Martin Roth (gaumless@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8066
commit 5714e1b58c7220cf22d2f07b3b95393673be53af Author: Martin Roth martin.roth@se-eng.com Date: Sat Jan 3 17:18:58 2015 -0700
drivers/intel/fsp: Add HOB tools to work with GUIDs
Add new functions to: - Compare two GUIDs - Find a hob based on its GUID - Print information about GUID_EXTENSION type HOBs - Print a GUID's address and value
Change-Id: I89377ec8ab7d98fe7dc129097e643aac061ab3a3 Signed-off-by: Martin Roth martin.roth@se-eng.com --- src/drivers/intel/fsp/fsp_util.h | 4 ++ src/drivers/intel/fsp/hob.c | 98 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 102 insertions(+)
diff --git a/src/drivers/intel/fsp/fsp_util.h b/src/drivers/intel/fsp/fsp_util.h index cb667dc..3c72f24 100644 --- a/src/drivers/intel/fsp/fsp_util.h +++ b/src/drivers/intel/fsp/fsp_util.h @@ -42,7 +42,11 @@ void ChipsetFspReturnPoint(EFI_STATUS Status, VOID *HobListPtr); void print_hob_mem_attributes(void *Hobptr); void print_hob_type_structure(u16 Hobtype, void *Hoblistptr); void print_hob_resource_attributes(void *Hobptr); +void print_guid_type_attributes(void *Hobptr); const char * get_hob_type_string(void *Hobptr); +void * find_hob_by_guid(void *Hoblistptr, EFI_GUID *guid1); +uint8_t guids_are_equal(EFI_GUID *guid1, EFI_GUID *guid2); +void printguid(EFI_GUID *guid);
/* Additional HOB types not included in the FSP: * #define EFI_HOB_TYPE_HANDOFF 0x0001 diff --git a/src/drivers/intel/fsp/hob.c b/src/drivers/intel/fsp/hob.c index 4537ffb..b336d99 100644 --- a/src/drivers/intel/fsp/hob.c +++ b/src/drivers/intel/fsp/hob.c @@ -20,8 +20,27 @@ #include <types.h> #include <string.h> #include <console/console.h> +#include <lib.h> // hexdump #include "fsp_util.h"
+ +/** Displays a GUID's address and value + * + * @param guid pointer to the GUID to display + */ +void printguid(EFI_GUID *guid) +{ + printk(BIOS_SPEW,"Address: %p Guid: %08lx-%04x-%04x-%02x%02x-" + "%02x%02x%02x%02x%02x%02x%02x%02x\n", + guid, (unsigned long)guid->Data1, + guid->Data2, guid->Data3, + guid->Data4[0], guid->Data4[1], + guid->Data4[2], guid->Data4[3], + guid->Data4[4], guid->Data4[5], + guid->Data4[6], guid->Data4[7], + guid->Data4[8], guid->Data4[9] ); +} + void print_hob_mem_attributes(void *Hobptr) { EFI_HOB_MEMORY_ALLOCATION *HobMemoryPtr = (EFI_HOB_MEMORY_ALLOCATION *)Hobptr; @@ -118,6 +137,27 @@ const char * get_hob_type_string(void *Hobptr) return Hobtypestring; }
+/** Displays the length, location, and GUID value of a GUID extension + * + * The EFI_HOB_GUID_TYPE is very basic - it just contains the standard + * HOB header containing the HOB type and length, and a GUID for + * identification. The rest of the data is undefined and must be known + * based on the GUID. + * + * This displays the entire HOB length, and the location of the start + * of the HOB, *NOT* the length of or the start of the data inside the HOB. + * + * @param Hobptr + */ +void print_guid_type_attributes(void *Hobptr) +{ + printk(BIOS_SPEW, " at location %p with length0x%0lx\n ", + Hobptr, (unsigned long)(((EFI_PEI_HOB_POINTERS *) \ + Hobptr)->Guid->Header.HobLength)); + printguid(&(((EFI_HOB_GUID_TYPE *)Hobptr)->Name)); + +} + /* Print out a structure of all the HOBs * that match a certain type: * Print all types (0x0000) @@ -159,6 +199,8 @@ void print_hob_type_structure(u16 Hobtype, void *Hoblistptr) print_hob_mem_attributes(Currenthob); break; case EFI_HOB_TYPE_RESOURCE_DESCRIPTOR: print_hob_resource_attributes(Currenthob); break; + case EFI_HOB_TYPE_GUID_EXTENSION: + print_guid_type_attributes(Currenthob); break; } }
@@ -170,3 +212,59 @@ void print_hob_type_structure(u16 Hobtype, void *Hoblistptr) } while (!Lasthob); printk(BIOS_DEBUG, "=== End of FSP HOB Data Structure ===\n\n"); } + + +/** Finds a HOB entry based on type and guid + * + * @param current_hob pointer to the start of the HOB list + * @param guid the GUID of the HOB entry to find + * @return pointer to the start of the requested HOB or NULL if not found. + */ +void * find_hob_by_guid(void *current_hob, EFI_GUID *guid) +{ + do { + switch (((EFI_HOB_GENERIC_HEADER *)current_hob)->HobType) { + + case EFI_HOB_TYPE_MEMORY_ALLOCATION: + if (guids_are_equal(guid, &(((EFI_HOB_MEMORY_ALLOCATION *) \ + current_hob)->AllocDescriptor.Name))) + return current_hob; + break; + case EFI_HOB_TYPE_RESOURCE_DESCRIPTOR: + if (guids_are_equal(guid, + &(((EFI_HOB_RESOURCE_DESCRIPTOR *) \ + current_hob)->Owner))) + return current_hob; + break; + case EFI_HOB_TYPE_GUID_EXTENSION: + if (guids_are_equal(guid, &(((EFI_HOB_GUID_TYPE *) \ + current_hob)->Name))) + return current_hob; + break; + } + + if (!END_OF_HOB_LIST(current_hob)) + current_hob = GET_NEXT_HOB(current_hob); /* Get next HOB pointer */ + } while (!END_OF_HOB_LIST(current_hob)); + + return NULL; +} + +/** Compares a pair of GUIDs to see if they are equal + * + * GUIDs are 128 bits long, so compare them as pairs of quadwords. + * + * @param guid1 pointer to the first of the GUIDs to compare + * @param guid2 pointer to the second of the GUIDs to compare + * @return 1 if the GUIDs were equal, 0 if GUIDs were not equal + */ +uint8_t guids_are_equal(EFI_GUID *guid1, EFI_GUID *guid2) +{ + uint64_t* guid_1 = (void *) guid1; + uint64_t* guid_2 = (void *) guid2; + + if ((*(guid_1) != *(guid_2)) || (*(guid_1 + 1) != *(guid_2 + 1))) + return 0; + + return 1; +}
