
Patch Set 6:
(4 comments)
https://review.coreboot.org/#/c/19849/5/src/drivers/spi/flashconsole.c File src/drivers/spi/flashconsole.c:
PS5, Line 18: #include <boot_device.h>
This isn't needed.
boot_device_rw() is defined there.
PS5, Line 24: #include <spi_flash.h>
This isn't needed.
Done
PS5, Line 26: 0x1000
This is pretty big, fwiw. Some people might run out of CAR space. You prob
yeah, it was 0x100, then I changed it to 0x1000 when I started using that buffer to read the sectors to find 0xff. I should probably dial it down back down to 0x100 (or 128? biggest line I found in my log is 113 bytes), and use a local buffer in the init for the sectors.
PS5, Line 149: ||
This should just remove the -1 as we'll flush when we reach full capacity.
Yeah, leftover from when I was using a '\0' to find the size of the line.
