Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84710?usp=email )
Change subject: Documentation/internals: Add devicetree language documentation ......................................................................
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: If868ad9a87cb2903bf144996fe3b87d29d4fc755 Reviewed-on: https://review.coreboot.org/c/coreboot/+/84710 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nicholas Chin nic.c3.14@gmail.com --- A Documentation/internals/devicetree_language.md M Documentation/internals/index.md 2 files changed, 1,310 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Nicholas Chin: Looks good to me, approved
diff --git a/Documentation/internals/devicetree_language.md b/Documentation/internals/devicetree_language.md new file mode 100644 index 0000000..0609559 --- /dev/null +++ b/Documentation/internals/devicetree_language.md @@ -0,0 +1,1309 @@ +# Devicetree Language + +Devicetrees use what's called a Domain Specific Language, so you need to +follow the rules of the language when you're writing a devicetree. +Fortunately, it's a relatively simple language, and because its use is +so limited, it can frequently be learned just by following existing +examples. + + +## Comments + +Comments in the devicetree are all single line style. They use the '#' +character to start the comment, and go to the end of the line. + + +### Comment Style + +* Put a space between the pound sign and the comment. + * # Good + * #Bad +* Sentence fragments are fine, but don't end them with a period. + + +### When to use comments + +There are standard locations where comments are typically used and +expected. + + +#### Starting a group of settings + +Similar to commenting a function with the intent of the function, it can +be useful to describe at the top of a block of settings with what's +being configured. + +Below is a good example. + +```text +# VR Settings Configuration for 4 Domains +# +----------------+-----------+-----------+-------------+----------+ +# | Domain/Setting | SA | IA | GT Unsliced | GT | +# +----------------+-----------+-----------+-------------+----------+ +# | Psi1Threshold | 20A | 20A | 20A | 20A | +# | Psi2Threshold | 4A | 5A | 5A | 5A | +# | Psi3Threshold | 1A | 1A | 1A | 1A | +# | Psi3Enable | 1 | 1 | 1 | 1 | +# | Psi4Enable | 1 | 1 | 1 | 1 | +# | ImonSlope | 0 | 0 | 0 | 0 | +# | ImonOffset | 0 | 0 | 0 | 0 | +# | IccMax | 7A | 34A | 35A | 35A | +# | VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | +# | AC LoadLine | 15 mOhm | 5.7 mOhm | 5.2 mOhm | 5.2 mOhm | +# | DC LoadLine | 14.3 mOhm | 4.83 mOhm | 4.2 mOhm | 4.2 mOhm | +# +----------------+-----------+-----------+-------------+----------+ +``` + + +#### End of keyword blocks + +If there are multiple end statements in a row, and it's not instantly +obvious which end statement closes which keyword block, It's useful to +add a comment to say what's being ended. + +Below, we have three end statements in a row and the start of these +blocks are probably close to the top of the file. Identifying what the +'end' statement is closing can be determined by the spacing, but it's +still useful to note it with a comment. + +```text + end # agesa northbridge + end # domain +end # northbridge/amd/agesa/family14/root_complex +``` + + +#### Identifying the reason for a setting + +Registers which don't have a name that makes it obvious what is being +set, or don't have a macro that identifies what it's being set to should +be commented. + +The register setting and macro below both describe what the setting is, +but don't describe what they're being used for. Adding the comment of +"Camera", gives the reader the extra information to know what's on that +USB port, and understand that you (generally) don't need overcurrent +protection for an internal camera. + +```text +register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # Camera +``` + +This below register is well named and tells you that there's going to be +a delay of 12ms, but without the comment, you don't know why. + +```text +register "stop_delay_ms" = "12" # NIC needs time to quiesce +``` + + +#### Devices without aliases + +It's been common in the past to comment device identifiers with what the +device is, but this may be less needed now with aliases, which allow +devices to be named in a meaningful way. + +For older platforms which don't have aliases set in the chipset.cb file, +or for non chipset