Thejaswani Putta has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34887 )
Change subject: Moffet: Add two variants - arcada_cml & sarien_cml ......................................................................
These variants are to support the EV sarien and arcada boards with CML SOC, the drallion variant will be used to support the upcoming EVT drallion board.
Signed-off-by: Thejaswani Putta thejaswani.putta@intel.com Change-Id: I766bdccb6f8b6924d6ae1abbe57035f4ff1f6f17 --- A src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc A src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb A src/mainboard/google/drallion/variants/arcada_cml/gpio.c A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h A src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc A src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb A src/mainboard/google/drallion/variants/sarien_cml/gpio.c A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h 18 files changed, 2,176 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/1
diff --git a/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc b/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc new file mode 100644 index 0000000..2bf028e --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc @@ -0,0 +1,19 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2018 Google LLC +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +bootblock-y += gpio.c +ramstage-y += gpio.c +romstage-y += gpio.c +verstage-y += gpio.c diff --git a/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb b/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb new file mode 100644 index 0000000..ebcf140 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb @@ -0,0 +1,392 @@ +chip soc/intel/cannonlake + + # GPE configuration + # Note that GPE events called out in ASL code rely on this + # route. i.e. If this route changes then the affected GPE + # offset bits also need to be changed. + register "gpe0_dw0" = "PMC_GPP_A" + register "gpe0_dw1" = "PMC_GPP_C" + register "gpe0_dw2" = "PMC_GPP_D" + + # EC host command ranges + register "gen1_dec" = "0x00040931" # 0x930-0x937 + register "gen2_dec" = "0x00040941" # 0x940-0x947 + register "gen3_dec" = "0x000c0951" # 0x950-0x95f + + # FSP configuration + register "SaGv" = "SaGv_Enabled" + register "HeciEnabled" = "0" + register "SataSalpSupport" = "1" + register "SataMode" = "Sata_AHCI" + register "SataPortsEnable[2]" = "1" + register "SataPortsDevSlp[2]" = "1" + register "InternalGfx" = "1" + register "SkipExtGfxScan" = "1" + register "PchPmSlpS3MinAssert" = "3" # 50ms + register "PchPmSlpS4MinAssert" = "4" # 4s + register "PchPmSlpSusMinAssert" = "4" # 4s + register "PchPmSlpAMinAssert" = "4" # 2s + register "PchUnlockGpioPads" = "1" + + register "speed_shift_enable" = "1" + register "psys_pmax" = "140" + register "s0ix_enable" = "1" + register "dptf_enable" = "1" + register "dmipwroptimize" = "1" + register "satapwroptimize" = "1" + register "tdp_pl1_override" = "25" + register "tdp_pl2_override" = "51" + register "Device4Enable" = "1" + register "AcousticNoiseMitigation" = "1" + register "SlowSlewRateForIa" = "2" + register "SlowSlewRateForGt" = "2" + register "SlowSlewRateForSa" = "0" + register "SlowSlewRateForFivr" = "2" + # Enable eDP device + register "DdiPortEdp" = "1" + # Enable HPD for DDI ports B/C + register "DdiPortBHpd" = "1" + register "DdiPortCHpd" = "1" + # Enable DDC for DDI port B + register "DdiPortBDdc" = "1" + + # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 5A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 6A | 70A | 31A | 31A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #| DcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #+----------------+-------+-------+-------+-------+ + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(6), + .voltage_limit = 1520, + .ac_loadline = 1030, + .dc_loadline = 1030, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(70), + .voltage_limit = 1520, + .ac_loadline = 180, + .dc_loadline = 180, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + # Intel Common SoC Config + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Left Type-C Port + register "usb2_ports[1]" = "USB2_PORT_LONG(OC0)" # Left Type-A Port + register "usb2_ports[2]" = "USB2_PORT_LONG(OC1)" # Right Type-A Port + register "usb2_ports[3]" = "USB2_PORT_EMPTY" + register "usb2_ports[4]" = "USB2_PORT_EMPTY" + register "usb2_ports[5]" = "USB2_PORT_LONG(OC_SKIP)" # Camera + register "usb2_ports[6]" = "{ + .enable = 1, \ + .ocpin = OC_SKIP, \ + .tx_bias = USB2_BIAS_0MV, \ + .tx_emp_enable = USB2_DE_EMP_ON_PRE_EMP_ON, \ + .pre_emp_bias = USB2_BIAS_28P15MV, \ + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, \ + }" # WWAN + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # USH + register "usb2_ports[8]" = "USB2_PORT_MID(OC_SKIP)" # Fingerprint + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Left Type-C Port + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # Left Type-A Port + register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC1)" # Right Type-A Port + register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC_SKIP)" # WWAN + register "usb3_ports[4]" = "USB3_PORT_EMPTY" + register "usb3_ports[5]" = "USB3_PORT_EMPTY" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| chipset_lockdown | CHIPSET_LOCKDOWN_COREBOOT | + #| I2C0 | Touchscreen | + #| I2C1 | Touchpad | + #| I2C4 | H1 TPM | + #+-------------------+---------------------------+ + + register "tcc_offset" = "1" + + # PCH Thermal Trip Temperature in deg C + register "common_soc_config.pch_thermal_trip" = "77" + + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 52, + .fall_time_ns = 110, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 52, + .fall_time_ns = 110, + .data_hold_time_ns = 330, + }, + .i2c[4] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + .rise_time_ns = 36, + .fall_time_ns = 99, + }, + }" + + # PCIe port 10 for M.2 2230 WLAN + register "PcieRpEnable[9]" = "1" + register "PcieClkSrcUsage[2]" = "9" + register "PcieClkSrcClkReq[2]" = "2" + + # PCIe port 11 for card reader + register "PcieRpEnable[10]" = "1" + register "PcieRpLtrEnable[10]" = "1" + register "PcieClkSrcUsage[1]" = "10" + register "PcieClkSrcClkReq[1]" = "1" + + # PCIe port 13 for M.2 2280 SSD + register "PcieRpEnable[12]" = "1" + register "PcieRpLtrEnable[12]" = "1" + register "PcieClkSrcUsage[4]" = "12" + register "PcieClkSrcClkReq[4]" = "4" + + # GPIO PM programming + register "gpio_override_pm" = "1" + + # GPIO community PM configuration + register "gpio_pm[COMM_0]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_1]" = "MISCCFG_GPSIDEDPCGEN | MISCCFG_GPRTCDLCGEN | MISCCFG_GSXSLCGEN | MISCCFG_GPDPCGEN | MISCCFG_GPDLCGEN" + register "gpio_pm[COMM_2]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_3]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_4]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + + device cpu_cluster 0 on + device lapic 0 on end + end + device domain 0 on + device pci 00.0 on end # Host Bridge + device pci 02.0 on end # Integrated Graphics Device + device pci 04.0 on end # SA Thermal device + device pci 12.0 on end # Thermal Subsystem + device pci 12.5 off end # UFS SCS + device pci 12.6 off end # GSPI #2 + device pci 13.0 on # Integrated Sensor Hub + chip drivers/intel/ish + register "firmware_name" = ""arcada_ish.bin"" + device generic 0 on end + end + end + device pci 14.0 on + chip drivers/usb/acpi + register "desc" = ""Root Hub"" + register "type" = "UPC_TYPE_HUB" + device usb 0.0 on + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 2.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 2.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 2.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.5 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.6 on end + end + chip drivers/usb/acpi + register "desc" = ""USH"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.7 on end + end + chip drivers/usb/acpi + register "desc" = ""Fingerprint"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.8 on end + end + chip drivers/usb/acpi + register "desc" = ""Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H15)" + device usb 2.9 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 3.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 3.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 3.2 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 3.3 on end + end + end + end + end # USB xHCI + device pci 14.1 off end # USB xDCI (OTG) + chip drivers/intel/wifi + register "wake" = "PME_B0_EN_BIT" + device pci 14.3 on end # CNVi wifi + end + device pci 14.5 off end # SDCard + device pci 15.0 on + chip drivers/i2c/hid + register "generic.hid" = ""WCOM48E2"" + register "generic.desc" = ""Wacom Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C23_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "generic.reset_delay_ms" = "120" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "generic.enable_delay_ms" = "55" + register "generic.has_power_resource" = "1" + register "generic.disable_gpio_export_in_crs" = "1" + register "hid_desc_reg_offset" = "0x1" + device i2c 0A on end + end + end # I2C #0 + device pci 15.1 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_B3_IRQ)" + register "probed" = "1" + device i2c 2c on end + end + end # I2C #1 + device pci 15.2 off end # I2C #2 + device pci 15.3 off end # I2C #3 + device pci 16.0 on end # Management Engine Interface 1 + device pci 16.1 off end # Management Engine Interface 2 + device pci 16.2 off end # Management Engine IDE-R + device pci 16.3 off end # Management Engine KT Redirection + device pci 16.4 off end # Management Engine Interface 3 + device pci 16.5 off end # Management Engine Interface 4 + device pci 17.0 on end # SATA + device pci 19.0 on + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D18_IRQ)" + device i2c 50 on end + end + end # I2C #4 + device pci 19.1 off end # I2C #5 + device pci 19.2 on end # UART #2 + device pci 1a.0 off end # eMMC + device pci 1c.0 off end # PCI Express Port 1 (USB) + device pci 1c.1 off end # PCI Express Port 2 (USB) + device pci 1c.2 off end # PCI Express Port 3 (USB) + device pci 1c.3 off end # PCI Express Port 4 (USB) + device pci 1c.4 off end # PCI Express Port 5 (USB) + device pci 1c.5 off end # PCI Express Port 6 + device pci 1c.6 off end # PCI Express Port 7 + device pci 1c.7 off end # PCI Express Port 8 + device pci 1d.0 on + smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "2230" "SlotDataBusWidth1X" + end # PCI Express Port 9 + device pci 1d.1 on end # PCI Express Port 10 + device pci 1d.2 on end # PCI Express Port 11 + device pci 1d.3 off end # PCI Express Port 12 + device pci 1d.4 on + smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "2280" "SlotDataBusWidth4X" + end # PCI Express Port 13 (x4) + device pci 1e.0 off end # UART #0 + device pci 1e.1 off end # UART #1 + device pci 1e.2 off end # GSPI #0 + device pci 1e.3 off end # GSPI #1 + device pci 1f.0 on + chip ec/google/wilco + device pnp 0c09.0 on end + end + end # LPC/eSPI + device pci 1f.1 on end # P2SB + device pci 1f.2 on end # Power Management Controller + device pci 1f.3 on end # Intel HDA + device pci 1f.4 on end # SMBus + device pci 1f.5 on end # PCH SPI + device pci 1f.6 off end # GbE + end +end diff --git a/src/mainboard/google/drallion/variants/arcada_cml/gpio.c b/src/mainboard/google/drallion/variants/arcada_cml/gpio.c new file mode 100644 index 0000000..ff0240c --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/gpio.c @@ -0,0 +1,279 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#include <variant/gpio.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* Pad configuration in ramstage */ +static const struct pad_config gpio_table[] = { +/* RCIN# */ PAD_NC(GPP_A0, NONE), +/* ESPI_IO0 */ +/* ESPI_IO1 */ +/* ESPI_IO2 */ +/* ESPI_IO3 */ +/* ESPI_CS# */ +/* SERIRQ */ +/* PIRQA# */ PAD_NC(GPP_A7, NONE), +/* CLKRUN# */ PAD_NC(GPP_A8, NONE), +/* ESPI_CLK */ +/* CLKOUT_LPC1 */ PAD_NC(GPP_A10, NONE), +/* PME# */ PAD_NC(GPP_A11, NONE), + /* ISH_LID_CL#_TAB */ +/* ISH_GP6 */ PAD_CFG_NF(GPP_A12, NONE, DEEP, NF2), +/* SUSWARN# */ PAD_NC(GPP_A13, NONE), +/* ESPI_RESET# */ +/* SUSACK# */ PAD_NC(GPP_A15, NONE), +/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), +/* SD_PWR_EN# */ PAD_NC(GPP_A17, NONE), + /* ISH_ACC1_INT# */ +/* ISH_GP0 */ PAD_CFG_NF(GPP_A18, NONE, DEEP, NF1), + /* ISH_ACC2_INT# */ +/* ISH_GP1 */ PAD_CFG_NF(GPP_A19, NONE, DEEP, NF1), +/* ISH_GP2 */ PAD_NC(GPP_A20, NONE), +/* ISH_GP3 */ PAD_NC(GPP_A21, NONE), + /* ISH_NB_MODE */ +/* ISH_GP4 */ PAD_CFG_NF(GPP_A22, NONE, DEEP, NF1), + /* ISH_LID_CL#_NB */ +/* ISH_GP5 */ PAD_CFG_NF(GPP_A23, NONE, DEEP, NF1), + +/* CORE_VID0 */ +/* CORE_VID1 */ +/* VRALERT# */ PAD_NC(GPP_B2, NONE), +/* CPU_GP2 */ PAD_CFG_GPI_APIC(GPP_B3, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TOUCHPAD_INTR# */ +/* CPU_GP3 */ PAD_CFG_GPI(GPP_B4, NONE, DEEP), /* TOUCH_SCREEN_DET# */ + /* LAN_CLKREQ_CPU_N */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), + /* CARD_CLKREQ_CPU_N */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), + /* WLAN_CLKREQ_CPU_N */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), + /* WWAN_CLKREQ_CPU_N */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), + /* SSD_CKLREQ_CPU_N */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), +/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), /* TBT_CLKREQ_CPU_N (nostuff) */ +/* EXT_PWR_GATE# */ PAD_CFG_GPO(GPP_B11, 0, DEEP), /* 3.3V_CAM_EN# */ +/* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), +/* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), +/* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), +/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), /* PRIM_CORE_OPT_DIS (nostuff) */ +/* GSPI0_CLK */ PAD_CFG_GPI(GPP_B16, NONE, DEEP), /* ONE_DIMM# */ +/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), /* RTC_DET# */ +/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), +/* GSPI1_CS# */ PAD_NC(GPP_B19, NONE), /* HDD_FALL_INT (nostuff) */ +/* GSPI1_CLK */ PAD_NC(GPP_B20, NONE), /* TPM_PIRQ# (nostuff) */ +/* GSPI1_MISO */ PAD_CFG_GPO(GPP_B21, 1, DEEP), /* PCH_3.3V_TS_EN */ +/* GSPI1_MOSI */ PAD_NC(GPP_B22, NONE), +/* SML1ALERT# */ PAD_NC(GPP_B23, DN_20K), + +/* SMBCLK */ PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), /* MEM_SMBCLK */ +/* SMBDATA */ PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), /* MEM_SMBDATA */ +/* SMBALERT# */ PAD_NC(GPP_C2, DN_20K), +/* SML0CLK */ PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), /* SML0_SMBCLK */ +/* SML0DATA */ PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), /* SML0_SMBDATA */ +/* SML0ALERT# */ PAD_NC(GPP_C5, DN_20K), +/* SM1CLK */ PAD_CFG_NF(GPP_C6, NONE, DEEP, NF1), /* SML1_SMBCLK */ +/* SM1DATA */ PAD_CFG_NF(GPP_C7, NONE, DEEP, NF1), /* SML1_SMBDATA */ +/* UART0_RXD */ PAD_NC(GPP_C8, NONE), /* PCH_TBT_PERST# (nostuff) */ +/* UART0_TXD */ PAD_NC(GPP_C9, NONE), +/* UART0_RTS# */ PAD_CFG_GPI(GPP_C10, NONE, DEEP), /* TYPEC_CON_SEL1 */ +/* UART0_CTS# */ PAD_CFG_GPI(GPP_C11, NONE, DEEP), /* TYPEC_CON_SEL2 */ +/* UART1_RXD */ PAD_CFG_GPI_SCI_LOW(GPP_C12, NONE, DEEP, + EDGE_SINGLE), /* SIO_EXT_WAKE# */ +/* UART1_TXD */ PAD_NC(GPP_C13, NONE), +/* UART1_RTS# */ PAD_CFG_GPI(GPP_C14, NONE, DEEP), /* LCD_CBL_DET# */ +/* UART1_CTS# */ PAD_NC(GPP_C15, NONE), +/* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* TS_I2C_SDA */ +/* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* TS_I2C_SCL */ +/* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* I2C1_SDA_TP */ +/* I2C1_SCL */ PAD_CFG_NF(GPP_C19, NONE, DEEP, NF1), /* I2C1_SCK_TP */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), +/* UART2_CTS# */ PAD_CFG_GPI_APIC(GPP_C23, NONE, PLTRST, + LEVEL, NONE), /* TS_INT# */ + +/* SPI1_CS# */ PAD_CFG_GPI_APIC(GPP_D0, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* MEDIACARD_IRQ# */ +/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), +/* SPI1_MISO */ PAD_CFG_GPI(GPP_D2, NONE, DEEP), /* ISH_LAN# */ +/* SPI1_MOSI */ PAD_NC(GPP_D3, NONE), +/* FASHTRIG */ PAD_NC(GPP_D4, NONE), /* TBT_FORCE_PWR (nostuff) */ + /* ISH_I2C0_ACC_SDA */ +/* ISH_I2C0_SDA */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), + /* ISH_I2C0_ACC_SCL */ +/* ISH_I2C0_SCL */ PAD_CFG_NF(GPP_D6, NONE, DEEP, NF1), +/* ISH_I2C1_SDA */ PAD_NC(GPP_D7, NONE), +/* ISH_I2C1_SCL */ PAD_NC(GPP_D8, NONE), +/* ISH_SPI_CS# */ PAD_CFG_GPI(GPP_D9, NONE, DEEP), /* IR_CAM_DET# */ +/* ISH_SPI_CLK */ PAD_NC(GPP_D10, NONE), +/* ISH_SPI_MISO */ PAD_CFG_GPI(GPP_D11, NONE, DEEP), /* TBT_DET# */ +/* ISH_SPI_MOSI */ PAD_NC(GPP_D12, NONE), + /* ISH_CPU_UART0_RX */ +/* ISH_UART0_RXD */ PAD_CFG_NF(GPP_D13, UP_20K, DEEP, NF1), + /* ISH_CPU_UART0_TX */ +/* ISH_UART0_TXD */ PAD_CFG_NF(GPP_D14, NONE, DEEP, NF1), +/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 1, DEEP), /* WWAN_FULL_PWR_EN */ +/* ISH_UART0_CTS# */ PAD_NC(GPP_D16, NONE), +/* DMIC_CLK1 */ PAD_CFG_GPI(GPP_D17, NONE, DEEP), /* KB_DET# */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* DMIC_CLK0 */ PAD_NC(GPP_D19, NONE), +/* DMIC_DATA0 */ PAD_NC(GPP_D20, NONE), +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 1, DEEP), /* WWAN_BB_RST# */ +/* SPI1_IO3 */ PAD_CFG_GPO(GPP_D22, 0, DEEP), /* WWAN_GPIO_PERST# */ +/* I2S_MCLK */ PAD_CFG_GPI_SCI_LOW(GPP_D23, NONE, DEEP, + EDGE_SINGLE), /* WWAN_GPIO_WAKE# */ + +/* SATAXPCIE0 */ PAD_NC(GPP_E0, NONE), + /* M3042_PCIE#_SATA */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), + /* M2880_PCIE_SATA# */ +/* SATAXPCIE2 */ PAD_CFG_NF(GPP_E2, NONE, DEEP, NF1), +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATA_DEVSLP0 */ PAD_NC(GPP_E4, NONE), +/* SATA_DEVSLP1 */ PAD_CFG_NF(GPP_E5, NONE, DEEP, NF1), /* M3042_DEVSLP */ +/* SATA_DEVSLP2 */ PAD_CFG_NF(GPP_E6, NONE, DEEP, NF1), /* M2280_DEVSLP */ +/* CPU_GP1 */ PAD_CFG_GPO(GPP_E7, 1, DEEP), /* TOUCH_SCREEN_PD# */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* USB2_OCO# */ PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), /* USB_OC0# */ +/* USB2_OC1# */ PAD_CFG_NF(GPP_E10, NONE, DEEP, NF1), /* USB_OC1# */ +/* USB2_OC2# */ PAD_NC(GPP_E11, NONE), +/* USB2_OC3# */ PAD_NC(GPP_E12, NONE), +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* DP_HPD_CPU */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* DP2_HPD_CPU */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* PCH_WP */ +/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), /* FFS_INT2 (nostuff) */ +/* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), +/* DDPB_CTRLCLK */ PAD_CFG_NF(GPP_E18, NONE, DEEP, NF1), /* HDMI_SCL_CPU */ +/* DDPB_CTRLDATA */ PAD_CFG_NF(GPP_E19, NONE, DEEP, NF1), /* HDMI_SDA_CPU */ +/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), +/* DDPC_CTRLDATA */ PAD_NC(GPP_E21, NONE), +/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), +/* DDPD_CTRLDATA */ PAD_NC(GPP_E23, NONE), + +/* CNV_PA_BLANKING */ PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), /* CNV_COEX3 */ +/* GPP_F1 */ PAD_NC(GPP_F1, NONE), +/* GPP_F2 */ PAD_NC(GPP_F2, NONE), +/* GPP_F3 */ PAD_NC(GPP_F3, NONE), +/* CNV_BRI_DT */ PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), +/* CNV_BRI_RSP */ PAD_CFG_NF(GPP_F5, NONE, DEEP, NF1), +/* CNV_RGI_DT */ PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), +/* CNV_RGI_RSP */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), +/* CNV_MFUART2_RXD */ PAD_CFG_NF(GPP_F8, NONE, DEEP, NF1), /* CNV_COEX2 */ +/* CNV_MFUART2_TXD */ PAD_CFG_NF(GPP_F9, NONE, DEEP, NF1), /* CNV_COEX1 */ +/* GPP_F10 */ PAD_NC(GPP_F10, NONE), +/* EMMC_CMD */ PAD_NC(GPP_F11, NONE), +/* EMMC_DATA0 */ PAD_NC(GPP_F12, NONE), +/* EMMC_DATA1 */ PAD_NC(GPP_F13, NONE), +/* EMMC_DATA2 */ PAD_NC(GPP_F14, NONE), +/* EMMC_DATA3 */ PAD_NC(GPP_F15, NONE), +/* EMMC_DATA4 */ PAD_NC(GPP_F16, NONE), +/* EMMC_DATA5 */ PAD_NC(GPP_F17, NONE), +/* EMMC_DATA6 */ PAD_NC(GPP_F18, NONE), +/* EMMC_DATA7 */ PAD_NC(GPP_F19, NONE), +/* EMMC_RCLK */ PAD_NC(GPP_F20, NONE), +/* EMMC_CLK */ PAD_NC(GPP_F21, NONE), +/* EMMC_RESET# */ PAD_NC(GPP_F22, NONE), +/* A4WP_PRESENT */ PAD_NC(GPP_F23, NONE), + +/* SD_CMD */ PAD_CFG_GPI(GPP_G0, NONE, DEEP), /* CAM_MIC_CBL_DET# */ +/* SD_DATA0 */ PAD_NC(GPP_G1, NONE), /* ANT_CONFIG (nostuff) */ +/* SD_DATA1 */ PAD_NC(GPP_G2, NONE), /* TBT_CIO_PLUG_EVT# (nostuff) */ +/* SD_DATA2 */ PAD_NC(GPP_G3, NONE), +/* SD_DATA3 */ PAD_CFG_GPI(GPP_G4, NONE, DEEP), /* CTLESS_DET# */ +/* SD_CD# */ PAD_CFG_GPO(GPP_G5, 1, DEEP), /* HOST_SD_WP# */ +/* SD_CLK */ PAD_CFG_GPO(GPP_G6, 1, DEEP), /* AUD_PWR_EN */ +/* SD_WP */ PAD_CFG_GPI(GPP_G7, NONE, DEEP), /* SPK_DET# */ + +/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), +/* I2S2_SFRM */ PAD_CFG_NF(GPP_H1, NONE, DEEP, NF3), /* CNV_RF_RESET# */ +/* I2S2_TXD */ PAD_CFG_NF(GPP_H2, NONE, DEEP, NF3), /* CLKREQ_CNV# */ +/* I2S2_RXD */ PAD_NC(GPP_H3, NONE), +/* I2C2_SDA */ PAD_NC(GPP_H4, NONE), +/* I2C2_SCL */ PAD_NC(GPP_H5, NONE), +/* I2C3_SDA */ PAD_NC(GPP_H6, NONE), +/* I2C3_SCL */ PAD_NC(GPP_H7, NONE), +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* I2C5_SDA */ PAD_NC(GPP_H10, NONE), /* ISH_I2C2_SDA */ +/* I2C5_SCL */ PAD_NC(GPP_H11, NONE), /* ISH_I2C2_SCL */ +/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), +/* M2_SKT2_CFG3 */ PAD_CFG_GPO(GPP_H15, 1, DEEP), /* BT_RADIO_DIS# */ +/* DDPF_CTRLCLK */ PAD_NC(GPP_H16, NONE), +/* DPPF_CTRLDATA */ PAD_NC(GPP_H17, NONE), +/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), /* C10_GATE# */ +/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), +/* IMGCLKOUT1 */ PAD_NC(GPP_H20, NONE), +/* GPP_H21 */ PAD_NC(GPP_H21, NONE), +/* GPP_H22 */ PAD_NC(GPP_H22, NONE), /* RTD3_CIO_PWR_EN (nostuff) */ +/* GPP_H23 */ PAD_NC(GPP_H23, NONE), + +/* BATLOW# */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* BATLOW# */ +/* ACPRESENT */ PAD_CFG_NF(GPD1, NONE, DEEP, NF1), /* AC_PRESENT */ +/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* LAN_WAKE# */ +/* PWRBTN# */ PAD_CFG_NF(GPD3, NONE, DEEP, NF1), /* SIO_PWRBTN# */ +/* SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* SIO_SLP_S3# */ +/* SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* SIO_SLP_S4# */ +/* SLP_A# */ PAD_CFG_NF(GPD6, NONE, DEEP, NF1), /* SIO_SLP_A# */ +/* GPD7 */ PAD_NC(GPD7, NONE), /* TBT_RTD3_WAKE# (nostuff) */ +/* SUSCLK */ PAD_CFG_NF(GPD8, NONE, DEEP, NF1), /* SUSCLK */ +/* SLP_WLAN# */ PAD_CFG_NF(GPD9, NONE, DEEP, NF1), /* SIO_SLP_WLAN# */ +/* SLP_S5# */ PAD_CFG_NF(GPD10, NONE, DEEP, NF1), /* SIO_SLP_S5# */ +/* LANPHYC */ PAD_CFG_NF(GPD11, NONE, DEEP, NF1), /* PM_LANPHY_EN */ +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { +/* M2_SKT2_CFG1 */ PAD_CFG_GPO(GPP_H13, 1, DEEP), /* M.2 SSD D3 cold */ +/* SSD RESET pin will stay low first */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 0, DEEP), /* D3 cold RST */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* RESET# need to stay low before FULL_CARD_POWER_OFF assert */ +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 0, DEEP), /* WWAN_BB_RST# */ +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* PCH_WP */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 1, DEEP), /* D3 cold RST */ +}; + +const struct pad_config *variant_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(gpio_table); + return gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} + +static const struct cros_gpio cros_gpios[] = { + CROS_GPIO_REC_AL(GPP_E8, CROS_GPIO_DEVICE_NAME), + CROS_GPIO_WP_AH(GPP_E15, CROS_GPIO_DEVICE_NAME), +}; + +const struct cros_gpio *variant_cros_gpios(size_t *num) +{ + *num = ARRAY_SIZE(cros_gpios); + return cros_gpios; +} diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl new file mode 100644 index 0000000..73e1dec --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl @@ -0,0 +1,73 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define DPTF_CPU_PASSIVE 98 +#define DPTF_CPU_CRITICAL 108 + +/* Skin Sensor for CPU VR temperature monitor */ +#define DPTF_TSR0_SENSOR_ID 1 +#define DPTF_TSR0_SENSOR_NAME "Skin" +#define DPTF_TSR0_PASSIVE 55 +#define DPTF_TSR0_CRITICAL 100 + +/* Memory Sensor for DDR temperature monitor */ +#define DPTF_TSR1_SENSOR_ID 2 +#define DPTF_TSR1_SENSOR_NAME "DDR" +#define DPTF_TSR1_PASSIVE 53 +#define DPTF_TSR1_CRITICAL 100 + +/* M.2 Sensor for Ambient temperature monitor */ +#define DPTF_TSR2_SENSOR_ID 3 +#define DPTF_TSR2_SENSOR_NAME "Ambient" +#define DPTF_TSR2_PASSIVE 38 +#define DPTF_TSR2_CRITICAL 93 + +#undef DPTF_ENABLE_FAN_CONTROL +#undef DPTF_ENABLE_CHARGER + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 500, 100, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Skin (TSR0) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 400, 40, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on DDR (TSR1) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 300, 50, 2, 0, 0, 0 }, + + /* CPU Throttle Effect on Ambient (TSR2) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR2, 1000, 100, 1, 0, 0, 0 }, +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 3000, /* PowerLimitMinimum */ + 21000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 15000, /* PowerLimitMinimum */ + 51000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + } +}) diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl new file mode 100644 index 0000000..41121d2 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2019 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define CAM_EN GPP_B11 /* Active low */ +#define TS_PD GPP_E7 + +/* Method called from LPIT prior to enter s0ix state */ +Method (MS0X, 1) +{ + If (Arg0) { + /* Turn off camera power */ + _SB.PCI0.STXS (CAM_EN) + } Else { + /* Turn on camera power */ + _SB.PCI0.CTXS (CAM_EN) + } +} + +/* Method called from _PTS prior to enter sleep state */ +Method (MPTS, 1) +{ + _SB.PCI0.LPCB.EC0.PTS (Arg0) + + /* Clear touch screen pd pin to avoid leakage */ + _SB.PCI0.CTXS (TS_PD) +} + +/* Method called from _WAK prior to wakeup */ +Method (MWAK, 1) +{ + _SB.PCI0.LPCB.EC0.WAK (Arg0) +} diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h new file mode 100644 index 0000000..01a17b5 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_EC_H +#define VARIANT_EC_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* EC wake pin */ +#define EC_WAKE_PIN GPE0_DW1_12 + +/* eSPI virtual wire reporting */ +#define EC_SCI_GPI GPE0_ESPI + +/* Enable PS/2 keyboard */ +#define SIO_EC_ENABLE_PS2K + +/* Enable DPTF */ +#define EC_ENABLE_DPTF + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h new file mode 100644 index 0000000..f7e0403 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* Flash Write Protect */ +#define GPIO_PCH_WP GPP_E15 + +/* Recovery mode */ +#define GPIO_REC_MODE GPP_E8 + +const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_early_gpio_table(size_t *num); + +struct cros_gpio; +const struct cros_gpio *variant_cros_gpios(size_t *num); + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h new file mode 100644 index 0000000..10fbaf1 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h @@ -0,0 +1,209 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MAINBOARD_HDA_VERB_H +#define MAINBOARD_HDA_VERB_H + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0295, // Codec Vendor / Device ID: Realtek ALC3204 + 0xffffffff, // Subsystem ID + 0x0000002b, // Number of jacks (NID entries) + + /* Rest Codec First */ + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb Table */ + AZALIA_SUBVENDOR(0x0, 0x102808b6), + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0x0, 0x12, 0xb7a60130), + AZALIA_PIN_CFG(0x0, 0x13, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0x0, 0x16, 0x40000000), + AZALIA_PIN_CFG(0x0, 0x17, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x19, 0x04a11030), + AZALIA_PIN_CFG(0x0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1d, 0x40c00001), + AZALIA_PIN_CFG(0x0, 0x1e, 0x421212f2), + AZALIA_PIN_CFG(0x0, 0x21, 0x04211020), + + /* D reset */ + 0x0205003C, + 0x0204F254, + 0x0205003C, + 0x0204F214, + /* JD1 - 2port JD mode */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* Set TRS type-1 */ + 0x02050045, + 0x02045289, + 0x02050049, + 0x02040049, + /* Set TRS type-2 + Set UAJ Line2 vref(ALC3254) */ + 0x0205004A, + 0x0204A830, + 0x02050063, + 0x0204CF00, + /* NID 0x20 set class-D to 2W@4ohm (+12dB gain) + * + Set sine tone gain(0x34) */ + 0x02050038, + 0x02043909, + 0x05C50000, + 0x05C43482, + /* AGC-1 Disable + (Front Gain=0dB ) */ + 0x05D50006, + 0x05D44C50, + 0x05D50002, + 0x05D44004, + /* AGC-2 (Backt Boost Gain= -0.375dB ,Limiter = -3dB) */ + 0x05D50003, + 0x05D45E5E, + 0x05D50001, + 0x05D4D788, + /* AGC-3 + AGC Enable */ + 0x05D50009, + 0x05D451FF, + 0x05D50006, + 0x05D44E50, + /* HP-JD Enable +Nokia type */ + 0x0205004A, + 0x02042010, + 0x02050008, + 0x02046A0C, + /* EAPD set to verb-control + I2C Un-use+ DVDD3.3V */ + 0x02050010, + 0x02040020, + 0x02050034, + 0x0204A23D, + /* Class D silent detection Enable -84dB threshold */ + 0x02050030, + 0x02049000, + 0x02050037, + 0x0204FE15, + /* Disable EQ + set 250Hz 3rd High Pass filter */ + 0x05350000, + 0x0534203A, + 0x05350000, + 0x0534203A, + /* Left Channel-1 */ + 0x0535001d, + 0x05340800, + 0x0535001e, + 0x05340800, + /* Left Channel-2 */ + 0x05350003, + 0x05341EF8, + 0x05350004, + 0x05340000, + /* Left Channel-3 */ + 0x05350005, + 0x053403EE, + 0x05350006, + 0x0534FA60, + /* Left Channel-4 */ + 0x05350007, + 0x05341E10, + 0x05350008, + 0x05347B86, + /* Left Channel-5 */ + 0x05350009, + 0x053401F7, + 0x0535000A, + 0x05349FB6, + /* Left Channel-6 */ + 0x0535000B, + 0x05341C00, + 0x0535000C, + 0x05340000, + /* Left Channel-7 */ + 0x0535000D, + 0x05340200, + 0x0535000E, + 0x05340000, + /* Right Channel-1 */ + 0x05450000, + 0x05442000, + 0x0545001d, + 0x05440800, + /* Right Channel-2 */ + 0x0545001e, + 0x05440800, + 0x05450003, + 0x05441EF8, + /* Right Channel-3 */ + 0x05450004, + 0x05440000, + 0x05450005, + 0x054403EE, + /* Right Channel-4 */ + 0x05450006, + 0x0544FA60, + 0x05450007, + 0x05441E10, + /* Right Channel-5 */ + 0x05450008, + 0x05447B86, + 0x05450009, + 0x054401F7, + /* Right Channel-6 */ + 0x0545000A, + 0x05449FB6, + 0x0545000B, + 0x05441C00, + /* Right Channel-7 */ + 0x0545000C, + 0x05440000, + 0x0545000D, + 0x05440200, + /* Right Channel-8 + EQ Update & Enable */ + 0x0545000E, + 0x05440000, + 0x05350000, + 0x0534E03A, + /* Enable all Microphone */ + 0x0205000D, + 0x0204A023, + 0x0205000D, + 0x0204A023, + /* Enable Internal Speaker (NID14) */ + 0x0205000F, + 0x02040000, + 0x0205000F, + 0x02040000, +}; + +const u32 pc_beep_verbs[] = { + /* PCBeep pass through to NID14 for ePSA test-1 */ + 0x02050036, + 0x020477D7, + 0x0143B000, + 0x01470740, + /* PCBeep pass through to NID14 for ePSA test-2 */ + 0x01470C02, + 0x01470C02, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES; + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h new file mode 100644 index 0000000..da1189e --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_H +#define VARIANT_H + +/* Arcada is SKU ID 2 and 4 */ +#define VARIANT_SKU_ID 2 +#define VARIANT_SKU_NAME "sku2" +#define VARIANT_SKU_ID_SIGNED_EC 4 +#define VARIANT_SKU_NAME_SIGNED_EC "sku4" + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc b/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc new file mode 100644 index 0000000..2bf028e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc @@ -0,0 +1,19 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2018 Google LLC +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +bootblock-y += gpio.c +ramstage-y += gpio.c +romstage-y += gpio.c +verstage-y += gpio.c diff --git a/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb b/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb new file mode 100644 index 0000000..d3aab62 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb @@ -0,0 +1,419 @@ +chip soc/intel/cannonlake + + # GPE configuration + # Note that GPE events called out in ASL code rely on this + # route. i.e. If this route changes then the affected GPE + # offset bits also need to be changed. + register "gpe0_dw0" = "PMC_GPP_A" + register "gpe0_dw1" = "PMC_GPP_C" + register "gpe0_dw2" = "PMC_GPP_D" + + # EC host command ranges + register "gen1_dec" = "0x00040931" # 0x930-0x937 + register "gen2_dec" = "0x00040941" # 0x940-0x947 + register "gen3_dec" = "0x000c0951" # 0x950-0x95f + + # FSP configuration + register "SaGv" = "SaGv_Enabled" + register "HeciEnabled" = "0" + register "SataSalpSupport" = "1" + register "SataMode" = "Sata_AHCI" + register "SataPortsEnable[0]" = "1" + register "SataPortsEnable[1]" = "1" + register "SataPortsEnable[2]" = "1" + register "SataPortsDevSlp[0]" = "1" + register "SataPortsDevSlp[1]" = "1" + register "SataPortsDevSlp[2]" = "1" + register "InternalGfx" = "1" + register "SkipExtGfxScan" = "1" + register "PchPmSlpS3MinAssert" = "3" # 50ms + register "PchPmSlpS4MinAssert" = "4" # 4s + register "PchPmSlpSusMinAssert" = "4" # 4s + register "PchPmSlpAMinAssert" = "4" # 2s + + register "speed_shift_enable" = "1" + register "s0ix_enable" = "1" + register "dptf_enable" = "1" + register "dmipwroptimize" = "1" + register "satapwroptimize" = "1" + register "AcousticNoiseMitigation" = "1" + register "SlowSlewRateForIa" = "2" + register "SlowSlewRateForGt" = "2" + register "SlowSlewRateForSa" = "2" + register "SlowSlewRateForFivr" = "2" + register "tdp_pl1_override" = "15" + register "tdp_pl2_override" = "51" + register "psys_pmax" = "136" + register "Device4Enable" = "1" + # Enable eDP device + register "DdiPortEdp" = "1" + # Enable HPD for DDI ports B/C + register "DdiPortBHpd" = "1" + register "DdiPortCHpd" = "1" + # Enable DDC for DDI port B + register "DdiPortBDdc" = "1" + + register "LanWakeFromDeepSx" = "0" + register "WolEnableOverride" = "0" + + # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 5A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 6A | 70A | 31A | 31A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #| DcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #+----------------+-------+-------+-------+-------+ + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(6), + .voltage_limit = 1520, + .ac_loadline = 1030, + .dc_loadline = 1030, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(70), + .voltage_limit = 1520, + .ac_loadline = 180, + .dc_loadline = 180, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + # Intel Common SoC Config + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Left Type-C Port + register "usb2_ports[1]" = "USB2_PORT_LONG(OC0)" # Right Type-A Port 1 + register "usb2_ports[2]" = "USB2_PORT_LONG(OC1)" # Left Type-A Port + register "usb2_ports[3]" = "USB2_PORT_LONG(OC2)" # Right Type-A Port 2 + register "usb2_ports[4]" = "USB2_PORT_EMPTY" + register "usb2_ports[5]" = "USB2_PORT_LONG(OC_SKIP)" # Camera + register "usb2_ports[6]" = "USB2_PORT_MID(OC_SKIP)" # WWAN + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # USH + register "usb2_ports[8]" = "USB2_PORT_MID(OC_SKIP)" # Fingerprint + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Left Type-C Port + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # Right Type-A Port 1 + register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC1)" # Left Type-A Port + register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC2)" # Right Type-A Port 2 + register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC_SKIP)" # WWAN + register "usb3_ports[5]" = "USB3_PORT_EMPTY" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| chipset_lockdown | CHIPSET_LOCKDOWN_COREBOOT | + #| I2C0 | Touchscreen | + #| I2C1 | Touchpad | + #| I2C4 | H1 TPM | + #+-------------------+---------------------------+ + + register "tcc_offset" = "10" + + # PCH Thermal Trip Temperature in deg C + register "common_soc_config.pch_thermal_trip" = "77" + + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 100, + .fall_time_ns = 80, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 80, + .fall_time_ns = 110, + }, + .i2c[4] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + .rise_time_ns = 36, + .fall_time_ns = 99, + }, + }" + + # PCIe port 8 for Card Reader + register "PcieRpEnable[7]" = "1" + register "PcieRpLtrEnable[7]" = "1" + register "PcieClkSrcUsage[4]" = "7" + register "PcieClkSrcClkReq[4]" = "4" + + # PCIe port 9 for LAN + register "PcieRpEnable[8]" = "1" + register "PcieClkSrcUsage[3]" = "PCIE_CLK_LAN" + register "PcieClkSrcClkReq[3]" = "3" + + # PCIe port 10 for M.2 2230 WLAN + register "PcieRpEnable[9]" = "1" + register "PcieClkSrcUsage[1]" = "9" + register "PcieClkSrcClkReq[1]" = "1" + + # PCIe port 13 for M.2 2280 SSD + register "PcieRpEnable[12]" = "1" + register "PcieRpLtrEnable[12]" = "1" + register "PcieClkSrcUsage[2]" = "12" + register "PcieClkSrcClkReq[2]" = "2" + + # GPIO PM programming + register "gpio_override_pm" = "1" + + # GPIO community PM configuration + register "gpio_pm[COMM_0]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_1]" = "MISCCFG_GPSIDEDPCGEN | MISCCFG_GPRTCDLCGEN | MISCCFG_GSXSLCGEN | MISCCFG_GPDPCGEN | MISCCFG_GPDLCGEN" + register "gpio_pm[COMM_2]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_3]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_4]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + + device cpu_cluster 0 on + device lapic 0 on end + end + device domain 0 on + device pci 00.0 on end # Host Bridge + device pci 02.0 on end # Integrated Graphics Device + device pci 04.0 on end # SA Thermal device + device pci 12.0 on end # Thermal Subsystem + device pci 12.5 off end # UFS SCS + device pci 12.6 off end # GSPI #2 + device pci 13.0 off end # Integrated Sensor Hub + device pci 14.0 on + chip drivers/usb/acpi + register "desc" = ""Root Hub"" + register "type" = "UPC_TYPE_HUB" + device usb 0.0 on + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 2.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 1"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 2.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 2.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 2"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device usb 2.4 on end + end + chip drivers/usb/acpi + register "desc" = ""Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.5 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.6 on end + end + chip drivers/usb/acpi + register "desc" = ""USH"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.7 on end + end + chip drivers/usb/acpi + register "desc" = ""Fingerprint"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.8 on end + end + chip drivers/usb/acpi + register "desc" = ""Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H15)" + device usb 2.9 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 3.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 1"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 3.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 3.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 2"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device usb 3.3 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 3.4 on end + end + end + end + end # USB xHCI + device pci 14.1 off end # USB xDCI (OTG) + chip drivers/intel/wifi + register "wake" = "PME_B0_EN_BIT" + device pci 14.3 on end # CNVi wifi + end + device pci 14.5 off end # SDCard + device pci 15.0 on + chip drivers/i2c/hid + register "generic.hid" = ""ELAN900C"" + register "generic.desc" = ""ELAN Touchscreen"" + register "generic.irq" = "ACPI_IRQ_EDGE_LOW(GPP_C23_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "generic.reset_delay_ms" = "10" + register "generic.enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "generic.enable_delay_ms" = "55" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + register "generic.device_present_gpio" = "GPP_B4" + register "generic.device_present_gpio_invert" = "1" + device i2c 10 on end + end + chip drivers/i2c/generic + register "hid" = ""MLFS0000"" + register "desc" = ""Melfas Touchscreen"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_C23_IRQ)" + register "probed" = "1" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "reset_delay_ms" = "10" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "enable_delay_ms" = "55" + register "has_power_resource" = "1" + register "device_present_gpio" = "GPP_B4" + register "device_present_gpio_invert" = "1" + device i2c 34 on end + end + end # I2C #0 + device pci 15.1 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_B3_IRQ)" + register "probed" = "1" + device i2c 2c on end + end + end # I2C #1 + device pci 15.2 off end # I2C #2 + device pci 15.3 off end # I2C #3 + device pci 16.0 on end # Management Engine Interface 1 + device pci 16.1 off end # Management Engine Interface 2 + device pci 16.2 off end # Management Engine IDE-R + device pci 16.3 off end # Management Engine KT Redirection + device pci 16.4 off end # Management Engine Interface 3 + device pci 16.5 off end # Management Engine Interface 4 + device pci 17.0 on end # SATA + device pci 19.0 on + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D18_IRQ)" + device i2c 50 on end + end + end # I2C #4 + device pci 19.1 off end # I2C #5 + device pci 19.2 on end # UART #2 + device pci 1a.0 off end # eMMC + device pci 1c.0 on end # PCI Express Port 1 (USB) + device pci 1c.1 off end # PCI Express Port 2 (USB) + device pci 1c.2 off end # PCI Express Port 3 (USB) + device pci 1c.3 off end # PCI Express Port 4 (USB) + device pci 1c.4 off end # PCI Express Port 5 (USB) + device pci 1c.5 off end # PCI Express Port 6 + device pci 1c.6 off end # PCI Express Port 7 + device pci 1c.7 on end # PCI Express Port 8 + device pci 1d.0 on + smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "2230" "SlotDataBusWidth1X" + end # PCI Express Port 9 + device pci 1d.1 on end # PCI Express Port 10 + device pci 1d.2 off end # PCI Express Port 11 + device pci 1d.3 off end # PCI Express Port 12 + device pci 1d.4 on + smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "2280" "SlotDataBusWidth4X" + end # PCI Express Port 13 (x4) + device pci 1e.0 off end # UART #0 + device pci 1e.1 off end # UART #1 + device pci 1e.2 off end # GSPI #0 + device pci 1e.3 off end # GSPI #1 + device pci 1f.0 on + chip ec/google/wilco + device pnp 0c09.0 on end + end + end # LPC/eSPI + device pci 1f.1 on end # P2SB + device pci 1f.2 on end # Power Management Controller + device pci 1f.3 on end # Intel HDA + device pci 1f.4 on end # SMBus + device pci 1f.5 on end # PCH SPI + device pci 1f.6 on end # GbE + end +end diff --git a/src/mainboard/google/drallion/variants/sarien_cml/gpio.c b/src/mainboard/google/drallion/variants/sarien_cml/gpio.c new file mode 100644 index 0000000..78db12e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/gpio.c @@ -0,0 +1,267 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#include <variant/gpio.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* Pad configuration in ramstage */ +static const struct pad_config gpio_table[] = { +/* RCIN# */ PAD_NC(GPP_A0, NONE), +/* ESPI_IO0 */ +/* ESPI_IO1 */ +/* ESPI_IO2 */ +/* ESPI_IO3 */ +/* ESPI_CS# */ +/* SERIRQ */ +/* PIRQA# */ PAD_NC(GPP_A7, NONE), +/* CLKRUN# */ PAD_NC(GPP_A8, NONE), +/* ESPI_CLK */ +/* CLKOUT_LPC1 */ PAD_NC(GPP_A10, NONE), +/* PME# */ PAD_NC(GPP_A11, NONE), +/* BM_BUSY# */ PAD_NC(GPP_A12, NONE), + +/* ESPI_RESET# */ + +/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), +/* SD_PWR_EN# */ PAD_NC(GPP_A17, NONE), +/* ISH_GP0 */ PAD_NC(GPP_A18, NONE), +/* ISH_GP1 */ PAD_NC(GPP_A19, NONE), +/* ISH_GP2 */ PAD_NC(GPP_A20, NONE), +/* ISH_GP3 */ PAD_NC(GPP_A21, NONE), +/* ISH_GP4 */ PAD_NC(GPP_A22, NONE), +/* ISH_GP5 */ PAD_NC(GPP_A23, NONE), + +/* CORE_VID0 */ +/* CORE_VID1 */ +/* VRALERT# */ PAD_NC(GPP_B2, NONE), +/* CPU_GP2 */ PAD_CFG_GPI_APIC(GPP_B3, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TOUCHPAD_INTR# */ +/* CPU_GP3 */ PAD_CFG_GPI(GPP_B4, NONE, DEEP), /* TOUCH_SCREEN_DET# */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), /* CLKREQ_PCIE#0 */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), /* CLKREQ_PCIE#1 */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), /* CLKREQ_PCIE#2 */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), /* CLKREQ_PCIE#3 */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), /* CLKREQ_PCIE#4 */ +/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), +/* EXT_PWR_GATE# */ PAD_CFG_GPO(GPP_B11, 0, DEEP), /* 3.3V_CAM_EN# */ +/* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), +/* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), +/* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), +/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), +/* GSPI0_CLK */ PAD_NC(GPP_B16, NONE), +/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), +/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), +/* GSPI1_CS# */ PAD_NC(GPP_B19, NONE), /* HDD_FALL_INT (nostuff) */ +/* GSPI1_CLK */ PAD_NC(GPP_B20, NONE), /* TPM_PIRQ# (nostuff) */ +/* GSPI1_MISO */ PAD_CFG_GPO(GPP_B21, 1, DEEP), /* PCH_3.3V_TS_EN */ +/* GSPI1_MOSI */ PAD_NC(GPP_B22, NONE), +/* SML1ALERT# */ PAD_NC(GPP_B23, DN_20K), + +/* SMBCLK */ PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), /* MEM_SMBCLK */ +/* SMBDATA */ PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), /* MEM_SMBDATA */ +/* SMBALERT# */ PAD_NC(GPP_C2, DN_20K), +/* SML0CLK */ PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), /* SML0_SMBCLK */ +/* SML0DATA */ PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), /* SML0_SMBDATA */ +/* SML0ALERT# */ PAD_NC(GPP_C5, DN_20K), +/* SM1CLK */ PAD_CFG_NF(GPP_C6, NONE, DEEP, NF1), /* SML1_SMBCLK */ +/* SM1DATA */ PAD_CFG_NF(GPP_C7, NONE, DEEP, NF1), /* SML1_SMBDATA */ +/* UART0_RXD */ PAD_NC(GPP_C8, NONE), +/* UART0_TXD */ PAD_NC(GPP_C9, NONE), +/* UART0_RTS# */ PAD_CFG_GPI(GPP_C10, NONE, DEEP), /* TYPEC_CON_SEL1 */ +/* UART0_CTS# */ PAD_CFG_GPI(GPP_C11, NONE, DEEP), /* TYPEC_CON_SEL2 */ +/* UART1_RXD */ PAD_CFG_GPI_SCI_LOW(GPP_C12, NONE, DEEP, + EDGE_SINGLE), /* SIO_EXT_WAKE# */ +/* UART1_TXD */ PAD_NC(GPP_C13, NONE), +/* UART1_RTS# */ PAD_CFG_GPI(GPP_C14, NONE, DEEP), /* LCD_CBL_DET# */ +/* UART1_CTS# */ PAD_NC(GPP_C15, NONE), +/* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* TS_I2C_SDA */ +/* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* TS_I2C_SCL */ +/* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* I2C1_SDA_TP */ +/* I2C1_SCL */ PAD_CFG_NF(GPP_C19, NONE, DEEP, NF1), /* I2C1_SCK_TP */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), +/* UART2_CTS# */ PAD_CFG_GPI_APIC(GPP_C23, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TS_INT# */ + +/* SPI1_CS# */ PAD_CFG_GPI_APIC(GPP_D0, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* MEDIACARD_IRQ# */ +/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), +/* SPI1_MISO */ PAD_NC(GPP_D2, NONE), +/* SPI1_MOSI */ PAD_CFG_GPI(GPP_D3, NONE, DEEP), /* RTC_DET# */ +/* FASHTRIG */ PAD_NC(GPP_D4, NONE), +/* ISH_I2C0_SDA */ PAD_NC(GPP_D5, NONE), +/* ISH_I2C0_SCL */ PAD_NC(GPP_D6, NONE), +/* ISH_I2C1_SDA */ PAD_NC(GPP_D7, NONE), +/* ISH_I2C1_SCL */ PAD_NC(GPP_D8, NONE), +/* ISH_SPI_CS# */ PAD_CFG_GPI(GPP_D9, NONE, DEEP), /* IR_CAM_DET# */ +/* ISH_SPI_CLK */ PAD_NC(GPP_D10, NONE), +/* ISH_SPI_MISO */ PAD_CFG_GPI(GPP_D11, NONE, DEEP), /* TBT_DET# */ +/* ISH_SPI_MOSI */ PAD_NC(GPP_D12, NONE), +/* ISH_UART0_RXD */ PAD_NC(GPP_D13, NONE), +/* ISH_UART0_TXD */ PAD_NC(GPP_D14, NONE), +/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 1, DEEP), /* WWAN_FULL_PWR_EN */ +/* ISH_UART0_CTS# */ PAD_NC(GPP_D16, NONE), +/* DMIC_CLK1 */ PAD_CFG_GPI(GPP_D17, NONE, DEEP), /* KB_DET# */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* DMIC_CLK0 */ PAD_NC(GPP_D19, NONE), +/* DMIC_DATA0 */ PAD_NC(GPP_D20, NONE), +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 1, DEEP), /* WWAN_BB_RST# */ +/* SPI1_IO3 */ PAD_CFG_GPO(GPP_D22, 0, DEEP), /* WWAN_GPIO_PERST# */ +/* I2S_MCLK */ PAD_CFG_GPI_SCI_LOW(GPP_D23, NONE, DEEP, + EDGE_SINGLE), /* WWAN_GPIO_WAKE# */ + +/* SATAXPCIE0 */ PAD_CFG_NF(GPP_E0, NONE, DEEP, NF1), /* HDD_DET# */ + /* M3042_PCIE#_SATA */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), + /* M2880_PCIE_SATA# */ +/* SATAXPCIE2 */ PAD_CFG_NF(GPP_E2, NONE, DEEP, NF1), +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATA_DEVSLP0 */ PAD_CFG_NF(GPP_E4, NONE, DEEP, NF1), /* HDD_DEVSLP */ +/* SATA_DEVSLP1 */ PAD_CFG_NF(GPP_E5, NONE, DEEP, NF1), /* M3042_DEVSLP */ +/* SATA_DEVSLP2 */ PAD_CFG_NF(GPP_E6, NONE, DEEP, NF1), /* M2280_DEVSLP */ +/* CPU_GP1 */ PAD_CFG_GPO(GPP_E7, 1, DEEP), /* TOUCH_SCREEN_PD# */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* USB2_OCO# */ PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), /* USB_OC0# */ +/* USB2_OC1# */ PAD_CFG_NF(GPP_E10, NONE, DEEP, NF1), /* USB_OC1# */ +/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, NF1), /* USB_OC2# */ +/* USB2_OC3# */ PAD_NC(GPP_E12, NONE), +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* HDMI_DP1_HPD */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* CPU_DP2_HPD */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* H1_FLASH_WP */ +/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), /* FFS_INT2 (nostuff) */ +/* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), +/* DDPB_CTRLCLK */ PAD_CFG_NF(GPP_E18, NONE, DEEP, NF1), +/* DDPB_CTRLDATA */ PAD_CFG_NF(GPP_E19, NONE, DEEP, NF1), +/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), +/* DDPC_CTRLDATA */ PAD_NC(GPP_E21, NONE), +/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), +/* DDPD_CTRLDATA */ PAD_NC(GPP_E23, NONE), + +/* CNV_PA_BLANKING */ PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), /* CNV_COEX3 */ +/* GPP_F1 */ PAD_NC(GPP_F1, NONE), /* T406 */ +/* GPP_F2 */ PAD_NC(GPP_F2, NONE), /* T407 */ +/* GPP_F3 */ PAD_NC(GPP_F3, NONE), +/* CNV_BRI_DT */ PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), +/* CNV_BRI_RSP */ PAD_CFG_NF(GPP_F5, NONE, DEEP, NF1), +/* CNV_RGI_DT */ PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), +/* CNV_RGI_RSP */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), +/* CNV_MFUART2_RXD */ PAD_CFG_NF(GPP_F8, NONE, DEEP, NF1), /* CNV_COEX2 */ +/* CNV_MFUART2_TXD */ PAD_CFG_NF(GPP_F9, NONE, DEEP, NF1), /* CNV_COEX1 */ +/* GPP_F10 */ PAD_NC(GPP_F10, NONE), +/* EMMC_CMD */ PAD_NC(GPP_F11, NONE), +/* EMMC_DATA0 */ PAD_NC(GPP_F12, NONE), +/* EMMC_DATA1 */ PAD_NC(GPP_F13, NONE), +/* EMMC_DATA2 */ PAD_NC(GPP_F14, NONE), +/* EMMC_DATA3 */ PAD_NC(GPP_F15, NONE), +/* EMMC_DATA4 */ PAD_NC(GPP_F16, NONE), +/* EMMC_DATA5 */ PAD_NC(GPP_F17, NONE), +/* EMMC_DATA6 */ PAD_NC(GPP_F18, NONE), +/* EMMC_DATA7 */ PAD_NC(GPP_F19, NONE), +/* EMMC_RCLK */ PAD_NC(GPP_F20, NONE), +/* EMMC_CLK */ PAD_NC(GPP_F21, NONE), +/* EMMC_RESET# */ PAD_NC(GPP_F22, NONE), +/* A4WP_PRESENT */ PAD_NC(GPP_F23, NONE), + +/* SD_CMD */ PAD_CFG_GPI(GPP_G0, NONE, DEEP), /* CAM_MIC_CBL_DET# */ +/* SD_DATA0 */ PAD_NC(GPP_G1, NONE), +/* SD_DATA1 */ PAD_NC(GPP_G2, NONE), +/* SD_DATA2 */ PAD_NC(GPP_G3, NONE), /* T383 */ +/* SD_DATA3 */ PAD_CFG_GPI(GPP_G4, NONE, DEEP), /* CTLESS_DET# */ +/* SD_CD# */ PAD_CFG_GPO(GPP_G5, 1, DEEP), /* HOST_SD_WP# */ +/* SD_CLK */ PAD_CFG_GPO(GPP_G6, 1, DEEP), /* AUD_PWR_EN */ +/* SD_WP */ PAD_NC(GPP_G7, NONE), /* T384 */ + +/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), +/* I2S2_SFRM */ PAD_CFG_NF(GPP_H1, NONE, DEEP, NF3), /* CNV_RF_RESET# */ +/* I2S2_TXD */ PAD_CFG_NF(GPP_H2, NONE, DEEP, NF3), /* CLKREQ_CNV# */ +/* I2S2_RXD */ PAD_CFG_GPO(GPP_H3, 0, DEEP), /* CNVI_EN# */ +/* I2C2_SDA */ PAD_NC(GPP_H4, NONE), /* T388 */ +/* I2C2_SCL */ PAD_NC(GPP_H5, NONE), /* T389 */ +/* I2C3_SDA */ PAD_NC(GPP_H6, NONE), /* T378 */ +/* I2C3_SCL */ PAD_NC(GPP_H7, NONE), /* T379 */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* I2C5_SDA */ PAD_NC(GPP_H10, NONE), +/* I2C5_SCL */ PAD_NC(GPP_H11, NONE), +/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), +/* M2_SKT2_CFG3 */ PAD_CFG_GPO(GPP_H15, 1, DEEP), /* BT_RADIO_DIS# */ +/* DDPF_CTRLCLK */ PAD_NC(GPP_H16, NONE), +/* DPPF_CTRLDATA */ PAD_NC(GPP_H17, NONE), +/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), /* C10_GATE# */ +/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), +/* IMGCLKOUT1 */ PAD_NC(GPP_H20, NONE), +/* GPP_H21 */ PAD_NC(GPP_H21, NONE), +/* GPP_H22 */ PAD_NC(GPP_H22, NONE), +/* GPP_H23 */ PAD_NC(GPP_H23, NONE), + +/* BATLOW# */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* BATLOW# */ +/* ACPRESENT */ PAD_CFG_NF(GPD1, NONE, DEEP, NF1), /* AC_PRESENT */ +/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* LAN_WAKE# */ +/* SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* SIO_SLP_S3# */ +/* SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* SIO_SLP_S4# */ +/* SLP_A# */ PAD_CFG_NF(GPD6, NONE, DEEP, NF1), /* SIO_SLP_A# */ +/* GPD7 */ PAD_NC(GPD7, NONE), +/* SUSCLK */ PAD_CFG_NF(GPD8, NONE, DEEP, NF1), /* SUSCLK */ +/* SLP_WLAN# */ PAD_CFG_NF(GPD9, NONE, DEEP, NF1), /* SIO_SLP_WLAN# */ +/* SLP_S5# */ PAD_CFG_NF(GPD10, NONE, DEEP, NF1), /* SIO_SLP_S5# */ +/* LANPHYC */ PAD_CFG_NF(GPD11, NONE, DEEP, NF1), /* PM_LANPHY_EN */ +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { +/* M2_SKT2_CFG1 */ PAD_CFG_GPO(GPP_H13, 1, DEEP), /* M.2 SSD D3 cold */ +/* SUSWARN# */ PAD_CFG_GPO(GPP_A13, 0, DEEP), /* Card reader D3 cold */ +/* SUSACK# */ PAD_CFG_GPO(GPP_A15, 0, DEEP), /* Card reader D3 cold */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* SSD RESET pin will stay low first */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 0, DEEP), /* D3 cold RST */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* RESET# need to stay low before FULL_CARD_POWER_OFF assert */ +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 0, DEEP), /* WWAN_BB_RST# */ +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* H1_FLASH_WP */ +/* PWRBTN# */ PAD_CFG_NF(GPD3, UP_20K, DEEP, NF1), /* SIO_PWRBTN# */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 1, DEEP), /* D3 cold RST */ +}; + +const struct pad_config *variant_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(gpio_table); + return gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} + +static const struct cros_gpio cros_gpios[] = { + CROS_GPIO_REC_AL(GPP_E8, CROS_GPIO_DEVICE_NAME), + CROS_GPIO_WP_AH(GPP_E15, CROS_GPIO_DEVICE_NAME), +}; + +const struct cros_gpio *variant_cros_gpios(size_t *num) +{ + *num = ARRAY_SIZE(cros_gpios); + return cros_gpios; +} diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl new file mode 100644 index 0000000..0cdbcd1 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl @@ -0,0 +1,73 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define DPTF_CPU_PASSIVE 99 +#define DPTF_CPU_CRITICAL 105 + +/* Skin Sensor for CPU VR temperature monitor */ +#define DPTF_TSR0_SENSOR_ID 1 +#define DPTF_TSR0_SENSOR_NAME "Skin" +#define DPTF_TSR0_PASSIVE 71 +#define DPTF_TSR0_CRITICAL 100 + +/* Memory Sensor for DDR temperature monitor */ +#define DPTF_TSR1_SENSOR_ID 2 +#define DPTF_TSR1_SENSOR_NAME "DDR" +#define DPTF_TSR1_PASSIVE 55 +#define DPTF_TSR1_CRITICAL 100 + +/* M.2 Sensor for Ambient temperature monitor */ +#define DPTF_TSR2_SENSOR_ID 3 +#define DPTF_TSR2_SENSOR_NAME "Ambient" +#define DPTF_TSR2_PASSIVE 90 +#define DPTF_TSR2_CRITICAL 100 + +#undef DPTF_ENABLE_FAN_CONTROL +#undef DPTF_ENABLE_CHARGER + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Skin (TSR0) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on DDR (TSR1) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Ambient (TSR2) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR2, 250, 10, 0, 0, 0, 0 }, +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 5000, /* PowerLimitMinimum */ + 15000, /* PowerLimitMaximum */ + 10000, /* TimeWindowMinimum */ + 10000, /* TimeWindowMaximum */ + 100 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 5000, /* PowerLimitMinimum */ + 51000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + } +}) diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl new file mode 100644 index 0000000..41121d2 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2019 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define CAM_EN GPP_B11 /* Active low */ +#define TS_PD GPP_E7 + +/* Method called from LPIT prior to enter s0ix state */ +Method (MS0X, 1) +{ + If (Arg0) { + /* Turn off camera power */ + _SB.PCI0.STXS (CAM_EN) + } Else { + /* Turn on camera power */ + _SB.PCI0.CTXS (CAM_EN) + } +} + +/* Method called from _PTS prior to enter sleep state */ +Method (MPTS, 1) +{ + _SB.PCI0.LPCB.EC0.PTS (Arg0) + + /* Clear touch screen pd pin to avoid leakage */ + _SB.PCI0.CTXS (TS_PD) +} + +/* Method called from _WAK prior to wakeup */ +Method (MWAK, 1) +{ + _SB.PCI0.LPCB.EC0.WAK (Arg0) +} diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h new file mode 100644 index 0000000..01a17b5 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_EC_H +#define VARIANT_EC_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* EC wake pin */ +#define EC_WAKE_PIN GPE0_DW1_12 + +/* eSPI virtual wire reporting */ +#define EC_SCI_GPI GPE0_ESPI + +/* Enable PS/2 keyboard */ +#define SIO_EC_ENABLE_PS2K + +/* Enable DPTF */ +#define EC_ENABLE_DPTF + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h new file mode 100644 index 0000000..f7e0403 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* Flash Write Protect */ +#define GPIO_PCH_WP GPP_E15 + +/* Recovery mode */ +#define GPIO_REC_MODE GPP_E8 + +const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_early_gpio_table(size_t *num); + +struct cros_gpio; +const struct cros_gpio *variant_cros_gpios(size_t *num); + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h new file mode 100644 index 0000000..6eb6d14 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h @@ -0,0 +1,152 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MAINBOARD_HDA_VERB_H +#define MAINBOARD_HDA_VERB_H + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0236, // Codec Vendor / Device ID: Realtek ALC3204 + 0xffffffff, // Subsystem ID + 0x0000001e, // Number of jacks (NID entries) + + /* Rest Codec First */ + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb Table */ + AZALIA_SUBVENDOR(0x0, 0x102808b8), + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0x0, 0x12, 0x90a60140), + AZALIA_PIN_CFG(0x0, 0x13, 0x40000000), + AZALIA_PIN_CFG(0x0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0x0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x19, 0x04a11030), + AZALIA_PIN_CFG(0x0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1d, 0x40700001), + AZALIA_PIN_CFG(0x0, 0x1e, 0x421212f2), + AZALIA_PIN_CFG(0x0, 0x21, 0x04211020), + + /* ALC3204 default-1 */ + 0x02050040, + 0x02049800, + 0x02050034, + 0x0204023C, + /* ALC3204 default-2 */ + 0x0205003C, + 0x02040354, + 0x0205003C, + 0x02040314, + /* ALC3204 Speaker output power - 4 ohm 2W (+12dB gain) + * + Combo Jack TRS setting */ + 0x02050038, + 0x02043901, + 0x02050045, + 0x02045089, + /* H/W AGC setting-1 */ + 0x02050016, + 0x02040C50, + 0x02050012, + 0x0204EBC2, + /* H/W AGC setting-2 */ + 0x02050013, + 0x0204401D, + 0x02050016, + 0x02044E50, + /* Zero data + EAPD to verb-control */ + 0x02050037, + 0x0204FE15, + 0x02050010, + 0x02040020, + /* Zero data */ + 0x02050030, + 0x02048000, + 0x02050030, + 0x02048000, + /* ALC3204 default-3 */ + 0x05750003, + 0x05740DA3, + 0x02050046, + 0x02040004, + /* ALC3204 default-4 */ + 0x0205001B, + 0x02040A4B, + 0x02050008, + 0x02046A6C, + /* JD1 */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* Microphone + Array MIC security Disable +ADC clock Enable */ + 0x0205000D, + 0x0204A020, + 0x02050005, + 0x02040700, + /* Speaker Enable */ + 0x0205000C, + 0x020401EF, + 0x0205000C, + 0x020401EF, + /* EQ Bypass + EQ HPF cutoff 250Hz */ + 0x05350000, + 0x0534201A, + 0x0535001d, + 0x05340800, + /* EQ-2 */ + 0x0535001e, + 0x05340800, + 0x05350003, + 0x05341EF8, + /* EQ-3 */ + 0x05350004, + 0x05340000, + 0x05450000, + 0x05442000, + /* EQ-4 */ + 0x0545001d, + 0x05440800, + 0x0545001e, + 0x05440800, + /* EQ-5 */ + 0x05450003, + 0x05441EF8, + 0x05450004, + 0x05440000, + /* EQ Update */ + 0x05350000, + 0x0534E01A, + 0x05350000, + 0x0534E01A, +}; + +const u32 pc_beep_verbs[] = { +/* PCBeep pass through to NID14 for ePSA test-1 */ + 0x02050036, + 0x02047717, + 0x02050036, + 0x02047717, +/* PCBeep pass through to NID14 for ePSA test-2 */ + 0x01470740, + 0x0143B000, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES; + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h new file mode 100644 index 0000000..bbb3e9e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_H +#define VARIANT_H + +/* Sarien is SKU ID 1 and 3 */ +#define VARIANT_SKU_ID 1 +#define VARIANT_SKU_NAME "sku1" +#define VARIANT_SKU_ID_SIGNED_EC 3 +#define VARIANT_SKU_NAME_SIGNED_EC "sku3" + +#endif
Mathew King has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34887 )
Change subject: Moffet: Add two variants - arcada_cml & sarien_cml ......................................................................
Patch Set 1:
Will you also update the Kconfing and Kconfig.name with these variants?
Mathew King has uploaded a new patch set (#2) to the change originally created by Thejaswani Putta. ( https://review.coreboot.org/c/coreboot/+/34887 )
These variants are to support the sarien and arcada boards with CML SOC, the drallion variant will be used to support the upcoming drallion board.
Signed-off-by: Thejaswani Putta thejaswani.putta@intel.com Change-Id: I766bdccb6f8b6924d6ae1abbe57035f4ff1f6f17 --- A src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc A src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb A src/mainboard/google/drallion/variants/arcada_cml/gpio.c A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h A src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc A src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb A src/mainboard/google/drallion/variants/sarien_cml/gpio.c A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h 18 files changed, 2,176 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/2
Mathew King has uploaded a new patch set (#3) to the change originally created by Thejaswani Putta. ( https://review.coreboot.org/c/coreboot/+/34887 )
Change subject: drallion: Add two variants - arcada_cml & sarien_cml ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/3
Hello Pratikkumar V Prajapati, Varun Joshi, Bernardo Perez Priego, Mathew King, Selma Bensaid, Bora Guvendik, build bot (Jenkins), Krzysztof M Sywula, Chiranjeevi Rapolu, Patrick Georgi, Martin Roth,
These variants are to support the EV sarien and arcada boards with CML SOC, the drallion variant will be used to support the upcoming EVT drallion board.
Signed-off-by: Thejaswani Putta thejaswani.putta@intel.com Change-Id: I766bdccb6f8b6924d6ae1abbe57035f4ff1f6f17 --- M src/mainboard/google/drallion/Kconfig M src/mainboard/google/drallion/Kconfig.name A src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc A src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb A src/mainboard/google/drallion/variants/arcada_cml/gpio.c A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h A src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc A src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb A src/mainboard/google/drallion/variants/sarien_cml/gpio.c A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h 20 files changed, 2,193 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/4
Thejaswani Putta has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34887 )
Patch Set 4:
Patch Set 1:
Yes, Done.
Patch Set 4:
(2 comments)
https://review.coreboot.org/c/coreboot/+/34887/4/src/mainboard/google/dralli... File src/mainboard/google/drallion/Kconfig.name:
https://review.coreboot.org/c/coreboot/+/34887/4/src/mainboard/google/dralli... PS4, Line 5: BOARD_GOOGLE_BASEBOARD_ARCADA_CML Just BOARD_GOOGLE_BASEBOARD_DRALLION
https://review.coreboot.org/c/coreboot/+/34887/4/src/mainboard/google/dralli... PS4, Line 9: BOARD_GOOGLE_BASEBOARD_SARIEN_CML same
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/5
Patch Set 5:
(2 comments)
Done
same
Done
Bernardo Perez Priego has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34887 )
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/34887/5/src/mainboard/google/dralli... File src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb:
https://review.coreboot.org/c/coreboot/+/34887/5/src/mainboard/google/dralli... PS5, Line 230: arcada_ish.bin Should this be called drallion_ish.bin?
Martin Roth has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34887 )
Patch Set 5:
(3 comments)
Can any of the files just include the baseboard versions to cut down on the amount of duplicated code?
https://review.coreboot.org/c/coreboot/+/34887/5//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/34887/5//COMMIT_MSG@7 PS5, Line 7: Moffet: What does "moffet" mean? Should this be "mb/google/drallion: Add arcada_cml & sarien_cml variants"?
https://review.coreboot.org/c/coreboot/+/34887/5//COMMIT_MSG@9 PS5, Line 9: EV What is EV?
https://review.coreboot.org/c/coreboot/+/34887/5//COMMIT_MSG@11 PS5, Line 11: EVT Please, don't *EVER* mention the phase of a project. This is confidential, along the lines of the OEM name, the name of the finished board, the OEM codename, the release date, etc. Chrome Unboxed definitely reads the commit messages, so please don't leak any information you don't need to. Please pass this along to everyone else as well.
Hello Pratikkumar V Prajapati, Varun Joshi, Bernardo Perez Priego, Mathew King, Selma Bensaid, Bora Guvendik, build bot (Jenkins), Krzysztof M Sywula, Martin Roth, Chiranjeevi Rapolu, Patrick Georgi,
Change subject: mb/google/drallion: Add two variants - arcada_cml & sarien_cml ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/6
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/34887/7
Patch Set 7:
(4 comments)
Thanks, Done!
What is EV?
Ack, Will make sure not to use such words. Thanks, modified
Please, don't *EVER* mention the phase of a project. […]
Yes, will never repeat it. Thanks for correcting, Done.
Should this be called drallion_ish. […]
Done
Patch Set 7: Code-Review+2
Verified on a Sarien/CML.
Patch Set 7:
(2 comments)
Thanks, Done!
