Attention is currently required from: Fred Reitberger, Jason Glenesk, Matt DeVillier, Raul Rangel.
Hello Felix Held, Fred Reitberger, Jason Glenesk, Raul Rangel, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/77092?usp=email
Change subject: soc/amd/*: Fix UART ACPI device status ......................................................................
Prior to commit d1c0f958d198 ("acpi: Call acpi_fill_ssdt() only for enabled devices"), uart_inject_ssdt() was used to set the ACPI status (_STA) for both enabled and disabled devices. The aforementioned commit limited it to being called only on enabled devices, which left disabled devices without any _STA method at all -- which the OS assumes means that the device is present and enabled.
To fix this, create the _STA method in the UART asl code for each port, and set the return value to a name variable (STAT) which defaults to 0 (not present/disabled). Then, have uart_inject_ssdt() set STAT to present and enabled (0xF) for UARTs actually present on the board.
TEST=build/boot google/skyrim (frostflow), dump ACPI tables, and verify that _STA returns 0xF only for UARTs enabled in devicetree.
Change-Id: Id89e74c3ea7f53280935898ee35311b7cf3b152a Signed-off-by: Matt DeVillier matt.devillier@amd.corp-partner.google.com --- M src/soc/amd/cezanne/acpi/mmio.asl M src/soc/amd/common/block/uart/uart.c M src/soc/amd/glinda/acpi/mmio.asl M src/soc/amd/mendocino/acpi/mmio.asl M src/soc/amd/phoenix/acpi/mmio.asl M src/soc/amd/picasso/acpi/mmio.asl M src/soc/amd/stoneyridge/acpi/mmio.asl 7 files changed, 132 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/77092/3