devices, it's still useful to add a comment after the +device is set. + + +### When not to use comments + +#### Magic numbers + +This overlaps somewhat with the next section, but if you find yourself +having to put in a comment to explain what's being set, evaluate whether +it can be expressed as a macro instead. + +``` +register "PmConfigSlpS3MinAssert" = "2" # 50ms +``` + +Instead of using the magic number 2, use a macro, just as you'd be +expected to do in your code. It's not obvious without the comment what +2 means, so use a macro instead. + +If there's some reason that a macro cannot be used, then sure, add a +comment, but this should be very unusual. + +#### Redundant comments + +With good naming, comments may not be needed. + +Example of redundant comments: + +```text +register "ipc1" = "0x00000000" # IPC1 +``` + +```text +register "link_freq[0]" = "360 * MHz" # 360 MHz +``` + +#### Devices with aliases + +For older chipset or SoC devices, or for non chipset devices that don't +have a chipset.cb file, it's still desirable to use comments on the +'device' line, but if the device has an alias, it should be used. + + +## Registers + +### Register Names + +Any registers which encode a value that has any sort of unit should +include the unit in the name instead of in a comment. + +The name "tFAW" in the register below is taken directly from the name in +the spec, but adding the units makes it a lot easier to understand. + +```text +register "tFAW" = "40000" # picoseconds +``` + +### Use Macros for encoded values + +If the value associated with the register encodes the unit, instead of +entering the value directly, add a macro for the value. + +```text +register "PchPmSlpS3MinAssert" = "3" # 50ms +``` + +This would be easier to understand if it had a macro, not just a magic +number, as seen below. + +```text +register "PchPmSlpS3MinAssert" = "ASSERT_50_MILLISEC" +``` + +## Devicetree Keywords + +alias, as, chip, cpu, cpu_cluster, device, domain, drq, end, field, +fw_config, generic, gpio, hidden, i2c, inherit, io, ioapic, ioapic_irq, +lapic, mandatory, mmio, off, on, option, pci, pnp, probe, ref, register, +smbios_dev_info, smbios_slot_desc, spi, subsystemid, usb, use + + +## Keyword Types + +The keywords are divided into a number of different categories. A few +keywords fall into more than one of these categories. + + +### Alias Types + +The alias type keywords are used to give human readable names to +devices, then later update that name for a specific usage. + +* alias, as, use + + +### Containers + +These keywords act to group information into logical units of different +sorts. + +* chip, device, domain, field, fw_config, end + + +### Device/Bus Types + +These keywords are used to identify the type of device being configured +and select the appropriate structure for configuration. + +* cpu, cpu_cluster, domain, generic, gpio, i2c, ioapic, lapic, mmio, + pci, pnp, ref, spi, usb + + +### Enumeration Status Modifiers + +The status modifiers determine how a device should be treated during +enumeration. + +* on, off, hidden, mandatory + + +### Firmware configuration + +* field, fw_config, option, probe, ref + + +### Resource allocation + +* drq, io, irq + + +### SMBIOS + +* smbios_dev_info, smbios_slot_desc + + +### Subsystem + +* inherit, subsystemid + + +### Register + +* register + + +### MPTABLE + +* ioapic_irq + + +## Keyword Definitions + +### alias + +* Keyword type: Alias +* Introduced in June of 2020, coreboot version 4.12 +* Usage: `device <device type> <device address> **alias** <ALIAS ID> <status modifier> ... end` + +Sometimes, the driver of one device needs to know about another device +that can be anywhere in the device hierarchy. Current applications boil +down to EEPROMs that store information that is consumed by some code +(e.g. MAC address). + +The idea is to give device nodes in the `devicetree.cb` an alias that +can later be used to link it to a device driver's `config` structure. +The driver has to declare a field of type `struct device *`, e.g. + +Override devices can add an alias if it does not exist, but cannot +change the alias for a device that already exists. + +Alias names are checked for conflicts both in the base tree and in the +override tree. + +References are resolved after the tree is parsed so aliases and +references do not need to be in a specific order in the tree. + +Example: +```text +device i2c 0x50 alias my_eeprom on