Jérémy Compostella has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84564?usp=email )
Change subject: mb/intel/ptlrvp: Add Intel Panther Lake RVP as copy of google/fatcat ......................................................................
This commit introduces the Intel Panther Lake (PTL) Reference Validation Platform (RVP) mainboard definition. It is aligned with the Google Fatcat mainboard in the coreboot codebase, with the commit hash e2ea7f22c6355d15515c049ca0dc4352173a0c01.
Intel's proprietary platform, commonly referred to as PTLRVP, and Google's Fatcat mainboard share a considerable degree of similarity in their design and capabilities. Nevertheless, Intel faces unique challenges and requires specific board configurations that Google does not. Consequently, there is a necessity for a specialized mainboard tailored to Intel's individual needs.
To maintain consistency with the Fatcat board definition, the Chrome OS Board Information (CBI) firmware configuration aligns with that of Google Fatcat. If necessary, new bits will be appended, starting from the end of the 32-bit firmware configuration field.
BUG=b:398880064 TEST=The Intel PTLRVP board successfully boots to the operating System.
Change-Id: I914f73ff06bfb801fc319b45b23d7ce4cb7a6d60 Signed-off-by: Jeremy Compostella jeremy.compostella@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84564 Reviewed-by: Cliff Huang cliff.huang@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Wonkyu Kim wonkyu.kim@intel.com --- A src/mainboard/intel/ptlrvp/Kconfig A src/mainboard/intel/ptlrvp/Kconfig.name A src/mainboard/intel/ptlrvp/Makefile.mk A src/mainboard/intel/ptlrvp/board_info.txt A src/mainboard/intel/ptlrvp/bootblock.c A src/mainboard/intel/ptlrvp/chromeos.c A src/mainboard/intel/ptlrvp/chromeos.fmd A src/mainboard/intel/ptlrvp/dsdt.asl A src/mainboard/intel/ptlrvp/ec.c A src/mainboard/intel/ptlrvp/mainboard.c A src/mainboard/intel/ptlrvp/romstage.c A src/mainboard/intel/ptlrvp/smihandler.c A src/mainboard/intel/ptlrvp/spd/Makefile.mk A src/mainboard/intel/ptlrvp/variants/baseboard/include/baseboard/variants.h A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/ec.h A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/gpio.h A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/memory.c A src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/ramstage.c A src/mainboard/intel/ptlrvp/variants/ptlrvp/Makefile.mk A src/mainboard/intel/ptlrvp/variants/ptlrvp/fw_config.c A src/mainboard/intel/ptlrvp/variants/ptlrvp/gpio.c A src/mainboard/intel/ptlrvp/variants/ptlrvp/hda_verb.c A src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/ec.h A src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/gpio.h A src/mainboard/intel/ptlrvp/variants/ptlrvp/memory.c A src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/Makefile.mk A src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/dram_id.generated.txt A src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt A src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb A src/mainboard/intel/ptlrvp/variants/ptlrvp/variant.c 32 files changed, 3,070 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Cliff Huang: Looks good to me, approved Wonkyu Kim: Looks good to me, approved
diff --git a/src/mainboard/intel/ptlrvp/Kconfig b/src/mainboard/intel/ptlrvp/Kconfig new file mode 100644 index 0000000..dd60855 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/Kconfig @@ -0,0 +1,144 @@ +## SPDX-License-Identifier: GPL-2.0-only + +config BOARD_INTEL_PTLRVP_COMMON + def_bool n + select BOARD_ROMSIZE_KB_32768 + select DRIVERS_GFX_GENERIC + select DRIVERS_I2C_GENERIC + select DRIVERS_I2C_HID + select DRIVERS_INTEL_DPTF + select DRIVERS_INTEL_MIPI_CAMERA + select DRIVERS_INTEL_PMC + select DRIVERS_INTEL_SOUNDWIRE + select DRIVERS_WWAN_FM350GL + select DRIVERS_AUDIO_SOF + select DRIVERS_SOUNDWIRE_ALC_BASE_7XX + select DRIVERS_SPI_ACPI + select DUMP_SMBIOS_TYPE17 + select EC_ACPI + select EC_GOOGLE_CHROMEEC + select EC_GOOGLE_CHROMEEC_BOARDID + select EC_GOOGLE_CHROMEEC_ESPI + select EC_GOOGLE_CHROMEEC_SKUID + select FW_CONFIG + select FW_CONFIG_SOURCE_CHROMEEC_CBI + select GENERATE_SMBIOS_TABLES + select GOOGLE_SMBIOS_MAINBOARD_VERSION + select HAVE_ACPI_RESUME + select HAVE_ACPI_TABLES + select HAVE_SPD_IN_CBFS + select I2C_TPM + select INTEL_LPSS_UART_FOR_CONSOLE + select MAINBOARD_DISABLE_STAGE_CACHE + select MAINBOARD_HAS_TPM2 + select MB_COMPRESS_RAMSTAGE_LZ4 + select PMC_IPC_ACPI_INTERFACE + select SOC_INTEL_COMMON_BLOCK_VARIANT_POWER_LIMIT + select SOC_INTEL_CSE_LITE_SYNC_BY_PAYLOAD + select SOC_INTEL_CSE_SEND_EOP_BY_PAYLOAD + select SOC_INTEL_PANTHERLAKE_U_H + select SOC_INTEL_TCSS_USE_PDC_PMC_USBC_MUX_CONFIGURATION + +config BOARD_INTEL_BASEBOARD_PTLRVP + def_bool n + select BOARD_INTEL_PTLRVP_COMMON + select CHROMEOS_WIFI_SAR if CHROMEOS + select DRIVERS_INTEL_ISH + select DRIVER_INTEL_ISH_HAS_MAIN_FW + select DRIVERS_INTEL_USB4_RETIMER + select HAVE_SLP_S0_GATE + select MAINBOARD_HAS_CHROMEOS + select MEMORY_SOLDERDOWN + select SOC_INTEL_COMMON_BLOCK_HDA_VERB + select SOC_INTEL_IOE_DIE_SUPPORT + select SOC_INTEL_ENABLE_USB4_PCIE_RESOURCES + select SYSTEM_TYPE_LAPTOP + select TPM_GOOGLE_TI50 + +config BOARD_INTEL_MODEL_PTLRVP + def_bool n + select BOARD_INTEL_BASEBOARD_PTLRVP + select DRIVERS_GENERIC_BAYHUB_LV2 + select DRIVERS_GENERIC_MAX98357A + +config BOARD_INTEL_PTLRVP + select BOARD_INTEL_MODEL_PTLRVP + select EC_GOOGLE_CHROMEEC_MEC + select MAINBOARD_USES_IFD_EC_REGION + +if BOARD_INTEL_PTLRVP_COMMON + +config BASEBOARD_DIR + string + default "ptlrvp" + +config CHROMEOS + select EC_GOOGLE_CHROMEEC_SWITCHES + select GBB_FLAG_DISABLE_EC_SOFTWARE_SYNC + select GBB_FLAG_FORCE_DEV_BOOT_USB + select GBB_FLAG_FORCE_MANUAL_RECOVERY + select HAS_RECOVERY_MRC_CACHE + +config CHROMEOS_WIFI_SAR + bool "Enable SAR options for ChromeOS build" + depends on CHROMEOS + select DSAR_ENABLE + select GEO_SAR_ENABLE + select SAR_ENABLE + select USE_SAR + +config DEVICETREE + default "variants/baseboard/$(CONFIG_BASEBOARD_DIR)/devicetree.cb" + +config DIMM_SPD_SIZE + default 512 + +config DRIVER_TPM_I2C_ADDR + hex + default 0x50 + +config DRIVER_TPM_I2C_BUS + hex + default 0x03 if BOARD_INTEL_MODEL_PTLRVP + +config HAVE_SLP_S0_GATE + def_bool n + +config MAINBOARD_DIR + default "intel/ptlrvp" + +config MAINBOARD_FAMILY + string + default "Intel_Ptlrvp" + +config MAINBOARD_PART_NUMBER + default "Ptlrvp" if BOARD_INTEL_PTLRVP + +config MEMORY_SOLDERDOWN + def_bool n + select CHROMEOS_DRAM_PART_NUMBER_IN_CBI if CHROMEOS + select HAVE_SPD_IN_CBFS + +config TPM_TIS_ACPI_INTERRUPT + int + default 47 if BOARD_INTEL_MODEL_PTLRVP # GPE0_DW1_15 (GPP_D15) + +# FIXME: update as per board schematics +config UART_FOR_CONSOLE + int + default 0 + +config USE_PM_ACPI_TIMER + default n + +config VARIANT_DIR + string + default "ptlrvp" if BOARD_INTEL_MODEL_PTLRVP + +config OVERRIDE_DEVICETREE + default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" + +config VBOOT + select VBOOT_LID_SWITCH + +endif # BOARD_INTEL_PTLRVP_COMMON diff --git a/src/mainboard/intel/ptlrvp/Kconfig.name b/src/mainboard/intel/ptlrvp/Kconfig.name new file mode 100644 index 0000000..f8d8f17 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/Kconfig.name @@ -0,0 +1,6 @@ +## SPDX-License-Identifier: GPL-2.0-only + +comment "Ptlrvp" + +config BOARD_INTEL_PTLRVP + bool "-> Ptlrvp" diff --git a/src/mainboard/intel/ptlrvp/Makefile.mk b/src/mainboard/intel/ptlrvp/Makefile.mk new file mode 100644 index 0000000..aea91d5 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/Makefile.mk @@ -0,0 +1,26 @@ +## SPDX-License-Identifier: GPL-2.0-only + +bootblock-y += bootblock.c + +verstage-$(CONFIG_CHROMEOS) += chromeos.c + +romstage-y += romstage.c +romstage-$(CONFIG_CHROMEOS) += chromeos.c + +ramstage-y += mainboard.c +ramstage-$(CONFIG_CHROMEOS) += chromeos.c +ramstage-y += ec.c +ramstage-$(CONFIG_SOC_INTEL_COMMON_BLOCK_HDA_VERB) += variants/$(VARIANT_DIR)/hda_verb.c + +smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c + +BASEBOARD_DIR:=$(call strip_quotes,$(CONFIG_BASEBOARD_DIR)) + +subdirs-y += variants/baseboard/$(BASEBOARD_DIR) +subdirs-y += variants/$(VARIANT_DIR) +subdirs-y += variants/$(VARIANT_DIR)/memory +subdirs-$(CONFIG_HAVE_SPD_IN_CBFS) += spd + +CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/variants/baseboard/include +CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/variants/baseboard/$(BASEBOARD_DIR)/include +CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/include diff --git a/src/mainboard/intel/ptlrvp/board_info.txt b/src/mainboard/intel/ptlrvp/board_info.txt new file mode 100644 index 0000000..c7de62f --- /dev/null +++ b/src/mainboard/intel/ptlrvp/board_info.txt @@ -0,0 +1,6 @@ +Vendor name: Intel +Board name: Ptlrvp +Category: laptop +ROM protocol: SPI +ROM socketed: n +Flashrom support: y diff --git a/src/mainboard/intel/ptlrvp/bootblock.c b/src/mainboard/intel/ptlrvp/bootblock.c new file mode 100644 index 0000000..6ee655e --- /dev/null +++ b/src/mainboard/intel/ptlrvp/bootblock.c @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/variants.h> +#include <bootblock_common.h> + +void bootblock_mainboard_early_init(void) +{ + const struct pad_config *pads; + size_t num; + + pads = variant_early_gpio_table(&num); + gpio_configure_pads(pads, num); +} diff --git a/src/mainboard/intel/ptlrvp/chromeos.c b/src/mainboard/intel/ptlrvp/chromeos.c new file mode 100644 index 0000000..5ed041f --- /dev/null +++ b/src/mainboard/intel/ptlrvp/chromeos.c @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/gpio.h> +#include <bootmode.h> +#include <boot/coreboot_tables.h> +#include <gpio.h> +#include <types.h> + +void fill_lb_gpios(struct lb_gpios *gpios) +{ + struct lb_gpio chromeos_gpios[] = { +#if CONFIG(VBOOT_LID_SWITCH) + {-1, ACTIVE_HIGH, get_lid_switch(), "lid"}, +#else + /* fake LID open to avoid shutdown in depthcharge */ + {-1, ACTIVE_HIGH, 1, "lid"}, +#endif + {-1, ACTIVE_HIGH, 0, "power"}, + {-1, ACTIVE_HIGH, gfx_get_init_done(), "oprom"}, + {-1, ACTIVE_HIGH, 0, "EC in RW"}, + }; + lb_add_gpios(gpios, chromeos_gpios, ARRAY_SIZE(chromeos_gpios)); +} + +int get_write_protect_state(void) +{ + return gpio_get(GPIO_PCH_WP); +} + +int get_ec_is_trusted(void) +{ + /* VB2_CONTEXT_EC_TRUSTED should be set according to the Ti50 boot mode. */ + return 0; +} diff --git a/src/mainboard/intel/ptlrvp/chromeos.fmd b/src/mainboard/intel/ptlrvp/chromeos.fmd new file mode 100644 index 0000000..693f485 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/chromeos.fmd @@ -0,0 +1,50 @@ +FLASH 32M { + SI_ALL 8M { + SI_DESC 16K + SI_EC 576K + SI_ME + } + SI_BIOS 24M { + RW_SECTION_A 8M { + VBLOCK_A 8K + FW_MAIN_A(CBFS) + RW_FWID_A 64 + } + # This section starts at the 16M boundary in SPI flash. + # PTL does not support a region crossing this boundary, + # because the SPI flash is memory-mapped into two non- + # contiguous windows. + RW_SECTION_B 8M { + VBLOCK_B 8K + FW_MAIN_B(CBFS) + RW_FWID_B 64 + } + RW_MISC 1M { + UNIFIED_MRC_CACHE(PRESERVE) 128K { + RECOVERY_MRC_CACHE 64K + RW_MRC_CACHE 64K + } + RW_ELOG(PRESERVE) 16K + RW_SHARED 16K { + SHARED_DATA 8K + VBLOCK_DEV 8K + } + RW_VPD(PRESERVE) 8K + RW_NVRAM(PRESERVE) 24K + } + RW_LEGACY(CBFS) 1M + RW_UNUSED 2M + # Make WP_RO region align with SPI vendor + # memory protected range specification. + WP_RO 4M { + RO_VPD(PRESERVE) 16K + RO_GSCVD 8K + RO_SECTION { + FMAP 2K + RO_FRID 64 + GBB@4K 12K + COREBOOT(CBFS) + } + } + } +} diff --git a/src/mainboard/intel/ptlrvp/dsdt.asl b/src/mainboard/intel/ptlrvp/dsdt.asl new file mode 100644 index 0000000..03882c6 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/dsdt.asl @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpi.h> +#include <variant/ec.h> +#include <variant/gpio.h> + +DefinitionBlock( + "dsdt.aml", + "DSDT", + ACPI_DSDT_REV_2, + OEM_ID, + ACPI_TABLE_CREATOR, + 0x20240917 +) +{ + #include <acpi/dsdt_top.asl> + #include <soc/intel/common/block/acpi/acpi/platform.asl> + + /* global NVS and variables */ + #include <soc/intel/common/block/acpi/acpi/globalnvs.asl> + + #include <cpu/intel/common/acpi/cpu.asl> + + Device (_SB.PCI0) { + #include <soc/intel/common/block/acpi/acpi/northbridge.asl> + #include <soc/intel/pantherlake/acpi/southbridge.asl> + #include <soc/intel/pantherlake/acpi/tcss.asl> + } + +#if CONFIG(EC_GOOGLE_CHROMEEC) + /* ChromeOS Embedded Controller */ + Scope (_SB.PCI0.LPCB) + { + /* ACPI code for EC SuperIO functions */ + #include <ec/google/chromeec/acpi/superio.asl> + /* ACPI code for EC functions */ + #include <ec/google/chromeec/acpi/ec.asl> + } +#endif + + #include <southbridge/intel/common/acpi/sleepstates.asl> +} diff --git a/src/mainboard/intel/ptlrvp/ec.c b/src/mainboard/intel/ptlrvp/ec.c new file mode 100644 index 0000000..f828bc5 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/ec.c @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpi.h> +#include <console/console.h> +#include <ec/ec.h> +#include <ec/google/chromeec/ec.h> +#include <variant/ec.h> + +void mainboard_ec_init(void) +{ + static const struct google_chromeec_event_info info = { + .log_events = MAINBOARD_EC_LOG_EVENTS, + .sci_events = MAINBOARD_EC_SCI_EVENTS, + .s3_wake_events = MAINBOARD_EC_S3_WAKE_EVENTS, + .s5_wake_events = MAINBOARD_EC_S5_WAKE_EVENTS, + .s0ix_wake_events = MAINBOARD_EC_S0IX_WAKE_EVENTS, + }; + + printk(BIOS_DEBUG, "mainboard: EC init\n"); + + google_chromeec_events_init(&info, acpi_is_wakeup_s3()); +} diff --git a/src/mainboard/intel/ptlrvp/mainboard.c b/src/mainboard/intel/ptlrvp/mainboard.c new file mode 100644 index 0000000..f514eb9 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/mainboard.c @@ -0,0 +1,74 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpi.h> +#include <acpi/acpigen.h> +#include <baseboard/gpio.h> +#include <baseboard/variants.h> +#include <device/device.h> +#include <ec/ec.h> +#include <soc/ramstage.h> +#include <stdlib.h> +#include <vendorcode/google/chromeos/chromeos.h> + +void __weak fw_config_gpio_padbased_override(struct pad_config *padbased_table) +{ + /* default implementation does nothing */ +} + +void mainboard_update_soc_chip_config(struct soc_intel_pantherlake_config *config) +{ + variant_update_soc_chip_config(config); +} + +void __weak variant_update_soc_chip_config(struct soc_intel_pantherlake_config *config) +{ + /* default implementation does nothing */ +} + +static void mainboard_init(void *chip_info) +{ + struct pad_config *padbased_table; + const struct pad_config *base_pads; + size_t base_num; + + padbased_table = new_padbased_table(); + base_pads = variant_gpio_table(&base_num); + gpio_padbased_override(padbased_table, base_pads, base_num); + fw_config_gpio_padbased_override(padbased_table); + gpio_configure_pads_with_padbased(padbased_table); + free(padbased_table); + baseboard_devtree_update(); +} + +void __weak baseboard_devtree_update(void) +{ + /* Override dev tree settings per baseboard */ +} + +void __weak variant_generate_s0ix_hook(enum s0ix_entry entry) +{ + /* Add board-specific MS0X entries */ + /* + if (s0ix_entry == S0IX_ENTRY) { + implement variant operations here + } + if (s0ix_entry == S0IX_EXIT) { + implement variant operations here + } + */ +} + +static void mainboard_dev_init(struct device *dev) +{ + mainboard_ec_init(); +} + +static void mainboard_enable(struct device *dev) +{ + dev->ops->init = mainboard_dev_init; +} + +struct chip_operations mainboard_ops = { + .init = mainboard_init, + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/intel/ptlrvp/romstage.c b/src/mainboard/intel/ptlrvp/romstage.c new file mode 100644 index 0000000..7b56e28 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/romstage.c @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/variants.h> +#include <fsp/api.h> +#include <soc/romstage.h> +#include <string.h> + +/* + * Placeholder to configure GPIO early from romstage relying on the FW_CONFIG. + * + * If any platform would like to override early GPIOs, they should override from + * the variant directory. + */ +__weak void