Done
Done
Martin Roth has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/34887 )
Signed-off-by: Thejaswani Putta thejaswani.putta@intel.com Change-Id: I766bdccb6f8b6924d6ae1abbe57035f4ff1f6f17 Reviewed-on: https://review.coreboot.org/c/coreboot/+/34887 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Mathew King mathewk@chromium.org --- M src/mainboard/google/drallion/Kconfig M src/mainboard/google/drallion/Kconfig.name A src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc A src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb A src/mainboard/google/drallion/variants/arcada_cml/gpio.c A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h A src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc A src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb A src/mainboard/google/drallion/variants/sarien_cml/gpio.c A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl A src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h A src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h 20 files changed, 2,193 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Mathew King: Looks good to me, approved
diff --git a/src/mainboard/google/drallion/Kconfig b/src/mainboard/google/drallion/Kconfig index deeca15..cff56a4 100644 --- a/src/mainboard/google/drallion/Kconfig +++ b/src/mainboard/google/drallion/Kconfig @@ -72,11 +72,15 @@
config MAINBOARD_FAMILY string - default "Google_Drallion" + default "Google_Arcada_cml" if BOARD_GOOGLE_ARCADA_CML + default "Google_Sarien_cml" if BOARD_GOOGLE_SARIEN_CML + default "Google_Drallion" if BOARD_GOOGLE_DRALLION
config MAINBOARD_PART_NUMBER string - default "Drallion" + default "Arcada_cml" if BOARD_GOOGLE_ARCADA_CML + default "Sarien_cml" if BOARD_GOOGLE_SARIEN_CML + default "Drallion" if BOARD_GOOGLE_DRALLION
config MAINBOARD_VENDOR string @@ -92,7 +96,9 @@
config VARIANT_DIR string - default "drallion" + default "arcada_cml" if BOARD_GOOGLE_ARCADA_CML + default "sarien_cml" if BOARD_GOOGLE_SARIEN_CML + default "drallion" if BOARD_GOOGLE_DRALLION
config DEVICETREE string diff --git a/src/mainboard/google/drallion/Kconfig.name b/src/mainboard/google/drallion/Kconfig.name index bd5d903..e67b915 100644 --- a/src/mainboard/google/drallion/Kconfig.name +++ b/src/mainboard/google/drallion/Kconfig.name @@ -1,5 +1,13 @@ comment "Drallion"
+config BOARD_GOOGLE_ARCADA_CML + bool "-> Arcada_cml" + select BOARD_GOOGLE_BASEBOARD_DRALLION + +config BOARD_GOOGLE_SARIEN_CML + bool "-> Sarien_cml" + select BOARD_GOOGLE_BASEBOARD_DRALLION + config BOARD_GOOGLE_DRALLION bool "-> Drallion" select BOARD_GOOGLE_BASEBOARD_DRALLION diff --git a/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc b/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc new file mode 100644 index 0000000..2bf028e --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/Makefile.inc @@ -0,0 +1,19 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2018 Google LLC +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +bootblock-y += gpio.c +ramstage-y += gpio.c +romstage-y += gpio.c +verstage-y += gpio.c diff --git a/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb b/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb new file mode 100644 index 0000000..fe3b6c9 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/devicetree.cb @@ -0,0 +1,392 @@ +chip soc/intel/cannonlake + + # GPE configuration + # Note that GPE events called out in ASL code rely on this + # route. i.e. If this route changes then the affected GPE + # offset bits also need to be changed. + register "gpe0_dw0" = "PMC_GPP_A" + register "gpe0_dw1" = "PMC_GPP_C" + register "gpe0_dw2" = "PMC_GPP_D" + + # EC host command ranges + register "gen1_dec" = "0x00040931" # 0x930-0x937 + register "gen2_dec" = "0x00040941" # 0x940-0x947 + register "gen3_dec" = "0x000c0951" # 0x950-0x95f + + # FSP configuration + register "SaGv" = "SaGv_Enabled" + register "HeciEnabled" = "0" + register "SataSalpSupport" = "1" + register "SataMode" = "Sata_AHCI" + register "SataPortsEnable[2]" = "1" + register "SataPortsDevSlp[2]" = "1" + register "InternalGfx" = "1" + register "SkipExtGfxScan" = "1" + register "PchPmSlpS3MinAssert" = "3" # 50ms + register "PchPmSlpS4MinAssert" = "4" # 4s + register "PchPmSlpSusMinAssert" = "4" # 4s + register "PchPmSlpAMinAssert" = "4" # 2s + register "PchUnlockGpioPads" = "1" + + register "speed_shift_enable" = "1" + register "psys_pmax" = "140" + register "s0ix_enable" = "1" + register "dptf_enable" = "1" + register "dmipwroptimize" = "1" + register "satapwroptimize" = "1" + register "tdp_pl1_override" = "25" + register "tdp_pl2_override" = "51" + register "Device4Enable" = "1" + register "AcousticNoiseMitigation" = "1" + register "SlowSlewRateForIa" = "2" + register "SlowSlewRateForGt" = "2" + register "SlowSlewRateForSa" = "0" + register "SlowSlewRateForFivr" = "2" + # Enable eDP device + register "DdiPortEdp" = "1" + # Enable HPD for DDI ports B/C + register "DdiPortBHpd" = "1" + register "DdiPortCHpd" = "1" + # Enable DDC for DDI port B + register "DdiPortBDdc" = "1" + + # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 5A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 6A | 70A | 31A | 31A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #| DcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #+----------------+-------+-------+-------+-------+ + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(6), + .voltage_limit = 1520, + .ac_loadline = 1030, + .dc_loadline = 1030, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(70), + .voltage_limit = 1520, + .ac_loadline = 180, + .dc_loadline = 180, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + # Intel Common SoC Config + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Left Type-C Port + register "usb2_ports[1]" = "USB2_PORT_LONG(OC0)" # Left Type-A Port + register "usb2_ports[2]" = "USB2_PORT_LONG(OC1)" # Right Type-A Port + register "usb2_ports[3]" = "USB2_PORT_EMPTY" + register "usb2_ports[4]" = "USB2_PORT_EMPTY" + register "usb2_ports[5]" = "USB2_PORT_LONG(OC_SKIP)" # Camera + register "usb2_ports[6]" = "{ + .enable = 1, \ + .ocpin = OC_SKIP, \ + .tx_bias = USB2_BIAS_0MV, \ + .tx_emp_enable = USB2_DE_EMP_ON_PRE_EMP_ON, \ + .pre_emp_bias = USB2_BIAS_28P15MV, \ + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, \ + }" # WWAN + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # USH + register "usb2_ports[8]" = "USB2_PORT_MID(OC_SKIP)" # Fingerprint + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Left Type-C Port + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # Left Type-A Port + register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC1)" # Right Type-A Port + register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC_SKIP)" # WWAN + register "usb3_ports[4]" = "USB3_PORT_EMPTY" + register "usb3_ports[5]" = "USB3_PORT_EMPTY" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| chipset_lockdown | CHIPSET_LOCKDOWN_COREBOOT | + #| I2C0 | Touchscreen | + #| I2C1 | Touchpad | + #| I2C4 | H1 TPM | + #+-------------------+---------------------------+ + + register "tcc_offset" = "1" + + # PCH Thermal Trip Temperature in deg C + register "common_soc_config.pch_thermal_trip" = "77" + + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 52, + .fall_time_ns = 110, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 52, + .fall_time_ns = 110, + .data_hold_time_ns = 330, + }, + .i2c[4] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + .rise_time_ns = 36, + .fall_time_ns = 99, + }, + }" + + # PCIe port 10 for M.2 2230 WLAN + register "PcieRpEnable[9]" = "1" + register "PcieClkSrcUsage[2]" = "9" + register "PcieClkSrcClkReq[2]" = "2" + + # PCIe port 11 for card reader + register "PcieRpEnable[10]" = "1" + register "PcieRpLtrEnable[10]" = "1" + register "PcieClkSrcUsage[1]" = "10" + register "PcieClkSrcClkReq[1]" = "1" + + # PCIe port 13 for M.2 2280 SSD + register "PcieRpEnable[12]" = "1" + register "PcieRpLtrEnable[12]" = "1" + register "PcieClkSrcUsage[4]" = "12" + register "PcieClkSrcClkReq[4]" = "4" + + # GPIO PM programming + register "gpio_override_pm" = "1" + + # GPIO community PM configuration + register "gpio_pm[COMM_0]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_1]" = "MISCCFG_GPSIDEDPCGEN | MISCCFG_GPRTCDLCGEN | MISCCFG_GSXSLCGEN | MISCCFG_GPDPCGEN | MISCCFG_GPDLCGEN" + register "gpio_pm[COMM_2]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_3]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_4]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + + device cpu_cluster 0 on + device lapic 0 on end + end + device domain 0 on + device pci 00.0 on end # Host Bridge + device pci 02.0 on end # Integrated Graphics Device + device pci 04.0 on end # SA Thermal device + device pci 12.0 on end # Thermal Subsystem + device pci 12.5 off end # UFS SCS + device pci 12.6 off end # GSPI #2 + device pci 13.0 on # Integrated Sensor Hub + chip drivers/intel/ish + register "firmware_name" = ""drallion_ish.bin"" + device generic 0 on end + end + end + device pci 14.0 on + chip drivers/usb/acpi + register "desc" = ""Root Hub"" + register "type" = "UPC_TYPE_HUB" + device usb 0.0 on + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 2.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 2.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 2.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.5 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.6 on end + end + chip drivers/usb/acpi + register "desc" = ""USH"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.7 on end + end + chip drivers/usb/acpi + register "desc" = ""Fingerprint"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.8 on end + end + chip drivers/usb/acpi + register "desc" = ""Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H15)" + device usb 2.9 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 3.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 3.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 3.2 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 3.3 on end + end + end + end + end # USB xHCI + device pci 14.1 off end # USB xDCI (OTG) + chip drivers/intel/wifi + register "wake" = "PME_B0_EN_BIT" + device pci 14.3 on end # CNVi wifi + end + device pci 14.5 off end # SDCard + device pci 15.0 on + chip drivers/i2c/hid + register "generic.hid" = ""WCOM48E2"" + register "generic.desc" = ""Wacom Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C23_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "generic.reset_delay_ms" = "120" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "generic.enable_delay_ms" = "55" + register "generic.has_power_resource" = "1" + register "generic.disable_gpio_export_in_crs" = "1" + register "hid_desc_reg_offset" = "0x1" + device i2c 0A on end + end + end # I2C #0 + device pci 15.1 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_B3_IRQ)" + register "probed" = "1" + device i2c 2c on end + end + end # I2C #1 + device pci 15.2 off end # I2C #2 + device pci 15.3 off end # I2C #3 + device pci 16.0 on end # Management Engine Interface 1 + device pci 16.1 off end # Management Engine Interface 2 + device pci 16.2 off end # Management Engine IDE-R + device pci 16.3 off end # Management Engine KT Redirection + device pci 16.4 off end # Management Engine Interface 3 + device pci 16.5 off end # Management Engine Interface 4 + device pci 17.0 on end # SATA + device pci 19.0 on + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D18_IRQ)" + device i2c 50 on end + end + end # I2C #4 + device pci 19.1 off end # I2C #5 + device pci 19.2 on end # UART #2 + device pci 1a.0 off end # eMMC + device pci 1c.0 off end # PCI Express Port 1 (USB) + device pci 1c.1 off end # PCI Express Port 2 (USB) + device pci 1c.2 off end # PCI Express Port 3 (USB) + device pci 1c.3 off end # PCI Express Port 4 (USB) + device pci 1c.4 off end # PCI Express Port 5 (USB) + device pci 1c.5 off end # PCI Express Port 6 + device pci 1c.6 off end # PCI Express Port 7 + device pci 1c.7 off end # PCI Express Port 8 + device pci 1d.0 on + smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "2230" "SlotDataBusWidth1X" + end # PCI Express Port 9 + device pci 1d.1 on end # PCI Express Port 10 + device pci 1d.2 on end # PCI Express Port 11 + device pci 1d.3 off end # PCI Express Port 12 + device pci 1d.4 on + smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "2280" "SlotDataBusWidth4X" + end # PCI Express Port 13 (x4) + device pci 1e.0 off end # UART #0 + device pci 1e.1 off end # UART #1 + device pci 1e.2 off end # GSPI #0 + device pci 1e.3 off end # GSPI #1 + device pci 1f.0 on + chip ec/google/wilco + device pnp 0c09.0 on end + end + end # LPC/eSPI + device pci 1f.1 on end # P2SB + device pci 1f.2 on end # Power Management Controller + device pci 1f.3 on end # Intel HDA + device pci 1f.4 on end # SMBus + device pci 1f.5 on end # PCH SPI + device pci 1f.6 off end # GbE + end +end diff --git a/src/mainboard/google/drallion/variants/arcada_cml/gpio.c b/src/mainboard/google/drallion/variants/arcada_cml/gpio.c new file mode 100644 index 0000000..ff0240c --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/gpio.c @@ -0,0 +1,279 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#include <variant/gpio.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* Pad configuration in ramstage */ +static const struct pad_config gpio_table[] = { +/* RCIN# */ PAD_NC(GPP_A0, NONE), +/* ESPI_IO0 */ +/* ESPI_IO1 */ +/* ESPI_IO2 */ +/* ESPI_IO3 */ +/* ESPI_CS# */ +/* SERIRQ */ +/* PIRQA# */ PAD_NC(GPP_A7, NONE), +/* CLKRUN# */ PAD_NC(GPP_A8, NONE), +/* ESPI_CLK */ +/* CLKOUT_LPC1 */ PAD_NC(GPP_A10, NONE), +/* PME# */ PAD_NC(GPP_A11, NONE), + /* ISH_LID_CL#_TAB */ +/* ISH_GP6 */ PAD_CFG_NF(GPP_A12, NONE, DEEP, NF2), +/* SUSWARN# */ PAD_NC(GPP_A13, NONE), +/* ESPI_RESET# */ +/* SUSACK# */ PAD_NC(GPP_A15, NONE), +/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), +/* SD_PWR_EN# */ PAD_NC(GPP_A17, NONE), + /* ISH_ACC1_INT# */ +/* ISH_GP0 */ PAD_CFG_NF(GPP_A18, NONE, DEEP, NF1), + /* ISH_ACC2_INT# */ +/* ISH_GP1 */ PAD_CFG_NF(GPP_A19, NONE, DEEP, NF1), +/* ISH_GP2 */ PAD_NC(GPP_A20, NONE), +/* ISH_GP3 */ PAD_NC(GPP_A21, NONE), + /* ISH_NB_MODE */ +/* ISH_GP4 */ PAD_CFG_NF(GPP_A22, NONE, DEEP, NF1), + /* ISH_LID_CL#_NB */ +/* ISH_GP5 */ PAD_CFG_NF(GPP_A23, NONE, DEEP, NF1), + +/* CORE_VID0 */ +/* CORE_VID1 */ +/* VRALERT# */ PAD_NC(GPP_B2, NONE), +/* CPU_GP2 */ PAD_CFG_GPI_APIC(GPP_B3, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TOUCHPAD_INTR# */ +/* CPU_GP3 */ PAD_CFG_GPI(GPP_B4, NONE, DEEP), /* TOUCH_SCREEN_DET# */ + /* LAN_CLKREQ_CPU_N */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), + /* CARD_CLKREQ_CPU_N */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), + /* WLAN_CLKREQ_CPU_N */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), + /* WWAN_CLKREQ_CPU_N */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), + /* SSD_CKLREQ_CPU_N */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), +/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), /* TBT_CLKREQ_CPU_N (nostuff) */ +/* EXT_PWR_GATE# */ PAD_CFG_GPO(GPP_B11, 0, DEEP), /* 3.3V_CAM_EN# */ +/* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), +/* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), +/* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), +/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), /* PRIM_CORE_OPT_DIS (nostuff) */ +/* GSPI0_CLK */ PAD_CFG_GPI(GPP_B16, NONE, DEEP), /* ONE_DIMM# */ +/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), /* RTC_DET# */ +/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), +/* GSPI1_CS# */ PAD_NC(GPP_B19, NONE), /* HDD_FALL_INT (nostuff) */ +/* GSPI1_CLK */ PAD_NC(GPP_B20, NONE), /* TPM_PIRQ# (nostuff) */ +/* GSPI1_MISO */ PAD_CFG_GPO(GPP_B21, 1, DEEP), /* PCH_3.3V_TS_EN */ +/* GSPI1_MOSI */ PAD_NC(GPP_B22, NONE), +/* SML1ALERT# */ PAD_NC(GPP_B23, DN_20K), + +/* SMBCLK */ PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), /* MEM_SMBCLK */ +/* SMBDATA */ PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), /* MEM_SMBDATA */ +/* SMBALERT# */ PAD_NC(GPP_C2, DN_20K), +/* SML0CLK */ PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), /* SML0_SMBCLK */ +/* SML0DATA */ PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), /* SML0_SMBDATA */ +/* SML0ALERT# */ PAD_NC(GPP_C5, DN_20K), +/* SM1CLK */ PAD_CFG_NF(GPP_C6, NONE, DEEP, NF1), /* SML1_SMBCLK */ +/* SM1DATA */ PAD_CFG_NF(GPP_C7, NONE, DEEP, NF1), /* SML1_SMBDATA */ +/* UART0_RXD */ PAD_NC(GPP_C8, NONE), /* PCH_TBT_PERST# (nostuff) */ +/* UART0_TXD */ PAD_NC(GPP_C9, NONE), +/* UART0_RTS# */ PAD_CFG_GPI(GPP_C10, NONE, DEEP), /* TYPEC_CON_SEL1 */ +/* UART0_CTS# */ PAD_CFG_GPI(GPP_C11, NONE, DEEP), /* TYPEC_CON_SEL2 */ +/* UART1_RXD */ PAD_CFG_GPI_SCI_LOW(GPP_C12, NONE, DEEP, + EDGE_SINGLE), /* SIO_EXT_WAKE# */ +/* UART1_TXD */ PAD_NC(GPP_C13, NONE), +/* UART1_RTS# */ PAD_CFG_GPI(GPP_C14, NONE, DEEP), /* LCD_CBL_DET# */ +/* UART1_CTS# */ PAD_NC(GPP_C15, NONE), +/* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* TS_I2C_SDA */ +/* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* TS_I2C_SCL */ +/* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* I2C1_SDA_TP */ +/* I2C1_SCL */ PAD_CFG_NF(GPP_C19, NONE, DEEP, NF1), /* I2C1_SCK_TP */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), +/* UART2_CTS# */ PAD_CFG_GPI_APIC(GPP_C23, NONE, PLTRST, + LEVEL, NONE), /* TS_INT# */ + +/* SPI1_CS# */ PAD_CFG_GPI_APIC(GPP_D0, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* MEDIACARD_IRQ# */ +/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), +/* SPI1_MISO */ PAD_CFG_GPI(GPP_D2, NONE, DEEP), /* ISH_LAN# */ +/* SPI1_MOSI */ PAD_NC(GPP_D3, NONE), +/* FASHTRIG */ PAD_NC(GPP_D4, NONE), /* TBT_FORCE_PWR (nostuff) */ + /* ISH_I2C0_ACC_SDA */ +/* ISH_I2C0_SDA */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), + /* ISH_I2C0_ACC_SCL */ +/* ISH_I2C0_SCL */ PAD_CFG_NF(GPP_D6, NONE, DEEP, NF1), +/* ISH_I2C1_SDA */ PAD_NC(GPP_D7, NONE), +/* ISH_I2C1_SCL */ PAD_NC(GPP_D8, NONE), +/* ISH_SPI_CS# */ PAD_CFG_GPI(GPP_D9, NONE, DEEP), /* IR_CAM_DET# */ +/* ISH_SPI_CLK */ PAD_NC(GPP_D10, NONE), +/* ISH_SPI_MISO */ PAD_CFG_GPI(GPP_D11, NONE, DEEP), /* TBT_DET# */ +/* ISH_SPI_MOSI */ PAD_NC(GPP_D12, NONE), + /* ISH_CPU_UART0_RX */ +/* ISH_UART0_RXD */ PAD_CFG_NF(GPP_D13, UP_20K, DEEP, NF1), + /* ISH_CPU_UART0_TX */ +/* ISH_UART0_TXD */ PAD_CFG_NF(GPP_D14, NONE, DEEP, NF1), +/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 1, DEEP), /* WWAN_FULL_PWR_EN */ +/* ISH_UART0_CTS# */ PAD_NC(GPP_D16, NONE), +/* DMIC_CLK1 */ PAD_CFG_GPI(GPP_D17, NONE, DEEP), /* KB_DET# */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* DMIC_CLK0 */ PAD_NC(GPP_D19, NONE), +/* DMIC_DATA0 */ PAD_NC(GPP_D20, NONE), +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 1, DEEP), /* WWAN_BB_RST# */ +/* SPI1_IO3 */ PAD_CFG_GPO(GPP_D22, 0, DEEP), /* WWAN_GPIO_PERST# */ +/* I2S_MCLK */ PAD_CFG_GPI_SCI_LOW(GPP_D23, NONE, DEEP, + EDGE_SINGLE), /* WWAN_GPIO_WAKE# */ + +/* SATAXPCIE0 */ PAD_NC(GPP_E0, NONE), + /* M3042_PCIE#_SATA */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), + /* M2880_PCIE_SATA# */ +/* SATAXPCIE2 */ PAD_CFG_NF(GPP_E2, NONE, DEEP, NF1), +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATA_DEVSLP0 */ PAD_NC(GPP_E4, NONE), +/* SATA_DEVSLP1 */ PAD_CFG_NF(GPP_E5, NONE, DEEP, NF1), /* M3042_DEVSLP */ +/* SATA_DEVSLP2 */ PAD_CFG_NF(GPP_E6, NONE, DEEP, NF1), /* M2280_DEVSLP */ +/* CPU_GP1 */ PAD_CFG_GPO(GPP_E7, 1, DEEP), /* TOUCH_SCREEN_PD# */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* USB2_OCO# */ PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), /* USB_OC0# */ +/* USB2_OC1# */ PAD_CFG_NF(GPP_E10, NONE, DEEP, NF1), /* USB_OC1# */ +/* USB2_OC2# */ PAD_NC(GPP_E11, NONE), +/* USB2_OC3# */ PAD_NC(GPP_E12, NONE), +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* DP_HPD_CPU */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* DP2_HPD_CPU */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* PCH_WP */ +/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), /* FFS_INT2 (nostuff) */ +/* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), +/* DDPB_CTRLCLK */ PAD_CFG_NF(GPP_E18, NONE, DEEP, NF1), /* HDMI_SCL_CPU */ +/* DDPB_CTRLDATA */ PAD_CFG_NF(GPP_E19, NONE, DEEP, NF1), /* HDMI_SDA_CPU */ +/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), +/* DDPC_CTRLDATA */ PAD_NC(GPP_E21, NONE), +/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), +/* DDPD_CTRLDATA */ PAD_NC(GPP_E23, NONE), + +/* CNV_PA_BLANKING */ PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), /* CNV_COEX3 */ +/* GPP_F1 */ PAD_NC(GPP_F1, NONE), +/* GPP_F2 */ PAD_NC(GPP_F2, NONE), +/* GPP_F3 */ PAD_NC(GPP_F3, NONE), +/* CNV_BRI_DT */ PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), +/* CNV_BRI_RSP */ PAD_CFG_NF(GPP_F5, NONE, DEEP, NF1), +/* CNV_RGI_DT */ PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), +/* CNV_RGI_RSP */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), +/* CNV_MFUART2_RXD */ PAD_CFG_NF(GPP_F8, NONE, DEEP, NF1), /* CNV_COEX2 */ +/* CNV_MFUART2_TXD */ PAD_CFG_NF(GPP_F9, NONE, DEEP, NF1), /* CNV_COEX1 */ +/* GPP_F10 */ PAD_NC(GPP_F10, NONE), +/* EMMC_CMD */ PAD_NC(GPP_F11, NONE), +/* EMMC_DATA0 */ PAD_NC(GPP_F12, NONE), +/* EMMC_DATA1 */ PAD_NC(GPP_F13, NONE), +/* EMMC_DATA2 */ PAD_NC(GPP_F14, NONE), +/* EMMC_DATA3 */ PAD_NC(GPP_F15, NONE), +/* EMMC_DATA4 */ PAD_NC(GPP_F16, NONE), +/* EMMC_DATA5 */ PAD_NC(GPP_F17, NONE), +/* EMMC_DATA6 */ PAD_NC(GPP_F18, NONE), +/* EMMC_DATA7 */ PAD_NC(GPP_F19, NONE), +/* EMMC_RCLK */ PAD_NC(GPP_F20, NONE), +/* EMMC_CLK */ PAD_NC(GPP_F21, NONE), +/* EMMC_RESET# */ PAD_NC(GPP_F22, NONE), +/* A4WP_PRESENT */ PAD_NC(GPP_F23, NONE), + +/* SD_CMD */ PAD_CFG_GPI(GPP_G0, NONE, DEEP), /* CAM_MIC_CBL_DET# */ +/* SD_DATA0 */ PAD_NC(GPP_G1, NONE), /* ANT_CONFIG (nostuff) */ +/* SD_DATA1 */ PAD_NC(GPP_G2, NONE), /* TBT_CIO_PLUG_EVT# (nostuff) */ +/* SD_DATA2 */ PAD_NC(GPP_G3, NONE), +/* SD_DATA3 */ PAD_CFG_GPI(GPP_G4, NONE, DEEP), /* CTLESS_DET# */ +/* SD_CD# */ PAD_CFG_GPO(GPP_G5, 1, DEEP), /* HOST_SD_WP# */ +/* SD_CLK */ PAD_CFG_GPO(GPP_G6, 1, DEEP), /* AUD_PWR_EN */ +/* SD_WP */ PAD_CFG_GPI(GPP_G7, NONE, DEEP), /* SPK_DET# */ + +/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), +/* I2S2_SFRM */ PAD_CFG_NF(GPP_H1, NONE, DEEP, NF3), /* CNV_RF_RESET# */ +/* I2S2_TXD */ PAD_CFG_NF(GPP_H2, NONE, DEEP, NF3), /* CLKREQ_CNV# */ +/* I2S2_RXD */ PAD_NC(GPP_H3, NONE), +/* I2C2_SDA */ PAD_NC(GPP_H4, NONE), +/* I2C2_SCL */ PAD_NC(GPP_H5, NONE), +/* I2C3_SDA */ PAD_NC(GPP_H6, NONE), +/* I2C3_SCL */ PAD_NC(GPP_H7, NONE), +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* I2C5_SDA */ PAD_NC(GPP_H10, NONE), /* ISH_I2C2_SDA */ +/* I2C5_SCL */ PAD_NC(GPP_H11, NONE), /* ISH_I2C2_SCL */ +/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), +/* M2_SKT2_CFG3 */ PAD_CFG_GPO(GPP_H15, 1, DEEP), /* BT_RADIO_DIS# */ +/* DDPF_CTRLCLK */ PAD_NC(GPP_H16, NONE), +/* DPPF_CTRLDATA */ PAD_NC(GPP_H17, NONE), +/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), /* C10_GATE# */ +/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), +/* IMGCLKOUT1 */ PAD_NC(GPP_H20, NONE), +/* GPP_H21 */ PAD_NC(GPP_H21, NONE), +/* GPP_H22 */ PAD_NC(GPP_H22, NONE), /* RTD3_CIO_PWR_EN (nostuff) */ +/* GPP_H23 */ PAD_NC(GPP_H23, NONE), + +/* BATLOW# */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* BATLOW# */ +/* ACPRESENT */ PAD_CFG_NF(GPD1, NONE, DEEP, NF1), /* AC_PRESENT */ +/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* LAN_WAKE# */ +/* PWRBTN# */ PAD_CFG_NF(GPD3, NONE, DEEP, NF1), /* SIO_PWRBTN# */ +/* SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* SIO_SLP_S3# */ +/* SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* SIO_SLP_S4# */ +/* SLP_A# */ PAD_CFG_NF(GPD6, NONE, DEEP, NF1), /* SIO_SLP_A# */ +/* GPD7 */ PAD_NC(GPD7, NONE), /* TBT_RTD3_WAKE# (nostuff) */ +/* SUSCLK */ PAD_CFG_NF(GPD8, NONE, DEEP, NF1), /* SUSCLK */ +/* SLP_WLAN# */ PAD_CFG_NF(GPD9, NONE, DEEP, NF1), /* SIO_SLP_WLAN# */ +/* SLP_S5# */ PAD_CFG_NF(GPD10, NONE, DEEP, NF1), /* SIO_SLP_S5# */ +/* LANPHYC */ PAD_CFG_NF(GPD11, NONE, DEEP, NF1), /* PM_LANPHY_EN */ +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { +/* M2_SKT2_CFG1 */ PAD_CFG_GPO(GPP_H13, 1, DEEP), /* M.2 SSD D3 cold */ +/* SSD RESET pin will stay low first */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 0, DEEP), /* D3 cold RST */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* RESET# need to stay low before FULL_CARD_POWER_OFF assert */ +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 0, DEEP), /* WWAN_BB_RST# */ +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* PCH_WP */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 1, DEEP), /* D3 cold RST */ +}; + +const struct pad_config *variant_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(gpio_table); + return gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} + +static const struct cros_gpio cros_gpios[] = { + CROS_GPIO_REC_AL(GPP_E8, CROS_GPIO_DEVICE_NAME), + CROS_GPIO_WP_AH(GPP_E15, CROS_GPIO_DEVICE_NAME), +}; + +const struct cros_gpio *variant_cros_gpios(size_t *num) +{ + *num = ARRAY_SIZE(cros_gpios); + return cros_gpios; +} diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl new file mode 100644 index 0000000..73e1dec --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/dptf.asl @@ -0,0 +1,73 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define DPTF_CPU_PASSIVE 98 +#define DPTF_CPU_CRITICAL 108 + +/* Skin Sensor for CPU VR temperature monitor */ +#define DPTF_TSR0_SENSOR_ID 1 +#define DPTF_TSR0_SENSOR_NAME "Skin" +#define DPTF_TSR0_PASSIVE 55 +#define DPTF_TSR0_CRITICAL 100 + +/* Memory Sensor for DDR temperature monitor */ +#define DPTF_TSR1_SENSOR_ID 2 +#define DPTF_TSR1_SENSOR_NAME "DDR" +#define DPTF_TSR1_PASSIVE 53 +#define DPTF_TSR1_CRITICAL 100 + +/* M.2 Sensor for Ambient temperature monitor */ +#define DPTF_TSR2_SENSOR_ID 3 +#define DPTF_TSR2_SENSOR_NAME "Ambient" +#define DPTF_TSR2_PASSIVE 38 +#define DPTF_TSR2_CRITICAL 93 + +#undef DPTF_ENABLE_FAN_CONTROL +#undef DPTF_ENABLE_CHARGER + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 500, 100, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Skin (TSR0) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 400, 40, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on DDR (TSR1) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 300, 50, 2, 0, 0, 0 }, + + /* CPU Throttle Effect on Ambient (TSR2) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR2, 1000, 100, 1, 0, 0, 0 }, +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 3000, /* PowerLimitMinimum */ + 21000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 15000, /* PowerLimitMinimum */ + 51000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + } +}) diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl new file mode 100644 index 0000000..41121d2 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/acpi/mainboard.asl @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2019 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define CAM_EN GPP_B11 /* Active low */ +#define TS_PD GPP_E7 + +/* Method called from LPIT prior to enter s0ix state */ +Method (MS0X, 1) +{ + If (Arg0) { + /* Turn off camera power */ + _SB.PCI0.STXS (CAM_EN) + } Else { + /* Turn on camera power */ + _SB.PCI0.CTXS (CAM_EN) + } +} + +/* Method called from _PTS prior to enter sleep state */ +Method (MPTS, 1) +{ + _SB.PCI0.LPCB.EC0.PTS (Arg0) + + /* Clear touch screen pd pin to avoid leakage */ + _SB.PCI0.CTXS (TS_PD) +} + +/* Method called from _WAK prior to wakeup */ +Method (MWAK, 1) +{ + _SB.PCI0.LPCB.EC0.WAK (Arg0) +} diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h new file mode 100644 index 0000000..01a17b5 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/ec.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_EC_H +#define VARIANT_EC_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* EC wake pin */ +#define EC_WAKE_PIN GPE0_DW1_12 + +/* eSPI virtual wire reporting */ +#define EC_SCI_GPI GPE0_ESPI + +/* Enable PS/2 keyboard */ +#define SIO_EC_ENABLE_PS2K + +/* Enable DPTF */ +#define EC_ENABLE_DPTF + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h new file mode 100644 index 0000000..f7e0403 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/gpio.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* Flash Write Protect */ +#define GPIO_PCH_WP GPP_E15 + +/* Recovery mode */ +#define GPIO_REC_MODE GPP_E8 + +const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_early_gpio_table(size_t *num); + +struct cros_gpio; +const struct cros_gpio *variant_cros_gpios(size_t *num); + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h new file mode 100644 index 0000000..10fbaf1 --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/hda_verb.h @@ -0,0 +1,209 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MAINBOARD_HDA_VERB_H +#define MAINBOARD_HDA_VERB_H + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0295, // Codec Vendor / Device ID: Realtek ALC3204 + 0xffffffff, // Subsystem ID + 0x0000002b, // Number of jacks (NID entries) + + /* Rest Codec First */ + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb Table */ + AZALIA_SUBVENDOR(0x0, 0x102808b6), + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0x0, 0x12, 0xb7a60130), + AZALIA_PIN_CFG(0x0, 0x13, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0x0, 0x16, 0x40000000), + AZALIA_PIN_CFG(0x0, 0x17, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x19, 0x04a11030), + AZALIA_PIN_CFG(0x0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1d, 0x40c00001), + AZALIA_PIN_CFG(0x0, 0x1e, 0x421212f2), + AZALIA_PIN_CFG(0x0, 0x21, 0x04211020), + + /* D reset */ + 0x0205003C, + 0x0204F254, + 0x0205003C, + 0x0204F214, + /* JD1 - 2port JD mode */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* Set TRS type-1 */ + 0x02050045, + 0x02045289, + 0x02050049, + 0x02040049, + /* Set TRS type-2 + Set UAJ Line2 vref(ALC3254) */ + 0x0205004A, + 0x0204A830, + 0x02050063, + 0x0204CF00, + /* NID 0x20 set class-D to 2W@4ohm (+12dB gain) + * + Set sine tone gain(0x34) */ + 0x02050038, + 0x02043909, + 0x05C50000, + 0x05C43482, + /* AGC-1 Disable + (Front Gain=0dB ) */ + 0x05D50006, + 0x05D44C50, + 0x05D50002, + 0x05D44004, + /* AGC-2 (Backt Boost Gain= -0.375dB ,Limiter = -3dB) */ + 0x05D50003, + 0x05D45E5E, + 0x05D50001, + 0x05D4D788, + /* AGC-3 + AGC Enable */ + 0x05D50009, + 0x05D451FF, + 0x05D50006, + 0x05D44E50, + /* HP-JD Enable +Nokia type */ + 0x0205004A, + 0x02042010, + 0x02050008, + 0x02046A0C, + /* EAPD set to verb-control + I2C Un-use+ DVDD3.3V */ + 0x02050010, + 0x02040020, + 0x02050034, + 0x0204A23D, + /* Class D silent detection Enable -84dB threshold */ + 0x02050030, + 0x02049000, + 0x02050037, + 0x0204FE15, + /* Disable EQ + set 250Hz 3rd High Pass filter */ + 0x05350000, + 0x0534203A, + 0x05350000, + 0x0534203A, + /* Left Channel-1 */ + 0x0535001d, + 0x05340800, + 0x0535001e, + 0x05340800, + /* Left Channel-2 */ + 0x05350003, + 0x05341EF8, + 0x05350004, + 0x05340000, + /* Left Channel-3 */ + 0x05350005, + 0x053403EE, + 0x05350006, + 0x0534FA60, + /* Left Channel-4 */ + 0x05350007, + 0x05341E10, + 0x05350008, + 0x05347B86, + /* Left Channel-5 */ + 0x05350009, + 0x053401F7, + 0x0535000A, + 0x05349FB6, + /* Left Channel-6 */ + 0x0535000B, + 0x05341C00, + 0x0535000C, + 0x05340000, + /* Left Channel-7 */ + 0x0535000D, + 0x05340200, + 0x0535000E, + 0x05340000, + /* Right Channel-1 */ + 0x05450000, + 0x05442000, + 0x0545001d, + 0x05440800, + /* Right Channel-2 */ + 0x0545001e, + 0x05440800, + 0x05450003, + 0x05441EF8, + /* Right Channel-3 */ + 0x05450004, + 0x05440000, + 0x05450005, + 0x054403EE, + /* Right Channel-4 */ + 0x05450006, + 0x0544FA60, + 0x05450007, + 0x05441E10, + /* Right Channel-5 */ + 0x05450008, + 0x05447B86, + 0x05450009, + 0x054401F7, + /* Right Channel-6 */ + 0x0545000A, + 0x05449FB6, + 0x0545000B, + 0x05441C00, + /* Right Channel-7 */ + 0x0545000C, + 0x05440000, + 0x0545000D, + 0x05440200, + /* Right Channel-8 + EQ Update & Enable */ + 0x0545000E, + 0x05440000, + 0x05350000, + 0x0534E03A, + /* Enable all Microphone */ + 0x0205000D, + 0x0204A023, + 0x0205000D, + 0x0204A023, + /* Enable Internal Speaker (NID14) */ + 0x0205000F, + 0x02040000, + 0x0205000F, + 0x02040000, +}; + +const u32 pc_beep_verbs[] = { + /* PCBeep pass through to NID14 for ePSA test-1 */ + 0x02050036, + 0x020477D7, + 0x0143B000, + 0x01470740, + /* PCBeep pass through to NID14 for ePSA test-2 */ + 0x01470C02, + 0x01470C02, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES; + +#endif diff --git a/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h new file mode 100644 index 0000000..da1189e --- /dev/null +++ b/src/mainboard/google/drallion/variants/arcada_cml/include/variant/variant.