end +``` + +static.c: + +```C +struct some_chip_driver_config { + DEVTREE_CONST struct device *needed_eeprom; +}; +``` + +### as + +* Keyword type: Alias +* Introduced in June of 2020, coreboot version 4.12 +* Usage: `use <Alias ID> as <Alias ID 2>` + +This keyword is used along with the 'use' keyword to give a more +specific name to a generic alias. + +The author of the devicetree is free to choose any alias name that is +unique in the devicetree. Later, when configuring the driver the alias +can be used to link the device with the field of a driver's config as in +the following example. + + +Example: + +```text +chip some/chip/driver + use my_eeprom as needed_eeprom +end +``` + + +### chip + +* Keyword type: Component type +* Introduced in initial sconfig implementation, pre coreboot 4.0 +* Usage: `**chip** <path to chip.h file> ... end` + +The chip keyword defines a section for a device inside a hierarchy of +devices. + +Following the chip keyword is a path to an optional chip.h file. If +this file exists, it should contain a structure of all register settings +available for this device. + +The section started with "chip" is closed with the "end" keyword. + +Note that register commands are chip based, not device based. + +Example: +```text +chip some/chip/driver # comment as desired + # A chip section must have at least one device inside it + ... +end # some/chip/driver +``` + + +### cpu + +* Keyword type: Device type +* Introduced in October of 2014, coreboot version 4.0 +* Usage: `device **cpu** <Identifier> [alias <alias ID>] <status modifier> ... end` + +The cpu device type was introduced In order to enumerate CPU devices +that are non-x86 (read: no lapic). + +This device type is not used very much, as most non-x86 platforms just +handle all the CPU configuration at the cpu_cluster level. + +Example: + +```text +device cpu 0 on end +``` + + +### cpu_cluster + +* Keyword type: Device type +* Introduced in initial sconfig implementation, pre coreboot 4.0 as apic_cluster +* Updated in May of 2010 - renamed from apic_cluster to lapic_cluster +* Updated in February of 2013 - Renamed from from lapic_cluster to cpu_cluster +* Usage: `device cpu_cluster <Identifier> [alias <alias ID>] <status modifier> …. end` + +The CPU Cluster is typically one of the two top-level devices in a +devicetree, with the other being the PCI Domain. Like the domain +keyword, the cpu_cluster acts as a bridge device to contain any CPU and +lapic devices. + +On x86 type devices, the CPU Cluster contains CPU chip entries for each +socket which then contain any lapics on the system. + +On ARM or other non-x86 devices, the CPU Cluster can either contain +multiple CPUs or it can just be marked 'on', leaving all CPU +configuration to be handled at the CPU Cluster level. + +Example: + +```text +device cpu_cluster 0 on + device lapic 0 on end +end +``` + +### device + +* Keyword type: Component type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device <device type> <Identifier> [alias <alias ID>] <status modifier>…. end` + +A chip defines a collection of one or more devices, and as such, the +device is the fundamental building block of devicetree. + +The device block tells coreboot that a device is present on the +mainboard, gives some information on how to find, access, and work with +the device based on the device type. + +Examples: + +```text +device cpu_cluster 0 on + device lapic 0 on end +end +``` + +### domain + +* Keyword type: Device type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Updated in: February of 2013: Renamed pci_domain to domain +* Usage: `device domain <identifier> [alias <alias ID>] <status modifier> ... end` + +The domain type device acts as a container for one or more chips, +defining a logical bus segment. + +As of 2022-04-29, the domain keyword is still used exclusively to define +PCI bus segments. + +Example: + +```text +device domain 0 on + device generic 0 alias dptf_policy on end + device pci 1f.0 on # 8086 229c - LPC bridge + device pnp 2e.209 off end # GPIO 4 + end +end +``` + + +### drq + +* Keyword type: Resource type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `drq 0x<register #> = <drq line>` + +Drq is used to configure a legacy DMA Request line register for a device +on a legacy bus - ISA/LPC/eSPI. + +The drq configuration is only allowed inside a pnp block. + +Example: + +```text +device pnp 2e.1 on # Parallel port + io 0x60 = 