fw_config_configure_pre_mem_gpio(void) +{ + /* Nothing to do */ +} + +void mainboard_memory_init_params(FSPM_UPD *memupd) +{ + const struct pad_config *pads; + size_t pads_num; + const struct mb_cfg *mem_config = variant_memory_params(); + bool half_populated = variant_is_half_populated(); + struct mem_spd spd_info; + + pads = variant_romstage_gpio_table(&pads_num); + if (pads_num) + gpio_configure_pads(pads, pads_num); + fw_config_configure_pre_mem_gpio(); + + memset(&spd_info, 0, sizeof(spd_info)); + variant_get_spd_info(&spd_info); + + memcfg_init(memupd, mem_config, &spd_info, half_populated); +} diff --git a/src/mainboard/intel/ptlrvp/smihandler.c b/src/mainboard/intel/ptlrvp/smihandler.c new file mode 100644 index 0000000..9208d51 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/smihandler.c @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <cpu/x86/smm.h> +#include <ec/google/chromeec/ec.h> +#include <ec/google/chromeec/smm.h> +#include <elog.h> +#include <intelblocks/smihandler.h> +#include <variant/ec.h> + +void mainboard_smi_sleep(u8 slp_typ) +{ + chromeec_smi_sleep(slp_typ, MAINBOARD_EC_S3_WAKE_EVENTS, MAINBOARD_EC_S5_WAKE_EVENTS); +} + +int mainboard_smi_apmc(u8 apmc) +{ + chromeec_smi_apmc(apmc, MAINBOARD_EC_SCI_EVENTS, MAINBOARD_EC_SMI_EVENTS); + return 0; +} + +void elog_gsmi_cb_mainboard_log_wake_source(void) +{ + google_chromeec_log_events(MAINBOARD_EC_LOG_EVENTS | MAINBOARD_EC_S0IX_WAKE_EVENTS); +} + +void mainboard_smi_espi_handler(void) +{ + chromeec_smi_process_events(); +} diff --git a/src/mainboard/intel/ptlrvp/spd/Makefile.mk b/src/mainboard/intel/ptlrvp/spd/Makefile.mk new file mode 100644 index 0000000..be4d98b --- /dev/null +++ b/src/mainboard/intel/ptlrvp/spd/Makefile.mk @@ -0,0 +1,6 @@ +## SPDX-License-Identifier: GPL-2.0-or-later +## + +ifneq ($(SPD_SOURCES),) +LIB_SPD_DEPS := $(SPD_SOURCES) +endif diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/include/baseboard/variants.h b/src/mainboard/intel/ptlrvp/variants/baseboard/include/baseboard/variants.h new file mode 100644 index 0000000..2a70408 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/include/baseboard/variants.h @@ -0,0 +1,40 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __BASEBOARD_VARIANTS_H__ +#define __BASEBOARD_VARIANTS_H__ + +#include <chip.h> +#include <soc/gpio.h> +#include <soc/meminit.h> +#include <stdint.h> +#include <vendorcode/google/chromeos/chromeos.h> + +/* The next set of functions return the gpio table and fill in the number of entries for + * each table. + */ + +const struct pad_config *variant_gpio_table(size_t *num); +const struct pad_config *variant_early_gpio_table(size_t *num); +const struct pad_config *variant_romstage_gpio_table(size_t *num); +void fw_config_configure_pre_mem_gpio(void); +void fw_config_gpio_padbased_override(struct pad_config *padbased_table); + +const struct mb_cfg *variant_memory_params(void); +void variant_get_spd_info(struct mem_spd *spd_info); +int variant_memory_sku(void); +bool variant_is_half_populated(void); +void variant_update_soc_chip_config(struct soc_intel_pantherlake_config *config); + +enum s0ix_entry { + S0IX_EXIT, + S0IX_ENTRY, +}; + +void variant_generate_s0ix_hook(enum s0ix_entry entry); + +/* Modify devictree settings during ramstage by baseboard */ +void baseboard_devtree_update(void); +/* Modify devictree settings during ramstage by dedicated variant */ +void variant_devtree_update(void); + +#endif /*__BASEBOARD_VARIANTS_H__ */ diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk new file mode 100644 index 0000000..47123cd --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/Makefile.mk @@ -0,0 +1,4 @@ +## SPDX-License-Identifier: GPL-2.0-only + +romstage-y += memory.c +ramstage-y += ramstage.c diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb new file mode 100644 index 0000000..2cf249f9 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/devicetree.cb @@ -0,0 +1,99 @@ +chip soc/intel/pantherlake + # GPE configuration + register "pmc_gpe0_dw0" = "GPP_A" + register "pmc_gpe0_dw1" = "GPP_D" + register "pmc_gpe0_dw2" = "GPP_E" + + # For Ptlrvp variants with microchip EC: + # EC host command ranges are in 0x800-0x807 & 0x200-0x20f + # For Ptlrvp variants with ITE/Nuvoton EC: + # EC host command ranges are in 0x800-0x8ff & 0x200-0x20f + register "gen1_dec" = "CONFIG(BOARD_INTEL_PTLRVP) ? 0x00040801 : 0x00fc0801" + register "gen2_dec" = "0x000c0201" + # EC memory map range is 0x900-0x9ff + register "gen3_dec" = "0x00fc0901" + + register "usb2_ports[0]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 0 + register "usb2_ports[1]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 1 + register "usb2_ports[2]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 2 + register "usb2_ports[3]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 3 + register "usb2_ports[4]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 4 + register "usb2_ports[5]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 5 + register "usb2_ports[6]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 6 + register "usb2_ports[7]" = "USB2_PORT_EMPTY" # Disable USB2.0 Port 7 + + register "usb3_ports[0]" = "USB3_PORT_EMPTY" # Disable USB3.0 Port 0 + register "usb3_ports[1]" = "USB3_PORT_EMPTY" # Disable USB3.0 Port 1 + + register "tcss_ports[0]" = "TCSS_PORT_EMPTY" # Disable USB-C Port 0 + register "tcss_ports[1]" = "TCSS_PORT_EMPTY" # Disable USB-C Port 1 + register "tcss_ports[2]" = "TCSS_PORT_EMPTY" # Disable USB-C Port 2 + register "tcss_ports[3]" = "TCSS_PORT_EMPTY" # Disable USB-C Port 3 + + # Enable SAGv + register "sagv" = "SAGV_ENABLED" + + register "sagv_freq_mhz[0]" = "2400" + register "sagv_gear[0]" = "GEAR_4" + + register "sagv_freq_mhz[1]" = "3200" + register "sagv_gear[1]" = "GEAR_4" + + register "sagv_freq_mhz[2]" = "6000" + register "sagv_gear[2]" = "GEAR_4" + + register "sagv_freq_mhz[3]" = "6400" + register "sagv_gear[3]" = "GEAR_4" + + # Enable s0ix + register "s0ix_enable" = "true" + + # DPTF enable + register "dptf_enable" = "true" + + # Setting TCC of 100C = Tj max (110) - TCC_Offset (10) + register "tcc_offset" = "10" + + # Disable C1 C-state auto-demotion + register "disable_c1_state_auto_demotion" = "true" + # Disable PKGC-state auto-demotion + register "disable_package_c_state_demotion" = "true" + + # Enable Energy Reporting + register "pch_pm_energy_report_enable" = "true" + + # Enable CNVi BT + register "cnvi_bt_core" = "true" + + register "serial_io_uart_mode" = "{ + [PchSerialIoIndexUART0] = PchSerialIoSkipInit, + [PchSerialIoIndexUART1] = PchSerialIoDisabled, + [PchSerialIoIndexUART2] = PchSerialIoDisabled, + }" + + register "serial_io_gspi_mode" = "{ + [PchSerialIoIndexGSPI0] = PchSerialIoPci, + [PchSerialIoIndexGSPI1] = PchSerialIoPci, + [PchSerialIoIndexGSPI0A] = PchSerialIoPci, + }" + + register "pch_hda_dsp_enable" = "true" + register "pch_hda_idisp_link_tmode" = "HDA_TMODE_8T" + register "pch_hda_idisp_link_frequency" = "HDA_LINKFREQ_96MHZ" + register "pch_hda_idisp_codec_enable" = "true" + register "pch_hda_sdi_enable" = "{ true, false }" + + device domain 0 on + device ref dtt on end + device ref npu on end + device ref xhci on end + device ref pmc_shared_sram on end + device ref heci1 on end + device ref uart0 on end + device ref soc_espi on + chip ec/google/chromeec + device pnp 0c09.0 on end + end + end + end +end diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/ec.h b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/ec.h new file mode 100644 index 0000000..f3e31b0 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/ec.h @@ -0,0 +1,82 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __BASEBOARD_EC_H__ +#define __BASEBOARD_EC_H__ + +#include <baseboard/gpio.h> +#include <ec/ec.h> +#include <ec/google/chromeec/ec_commands.h> + +#define