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_H +#define VARIANT_H + +/* Arcada is SKU ID 2 and 4 */ +#define VARIANT_SKU_ID 2 +#define VARIANT_SKU_NAME "sku2" +#define VARIANT_SKU_ID_SIGNED_EC 4 +#define VARIANT_SKU_NAME_SIGNED_EC "sku4" + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc b/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc new file mode 100644 index 0000000..2bf028e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/Makefile.inc @@ -0,0 +1,19 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2018 Google LLC +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +bootblock-y += gpio.c +ramstage-y += gpio.c +romstage-y += gpio.c +verstage-y += gpio.c diff --git a/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb b/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb new file mode 100644 index 0000000..d3aab62 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/devicetree.cb @@ -0,0 +1,419 @@ +chip soc/intel/cannonlake + + # GPE configuration + # Note that GPE events called out in ASL code rely on this + # route. i.e. If this route changes then the affected GPE + # offset bits also need to be changed. + register "gpe0_dw0" = "PMC_GPP_A" + register "gpe0_dw1" = "PMC_GPP_C" + register "gpe0_dw2" = "PMC_GPP_D" + + # EC host command ranges + register "gen1_dec" = "0x00040931" # 0x930-0x937 + register "gen2_dec" = "0x00040941" # 0x940-0x947 + register "gen3_dec" = "0x000c0951" # 0x950-0x95f + + # FSP configuration + register "SaGv" = "SaGv_Enabled" + register "HeciEnabled" = "0" + register "SataSalpSupport" = "1" + register "SataMode" = "Sata_AHCI" + register "SataPortsEnable[0]" = "1" + register "SataPortsEnable[1]" = "1" + register "SataPortsEnable[2]" = "1" + register "SataPortsDevSlp[0]" = "1" + register "SataPortsDevSlp[1]" = "1" + register "SataPortsDevSlp[2]" = "1" + register "InternalGfx" = "1" + register "SkipExtGfxScan" = "1" + register "PchPmSlpS3MinAssert" = "3" # 50ms + register "PchPmSlpS4MinAssert" = "4" # 4s + register "PchPmSlpSusMinAssert" = "4" # 4s + register "PchPmSlpAMinAssert" = "4" # 2s + + register "speed_shift_enable" = "1" + register "s0ix_enable" = "1" + register "dptf_enable" = "1" + register "dmipwroptimize" = "1" + register "satapwroptimize" = "1" + register "AcousticNoiseMitigation" = "1" + register "SlowSlewRateForIa" = "2" + register "SlowSlewRateForGt" = "2" + register "SlowSlewRateForSa" = "2" + register "SlowSlewRateForFivr" = "2" + register "tdp_pl1_override" = "15" + register "tdp_pl2_override" = "51" + register "psys_pmax" = "136" + register "Device4Enable" = "1" + # Enable eDP device + register "DdiPortEdp" = "1" + # Enable HPD for DDI ports B/C + register "DdiPortBHpd" = "1" + register "DdiPortCHpd" = "1" + # Enable DDC for DDI port B + register "DdiPortBDdc" = "1" + + register "LanWakeFromDeepSx" = "0" + register "WolEnableOverride" = "0" + + # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 5A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 6A | 70A | 31A | 31A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #| DcLoadline | 10.3 | 1.8 | 3.1 | 3.1 | + #+----------------+-------+-------+-------+-------+ + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(6), + .voltage_limit = 1520, + .ac_loadline = 1030, + .dc_loadline = 1030, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(70), + .voltage_limit = 1520, + .ac_loadline = 180, + .dc_loadline = 180, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(31), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + # Intel Common SoC Config + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Left Type-C Port + register "usb2_ports[1]" = "USB2_PORT_LONG(OC0)" # Right Type-A Port 1 + register "usb2_ports[2]" = "USB2_PORT_LONG(OC1)" # Left Type-A Port + register "usb2_ports[3]" = "USB2_PORT_LONG(OC2)" # Right Type-A Port 2 + register "usb2_ports[4]" = "USB2_PORT_EMPTY" + register "usb2_ports[5]" = "USB2_PORT_LONG(OC_SKIP)" # Camera + register "usb2_ports[6]" = "USB2_PORT_MID(OC_SKIP)" # WWAN + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # USH + register "usb2_ports[8]" = "USB2_PORT_MID(OC_SKIP)" # Fingerprint + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Left Type-C Port + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # Right Type-A Port 1 + register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC1)" # Left Type-A Port + register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC2)" # Right Type-A Port 2 + register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC_SKIP)" # WWAN + register "usb3_ports[5]" = "USB3_PORT_EMPTY" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| chipset_lockdown | CHIPSET_LOCKDOWN_COREBOOT | + #| I2C0 | Touchscreen | + #| I2C1 | Touchpad | + #| I2C4 | H1 TPM | + #+-------------------+---------------------------+ + + register "tcc_offset" = "10" + + # PCH Thermal Trip Temperature in deg C + register "common_soc_config.pch_thermal_trip" = "77" + + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 100, + .fall_time_ns = 80, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 80, + .fall_time_ns = 110, + }, + .i2c[4] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + .rise_time_ns = 36, + .fall_time_ns = 99, + }, + }" + + # PCIe port 8 for Card Reader + register "PcieRpEnable[7]" = "1" + register "PcieRpLtrEnable[7]" = "1" + register "PcieClkSrcUsage[4]" = "7" + register "PcieClkSrcClkReq[4]" = "4" + + # PCIe port 9 for LAN + register "PcieRpEnable[8]" = "1" + register "PcieClkSrcUsage[3]" = "PCIE_CLK_LAN" + register "PcieClkSrcClkReq[3]" = "3" + + # PCIe port 10 for M.2 2230 WLAN + register "PcieRpEnable[9]" = "1" + register "PcieClkSrcUsage[1]" = "9" + register "PcieClkSrcClkReq[1]" = "1" + + # PCIe port 13 for M.2 2280 SSD + register "PcieRpEnable[12]" = "1" + register "PcieRpLtrEnable[12]" = "1" + register "PcieClkSrcUsage[2]" = "12" + register "PcieClkSrcClkReq[2]" = "2" + + # GPIO PM programming + register "gpio_override_pm" = "1" + + # GPIO community PM configuration + register "gpio_pm[COMM_0]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_1]" = "MISCCFG_GPSIDEDPCGEN | MISCCFG_GPRTCDLCGEN | MISCCFG_GSXSLCGEN | MISCCFG_GPDPCGEN | MISCCFG_GPDLCGEN" + register "gpio_pm[COMM_2]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_3]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + register "gpio_pm[COMM_4]" = "MISCCFG_ENABLE_GPIO_PM_CONFIG" + + device cpu_cluster 0 on + device lapic 0 on end + end + device domain 0 on + device pci 00.0 on end # Host Bridge + device pci 02.0 on end # Integrated Graphics Device + device pci 04.0 on end # SA Thermal device + device pci 12.0 on end # Thermal Subsystem + device pci 12.5 off end # UFS SCS + device pci 12.6 off end # GSPI #2 + device pci 13.0 off end # Integrated Sensor Hub + device pci 14.0 on + chip drivers/usb/acpi + register "desc" = ""Root Hub"" + register "type" = "UPC_TYPE_HUB" + device usb 0.0 on + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 2.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 1"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 2.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 2.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 2"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device usb 2.4 on end + end + chip drivers/usb/acpi + register "desc" = ""Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.5 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.6 on end + end + chip drivers/usb/acpi + register "desc" = ""USH"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.7 on end + end + chip drivers/usb/acpi + register "desc" = ""Fingerprint"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 2.8 on end + end + chip drivers/usb/acpi + register "desc" = ""Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H15)" + device usb 2.9 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-C Port"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device usb 3.0 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 1"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device usb 3.1 on end + end + chip drivers/usb/acpi + register "desc" = ""Left Type-A Port"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device usb 3.2 on end + end + chip drivers/usb/acpi + register "desc" = ""Right Type-A Port 2"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device usb 3.3 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device usb 3.4 on end + end + end + end + end # USB xHCI + device pci 14.1 off end # USB xDCI (OTG) + chip drivers/intel/wifi + register "wake" = "PME_B0_EN_BIT" + device pci 14.3 on end # CNVi wifi + end + device pci 14.5 off end # SDCard + device pci 15.0 on + chip drivers/i2c/hid + register "generic.hid" = ""ELAN900C"" + register "generic.desc" = ""ELAN Touchscreen"" + register "generic.irq" = "ACPI_IRQ_EDGE_LOW(GPP_C23_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "generic.reset_delay_ms" = "10" + register "generic.enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "generic.enable_delay_ms" = "55" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + register "generic.device_present_gpio" = "GPP_B4" + register "generic.device_present_gpio_invert" = "1" + device i2c 10 on end + end + chip drivers/i2c/generic + register "hid" = ""MLFS0000"" + register "desc" = ""Melfas Touchscreen"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_C23_IRQ)" + register "probed" = "1" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E7)" + register "reset_delay_ms" = "10" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + register "enable_delay_ms" = "55" + register "has_power_resource" = "1" + register "device_present_gpio" = "GPP_B4" + register "device_present_gpio_invert" = "1" + device i2c 34 on end + end + end # I2C #0 + device pci 15.1 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_B3_IRQ)" + register "probed" = "1" + device i2c 2c on end + end + end # I2C #1 + device pci 15.2 off end # I2C #2 + device pci 15.3 off end # I2C #3 + device pci 16.0 on end # Management Engine Interface 1 + device pci 16.1 off end # Management Engine Interface 2 + device pci 16.2 off end # Management Engine IDE-R + device pci 16.3 off end # Management Engine KT Redirection + device pci 16.4 off end # Management Engine Interface 3 + device pci 16.5 off end # Management Engine Interface 4 + device pci 17.0 on end # SATA + device pci 19.0 on + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D18_IRQ)" + device i2c 50 on end + end + end # I2C #4 + device pci 19.1 off end # I2C #5 + device pci 19.2 on end # UART #2 + device pci 1a.0 off end # eMMC + device pci 1c.0 on end # PCI Express Port 1 (USB) + device pci 1c.1 off end # PCI Express Port 2 (USB) + device pci 1c.2 off end # PCI Express Port 3 (USB) + device pci 1c.3 off end # PCI Express Port 4 (USB) + device pci 1c.4 off end # PCI Express Port 5 (USB) + device pci 1c.5 off end # PCI Express Port 6 + device pci 1c.6 off end # PCI Express Port 7 + device pci 1c.7 on end # PCI Express Port 8 + device pci 1d.0 on + smbios_slot_desc "SlotTypeM2Socket1_SD" "SlotLengthOther" "2230" "SlotDataBusWidth1X" + end # PCI Express Port 9 + device pci 1d.1 on end # PCI Express Port 10 + device pci 1d.2 off end # PCI Express Port 11 + device pci 1d.3 off end # PCI Express Port 12 + device pci 1d.4 on + smbios_slot_desc "SlotTypeM2Socket3" "SlotLengthOther" "2280" "SlotDataBusWidth4X" + end # PCI Express Port 13 (x4) + device pci 1e.0 off end # UART #0 + device pci 1e.1 off end # UART #1 + device pci 1e.2 off end # GSPI #0 + device pci 1e.3 off end # GSPI #1 + device pci 1f.0 on + chip ec/google/wilco + device pnp 0c09.0 on end + end + end # LPC/eSPI + device pci 1f.1 on end # P2SB + device pci 1f.2 on end # Power Management Controller + device pci 1f.3 on end # Intel HDA + device pci 1f.4 on end # SMBus + device pci 1f.5 on end # PCH SPI + device pci 1f.6 on end # GbE + end +end diff --git a/src/mainboard/google/drallion/variants/sarien_cml/gpio.c b/src/mainboard/google/drallion/variants/sarien_cml/gpio.c new file mode 100644 index 0000000..78db12e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/gpio.c @@ -0,0 +1,267 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#include <variant/gpio.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* Pad configuration in ramstage */ +static const struct pad_config gpio_table[] = { +/* RCIN# */ PAD_NC(GPP_A0, NONE), +/* ESPI_IO0 */ +/* ESPI_IO1 */ +/* ESPI_IO2 */ +/* ESPI_IO3 */ +/* ESPI_CS# */ +/* SERIRQ */ +/* PIRQA# */ PAD_NC(GPP_A7, NONE), +/* CLKRUN# */ PAD_NC(GPP_A8, NONE), +/* ESPI_CLK */ +/* CLKOUT_LPC1 */ PAD_NC(GPP_A10, NONE), +/* PME# */ PAD_NC(GPP_A11, NONE), +/* BM_BUSY# */ PAD_NC(GPP_A12, NONE), + +/* ESPI_RESET# */ + +/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), +/* SD_PWR_EN# */ PAD_NC(GPP_A17, NONE), +/* ISH_GP0 */ PAD_NC(GPP_A18, NONE), +/* ISH_GP1 */ PAD_NC(GPP_A19, NONE), +/* ISH_GP2 */ PAD_NC(GPP_A20, NONE), +/* ISH_GP3 */ PAD_NC(GPP_A21, NONE), +/* ISH_GP4 */ PAD_NC(GPP_A22, NONE), +/* ISH_GP5 */ PAD_NC(GPP_A23, NONE), + +/* CORE_VID0 */ +/* CORE_VID1 */ +/* VRALERT# */ PAD_NC(GPP_B2, NONE), +/* CPU_GP2 */ PAD_CFG_GPI_APIC(GPP_B3, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TOUCHPAD_INTR# */ +/* CPU_GP3 */ PAD_CFG_GPI(GPP_B4, NONE, DEEP), /* TOUCH_SCREEN_DET# */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), /* CLKREQ_PCIE#0 */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), /* CLKREQ_PCIE#1 */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), /* CLKREQ_PCIE#2 */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), /* CLKREQ_PCIE#3 */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), /* CLKREQ_PCIE#4 */ +/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), +/* EXT_PWR_GATE# */ PAD_CFG_GPO(GPP_B11, 0, DEEP), /* 3.3V_CAM_EN# */ +/* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), +/* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), +/* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), +/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), +/* GSPI0_CLK */ PAD_NC(GPP_B16, NONE), +/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), +/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), +/* GSPI1_CS# */ PAD_NC(GPP_B19, NONE), /* HDD_FALL_INT (nostuff) */ +/* GSPI1_CLK */ PAD_NC(GPP_B20, NONE), /* TPM_PIRQ# (nostuff) */ +/* GSPI1_MISO */ PAD_CFG_GPO(GPP_B21, 1, DEEP), /* PCH_3.3V_TS_EN */ +/* GSPI1_MOSI */ PAD_NC(GPP_B22, NONE), +/* SML1ALERT# */ PAD_NC(GPP_B23, DN_20K), + +/* SMBCLK */ PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), /* MEM_SMBCLK */ +/* SMBDATA */ PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), /* MEM_SMBDATA */ +/* SMBALERT# */ PAD_NC(GPP_C2, DN_20K), +/* SML0CLK */ PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), /* SML0_SMBCLK */ +/* SML0DATA */ PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), /* SML0_SMBDATA */ +/* SML0ALERT# */ PAD_NC(GPP_C5, DN_20K), +/* SM1CLK */ PAD_CFG_NF(GPP_C6, NONE, DEEP, NF1), /* SML1_SMBCLK */ +/* SM1DATA */ PAD_CFG_NF(GPP_C7, NONE, DEEP, NF1), /* SML1_SMBDATA */ +/* UART0_RXD */ PAD_NC(GPP_C8, NONE), +/* UART0_TXD */ PAD_NC(GPP_C9, NONE), +/* UART0_RTS# */ PAD_CFG_GPI(GPP_C10, NONE, DEEP), /* TYPEC_CON_SEL1 */ +/* UART0_CTS# */ PAD_CFG_GPI(GPP_C11, NONE, DEEP), /* TYPEC_CON_SEL2 */ +/* UART1_RXD */ PAD_CFG_GPI_SCI_LOW(GPP_C12, NONE, DEEP, + EDGE_SINGLE), /* SIO_EXT_WAKE# */ +/* UART1_TXD */ PAD_NC(GPP_C13, NONE), +/* UART1_RTS# */ PAD_CFG_GPI(GPP_C14, NONE, DEEP), /* LCD_CBL_DET# */ +/* UART1_CTS# */ PAD_NC(GPP_C15, NONE), +/* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* TS_I2C_SDA */ +/* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* TS_I2C_SCL */ +/* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* I2C1_SDA_TP */ +/* I2C1_SCL */ PAD_CFG_NF(GPP_C19, NONE, DEEP, NF1), /* I2C1_SCK_TP */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), +/* UART2_CTS# */ PAD_CFG_GPI_APIC(GPP_C23, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* TS_INT# */ + +/* SPI1_CS# */ PAD_CFG_GPI_APIC(GPP_D0, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* MEDIACARD_IRQ# */ +/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), +/* SPI1_MISO */ PAD_NC(GPP_D2, NONE), +/* SPI1_MOSI */ PAD_CFG_GPI(GPP_D3, NONE, DEEP), /* RTC_DET# */ +/* FASHTRIG */ PAD_NC(GPP_D4, NONE), +/* ISH_I2C0_SDA */ PAD_NC(GPP_D5, NONE), +/* ISH_I2C0_SCL */ PAD_NC(GPP_D6, NONE), +/* ISH_I2C1_SDA */ PAD_NC(GPP_D7, NONE), +/* ISH_I2C1_SCL */ PAD_NC(GPP_D8, NONE), +/* ISH_SPI_CS# */ PAD_CFG_GPI(GPP_D9, NONE, DEEP), /* IR_CAM_DET# */ +/* ISH_SPI_CLK */ PAD_NC(GPP_D10, NONE), +/* ISH_SPI_MISO */ PAD_CFG_GPI(GPP_D11, NONE, DEEP), /* TBT_DET# */ +/* ISH_SPI_MOSI */ PAD_NC(GPP_D12, NONE), +/* ISH_UART0_RXD */ PAD_NC(GPP_D13, NONE), +/* ISH_UART0_TXD */ PAD_NC(GPP_D14, NONE), +/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 1, DEEP), /* WWAN_FULL_PWR_EN */ +/* ISH_UART0_CTS# */ PAD_NC(GPP_D16, NONE), +/* DMIC_CLK1 */ PAD_CFG_GPI(GPP_D17, NONE, DEEP), /* KB_DET# */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* DMIC_CLK0 */ PAD_NC(GPP_D19, NONE), +/* DMIC_DATA0 */ PAD_NC(GPP_D20, NONE), +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 1, DEEP), /* WWAN_BB_RST# */ +/* SPI1_IO3 */ PAD_CFG_GPO(GPP_D22, 0, DEEP), /* WWAN_GPIO_PERST# */ +/* I2S_MCLK */ PAD_CFG_GPI_SCI_LOW(GPP_D23, NONE, DEEP, + EDGE_SINGLE), /* WWAN_GPIO_WAKE# */ + +/* SATAXPCIE0 */ PAD_CFG_NF(GPP_E0, NONE, DEEP, NF1), /* HDD_DET# */ + /* M3042_PCIE#_SATA */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), + /* M2880_PCIE_SATA# */ +/* SATAXPCIE2 */ PAD_CFG_NF(GPP_E2, NONE, DEEP, NF1), +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATA_DEVSLP0 */ PAD_CFG_NF(GPP_E4, NONE, DEEP, NF1), /* HDD_DEVSLP */ +/* SATA_DEVSLP1 */ PAD_CFG_NF(GPP_E5, NONE, DEEP, NF1), /* M3042_DEVSLP */ +/* SATA_DEVSLP2 */ PAD_CFG_NF(GPP_E6, NONE, DEEP, NF1), /* M2280_DEVSLP */ +/* CPU_GP1 */ PAD_CFG_GPO(GPP_E7, 1, DEEP), /* TOUCH_SCREEN_PD# */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* USB2_OCO# */ PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), /* USB_OC0# */ +/* USB2_OC1# */ PAD_CFG_NF(GPP_E10, NONE, DEEP, NF1), /* USB_OC1# */ +/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, NF1), /* USB_OC2# */ +/* USB2_OC3# */ PAD_NC(GPP_E12, NONE), +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* HDMI_DP1_HPD */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* CPU_DP2_HPD */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* H1_FLASH_WP */ +/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), /* FFS_INT2 (nostuff) */ +/* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), +/* DDPB_CTRLCLK */ PAD_CFG_NF(GPP_E18, NONE, DEEP, NF1), +/* DDPB_CTRLDATA */ PAD_CFG_NF(GPP_E19, NONE, DEEP, NF1), +/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), +/* DDPC_CTRLDATA */ PAD_NC(GPP_E21, NONE), +/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), +/* DDPD_CTRLDATA */ PAD_NC(GPP_E23, NONE), + +/* CNV_PA_BLANKING */ PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), /* CNV_COEX3 */ +/* GPP_F1 */ PAD_NC(GPP_F1, NONE), /* T406 */ +/* GPP_F2 */ PAD_NC(GPP_F2, NONE), /* T407 */ +/* GPP_F3 */ PAD_NC(GPP_F3, NONE), +/* CNV_BRI_DT */ PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), +/* CNV_BRI_RSP */ PAD_CFG_NF(GPP_F5, NONE, DEEP, NF1), +/* CNV_RGI_DT */ PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), +/* CNV_RGI_RSP */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), +/* CNV_MFUART2_RXD */ PAD_CFG_NF(GPP_F8, NONE, DEEP, NF1), /* CNV_COEX2 */ +/* CNV_MFUART2_TXD */ PAD_CFG_NF(GPP_F9, NONE, DEEP, NF1), /* CNV_COEX1 */ +/* GPP_F10 */ PAD_NC(GPP_F10, NONE), +/* EMMC_CMD */ PAD_NC(GPP_F11, NONE), +/* EMMC_DATA0 */ PAD_NC(GPP_F12, NONE), +/* EMMC_DATA1 */ PAD_NC(GPP_F13, NONE), +/* EMMC_DATA2 */ PAD_NC(GPP_F14, NONE), +/* EMMC_DATA3 */ PAD_NC(GPP_F15, NONE), +/* EMMC_DATA4 */ PAD_NC(GPP_F16, NONE), +/* EMMC_DATA5 */ PAD_NC(GPP_F17, NONE), +/* EMMC_DATA6 */ PAD_NC(GPP_F18, NONE), +/* EMMC_DATA7 */ PAD_NC(GPP_F19, NONE), +/* EMMC_RCLK */ PAD_NC(GPP_F20, NONE), +/* EMMC_CLK */ PAD_NC(GPP_F21, NONE), +/* EMMC_RESET# */ PAD_NC(GPP_F22, NONE), +/* A4WP_PRESENT */ PAD_NC(GPP_F23, NONE), + +/* SD_CMD */ PAD_CFG_GPI(GPP_G0, NONE, DEEP), /* CAM_MIC_CBL_DET# */ +/* SD_DATA0 */ PAD_NC(GPP_G1, NONE), +/* SD_DATA1 */ PAD_NC(GPP_G2, NONE), +/* SD_DATA2 */ PAD_NC(GPP_G3, NONE), /* T383 */ +/* SD_DATA3 */ PAD_CFG_GPI(GPP_G4, NONE, DEEP), /* CTLESS_DET# */ +/* SD_CD# */ PAD_CFG_GPO(GPP_G5, 1, DEEP), /* HOST_SD_WP# */ +/* SD_CLK */ PAD_CFG_GPO(GPP_G6, 1, DEEP), /* AUD_PWR_EN */ +/* SD_WP */ PAD_NC(GPP_G7, NONE), /* T384 */ + +/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), +/* I2S2_SFRM */ PAD_CFG_NF(GPP_H1, NONE, DEEP, NF3), /* CNV_RF_RESET# */ +/* I2S2_TXD */ PAD_CFG_NF(GPP_H2, NONE, DEEP, NF3), /* CLKREQ_CNV# */ +/* I2S2_RXD */ PAD_CFG_GPO(GPP_H3, 0, DEEP), /* CNVI_EN# */ +/* I2C2_SDA */ PAD_NC(GPP_H4, NONE), /* T388 */ +/* I2C2_SCL */ PAD_NC(GPP_H5, NONE), /* T389 */ +/* I2C3_SDA */ PAD_NC(GPP_H6, NONE), /* T378 */ +/* I2C3_SCL */ PAD_NC(GPP_H7, NONE), /* T379 */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* I2C5_SDA */ PAD_NC(GPP_H10, NONE), +/* I2C5_SCL */ PAD_NC(GPP_H11, NONE), +/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), +/* M2_SKT2_CFG3 */ PAD_CFG_GPO(GPP_H15, 1, DEEP), /* BT_RADIO_DIS# */ +/* DDPF_CTRLCLK */ PAD_NC(GPP_H16, NONE), +/* DPPF_CTRLDATA */ PAD_NC(GPP_H17, NONE), +/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), /* C10_GATE# */ +/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), +/* IMGCLKOUT1 */ PAD_NC(GPP_H20, NONE), +/* GPP_H21 */ PAD_NC(GPP_H21, NONE), +/* GPP_H22 */ PAD_NC(GPP_H22, NONE), +/* GPP_H23 */ PAD_NC(GPP_H23, NONE), + +/* BATLOW# */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* BATLOW# */ +/* ACPRESENT */ PAD_CFG_NF(GPD1, NONE, DEEP, NF1), /* AC_PRESENT */ +/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* LAN_WAKE# */ +/* SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* SIO_SLP_S3# */ +/* SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* SIO_SLP_S4# */ +/* SLP_A# */ PAD_CFG_NF(GPD6, NONE, DEEP, NF1), /* SIO_SLP_A# */ +/* GPD7 */ PAD_NC(GPD7, NONE), +/* SUSCLK */ PAD_CFG_NF(GPD8, NONE, DEEP, NF1), /* SUSCLK */ +/* SLP_WLAN# */ PAD_CFG_NF(GPD9, NONE, DEEP, NF1), /* SIO_SLP_WLAN# */ +/* SLP_S5# */ PAD_CFG_NF(GPD10, NONE, DEEP, NF1), /* SIO_SLP_S5# */ +/* LANPHYC */ PAD_CFG_NF(GPD11, NONE, DEEP, NF1), /* PM_LANPHY_EN */ +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { +/* M2_SKT2_CFG1 */ PAD_CFG_GPO(GPP_H13, 1, DEEP), /* M.2 SSD D3 cold */ +/* SUSWARN# */ PAD_CFG_GPO(GPP_A13, 0, DEEP), /* Card reader D3 cold */ +/* SUSACK# */ PAD_CFG_GPO(GPP_A15, 0, DEEP), /* Card reader D3 cold */ +/* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVOTX_UART */ +/* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVORX_UART */ +/* SSD RESET pin will stay low first */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 0, DEEP), /* D3 cold RST */ +/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, NF1), /* I2C_SDA_H1 */ +/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, NF1), /* I2C_SCL_H1 */ +/* DMIC_DATA1 */ PAD_CFG_GPI_APIC(GPP_D18, NONE, PLTRST, + EDGE_SINGLE, INVERT), /* H1_PCH_INT_ODL */ +/* RESET# need to stay low before FULL_CARD_POWER_OFF assert */ +/* SPI1_IO2 */ PAD_CFG_GPO(GPP_D21, 0, DEEP), /* WWAN_BB_RST# */ +/* CPU_GP0 */ PAD_CFG_GPI(GPP_E3, NONE, DEEP), /* MEM_INTERLEAVED */ +/* SATALED# */ PAD_CFG_GPI(GPP_E8, NONE, DEEP), /* RECOVERY# */ +/* DDPD_HPD2 */ PAD_CFG_GPI(GPP_E15, NONE, DEEP), /* H1_FLASH_WP */ +/* PWRBTN# */ PAD_CFG_NF(GPD3, UP_20K, DEEP, NF1), /* SIO_PWRBTN# */ +/* M2_SKT2_CFG0 */ PAD_CFG_GPO(GPP_H12, 1, DEEP), /* D3 cold RST */ +}; + +const struct pad_config *variant_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(gpio_table); + return gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} + +static const struct cros_gpio cros_gpios[] = { + CROS_GPIO_REC_AL(GPP_E8, CROS_GPIO_DEVICE_NAME), + CROS_GPIO_WP_AH(GPP_E15, CROS_GPIO_DEVICE_NAME), +}; + +const struct cros_gpio *variant_cros_gpios(size_t *num) +{ + *num = ARRAY_SIZE(cros_gpios); + return cros_gpios; +} diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl new file mode 100644 index 0000000..0cdbcd1 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/dptf.asl @@ -0,0 +1,73 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define DPTF_CPU_PASSIVE 99 +#define DPTF_CPU_CRITICAL 105 + +/* Skin Sensor for CPU VR temperature monitor */ +#define DPTF_TSR0_SENSOR_ID 1 +#define DPTF_TSR0_SENSOR_NAME "Skin" +#define DPTF_TSR0_PASSIVE 71 +#define DPTF_TSR0_CRITICAL 100 + +/* Memory Sensor for DDR temperature monitor */ +#define DPTF_TSR1_SENSOR_ID 2 +#define DPTF_TSR1_SENSOR_NAME "DDR" +#define DPTF_TSR1_PASSIVE 55 +#define DPTF_TSR1_CRITICAL 100 + +/* M.2 Sensor for Ambient temperature monitor */ +#define DPTF_TSR2_SENSOR_ID 3 +#define DPTF_TSR2_SENSOR_NAME "Ambient" +#define DPTF_TSR2_PASSIVE 90 +#define DPTF_TSR2_CRITICAL 100 + +#undef DPTF_ENABLE_FAN_CONTROL +#undef DPTF_ENABLE_CHARGER + +Name (DTRT, Package () { + /* CPU Throttle Effect on CPU */ + Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Skin (TSR0) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on DDR (TSR1) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 250, 10, 0, 0, 0, 0 }, + + /* CPU Throttle Effect on Ambient (TSR2) */ + Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR2, 250, 10, 0, 0, 0, 0 }, +}) + +Name (MPPC, Package () +{ + 0x2, /* Revision */ + Package () { /* Power Limit 1 */ + 0, /* PowerLimitIndex, 0 for Power Limit 1 */ + 5000, /* PowerLimitMinimum */ + 15000, /* PowerLimitMaximum */ + 10000, /* TimeWindowMinimum */ + 10000, /* TimeWindowMaximum */ + 100 /* StepSize */ + }, + Package () { /* Power Limit 2 */ + 1, /* PowerLimitIndex, 1 for Power Limit 2 */ + 5000, /* PowerLimitMinimum */ + 51000, /* PowerLimitMaximum */ + 28000, /* TimeWindowMinimum */ + 28000, /* TimeWindowMaximum */ + 100 /* StepSize */ + } +}) diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl new file mode 100644 index 0000000..41121d2 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/acpi/mainboard.asl @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2019 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define CAM_EN GPP_B11 /* Active low */ +#define TS_PD GPP_E7 + +/* Method called from LPIT prior to enter s0ix state */ +Method (MS0X, 1) +{ + If (Arg0) { + /* Turn off camera power */ + _SB.PCI0.STXS (CAM_EN) + } Else { + /* Turn on camera power */ + _SB.PCI0.CTXS (CAM_EN) + } +} + +/* Method called from _PTS prior to enter sleep state */ +Method (MPTS, 1) +{ + _SB.PCI0.LPCB.EC0.PTS (Arg0) + + /* Clear touch screen pd pin to avoid leakage */ + _SB.PCI0.CTXS (TS_PD) +} + +/* Method called from _WAK prior to wakeup */ +Method (MWAK, 1) +{ + _SB.PCI0.LPCB.EC0.WAK (Arg0) +} diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h new file mode 100644 index 0000000..01a17b5 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/ec.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_EC_H +#define VARIANT_EC_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* EC wake pin */ +#define EC_WAKE_PIN GPE0_DW1_12 + +/* eSPI virtual wire reporting */ +#define EC_SCI_GPI GPE0_ESPI + +/* Enable PS/2 keyboard */ +#define SIO_EC_ENABLE_PS2K + +/* Enable DPTF */ +#define EC_ENABLE_DPTF + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h new file mode 100644 index 0000000..f7e0403 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/gpio.h @@ -0,0 +1,34 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* Flash Write Protect */ +#define GPIO_PCH_WP GPP_E15 + +/* Recovery mode */ +#define GPIO_REC_MODE GPP_E8 + +const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_early_gpio_table(size_t *num); + +struct cros_gpio; +const struct cros_gpio *variant_cros_gpios(size_t *num); + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h new file mode 100644 index 0000000..6eb6d14 --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/hda_verb.h @@ -0,0 +1,152 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MAINBOARD_HDA_VERB_H +#define MAINBOARD_HDA_VERB_H + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0236, // Codec Vendor / Device ID: Realtek ALC3204 + 0xffffffff, // Subsystem ID + 0x0000001e, // Number of jacks (NID entries) + + /* Rest Codec First */ + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb Table */ + AZALIA_SUBVENDOR(0x0, 0x102808b8), + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0x0, 0x12, 0x90a60140), + AZALIA_PIN_CFG(0x0, 0x13, 0x40000000), + AZALIA_PIN_CFG(0x0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0x0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x19, 0x04a11030), + AZALIA_PIN_CFG(0x0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0x0, 0x1d, 0x40700001), + AZALIA_PIN_CFG(0x0, 0x1e, 0x421212f2), + AZALIA_PIN_CFG(0x0, 0x21, 0x04211020), + + /* ALC3204 default-1 */ + 0x02050040, + 0x02049800, + 0x02050034, + 0x0204023C, + /* ALC3204 default-2 */ + 0x0205003C, + 0x02040354, + 0x0205003C, + 0x02040314, + /* ALC3204 Speaker output power - 4 ohm 2W (+12dB gain) + * + Combo Jack TRS setting */ + 0x02050038, + 0x02043901, + 0x02050045, + 0x02045089, + /* H/W AGC setting-1 */ + 0x02050016, + 0x02040C50, + 0x02050012, + 0x0204EBC2, + /* H/W AGC setting-2 */ + 0x02050013, + 0x0204401D, + 0x02050016, + 0x02044E50, + /* Zero data + EAPD to verb-control */ + 0x02050037, + 0x0204FE15, + 0x02050010, + 0x02040020, + /* Zero data */ + 0x02050030, + 0x02048000, + 0x02050030, + 0x02048000, + /* ALC3204 default-3 */ + 0x05750003, + 0x05740DA3, + 0x02050046, + 0x02040004, + /* ALC3204 default-4 */ + 0x0205001B, + 0x02040A4B, + 0x02050008, + 0x02046A6C, + /* JD1 */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* Microphone + Array MIC security Disable +ADC clock Enable */ + 0x0205000D, + 0x0204A020, + 0x02050005, + 0x02040700, + /* Speaker Enable */ + 0x0205000C, + 0x020401EF, + 0x0205000C, + 0x020401EF, + /* EQ Bypass + EQ HPF cutoff 250Hz */ + 0x05350000, + 0x0534201A, + 0x0535001d, + 0x05340800, + /* EQ-2 */ + 0x0535001e, + 0x05340800, + 0x05350003, + 0x05341EF8, + /* EQ-3 */ + 0x05350004, + 0x05340000, + 0x05450000, + 0x05442000, + /* EQ-4 */ + 0x0545001d, + 0x05440800, + 0x0545001e, + 0x05440800, + /* EQ-5 */ + 0x05450003, + 0x05441EF8, + 0x05450004, + 0x05440000, + /* EQ Update */ + 0x05350000, + 0x0534E01A, + 0x05350000, + 0x0534E01A, +}; + +const u32 pc_beep_verbs[] = { +/* PCBeep pass through to NID14 for ePSA test-1 */ + 0x02050036, + 0x02047717, + 0x02050036, + 0x02047717, +/* PCBeep pass through to NID14 for ePSA test-2 */ + 0x01470740, + 0x0143B000, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES; + +#endif diff --git a/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h new file mode 100644 index 0000000..bbb3e9e --- /dev/null +++ b/src/mainboard/google/drallion/variants/sarien_cml/include/variant/variant.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2018 Google LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef VARIANT_H +#define VARIANT_H + +/* Sarien is SKU ID 1 and 3 */ +#define VARIANT_SKU_ID 1 +#define VARIANT_SKU_NAME "sku1" +#define VARIANT_SKU_ID_SIGNED_EC 3 +#define VARIANT_SKU_NAME_SIGNED_EC "sku3" + +#endif