0x378 + irq 0x70 = 7 + drq 0x74 = 3 +end +``` + +### end + +* Keyword type: Component type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `<device | chip | domain | field | fw_config> ... end` + +End is used to close a chip, device, field, or fw_config block. + +Example: + +```text +chip northbridge/intel/x4x + device domain 0 on + chip southbridge/intel/i82801gx + device pci 1f.0 on # ISA bridge + chip superio/winbond/w83627dhg + device pnp 2e.1 on # LPT + io 0x60 = 0x378 + irq 0x70 = 7 + drq 0x74 = 3 + end # LPT + end # superio/winbond/w83627dhg + end # ISA Bridge + end # Southbridge + end # domain 0 +end # Northbridge +``` + +### field + +* Keyword type: Firmware config +* Introduced in: May of 2020, coreboot version 4.12 +* Usage: `field <Identifier string> <low bit> <high bit> [ | <low bit> <high bit> …] ... end` + +Fields define the bits used in the Firmware config runtime options. +Note that the bits in a field can be discontiguous. + +All field definitions must be inside a fw_config block. + +Example: + +```text +field AUDIO 8 10 | 29 29 + option NONE 0 + option MAX98357_ALC5682I_I2S 1 + option MAX98373_ALC5682I_I2S 2 + option MAX98373_ALC5682_SNDW 3 + option MAX98373_ALC5682I_I2S_UP4 4 + option MAX98360_ALC5682I_I2S 5 + option RT1011_ALC5682I_I2S 6 + option AUDIO_FOO 7 + option AUDIO_BAR 8 + option AUDIO_QUUX 9 + option AUDIO_BLAH1 10 + option AUDIO_BLAH2 15 +end +``` + +static_fw_config.h: + +```C + FW_CONFIG_FIELD_AUDIO_MASK 0x20000700 + FW_CONFIG_FIELD_AUDIO_OPTION_NONE_VALUE 0x0 + FW_CONFIG_FIELD_AUDIO_OPTION_MAX98357_ALC5682I_I2S_VALUE 0x100 + FW_CONFIG_FIELD_AUDIO_OPTION_MAX98373_ALC5682I_I2S_VALUE 0x200 + FW_CONFIG_FIELD_AUDIO_OPTION_MAX98373_ALC5682_SNDW_VALUE 0x300 + FW_CONFIG_FIELD_AUDIO_OPTION_MAX98373_ALC5682I_I2S_UP4_VALUE 0x400 + FW_CONFIG_FIELD_AUDIO_OPTION_MAX98360_ALC5682I_I2S_VALUE 0x500 + FW_CONFIG_FIELD_AUDIO_OPTION_RT1011_ALC5682I_I2S_VALUE 0x600 + FW_CONFIG_FIELD_AUDIO_OPTION_AUDIO_FOO_VALUE 0x700 + FW_CONFIG_FIELD_AUDIO_OPTION_AUDIO_BAR_VALUE 0x20000000 + FW_CONFIG_FIELD_AUDIO_OPTION_AUDIO_QUUX_VALUE 0x20000100 + FW_CONFIG_FIELD_AUDIO_OPTION_AUDIO_BLAH1_VALUE 0x20000200 + FW_CONFIG_FIELD_AUDIO_OPTION_AUDIO_BLAH2_VALUE 0x20000700 +``` + +### fw_config + +* Keyword type: Firmware config +* Introduced in: May of 2020, coreboot version 4.12 +* Usage: fw_config + +Fw_config is the top level token for defining firmware config fields. +All field and option definitions must be inside the fw_config block. +Note that the table can be defined before any chips are configured. + +Example: +```text +fw_config + field USB_DB 0 1 + option USB_DB_A1_PS8811_C1_PS8818 0 + option USB_DB_A1_ANX7491_C1_ANX7451 1 + end + field FORM_FACTOR 2 + option FORM_FACTOR_CLAMSHELL 0 + option FORM_FACTOR_CONVERTIBLE 1 + end +end +``` + + +### generic + +* Keyword type: Device type +* Introduced in: May of 2016, coreboot version 4.4 +* Usage: `device generic <identifier> [alias <alias ID>] <status modifier> ... end` + +This allows the devicetree to describe a device that does not have a +specific bus, but may need to be described in tables for the operating +system. For instance some chips may have various GPIO connections that +need to be described but do not fall under any other device. + +Example: +```text +device pci 0c.0 on # CNVi + chip drivers/wifi/generic + register "wake" = "GPE0A_CNVI_PME_STS" + device generic 0 on end + end +end +``` + + +### gpio + +* Keyword type: Device type +* Introduced in: December 2020, coreboot version 4.13 +* Usage: `device **gpio** <identifier> [alias <alias ID>] <status modifier> ... end` + +The general idea behind this is that every chip can have gpios that +shall be accessible in a very generic way by any driver through the +devicetree. + +The chip that implements the chip-specific gpio operations has to assign +them to the generic device operations struct, which then gets assigned +to the gpio device during device probing. See CB:48583 for how this gets +done for the SoCs using intel/blocks/gpio. + +The gpio device then can be added to the devicetree with an alias name +like in the following example: + +```text +chip soc/whateverlake + device gpio 0 alias soc_gpio on end + ... +end +``` + +Any driver that requires access to this gpio device needs to have a +device pointer (or multiple) and an option for specifying the gpio to be +used in its chip config like this: + +```C +struct drivers_ipmi_config { + ... + DEVTREE_CONST struct device *gpio_dev; + u16 post_complete_gpio; + ... +}; +``` + +The device `soc_gpio` can then be linked to the chip driver's `gpio_dev` +above by using the syntax `use ... as ...