MAINBOARD_EC_SCI_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_CONNECTED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_DISCONNECTED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_CRITICAL) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_LOW) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_STATUS) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_MKBP) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_MODE_CHANGE) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_PD_MCU) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_THRESHOLD) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_START) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_STOP) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_USB_MUX)) +#define MAINBOARD_EC_SMI_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED)) +/* EC can wake from S5 with lid or power button */ +#define MAINBOARD_EC_S5_WAKE_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_POWER_BUTTON)) +/* + * EC can wake from S3/S0ix with: + * 1. Lid open + * 2. AC Connect/Disconnect + * 3. Power button + * 4. Key press + * 5. Mode change + * 6. Low battery + */ +#define MAINBOARD_EC_S3_WAKE_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_CONNECTED) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_DISCONNECTED) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_CRITICAL) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_SHUTDOWN) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_KEY_PRESSED) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_MODE_CHANGE) | \ + MAINBOARD_EC_S5_WAKE_EVENTS) +#define MAINBOARD_EC_S0IX_WAKE_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_HANG_DETECT) | \ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_USB_MUX) | \ + MAINBOARD_EC_S3_WAKE_EVENTS) +/* Log EC wake events plus EC shutdown events */ +#define MAINBOARD_EC_LOG_EVENTS \ + (EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_SHUTDOWN) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_PANIC) |\ + EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_SHUTDOWN)) +/* + * ACPI related definitions for ASL code. + */ + +/* Enable EC backed ALS device in ACPI */ +#define EC_ENABLE_ALS_DEVICE + +/* Enable Keyboard Backlight */ +#define EC_ENABLE_KEYBOARD_BACKLIGHT + +/* Enable LID switch and provide wake pin for EC */ +#define EC_ENABLE_LID_SWITCH +#define EC_ENABLE_WAKE_PIN GPE_EC_WAKE + +/* Enable MKBP for buttons and switches */ +#define EC_ENABLE_MKBP_DEVICE + +/* Enable EC backed PD MCU device in ACPI */ +#define EC_ENABLE_PD_MCU_DEVICE + +#define SIO_EC_ENABLE_PS2K /* Enable PS/2 Keyboard */ +#define SIO_EC_HOST_ENABLE /* EC Host Interface Resources */ +#define SIO_EC_MEMMAP_ENABLE /* EC Memory Map Resources */ + +#endif /* __BASEBOARD_EC_H__ */ diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/gpio.h b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/gpio.h new file mode 100644 index 0000000..5a77e4e --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/include/baseboard/gpio.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __BASEBOARD_GPIO_H__ +#define __BASEBOARD_GPIO_H__ + +#include <soc/gpe.h> +#include <soc/gpio.h> + +/* FIXME: update below code as per board schematics */ +/* eSPI virtual wire reporting */ +#define EC_SCI_GPI GPE0_ESPI +/* GPIO IRQ for tight timestamps / wake support */ +#define EC_SYNC_IRQ 0 +/* WP signal to PCH */ +#define GPIO_PCH_WP 0 + +#endif /* __BASEBOARD_GPIO_H__ */ diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/memory.c b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/memory.c new file mode 100644 index 0000000..4f621f3 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/memory.c @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-3.0-or-later */ + +#include <baseboard/variants.h> + +static const struct mb_cfg baseboard_memcfg = { + .type = MEM_TYPE_LP5X, + + /* TODO: Add Memory configuration */ + .ect = 1, /* Early Command Training */ +}; + +const struct mb_cfg *__weak variant_memory_params(void) +{ + return &baseboard_memcfg; +} + +int __weak variant_memory_sku(void) +{ + return 0; +} + +bool __weak variant_is_half_populated(void) +{ + return 0; +} + +void __weak variant_get_spd_info(struct mem_spd *spd_info) +{ + spd_info->topo = MEM_TOPO_MEMORY_DOWN; + spd_info->cbfs_index = variant_memory_sku(); +} diff --git a/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/ramstage.c b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/ramstage.c new file mode 100644 index 0000000..030b587 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/baseboard/ptlrvp/ramstage.c @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/variants.h> +#include <ec/google/chromeec/ec.h> + +/* + * SKU_ID, TDP (Watts), pl1_min (milliWatts), pl1_max (milliWatts), + * pl2_min (milliWatts), pl2_max (milliWatts), pl4 (milliWatts) + */ +const struct cpu_tdp_power_limits power_optimized_limits[] = { + { + .mch_id = PCI_DID_INTEL_PTL_H_ID_1, + .cpu_tdp = TDP_25W, + .power_limits_index = PTL_H_1_CORE, + .pl1_min_power = 10000, + .pl1_max_power = 25000, + .pl2_min_power = 50000, + .pl2_max_power = 50000, + .pl4_power = 65000 + }, + { + .mch_id = PCI_DID_INTEL_PTL_H_ID_2, + .cpu_tdp = TDP_25W, + .power_limits_index = PTL_H_1_CORE, + .pl1_min_power = 10000, + .pl1_max_power = 25000, + .pl2_min_power = 50000, + .pl2_max_power = 50000, + .pl4_power = 65000 + }, + { + .mch_id = PCI_DID_INTEL_PTL_H_ID_3, + .cpu_tdp = TDP_25W, + .power_limits_index = PTL_H_2_CORE, + .pl1_min_power = 10000, + .pl1_max_power = 25000, + .pl2_min_power = 50000, + .pl2_max_power = 50000, + .pl4_power = 65000 + }, + { + .mch_id = PCI_DID_INTEL_PTL_H_ID_4, + .cpu_tdp = TDP_25W, + .power_limits_index = PTL_H_2_CORE, + .pl1_min_power = 10000, + .pl1_max_power = 25000, + .pl2_min_power = 50000, + .pl2_max_power = 50000, + .pl4_power = 65000 + }, +}; + +void baseboard_devtree_update(void) +{ + /* Don't optimize the power limit if booting with barrel attached */ + if (google_chromeec_is_barrel_charger_present()) + return; + + if (!google_chromeec_is_battery_present()) + variant_update_cpu_power_limits(power_optimized_limits, + ARRAY_SIZE(power_optimized_limits)); +} diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/Makefile.mk b/src/mainboard/intel/ptlrvp/variants/ptlrvp/Makefile.mk new file mode 100644 index 0000000..eb361df --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/Makefile.mk @@ -0,0 +1,9 @@ +## SPDX-License-Identifier: GPL-2.0-only + +bootblock-y += gpio.c +romstage-y += gpio.c +romstage-y += memory.c +romstage-$(CONFIG_FW_CONFIG) += fw_config.c +ramstage-y += gpio.c +ramstage-$(CONFIG_FW_CONFIG) += variant.c +ramstage-$(CONFIG_FW_CONFIG) += fw_config.c diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/fw_config.c b/src/mainboard/intel/ptlrvp/variants/ptlrvp/fw_config.c new file mode 100644 index 0000000..9419caf --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/fw_config.c @@ -0,0 +1,651 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <baseboard/variants.h> +#include <console/console.h> +#include <fw_config.h> +#include <gpio.h> +#include <inttypes.h> + +/* t: base table; o: override table */ +#define GPIO_PADBASED_OVERRIDE(t, o) gpio_padbased_override(t, o, ARRAY_SIZE(o)) +/* t: table */ +#define GPIO_CONFIGURE_PADS(t) gpio_configure_pads(t, ARRAY_SIZE(t)) + +static const struct pad_config i2s_enable_pads[] = { + /* I2S_MCLK1_OUT */ + PAD_CFG_NF(GPP_D09, NONE, DEEP, NF2), + /* I2S0_SCLK_HDR */ + PAD_CFG_NF(GPP_D10, NONE, DEEP, NF2), + /* I2S0_SFRM_HDR */ + PAD_CFG_NF(GPP_D11, NONE, DEEP, NF2), + /* I2S0_TXD_HDR */ + PAD_CFG_NF(GPP_D12, NONE, DEEP, NF2), + /* I2S0_RXD_HDR */ + PAD_CFG_NF(GPP_D13, NONE, DEEP, NF2), + /* I2S1_SCLK_HDR */ + PAD_CFG_NF(GPP_S00, NONE, DEEP, NF6), + /* I2S1_SFRM_HDR */ + PAD_CFG_NF(GPP_S01, NONE, DEEP, NF6), + /* I2S1_TXD_HDR */ + PAD_CFG_NF(GPP_S02, NONE, DEEP, NF6), + /* I2S1_RXD_HDR */ + PAD_CFG_NF(GPP_S03, NONE, DEEP, NF6), + + /* DMIC_CLK */ + PAD_CFG_NF(GPP_D16, NONE, DEEP, NF3), + /* DMIC_DATA */ + PAD_CFG_NF(GPP_D17, NONE, DEEP, NF3), + + /* DMIC_CLK */ + PAD_CFG_NF(GPP_S04, NONE, DEEP, NF5), + /* DMIC_DATA */ + PAD_CFG_NF(GPP_S05, NONE, DEEP, NF5), +}; + +static const struct pad_config hda_enable_pads[] = { + /* HDA_BCLK */ + PAD_CFG_NF(GPP_D10, NONE, DEEP, NF1), + /* HDA_SYNC */ + PAD_CFG_NF(GPP_D11, NATIVE, DEEP, NF1), + /* HDA_SDO */ + PAD_CFG_NF(GPP_D12, NATIVE, DEEP, NF1), + /* HDA_SDI_0 */ + PAD_CFG_NF(GPP_D13, NATIVE, DEEP, NF1), + /* HDA_RST_B */ + PAD_CFG_NF(GPP_D16, NONE, DEEP, NF1), + /* HDA_SDI_1 */ + PAD_CFG_NF(GPP_D17, NATIVE, DEEP, NF1), + + /* DMIC_CLK */ + PAD_CFG_NF(GPP_S04, NONE, DEEP, NF5), + /* DMIC_DATA */ + PAD_CFG_NF(GPP_S05, NONE, DEEP, NF5), +}; + +static const struct pad_config sndw_external_codec_enable_pads[] = { + /* Soundwire - External codec - JE Header */ + /* SNDW3_CLK */ + PAD_CFG_NF(GPP_S00, NONE, DEEP, NF1), + /* SNDW3_DATA0 */ + PAD_CFG_NF(GPP_S01, NONE, DEEP, NF1), + /* SNDW0_CLK */ + PAD_CFG_NF(GPP_S02, NONE, DEEP, NF3), + /* SNDW0_DATA */ + PAD_CFG_NF(GPP_S03, NONE, DEEP, NF3), + /* SNDW2_CLK */ + PAD_CFG_NF(GPP_S04, NONE, DEEP, NF2), + /* SNDW2_DATA */ + PAD_CFG_NF(GPP_S05, NONE, DEEP, NF2), + /* SNDW1_CLK */ + PAD_CFG_NF(GPP_S06, NONE, DEEP, NF3), + /* SNDW1_DATA */ + PAD_CFG_NF(GPP_S07, NONE, DEEP, NF3), + + /* GPP_D13: RST_HP_L */ + PAD_CFG_GPO(GPP_D13, 1, PLTRST), +}; + +static const struct pad_config bt_i2s_enable_pads[] = { + /* GPP_V30 : [] ==> BT_I2S_BCLK - SSP2 */ + PAD_CFG_NF(GPP_VGPIO30, NONE, DEEP, NF3), + /* GPP_V31 : [] ==> BT_I2S_SYNC - SSP2 */ + PAD_CFG_NF(GPP_VGPIO31, NONE, DEEP, NF3), + /* GPP_V32 : [] ==> BT_I2S_SDO - SSP2 */ + PAD_CFG_NF(GPP_VGPIO32, NONE, DEEP, NF3), + /* GPP_V33 : [] ==> BT_I2S_SDI - SSP2 */ + PAD_CFG_NF(GPP_VGPIO33, NONE, DEEP, NF3), + /* GPP_V34 : [] ==> SSP_SCLK */ + PAD_CFG_NF(GPP_VGPIO34, NONE, DEEP, NF1), + /* GPP_V35 : [] ==> SSP_SFRM */ + PAD_CFG_NF(GPP_VGPIO35, NONE, DEEP, NF1), + /* GPP_V36 : [] ==> SSP_TXD */ + PAD_CFG_NF(GPP_VGPIO36, NONE, DEEP, NF1), + /* GPP_V37 : [] ==> SSP_RXD */ + PAD_CFG_NF(GPP_VGPIO37, NONE, DEEP, NF1), +}; + +static const struct pad_config bt_i2s_disable_pads[] = { + /* GPP_V30 : [] ==> BT_I2S_BCLK */ + PAD_NC(GPP_VGPIO30, NONE), + /* GPP_V31 : [] ==> BT_I2S_SYNC */ + PAD_NC(GPP_VGPIO31, NONE), + /* GPP_V32 : [] ==> BT_I2S_SDO */ + PAD_NC(GPP_VGPIO32, NONE), + /* GPP_V33 : [] ==> BT_I2S_SDI */ + PAD_NC(GPP_VGPIO33, NONE), + /* GPP_V34 : [] ==> SSP2_SCLK */ + PAD_NC(GPP_VGPIO34, NONE), + /* GPP_V35 : [] ==> SSP2_SFRM */ + PAD_NC(GPP_VGPIO35, NONE), + /* GPP_V36 : [] ==> SSP_TXD */ + PAD_NC(GPP_VGPIO36, NONE), + /* GPP_V37 : [] ==> SSP_RXD */ + PAD_NC(GPP_VGPIO37, NONE), +}; + +static const struct pad_config sndw_alc722_enable_pads[] = { + /* SNDW3_CLK */ + PAD_CFG_NF(GPP_S00, NONE, DEEP, NF1), + /* SNDW3_DATA0 */ + PAD_CFG_NF(GPP_S01, NONE, DEEP, NF1), + /* SNDW3_DATA1 */ + PAD_CFG_NF(GPP_S02, NONE, DEEP, NF1), + /* SNDW3_DATA2 */ + PAD_CFG_NF(GPP_S03, NONE, DEEP, NF1), + /* DMIC_CLK_A0 */ + PAD_CFG_NF(GPP_S04, NONE, DEEP, NF5), + /* DMIC_DATA_0 */ + PAD_CFG_NF(GPP_S05, NONE, DEEP, NF5), + /* SNDW1_CLK */ + PAD_CFG_NF(GPP_S06, NONE, DEEP, NF3), + /* SNDW1_DATA */ + PAD_CFG_NF(GPP_S07, NONE, DEEP, NF3), + + /* DMIC_CLK */ + PAD_CFG_NF(GPP_D16, NONE, DEEP, NF3), + /* DMIC_DATA */ + PAD_CFG_NF(GPP_D17, NONE, DEEP, NF3), +}; + +static const struct pad_config audio_disable_pads[] = { + PAD_NC(GPP_S00, NONE), + PAD_NC(GPP_S01, NONE), + PAD_NC(GPP_S02, NONE), + PAD_NC(GPP_S03, NONE), + PAD_NC(GPP_S04, NONE), + PAD_NC(GPP_S05, NONE), + PAD_NC(GPP_S06, NONE), + PAD_NC(GPP_S07, NONE), + PAD_NC(GPP_D09, NONE), + PAD_NC(GPP_D10, NONE), + PAD_NC(GPP_D11, NONE), + PAD_NC(GPP_D12, NONE), + PAD_NC(GPP_D13, NONE), + PAD_NC(GPP_D16, NONE), + PAD_NC(GPP_D17, NONE), +}; + +static const struct pad_config pre_mem_x1slot_pads[] = { + /* GPP_A08: X1_PCIE_SLOT_PWR_EN */ + PAD_CFG_GPO(GPP_A08, 0, PLTRST), +}; +static const struct pad_config x1slot_pads[] = { + /* GPP_A08: X1_PCIE_SLOT_PWR_EN */ + PAD_CFG_GPO(GPP_A08, 1, PLTRST), + /* GPP_D19: X1_DT_PCIE_RST_N */ + PAD_CFG_GPO(GPP_D19, 1, PLTRST), + /* GPP_B25: X1_SLOT_WAKE_N */ + PAD_CFG_GPI_SCI_LOW(GPP_B25, NONE, DEEP, LEVEL), +}; + +static const struct pad_config x1slot_disable_pads[] = { + /* GPP_A08: X1_PCIE_SLOT_PWR_EN */ + PAD_CFG_GPO(GPP_A08, 0, PLTRST), + /* GPP_D19: X1_DT_PCIE_RST_N */ + PAD_NC(GPP_D19, NONE), + /* GPP_B25: X1_SLOT_WAKE_N */ + PAD_NC(GPP_B25, NONE) +}; + +/* + * WWAN: power sequence requires three stages: + * step 1: 3.3V power, FCP# (Full Card Power), RST#, and PERST# off + * step 2: deassert FCP# + * step 3: deassert RST# first, and then PERST#. + * NOTE: Since PERST# is gated by platform reset, PERST# deassertion will happen + * at much later time and time between RST# and PERSET# is guaranteed. + */ +static const struct pad_config pre_mem_wwan_pwr_seq1_pads[] = { + /* GPP_H16: WWAN_PWREN */ + PAD_CFG_GPO(GPP_H16, 1, PLTRST), + /* GPP_A09: M.2_WWAN_FCP_OFF_N */ + PAD_CFG_GPO(GPP_A09, 0, PLTRST), + /* GPP_B20: M.2_WWAN_RST_N */ + PAD_CFG_GPO(GPP_B20, 0, PLTRST), + /* GPP_D03: M.2_WWAN_PERST_GPIO_N */ + PAD_CFG_GPO(GPP_D03, 0, PLTRST), +}; + +static const struct pad_config pre_mem_wwan_pwr_seq2_pads[] = { + /* GPP_A09: M.2_WWAN_FCP_OFF_N */ + PAD_CFG_GPO(GPP_A09, 1, PLTRST), +}; + +static const struct pad_config wwan_pwr_seq3_pads[] = { + /* GPP_D03: M.2_WWAN_PERST_GPIO_N */ + PAD_CFG_GPO(GPP_D03, 1, PLTRST), + /* GPP_B20: M.2_WWAN_RST_N */ + PAD_CFG_GPO(GPP_B20, 1, PLTRST), + /* GPP_E02: WWAN_WAKE_GPIO_N */ + PAD_CFG_GPI_SCI_LOW(GPP_E02, NONE, DEEP, LEVEL), +}; + +static const struct pad_config wwan_disable_pads[] = { + /* GPP_A09: M.2_WWAN_FCP_OFF_N */ + PAD_NC(GPP_A09, NONE), + /* GPP_D03: M.2_WWAN_PERST_GPIO_N */ + PAD_NC(GPP_D03, NONE), + /* GPP_B20: M.2_WWAN_RST_N */ + PAD_NC(GPP_B20, NONE), + /* GPP_H16: WWAN_PWREN */ + PAD_NC(GPP_H16, NONE), + /* GPP_A10: M.2_WWAN_DISABLE_N */ + PAD_NC(GPP_A10, NONE), + /* GPP_E02: WWAN_WAKE_GPIO_N */ + PAD_NC(GPP_E02, NONE), +}; + +/* Gen4 NVME: at the top M.2 slot */ +static const struct pad_config pre_mem_gen4_ssd_pwr_pads[] = { + /* GPP_B10: GEN4_SSD_PWREN */ + PAD_CFG_GPO(GPP_B10, 0, PLTRST), +}; + +static const struct pad_config gen4_ssd_pads[] = { + /* GPP_B10: GEN4_SSD_PWREN */ + PAD_CFG_GPO(GPP_B10, 1, PLTRST), + /* GPP_B09: M2_GEN4_SSD_RESET_N */ + PAD_CFG_GPO(GPP_B09, 1, PLTRST), +}; + +static const struct pad_config ufs_enable_pads[] = { + /* GPP_D21: GPP_D21_UFS_REFCLK */ + PAD_CFG_NF(GPP_D21, NONE, DEEP, NF1), +}; + +/* Gen5 NVME: at the bottom M.2 slot */ +static const struct pad_config pre_mem_gen5_ssd_pwr_pads[] = { + /* GPP_B16: GEN5_SSD_PWREN */ + PAD_CFG_GPO(GPP_B16, 0, PLTRST), +}; + +static const struct pad_config gen5_ssd_pads[] = { + /* GPP_B16: GEN5_SSD_PWREN */ + PAD_CFG_GPO(GPP_B16, 1, PLTRST), + /* GPP_E03: M2_GEN5_SSD_RESET_N */ + PAD_CFG_GPO(GPP_E03, 1, PLTRST), +}; + +static const struct pad_config peg_x4slot_wake_disable_pads[] = { + /* GPP_D24: PEG_SLOT_WAKE_N */ + PAD_NC(GPP_D24, NONE), + /* GPP_D25: X4_SLOT_WAKE_N */ + PAD_NC(GPP_D25, NONE), +}; + +static const struct pad_config pcie_wlan_enable_pads[] = { + /* GPP_A11: WLAN_RST_N */ + PAD_CFG_GPO(GPP_A11, 1, PLTRST), + /* GPP_A12: WIFI_WAKE_N */ + PAD_CFG_GPI_SCI_LOW(GPP_A12, NONE, DEEP, LEVEL), +}; + +static const struct pad_config pcie_wlan_disable_pads[] = { + /* GPP_A11: WLAN_RST_N */ + PAD_NC(GPP_A11, NONE), + /* GPP_A12: WIFI_WAKE_N */ + PAD_NC(GPP_A12, NONE), +}; + +static const struct pad_config cnvi_enable_pads[] = { + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F00, NONE, DEEP, NF1), + /* GPP_F01: M.2_CNV_BRI_RSP_BT_UART2_RXD */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F01, NONE, DEEP, NF1), + /* GPP_F02: M.2_CNV_RGI_DT_BT_UART2_TXD */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F02, NONE, DEEP, NF1), + /* GPP_F03: M.2_CNV_RGI_RSP_BT_UART2_CTS_N */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F03, NONE, DEEP, NF1), + /* GPP_F04: CNV_RF_RESET_R_N */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F04, NONE, DEEP, NF1), + /* GPP_F05: CRF_CLKREQ_R */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F05, NONE, DEEP, NF3), + /* GPP_A16: BT_RF_KILL_N */ + PAD_CFG_GPO(GPP_A16, 1, DEEP), + /* GPP_A17: WIFI_RF_KILL_N */ + PAD_CFG_GPO(GPP_A17, 