Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/54363 )
Change subject: mb/asus/p8h61-m_pro/Kconfig: Sort selects ......................................................................
In preparation to switch the Asus H61 boards to a variant setup, sort the `select` lines in Kconfig alphabetically.
Change-Id: I96486d57250e901d872e4ef12967c2aadd9791ea Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/54363 Reviewed-by: Patrick Georgi pgeorgi@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/asus/p8h61-m_pro/Kconfig 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/src/mainboard/asus/p8h61-m_pro/Kconfig b/src/mainboard/asus/p8h61-m_pro/Kconfig index d7b0c29..5674549 100644 --- a/src/mainboard/asus/p8h61-m_pro/Kconfig +++ b/src/mainboard/asus/p8h61-m_pro/Kconfig @@ -5,21 +5,21 @@ config BOARD_SPECIFIC_OPTIONS def_bool y select BOARD_ROMSIZE_KB_4096 + select DRIVERS_ASMEDIA_ASPM_BLACKLIST select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES - select NORTHBRIDGE_INTEL_SANDYBRIDGE - select SERIRQ_CONTINUOUS_MODE - select SOUTHBRIDGE_INTEL_BD82X6X - select USE_NATIVE_RAMINIT - select SUPERIO_NUVOTON_NCT6776 - select MAINBOARD_HAS_LIBGFXINIT - select HAVE_OPTION_TABLE select HAVE_CMOS_DEFAULT - select DRIVERS_ASMEDIA_ASPM_BLACKLIST + select HAVE_OPTION_TABLE + select INTEL_GMA_HAVE_VBT + select MAINBOARD_HAS_LIBGFXINIT select MAINBOARD_HAS_LPC_TPM + select NORTHBRIDGE_INTEL_SANDYBRIDGE select REALTEK_8168_RESET select RT8168_SET_LED_MODE - select INTEL_GMA_HAVE_VBT + select SERIRQ_CONTINUOUS_MODE + select SOUTHBRIDGE_INTEL_BD82X6X + select SUPERIO_NUVOTON_NCT6776 + select USE_NATIVE_RAMINIT
config MAINBOARD_DIR string