`, which was introduced in +commit 8e1ea52: + +```text +chip drivers/ipmi + use soc_gpio as gpio_dev + register "bmc_jumper_gpio" = "GPP_D22" + ... +end +``` + +The IPMI driver can then use the generic gpio operations without any +knowlege of the chip's specifics: + +```C +unsigned int gpio_val; +const struct gpio_operations *gpio_ops; +gpio_ops = dev_get_gpio_ops(conf->gpio_dev); +gpio_val = gpio_ops->get(conf->bmc_jumper_gpio); +``` + +For a full example have a look at CB:48096 and CB:48095. + + +### hidden + +* Keyword type: Enumeration Status Modifier +* Introduced in: September 2018, coreboot version 4.8 +* Updated in: February of 2020, coreboot version 4.11 +* Usage: `device <device type> <identifier> [alias <alias ID>] hidden ... end` + +The "Hidden" keyword was added to support devices sharing the same +driver to update their ACPI status with different values. If a device +is marked as Hidden, it omits the "SHOW_IN_UI" field, which prevents the +device from showing up in the OSPM user interface. This was added to +prevent ChromeOS specific devices from showing up in Windows, for +example. It does not look like this keyword was ever actually used in +this capacity, but the code for this is still present. + +In 2020, the "Hidden" keyword's use was expanded to fix the problem of +PCI devices which have been hidden by disabling access to the config +space. Because the Device/Vendor IDs read back as 0xffffffff from the +hidden device, it appears that there is no PCI device located at that +Bus/Device/Function. This causes coreboot to remove the device at the +end of PCI enumeration. To fix this, if a device uses 'hidden' instead +of 'on', then it will be assumed during PCI enumeration that the device +indeed does exist, and it will not be removed. This allows coreboot to +manually assign resources to the device even though it doesn't appear to +exist. + +Example: +```text +device pci 1f.2 alias pmc hidden end +``` + +static.c: + +```C +.enabled = 1, +.hidden = 1, +.mandatory = 0, +``` + + +### i2c + +* Keyword type: Device type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device I2c <identifier> [alias <alias ID>] <status modifier> ... end` + +Example: + +```text +device i2c 2c on end +chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPIO_9)" + register "wake" = "GEVENT_22" + register "probed" = "1" + device i2c 15 on end +end +``` + +### inherit + +* Keyword type: subsystem +* Introduced in: March of 2011, coreboot version 4.0 +* Usage: `subsystemid beee c001 inherit` + +Used to modify the subsystemid keyword, inherit makes the ID apply to +all subdevices and functions. + +Example: +```text +device pci 00.0 on + subsystemid 0xdead 0xbeef inherit +end +``` + + +### io + +* Keyword type: Resource +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `io 0x<address> = 0x<value>` + +The io command is used to set an legacy device's io register to a value. + +Example: + +```text +device pnp 4e.06 on # Keyboard + io 0x60 = 0x0060 + io 0x62 = 0x0064 + irq 0x70 = 1 +end +``` + +### ioapic + +* Keyword type: Device type + +* Usage: `device ioapic <identifier> [alias <alias ID>] <status modifier> ... end` + + +### ioapic_irq + +* Keyword type: Mpinit type +* Introduced in: June of 2012, coreboot version 4.0 +* Usage: `ioapic_irq <APICID> <INTA|INTB|INTC|INTD> <INTPIN>` + +This keyword is used to support autogeneration of the MPTABLE from +devicetree.cb. This is done by a write_smp_table() declared weak in +mpspec.c. If the mainboard doesn't provide its own function, this +generic implementation is called. + +The ioapic_irq directive can be used in pci and pci_domain devices. If +there's no directive, the autogen code traverses the tree back to the +pci_domain and stops at the first device which sets such a directive, +and uses that information to generate the entry according to PCI IRQ +routing rules. + +```text +``` + + +### irq + +* Keyword type: Resource type +* Introduced in initial sconfig implementation, pre coreboot 4.0 +* Usage: `irq 0x<address> = 0x<value>` + +Irq is used to configure a legacy interrupt Request line register for a +device on a legacy bus - ISA/LPC/eSPI. + +The irq configuration is only allowed inside a pnp block. + +Example: + +```text +irq 