1, DEEP), +}; + +static const struct pad_config cnvi_disable_pads[] = { + /* GPP_F00: M.2_CNV_BRI_DT_BT_UART2_RTS_N */ + PAD_NC(GPP_F00, NONE), + /* GPP_F01: M.2_CNV_BRI_RSP_BT_UART2_RXD */ + PAD_NC(GPP_F01, NONE), + /* GPP_F02: M.2_CNV_RGI_DT_BT_UART2_TXD */ + PAD_NC(GPP_F02, NONE), + /* GPP_F03: M.2_CNV_RGI_RSP_BT_UART2_CTS_N */ + PAD_NC(GPP_F03, NONE), + /* GPP_F04: CNV_RF_RESET_R_N */ + PAD_NC(GPP_F04, NONE), + /* GPP_F05: CRF_CLKREQ_R */ + PAD_NC(GPP_F05, NONE), + + /* GPP_A16: BT_RF_KILL_N */ + PAD_NC(GPP_A16, NONE), + /* GPP_A17: WIFI_RF_KILL_N */ + PAD_NC(GPP_A17, NONE), +}; + +static const struct pad_config touchscreen_disable_pads[] = { + /* GPP_F08: TCH_PNL1_PWR_EN */ + PAD_CFG_GPO(GPP_F08, 0, PLTRST), + + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 */ + PAD_NC(GPP_E11, NONE), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 NF8: I2C4_SCL */ + PAD_NC(GPP_E12, NONE), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 NF8: I2C4 SDA */ + PAD_NC(GPP_E13, NONE), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 */ + PAD_NC(GPP_E14, NONE), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 */ + PAD_NC(GPP_E15, NONE), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 */ + PAD_NC(GPP_E16, NONE), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 */ + PAD_NC(GPP_E17, NONE), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 */ + PAD_NC(GPP_E18, NONE), +}; + +static const struct pad_config touchscreen_lpss_i2c_enable_pads[] = { + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 */ + PAD_NC(GPP_E11, NONE), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 NF8: I2C4_SCL */ + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF8), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 NF8: I2C4 SDA */ + PAD_CFG_NF(GPP_E13, NONE, DEEP, NF8), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 */ + PAD_NC(GPP_E14, NONE), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 */ + PAD_NC(GPP_E15, NONE), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 */ + PAD_NC(GPP_E17, NONE), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 */ + PAD_CFG_GPI_APIC(GPP_E18, NONE, PLTRST, LEVEL, NONE), +}; + +static const struct pad_config touchscreen_thc_i2c_enable_pads[] = { + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 */ + PAD_NC(GPP_E11, NONE), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 NF1: THC I2C0_SCL */ + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF1), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 NF1: THC I2C0 SDA */ + PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 */ + PAD_NC(GPP_E14, NONE), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 */ + PAD_NC(GPP_E15, NONE), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 */ + PAD_NC(GPP_E17, NONE), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 */ + PAD_CFG_GPI_APIC(GPP_E18, NONE, PLTRST, LEVEL, NONE), +}; + +static const struct pad_config touchscreen_gspi_enable_pads[] = { + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 NF5: GSPI0 */ + PAD_CFG_NF(GPP_E11, NONE, DEEP, NF5), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 NF5: GSPI0 */ + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF5), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 NF5: GSPI0 */ + PAD_CFG_NF(GPP_E13, NONE, DEEP, NF5), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 */ + PAD_NC(GPP_E14, NONE), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 */ + PAD_NC(GPP_E15, NONE), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 NF5: GSPI0 */ + PAD_CFG_NF(GPP_E17, NONE, DEEP, NF5), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 */ + PAD_CFG_GPI_APIC(GPP_E18, NONE, PLTRST, EDGE_SINGLE, INVERT) +}; + +static const struct pad_config touchscreen_thc_spi_enable_pads[] = { + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E11, NONE, DEEP, NF3), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF3), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E13, NONE, DEEP, NF3), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E14, NONE, DEEP, NF3), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E15, NONE, DEEP, NF3), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 NF3: THC HID-SPI */ + /* THC NOTE: use GPO instead of NF for THC0 Rst */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E17, NONE, DEEP, NF3), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 NF3: THC HID-SPI */ + PAD_CFG_NF(GPP_E18, NONE, DEEP, NF3), +}; + +static const struct pad_config touchpad_thc_i2c_enable_pads[] = { + /* GPP_F12: NF1: thc_i2c1_scl */ + PAD_CFG_NF(GPP_F12, NONE, DEEP, NF1), + /* GPP_F13: NF1: thc_i2c1_sda */ + PAD_CFG_NF(GPP_F13, NONE, DEEP, NF1), +}; + +static const struct pad_config touchpad_lpss_i2c_enable_pads[] = { + /* GPP_F12: THC_I2C1_SCL_TCH_PAD */ + PAD_CFG_NF(GPP_F12, NONE, DEEP, NF8), + /* GPP_F13: THC_I2C1_SDA_TCH_PAD */ + PAD_CFG_NF(GPP_F13, NONE, DEEP, NF8), + /* GPP_A13: TCH_PAD_INT_N */ + PAD_CFG_GPI_IRQ_WAKE(GPP_A13, NONE, PWROK, EDGE_SINGLE, INVERT), +}; + +static const struct pad_config touchpad_i2c_disable_pads[] = { + /* GPP_F12: THC_I2C1_SCL_TCH_PAD */ + PAD_NC(GPP_F12, NONE), + /* GPP_F13: THC_I2C1_SDA_TCH_PAD */ + PAD_NC(GPP_F13, NONE), + /* GPP_A13: TCH_PAD_INT_N */ + PAD_NC(GPP_A13, NONE), +}; + +static const struct pad_config ish_disable_pads[] = { + /* GPP_D06: NC */ + PAD_NC(GPP_D06, NONE), + /* GPP_E05: NC */ + PAD_NC(GPP_E05, NONE), + /* GPP_F23: NC */ + PAD_NC(GPP_F23, NONE), +}; + +static const struct pad_config ish_enable_pads[] = { + /* GPP_D06: ISH_UART0_TXD */ + PAD_CFG_NF(GPP_D06, NONE, DEEP, NF2), + /* GPP_E05: ISH_GP_7_SNSR_HDR */ + PAD_CFG_NF(GPP_E05, NONE, DEEP, NF4), + /* GPP_F23: ISH_GP_9A */ + PAD_CFG_NF(GPP_F23, NONE, DEEP, NF8), +}; + +static const struct pad_config fp_disable_pads[] = { + PAD_NC(GPP_C15, NONE), + /* GPP_D01: MOD_TCSS1_TYP_A_VBUS_EN */ + PAD_CFG_GPO(GPP_D01, 1, DEEP), + /* FIXME: b/390031369 + * use dedicated GPIO PIN for codec enable + * when FPS is enabled. + */ + /* GPP_E19: CODEC_EN */ + PAD_CFG_GPO(GPP_E19, 1, PLTRST), + PAD_NC(GPP_E20, NONE), + PAD_NC(GPP_F14, NONE), + PAD_NC(GPP_F15, NONE), + PAD_NC(GPP_F16, NONE), + PAD_NC(GPP_F18, NONE), +}; + +static const struct pad_config fp_enable_pads[] = { + /* GPP_C15: FPS_RST_N */ + PAD_CFG_GPO_LOCK(GPP_C15, 1, LOCK_CONFIG), + /* GPP_D01: FPS_SOC_INT_L */ + PAD_CFG_GPI_IRQ_WAKE(GPP_D01, NONE, PWROK, LEVEL, INVERT), + /* GPP_E19: FPMCU_PWREN */ + PAD_CFG_GPO(GPP_E19, 1, DEEP), + /* GPP_E20: FPMCU_FW_UPDATE */ + PAD_CFG_GPO_LOCK(GPP_E20, 0, LOCK_CONFIG), + /* GPP_F14: GPSI0A_MOSI */ + PAD_CFG_NF(GPP_F14, NONE, DEEP, NF8), + /* GPP_F15: GSPI0A_MISO */ + PAD_CFG_NF(GPP_F15, NONE, DEEP, NF8), + /* GPP_F16: GPSI0A_CLK */ + PAD_CFG_NF(GPP_F16, NONE, DEEP, NF8), + /* GPP_F18: GSPI0A_CS0 */ + PAD_CFG_NF(GPP_F18, NONE, DEEP, NF8), +}; + +static const struct pad_config pre_mem_fp_enable_pads[] = { + /* GPP_C15: FPS_RST_N */ + PAD_CFG_GPO(GPP_C15, 0, DEEP), +}; + +void fw_config_configure_pre_mem_gpio(void) +{ + if (!fw_config_is_provisioned()) { + printk(BIOS_WARNING, "FW_CONFIG is not provisioned, Exiting\n"); + return; + } + + if (!fw_config_probe(FW_CONFIG(CELLULAR, CELLULAR_ABSENT))) + GPIO_CONFIGURE_PADS(pre_mem_wwan_pwr_seq1_pads); + + if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME_GEN4))) { + GPIO_CONFIGURE_PADS(pre_mem_gen4_ssd_pwr_pads); + } else if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME_GEN5))) { + GPIO_CONFIGURE_PADS(pre_mem_gen5_ssd_pwr_pads); + } else if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UNKNOWN))) { + GPIO_CONFIGURE_PADS(pre_mem_gen4_ssd_pwr_pads); + GPIO_CONFIGURE_PADS(pre_mem_gen5_ssd_pwr_pads); + } + + if (!fw_config_probe(FW_CONFIG(SD, SD_NONE))) + GPIO_CONFIGURE_PADS(pre_mem_x1slot_pads); + + /* + * NOTE: We place WWAN sequence 2 here. According to the WWAN FIBOCOM + * FM350-GL datasheet, the minimum time requirement (Tpr: time between 3.3V + * and FCP#) is '0'. Therefore, it will be fine even though there is no + * GPIO configured for other PADs via fw_config to have the time delay + * introduced