Attention is currently required from: Arthur Heymans, Christian Walter, Jincheng Li, Johnny Lin, Jonathan Zhang, Lean Sheng Tan, Shuo Liu, Tim Chu.
Hello Arthur Heymans, Christian Walter, Jincheng Li, Johnny Lin, Jonathan Zhang, Lean Sheng Tan, Patrick Rudolph, Tim Chu, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81374?usp=email
Change subject: soc/intel/xeon_sp/gnr: Add soc_pci_domain_fill_ssdt ......................................................................
Domain device objects are created with HID/CID/UID.
Dynamic domain SSDT generation could benefit the support of SoCs with multiple SKUs, or the case where one set of codes supports multiple SoCs. One possible side-effect might be the extra performance cost for generating these tables, which should not bring big impact on high performance server CPUs.
GNR codes run with dynamic domain SSDT generation to fit for both GraniteRapids and SierraForest SoCs.
Change-Id: I28bfdf74d8044235f79f67d832860d8b4306670c Signed-off-by: Shuo Liu shuo.liu@intel.com Signed-off-by: Jincheng Li jincheng.li@intel.com --- M src/soc/intel/xeon_sp/gnr/soc_acpi.c 1 file changed, 37 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/81374/4