0xc5 = 0x1f +``` + +```text +chip superio/fintek/f71808a + device pnp 4e.4 on # Hardware monitor + io 0x60 = 0x295 + irq 0x70 = 0 + end +end +``` + +### lapic + +* Keyword type: Device type +* Introduced in initial sconfig implementation, pre coreboot 4.0 +* Updated in May of 2010 - Renamed apic to lapic +* Usage: `device lapic <identifier> [alias <alias ID>] <status modifier> ... end` + +Defines an lapic device on an x86 mainboard. + +Example: + +```text +device cpu_cluster 0 on # (L)APIC cluster + chip cpu/intel/slot_1 # CPU socket 0 + device lapic 0 on end # Local APIC of CPU 0 + end + chip cpu/intel/slot_1 # CPU socket 1 + device lapic 1 on end # Local APIC of CPU 1 + end +end +``` + +### mandatory + +* Keyword type: Enumeration Status Modifier +* Introduced in: February of 2020, coreboot version 4.11 +* Usage: `device <device type> <identifier> [alias <alias ID>] mandatory ... end` + +The Mandatory keyword allows for minimal PCI scanning which speeds up the +boot process. Only devices marked "mandatory" get enabled and scanned +during PCI enumeration when the MINIMAL_PCI_SCANNING Kconfig option is +enabled. + +If MINIMAL_PCI_SCANNING is not enabled, this means the same as 'on'. + +static.c: + +```C +.enabled = 1, +.hidden = 0, +.mandatory = 1, +``` + +example: + +```text +device pci 1f.0 mandatory # LPC + chip drivers/pc80/tpm + device pnp 0c31.0 on end + end # tpm +end # LPC +``` + + +### mmio + +* Keyword type: Device type +* Introduced in January of 2018, coreboot version 4.7 +* Usage: `device mmio 0x<address> [alias <alias ID>] <status modifier> ... end` + +The mmio keyword allows fixed memory-mapped IO addressed devices to be +assigned to given values. + +AMD platforms perform a significant amount of configuration through these +MMIO addresses, including I2C bus configuration. + +example: + +```text +device mmio 0xfedc9000 alias uart_0 off end +device mmio 0xfedca000 alias uart_1 off end +device mmio 0xfedc2000 on # I2C 0 + + chip drivers/generic/adau7002 + device generic 0.0 on end + end + + chip drivers/i2c/da7219 + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_LOW(GPIO_14)" + end + + chip drivers/generic/max98357a + register "hid" = ""MX98357A"" + register "sdmode_delay" = "5" + device generic 0.1 on end + end + +end # I2C 0 +``` + + +### off + +* Keyword type: Enumeration Status Modifier +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device <device type> <identifier> [alias <alias ID>] off ... end` + +Indicates that the device should be disabled if possible and should not +be enumerated or configured. To disable a device, the code to disable it +must be present in the chipset/SoC code, though it isn't always possible +to actually disable the device. + +Note that If a device (especially PCI devices) is marked as 'off', but +does not get disabled, the OS or a driver may discover the device during +its enumeration sequence and assign it resources anyway. + +static.c: + +```C +.enabled = 0 +.hidden = 0, +.mandatory = 0, +``` + +example: + +```text +device usb 2.6 off end +device pnp 2e.0 off end # FDC +device pci 15.2 off end +``` + +### on + +* Keyword type: Enumeration Status Modifier +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device <device type> <identifier> [alias <alias ID>] on ... end` + +Marks a device as present and enabled. This indicates that the device +should be enumerated and configured. + +static.c: + +```C +.enabled = 1 +.hidden = 0, +.mandatory = 0, +``` + +Example: + +```text +device lapic 0 on end +device pci 00.0 on end # Host Bridge +device pnp 0c31.0 on end +``` + +### option + +* Keyword type: Firmware config +* Usage: `option <name> <value>` + +Options define the values which may be used in a firmware config field. +The option keyword may only be used inside a field, which may only be +used inside an fw_config block. + +Example: + +```text +fw_config + field OLED_SCREEN 28 + option OLED_NOT_PRESENT 0 + option OLED_PRESENT 1 + end +end +``` + +### pci + +* Keyword type: Device type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device pci <dev.func> [alias <alias ID>] <status modifier> …. end` + +The pci device type defines a PCI or PCIe device on the PCI logical bus. + +Resources for all PCI devices are assigned automatically, or must be +assigned in code if they're non-standard. + +Currently, only a single segment is supported, but there is work to make +multiple different segments supported, each with a bus 0. Because the +bus is not specified, It's assumed that all pci devices that are not +behind a pci bridge device are on bus 0. If there are additional pci +busses in a chip, they can be added behind their bridge device. + +Examples: + +```text +device pci 1a.0 on end # USB2 EHCI #2 +device pci 1b.0 on # High Definition Audio + subsystemid 0x1a86 0x4352 +end +``` + +Example - ISA bus under PCI to ISA bridge: + +```text +device pci 4.0 on # ISA bridge + chip superio/winbond/w83977tf # Super I/O + device pnp 3f0.2 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + end +end +``` + +Example - PCI Bus under a PCI to PCI bridge: + +```text +device pci 08.0 on end # Dummy Host Bridge, do not disable +device pci 08.1 alias gpp_bridge_a off # Internal GPP Bridge 0 to Bus A + device pci 0.0 alias gfx off end # Internal GPU (GFX) + device pci 0.1 alias gfx_hda off end # Display HDA (GFXAZ) +end +``` + + +### pnp + +* Keyword type: Device type +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `device pnp <Identifier> [alias <alias ID>] <status modifier>…. end` + +pnp is used to define an IO addressed device within a chip on a legacy +bus - ISA, LPC, or eSPI. The identifier is the IO address used to +access the chip, followed by the identifier for the device within the +chip. + +The io, irq, and drq resource identifiers are allowed only inside a pnp +device. + +Example: + +```text +chip superio/ite/it8783ef + device pnp 2e.0 off end # Floppy + device pnp 2e.1 on # COM 1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end +end +``` + +### probe + +* Keyword type: Firmware config +* Introduced in May of 2020, coreboot version 4.12 +* Usage: `probe <Field Name> <Option Name>` + +The fields and options can be used to probe for a device and have that +device be disabled if it is not found at boot time. + +Example: + +```text +fw_config + field FEATURE 0 0 + option DISABLE 0 + option ENABLE 1 + end +end + +chip drivers/generic/feature + device generic 0 on + probe FEATURE ENABLE + end +end +``` + + +### ref + +* Keyword type: Device type (alias) +* Introduced in July of 2020, coreboot version 4.12 +* Usage: `device REF <Identifier> <status modifier>…. end` + +This allows the chipset to assign alias names to devices as well as set +default register values. This works for both the baseboard devicetree.cb +as well as variant overridetree.cb. + +Example: + +chipset.cb: + +```text +device pci 15.0 alias i2c0 off end +``` + +devicetree.cb: + +```text +device ref i2c0 on end +``` + +### register + +* Keyword type: Register +* Introduced in: Initial sconfig implementation, pre coreboot 4.0 +* Usage: `register "name" = "value"` + +The register keyword was initially intended to supply just that - +information for device register values. Over the years, its use has been +expanded to much more than this, becoming a general configuration +mechanism. + +All values set by the register keyword MUST be defined in the chip.h +file. The register keyword only works at the chip level, not at the +device level. + +Any register defined in the chip.h file that is not set in the +devicetree file gets set to zero. + +To double quote a value, use two sets of quotes: `register "name" = ""string""` + +Examples: + +```text +register "desc" = ""USB2 Type-A Rear Lower"" +register "pcie_power_limits" = "{ { 10, 0 }, { 0, 0 }, { 0, 0 }, + { 0, 0 }, { 10, 0 }, { 0, 0 } }" +register "SataPortsEnable[0]" = "1" +register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_B3_IRQ)" +register "common_soc_config" = "{ + // Touchpad I2C bus + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 80, + .fall_time_ns = 110, + }, + }" +``` + + +### smbios_dev_info + +* Keyword type: smbios +* Introduced in: May of 2019, coreboot version 4.9 +* Usage: `smbios_dev_info <Identifier>` + +Specify the instance ID and RefDes (Reference Designation) of onboard +devices. + +The `SMBIOS_TYPE41_PROVIDED_BY_DEVTREE` Kconfig option enables using +this syntax to control the generated Type 41 entries (Onboard Devices +Extended Information). When this option is enabled, Type 41 entries are +only autogenerated for devices with a defined instance ID. This avoids +having to keep track of which instance IDs have been used for every +device class. + +Using `smbios_dev_info` when `SMBIOS_TYPE41_PROVIDED_BY_DEVTREE` is not +enabled will result in a build-time error, as the syntax is meaningless +in this case. This is done with preprocessor guards around the Type 41 +members in `struct device` and the code which uses the guarded members. +Although the preprocessor usage isn't particularly elegant, adjusting the +devicetree syntax and/or grammar depending on a Kconfig option is +probably even worse. + +Example: + +```text +device pci 1c.0 on # PCIe Port #1 + device pci 00.0 on + smbios_dev_info 6 + end +end +device pci 1c.1 on # PCIe Port #2 + device pci 00.0 on + smbios_dev_info 42 "PCIe-PCI Time Machine" + end +end +``` + +### smbios_slot_desc + +* Keyword type: smbios +* Introduced in: May of 2019, coreboot version 4.9 +* Usage: `smbios_slot_desc** <type> <length> [designation] [data width]` + +Add the new field 'smbios_slot_desc', which takes 2 to 4 arguments. +The field is only valid for PCI devices and only compiled if SMBIOS +table generation is enabled. + +smbios_slot_desc arguments - described in src/include/smbios.h: + +1. slot type: enum misc_slot_type +2. slot length: enum misc_slot_length +3. slot designation (optional): text string +4. slot data width (optional): enum slot_data_bus_bandwidth + +Example: + +```text +device pci 1c.1 on + smbios_slot_desc "SlotTypePciExpressGen3X16" "SlotLengthOther" "SLOT2" "SlotDataBusWidth8X" +end # PCIe Port #2 Integrated Wireless LAN +``` + +### spi + +* Keyword type: Device type +* Introduced in: February of 2017, coreboot version 4.5 +* Usage: device **SPI** <Identifier> [alias <alias ID>] <status modifier>…. end + +The SPI device takes only one parameter, the chip-select for the device +on the SPI bus. + +Example: + +```text +device spi 0 alias spi_tpm on end +``` + + +### subsystemid + +* Keyword type: Subsystem +* Introduced in: March of 2011, coreboot version 4.0 +* Usage: `subsystemid <vendor> <device> [inherit]` + +Sets a PCI subsystem ID. + +If the user wants to have this ID inherited to all subdevices/functions, +they can add the keyword 'inherit' after the ID. + +If the user doesn't want to inherit the subsystem value for a single +device, they can specify 'subsystemid 0 0' on this particular device. + +Example: + +```text +device pci 00.0 on + subsystemid 0xdead 0xbeef +end +``` + +or + +```text +device pci 00.0 on + subsystemid 0xdead 0xbeef inherit +end +``` + +### usb + +* Keyword type: Device type +* Introduced in: May of 2018, coreboot version 4.7 +* Usage: `device usb <Identifier> [alias <alias ID>] <status modifier> ... end` + +This supports describing USB ports in the devicetree. It allows a USB +port location to be described in the tree with configuration +information, and ACPI code to be generated that provides this +information to the OS. + +The usb symbol works with the scan_usb_bus() operation to scan bridges +for devices so a tree of ports and hubs can be created. + +The device address is computed with a 'port type' and a 'port id' which +is flexible for the SOC to handle depending on their specific USB setup +This also allows USB2 and USB3 ports to be described separately. + +For example a board may have devices on two ports, one with a USB2 +device and one with a USB3 device, both of which are connected to an +xHCI controller with a root hub: + +```text + xHCI + | + RootHub + | | + USB2[0] USB3[2] +``` + +This is described by the following example: + +```text +device pci 14.0 on + chip drivers/usb/acpi + register "name" = ""Root Hub"" + device usb 0.0 on + + chip drivers/usb/acpi + register "name" = ""USB 2.0 Port 0"" + device usb 2.0 on end + end + + chip drivers/usb/acpi + register "name" = ""USB 3.0 Port 2"" + device usb 3.2 on end + end + + end # device usb 0.0 + end # chip drivers/usb/acpi +end # device pci 14.0 +``` + +### use + +* Keyword type: Alias +* Introduced in September of 2020, coreboot version 4.12 +* Usage: `use <Alias ID> as <Alias ID2>` + +The author of the devicetree is free to choose any alias name that is +unique in the devicetree. Later, when configuring the driver for a +board, the alias can be used to link the device with the field of a +driver's config, giving it a specific name. + +Example: + +```text +chip some/chip/driver + use my_eeprom as needed_eeprom +end +``` diff --git a/Documentation/internals/index.md b/Documentation/internals/index.md index 01d5696..17dee55 100644 --- a/Documentation/internals/index.md +++ b/Documentation/internals/index.md @@ -9,5 +9,6 @@ :maxdepth: 1
coreboot devicetree <devicetree.md> +coreboot devicetree language <devicetree_language.md>