in between sequence 1 and 2. Also, FCP# was not the last PAD + * configured in sequence 1. Although the Tpr is '0' in the datasheet, three + * stages are preserved at this time to guarantee the sequence shown in the + * datasheet timing diagram. + */ + if (!fw_config_probe(FW_CONFIG(CELLULAR, CELLULAR_ABSENT))) + GPIO_CONFIGURE_PADS(pre_mem_wwan_pwr_seq2_pads); + + if (fw_config_probe(FW_CONFIG(FP, FP_PRESENT))) + GPIO_CONFIGURE_PADS(pre_mem_fp_enable_pads); + +} + +void fw_config_gpio_padbased_override(struct pad_config *padbased_table) +{ + if (!fw_config_is_provisioned()) { + printk(BIOS_WARNING, "FW_CONFIG is not provisioned, Exiting\n"); + return; + } + + if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME_GEN4))) { + GPIO_PADBASED_OVERRIDE(padbased_table, gen4_ssd_pads); + } else if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_NVME_GEN5))) { + GPIO_PADBASED_OVERRIDE(padbased_table, gen5_ssd_pads); + } else if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UFS))) { + GPIO_PADBASED_OVERRIDE(padbased_table, ufs_enable_pads); + } else if (fw_config_probe(FW_CONFIG(STORAGE, STORAGE_UNKNOWN))) { + GPIO_PADBASED_OVERRIDE(padbased_table, gen4_ssd_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, gen5_ssd_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, ufs_enable_pads); + } + + if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_NONE))) { + GPIO_PADBASED_OVERRIDE(padbased_table, audio_disable_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, bt_i2s_disable_pads); + } else if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_MAX98360_ALC5682I_I2S))) { + printk(BIOS_INFO, "Configure GPIOs for I2S MAX98360 ALC5682 audio.\n"); + GPIO_PADBASED_OVERRIDE(padbased_table, i2s_enable_pads); + printk(BIOS_INFO, "Configure GPIOs for BT offload mode.\n"); + GPIO_PADBASED_OVERRIDE(padbased_table, bt_i2s_enable_pads); + } else if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_MAX98373_ALC5682_SNDW))) { + GPIO_PADBASED_OVERRIDE(padbased_table, sndw_external_codec_enable_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, bt_i2s_disable_pads); + } else if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_ALC722_SNDW)) || + fw_config_probe(FW_CONFIG(AUDIO, AUDIO_ALC721_SNDW))) { + printk(BIOS_INFO, "Configure GPIOs for Soundwire audio.\n"); + GPIO_PADBASED_OVERRIDE(padbased_table, sndw_alc722_enable_pads); + printk(BIOS_INFO, "Configure GPIOs for BT offload mode.\n"); + GPIO_PADBASED_OVERRIDE(padbased_table, bt_i2s_enable_pads); + } else if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_ALC256_HDA))) { + printk(BIOS_INFO, "Configure GPIOs for HDA ALC 256 mode.\n"); + GPIO_PADBASED_OVERRIDE(padbased_table, hda_enable_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, bt_i2s_disable_pads); + } + + if (fw_config_probe(FW_CONFIG(WIFI, WIFI_PCIE_6)) || + fw_config_probe(FW_CONFIG(WIFI, WIFI_PCIE_7))) { + GPIO_PADBASED_OVERRIDE(padbased_table, pcie_wlan_enable_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, cnvi_disable_pads); + } else if (fw_config_probe(FW_CONFIG(WIFI, WIFI_CNVI_6)) || + fw_config_probe(FW_CONFIG(WIFI, WIFI_CNVI_7))) { + GPIO_PADBASED_OVERRIDE(padbased_table, cnvi_enable_pads); + GPIO_PADBASED_OVERRIDE(padbased_table, pcie_wlan_disable_pads); + } + + if (fw_config_probe(FW_CONFIG(CELLULAR, CELLULAR_PCIE)) || + fw_config_probe(FW_CONFIG(CELLULAR, CELLULAR_USB))) { + GPIO_PADBASED_OVERRIDE(padbased_table, wwan_pwr_seq3_pads); + } else { + GPIO_PADBASED_OVERRIDE(padbased_table, wwan_disable_pads); + } + + if (fw_config_probe(FW_CONFIG(SD, SD_NONE))) + GPIO_PADBASED_OVERRIDE(padbased_table, x1slot_disable_pads); + else + GPIO_PADBASED_OVERRIDE(padbased_table, x1slot_pads); + + if (fw_config_probe(FW_CONFIG(TOUCHPAD, TOUCHPAD_LPSS_I2C))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchpad_lpss_i2c_enable_pads); + else if (fw_config_probe(FW_CONFIG(TOUCHPAD, TOUCHPAD_THC_I2C))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchpad_thc_i2c_enable_pads); + else + GPIO_PADBASED_OVERRIDE(padbased_table, touchpad_i2c_disable_pads); + + if (fw_config_probe(FW_CONFIG(TOUCHSCREEN, TOUCHSCREEN_LPSS_I2C))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchscreen_lpss_i2c_enable_pads); + else if (fw_config_probe(FW_CONFIG(TOUCHSCREEN, TOUCHSCREEN_THC_I2C))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchscreen_thc_i2c_enable_pads); + else if (fw_config_probe(FW_CONFIG(TOUCHSCREEN, TOUCHSCREEN_GSPI))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchscreen_gspi_enable_pads); + else if (fw_config_probe(FW_CONFIG(TOUCHSCREEN, TOUCHSCREEN_THC_SPI))) + GPIO_PADBASED_OVERRIDE(padbased_table, touchscreen_thc_spi_enable_pads); + else + GPIO_PADBASED_OVERRIDE(padbased_table, touchscreen_disable_pads); + + if (fw_config_probe(FW_CONFIG(ISH, ISH_DISABLE))) + GPIO_PADBASED_OVERRIDE(padbased_table, ish_disable_pads); + else + GPIO_PADBASED_OVERRIDE(padbased_table, ish_enable_pads); + + /* NOTE: disable PEG (x8 slot) and x4 slot wake for now */ + GPIO_PADBASED_OVERRIDE(padbased_table, peg_x4slot_wake_disable_pads); + + if (fw_config_probe(FW_CONFIG(FP, FP_PRESENT))) + GPIO_CONFIGURE_PADS(fp_enable_pads); + else + GPIO_CONFIGURE_PADS(fp_disable_pads); +} diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/gpio.c b/src/mainboard/intel/ptlrvp/variants/ptlrvp/gpio.c new file mode 100644 index 0000000..1accd4d --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/gpio.c @@ -0,0 +1,419 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/gpio.h> +#include <baseboard/variants.h> +#include <boardid.h> +#include <soc/gpio.h> + +/* Pad configuration in ramstage*/ +static const struct pad_config gpio_table[] = { + /* GPP_A00: ESPI_IO0_EC_R */ + /* GPP_A00 : GPP_A00 ==> ESPI_IO0_EC_R configured on reset, do not touch */ + + /* GPP_A01: ESPI_IO1_EC_R */ + /* GPP_A01 : GPP_A01 ==> ESPI_IO1_EC_R configured on reset, do not touch */ + + /* GPP_A02: ESPI_IO2_EC_R */ + /* GPP_A02 : GPP_A02 ==> ESPI_IO2_EC_R configured on reset, do not touch */ + + /* GPP_A03: ESPI_IO3_EC_R */ + /* GPP_A03 : GPP_A03 ==> ESPI_IO3_EC_R configured on reset, do not touch */ + + /* GPP_A04: ESPI_CS0_EC_R_N */ + /* GPP_A04 : GPP_A04 ==> ESPI_CS0_HDR_L configured on reset, do not touch */ + + /* GPP_A05: ESPI_CLK_EC_R */ + /* GPP_A05 : GPP_A05 ==> ESPI_CLK_HDR configured on reset, do not touch */ + + /* GPP_A06: ESPI_RST_EC_R_N */ + /* GPP_A06 : GPP_A06 ==> ESPI_RST_HDR configured on reset, do not touch */ + + /* GPP_A09: M.2_WWAN_FCP_OFF_N */ + PAD_CFG_GPO(GPP_A09, 1, PLTRST), + /* GPP_A10: M.2_WWAN_DISABLE_N */ + PAD_CFG_GPO(GPP_A10, 1, PLTRST), + /* GPP_A11: WLAN_RST_N */ + PAD_CFG_GPO(GPP_A11, 1, PLTRST), + /* GPP_A12: WIFI_WAKE_N */ + PAD_CFG_GPI_SCI_LOW(GPP_A12, NONE, DEEP, LEVEL), + /* GPP_A15: GPP_A15_DNX_FORCE_RELOAD */ + PAD_CFG_NF(GPP_A15, NONE, DEEP, NF1), + /* GPP_A16: BT_RF_KILL_N */ + PAD_CFG_GPO(GPP_A16, 1, DEEP), + /* GPP_A17: WIFI_RF_KILL_N */ + PAD_CFG_GPO(GPP_A17, 1, DEEP), + + /* GPP_B00: USBC_SML_CLK_PD */ + PAD_CFG_NF(GPP_B00, NONE, DEEP, NF1), + /* GPP_B01: USBC_SML_DATA_PD */ + PAD_CFG_NF(GPP_B01, NONE, DEEP, NF1), + /* GPP_B02: ISH_I2C0_SDA_SNSR_HDR */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_B02, NONE, DEEP, NF3), + /* GPP_B03: ISH_I2C0_SCL_SNSR_HDR */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_B03, NONE, DEEP, NF3), + /* GPP_B04: ISH_GP_0_SNSR_HDR */ + PAD_CFG_NF(GPP_B04, NONE, DEEP, NF4), + /* GPP_B05: ISH_GP_1_SNSR_HDR */ + PAD_CFG_NF(GPP_B05, NONE, DEEP, NF4), + /* GPP_B06: ISH_GP_2_SNSR_HDR */ + PAD_CFG_NF(GPP_B06, NONE, DEEP, NF4), + /* GPP_B07: ISH_GP_3_SNSR_HDR */ + PAD_CFG_NF(GPP_B07, NONE, DEEP, NF4), + /* GPP_B08: ISH_GP_4_SNSR_HDR */ + PAD_CFG_NF(GPP_B08, NONE, DEEP, NF4), + /* GPP_B09: M2_GEN4_SSD_RESET_N */ + PAD_CFG_GPO(GPP_B09, 1, PLTRST), + /* GPP_B10: GEN4_SSD_PWREN */ + PAD_CFG_GPO(GPP_B10, 1, PLTRST), + /* GPP_B11: MOD_TCSS1_DISP_HPD3 */ + PAD_CFG_NF(GPP_B11, NONE, DEEP, NF2), + /* GPP_B12: PM_SLP_S0_N */ + PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), + /* GPP_B13: PLT_RST_N */ + PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), + /* GPP_B14: MOD_TCSS2_DISP_HPD4 */ + PAD_CFG_NF(GPP_B14, NONE, DEEP, NF2), + /* GPP_B15: MOD_TCSS_USB_TYP_A_OC3_N */ + PAD_CFG_NF(GPP_B15, NONE, DEEP, NF1), + /* GPP_B16: GEN5_SSD_PWREN */ + PAD_CFG_GPO(GPP_B16, 1, PLTRST), + /* GPP_B17: Not used */ + PAD_NC(GPP_B17, NONE), + /* GPP_B18: ISH_I2C2_SDA_SNSR_HDR */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_B18, NONE, DEEP, NF1), + /* GPP_B19: ISH_I2C2_SCL_SNSR_HDR */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_B19, NONE, DEEP, NF1), + /* GPP_B20: M.2_WWAN_RST_N */ + PAD_CFG_GPO(GPP_B20, 1, PLTRST), + /* GPP_B21: TCP_RETIMER_FORCE_PWR */ + PAD_CFG_GPO(GPP_B21, 0, DEEP), + /* GPP_B22: ISH_GP_5_SNSR_HDR */ + PAD_CFG_NF(GPP_B22, NONE, DEEP, NF4), + /* GPP_B23: ISH_GP_6_SNSR_HDR */ + PAD_CFG_NF(GPP_B23, NONE, DEEP, NF4), + /* GPP_B24: ESPI_ALERT0_EC_R_N */ + PAD_NC(GPP_B24, NONE), + + /* GPP_C00: GPP_C0_SMBCLK */ + PAD_CFG_NF(GPP_C00, NONE, DEEP, NF1), + /* GPP_C01: GPP_C1_SMBDATA */ + PAD_CFG_NF(GPP_C01, NONE, DEEP, NF1), + /* GPP_C02: Not used */ + PAD_NC(GPP_C02, NONE), + /* GPP_C03: TCP_LAN_SML0_SCL_R */ + PAD_CFG_NF(GPP_C03, NONE, DEEP, NF1), + /* GPP_C04: TCP_LAN_SML0_SDA_R */ + PAD_CFG_NF(GPP_C04, NONE, DEEP, NF1), + /* GPP_C06: SML1_CLK */ + PAD_CFG_NF(GPP_C06, NONE, DEEP, NF1), + /* GPP_C07: SML1_DATA */ + PAD_CFG_NF(GPP_C07, NONE, DEEP, NF1), + /* GPP_C09: CLKREQ0_X8_GEN5_DT_CEM_SLOT_N */ + PAD_CFG_NF(GPP_C09, NONE, DEEP, NF1), + /* GPP_C10: CLKREQ1_X4_GEN5_M2_SSD_N */ + PAD_CFG_NF(GPP_C10, NONE, DEEP, NF1), + /* GPP_C11: CLKREQ2_X1_GEN4_DT_CEM_SLOT_N */ + PAD_CFG_NF(GPP_C11, NONE, DEEP, NF1), + /* GPP_C12: CLKREQ3_X1_GEN1_GBE_LAN_N */ + PAD_CFG_NF(GPP_C12, NONE, DEEP, NF1), + /* GPP_C13: CLKREQ4_X1_GEN4_M2_WLAN_N */ + PAD_CFG_NF(GPP_C13, NONE, DEEP, NF1), + /* GPP_C14: CLKREQ5_X1_GEN4_M2_WWAN_N */ + PAD_CFG_NF(GPP_C14, NONE, DEEP, NF1), + /* GPP_C16: TBT_LSX0_TXD */ + PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), + /* GPP_C17: TBT_LSX0_RXD */ + PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), + /* GPP_C18: TBT_LSX1_TXD */ + PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), + /* GPP_C19: TBT_LSX1_RXD */ + PAD_CFG_NF(GPP_C19, NONE, DEEP, NF1), + /* GPP_C20: MOD_TCSS1_LS_TX_DDC_SCL */ + PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), + /* GPP_C21: MOD_TCSS1_LS_RX_DDC_SDA */ + PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), + /* GPP_C22: MOD_TCSS2_LS_TX_DDC_SCL */ + PAD_CFG_NF(GPP_C22, NONE, DEEP, NF2), + /* GPP_C23: MOD_TCSS2_LS_RX_DDC_SDA */ + PAD_CFG_NF(GPP_C23, NONE, DEEP, NF2), + + /* GPP_D00: IMGCLKOUT_1 */ + PAD_CFG_NF(GPP_D00, NONE, DEEP, NF1), + /* GPP_D02: Not used */ + PAD_NC(GPP_D02, NONE), + /* GPP_D03: M.2_WWAN_PERST_GPIO_N */ + PAD_CFG_GPO(GPP_D03, 1, PLTRST), + /* GPP_D04: IMGCLKOUT_0 */ + PAD_CFG_NF(GPP_D04, NONE, DEEP, NF1), + /* GPP_D05: disable ISH_UART0_RXD */ + PAD_NC(GPP_D05, NONE), + /* GPP_D07: NC */ + PAD_NC(GPP_D07, NONE), + /* GPP_D08: NC */ + PAD_NC(GPP_D08, NONE), + /* GPP_D09: PEG_SLOT_RST_N */ + PAD_CFG_GPO(GPP_D09, 1, PLTRST), + /* GPP_D10: HDA_BCLK */ + PAD_CFG_NF(GPP_D10, NONE, DEEP, NF1), + /* GPP_D11: HDA_SYNC */ + PAD_CFG_NF(GPP_D11, NONE, DEEP, NF1), + /* GPP_D12: HDA_SDO */ + PAD_CFG_NF(GPP_D12, NONE, DEEP, NF1), + /* GPP_D13: HDA_SDI0 */ + PAD_CFG_NF(GPP_D13, NONE, DEEP, NF1), + /* GPP_D14: COINLESS_MODE_SELECT */ + PAD_CFG_GPI_TRIG_OWN(GPP_D14, NONE, PLTRST, LEVEL, ACPI), + /* GPP_D15: SPI_TPM_INT_N */ + PAD_CFG_GPI_APIC_LOCK(GPP_D15, NONE, LEVEL, INVERT, LOCK_CONFIG), + /* GPP_D16: HDA_RST_N_HDR */ + PAD_CFG_NF(GPP_D16, NONE, DEEP, NF1), + /* GPP_D17: HDA_SDI1_HDR */ + PAD_CFG_NF(GPP_D17, NONE, DEEP, NF1), + /* GPP_D18: CLKREQ6_X4_GEN4_M2_SSD_N */ + PAD_CFG_NF(GPP_D18, NONE, DEEP, NF1), + /* GPP_D20: CSE_EARLY_SW */ + PAD_CFG_GPI_SCI_HIGH(GPP_D20, NONE, DEEP, LEVEL), + /* GPP_D21: NC */ + PAD_NC(GPP_D21, NONE), + /* GPP_D22: BPKI3C_SDA */ + PAD_CFG_NF(GPP_D22, NONE, DEEP, NF1), + /* GPP_D23: BPKI3C_SCL */ + PAD_CFG_NF(GPP_D23, NONE, DEEP, NF1), + /* GPP_D24: PEG_SLOT_WAKE_N */ + PAD_CFG_GPI_SCI_LOW(GPP_D24, NONE, DEEP, LEVEL), + /* GPP_D25: X4_SLOT_WAKE_N */ + PAD_CFG_GPI_SCI_LOW(GPP_D25, NONE, DEEP, LEVEL), + + /* GPP_E01: CRD2_RST_N */ + PAD_CFG_GPO(GPP_E01, 1, PLTRST), + /* GPP_E02: WWAN_WAKE_GPIO_N */ + PAD_CFG_GPI_SCI_LOW(GPP_E02, NONE, DEEP, LEVEL), + /* GPP_E03: M2_GEN5_SSD_RESET_N */ + PAD_CFG_GPO(GPP_E03, 1, PLTRST), + /* GPP_E06: SECURE_CAM_SW */ + PAD_CFG_GPI_TRIG_OWN(GPP_E06, NONE, PLTRST, LEVEL, ACPI), + /* GPP_E07: Not used */ + PAD_NC(GPP_E07, NONE), + /* GPP_E08: Not used */ + PAD_NC(GPP_E08, NONE), + /* GPP_E09: USB_RD_FP_CONN_12_OC0_N */ + PAD_CFG_NF(GPP_E09, NONE, DEEP, NF1), + /* GPP_E10: CRD1_RST_N */ + PAD_CFG_GPO(GPP_E10, 1, PLTRST), + /* GPP_E11: THC0_SPI1_CLK_TCH_PNL1 */ + PAD_CFG_NF(GPP_E11, NONE, DEEP, NF3), + /* GPP_E12: THC0_SPI1_IO_0_I2C4_SCL_TCH_PNL1 */ + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF3), + /* GPP_E13: THC0_SPI1_IO_1_I2C4_SDA_TCH_PNL1 */ + PAD_CFG_NF(GPP_E13, NONE, DEEP, NF3), + /* GPP_E14: THC0_SPI1_IO_2_TCH_PNL1 */ + PAD_CFG_NF(GPP_E14, NONE, DEEP, NF3), + /* GPP_E15: THC0_SPI1_IO_3_TCH_PNL1 */ + PAD_CFG_NF(GPP_E15, NONE, DEEP, NF3), + /* GPP_E16: THC0_SPI1_RST_N_TCH_PNL1 */ + /* THC NOTE: use GPO instead of GPO for THC0 Rst */ + PAD_CFG_GPO(GPP_E16, 1, DEEP), + /* GPP_E17: THC0_SPI1_CS0_N_TCH_PNL1 */ + PAD_CFG_NF(GPP_E17, NONE, DEEP, NF3), + /* GPP_E18: THC0_SPI1_INT_N_TCH_PNL1 */ + PAD_CFG_NF(GPP_E18, NONE, DEEP, NF3), + /* GPP_E21: I2C_PMC_PD_INT_N */ + PAD_CFG_NF(GPP_E21, NONE, DEEP, NF1), + /* GPP_E22: THC0_SPI1_DSYNC */ + PAD_CFG_NF(GPP_E22, NONE, DEEP, NF3), + + /* GPP_F00: M.2_CNV_BRI_DT_BT_UART2_RTS_N */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F00, NONE, DEEP, NF1), + /* GPP_F01: M.2_CNV_BRI_RSP_BT_UART2_RXD */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F01, NONE, DEEP, NF1), + /* GPP_F02: M.2_CNV_RGI_DT_BT_UART2_TXD */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F02, NONE, DEEP, NF1), + /* GPP_F03: M.2_CNV_RGI_RSP_BT_UART2_CTS_N */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F03, NONE, DEEP, NF1), + /* GPP_F04: CNV_RF_RESET_R_N */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F04, NONE, DEEP, NF1), + /* GPP_F05: CRF_CLKREQ_R */ + /* NOTE: IOSSTAGE: 'Ignore' for S0ix */ + PAD_CFG_NF_IOSTANDBY_IGNORE(GPP_F05, NONE, DEEP, NF3), + /* GPP_F06: WLAN_WWAN_COEX3 */ + PAD_CFG_NF(GPP_F06, NONE, DEEP, NF1), + /* GPP_F07: IMGCLKOUT_2 */ + PAD_CFG_NF(GPP_F07, NONE, DEEP, NF2), + /* GPP_F08: TCH_PNL1_PWR_EN */ + PAD_CFG_GPO(GPP_F08, 1, PLTRST), + /* GPP_F09: NC */ + PAD_NC(GPP_F09, NONE), + /* GPP_F10: PEG_SLOT_PWR_EN_N */ + PAD_CFG_GPO(GPP_F10, 0, PLTRST), + /* GPP_F11: MOD_TCSS2_TYP_A_VBUS_EN */ + PAD_CFG_GPO(GPP_F11, 1, DEEP), + /* GPP_F12: THC_I2C1_SCL_TCH_PAD */ + PAD_CFG_NF(GPP_F12, NONE, DEEP, NF8), + /* GPP_F13: THC_I2C1_SDA_TCH_PAD */ + PAD_CFG_NF(GPP_F13, NONE, DEEP, NF8), + /* GPP_F17: Not used */ + PAD_CFG_GPI_INT(GPP_F17, NONE, PLTRST, EDGE_BOTH), + /* GPP_F19: GPP_PRIVACY_LED_CAM2 */ + PAD_CFG_GPO(GPP_F19, 0, PLTRST), + /* GPP_F20: GPP_PRIVACY_LED_CAM1_CVS_HST_WAKE */ + PAD_CFG_GPO(GPP_F20, 0, PLTRST), + /* GPP_F22: THC1_SPI2_DSYNC */ + PAD_CFG_NF(GPP_F22, NONE, DEEP, NF3), + + /* GPP_H00: Not used */ + PAD_NC(GPP_H00, NONE), + /* GPP_H01: CRD_CAM_STROBE */ + PAD_CFG_GPO(GPP_H01, 0, PLTRST), + /* GPP_H02: DEBUG_TRACE_PNP */ + PAD_CFG_GPO(GPP_H02, 1, PLTRST), + /* GPP_H03: MIC MUTE */ + PAD_CFG_NF(GPP_H03, NONE, DEEP, NF1), + /* GPP_H04: I2C2_SDA_CAM_FLSH */ + PAD_CFG_NF(GPP_H04, NONE, DEEP, NF1), + /* GPP_H05: I2C2_SCL_CAM_FLSH */ + PAD_CFG_NF(GPP_H05, NONE, DEEP, NF1), + /* GPP_H06: I2C3_SDA_PSS */ + PAD_CFG_NF(GPP_H06, NONE, DEEP, NF1), + /* GPP_H07: I2C3_SCL_PSS */ + PAD_CFG_NF(GPP_H07, NONE, DEEP, NF1), + /* GPP_H08: UART0_BUF_RXD */ + PAD_CFG_NF(GPP_H08, NONE, DEEP, NF1), + /* GPP_H09: UART0_BUF_TXD */ + PAD_CFG_NF(GPP_H09, NONE, DEEP, NF1), + /* GPP_H10: UART0_BUF_RTS */ + PAD_CFG_NF(GPP_H10, NONE, DEEP, NF1), + /* GPP_H11: UART0_BUF_CTS */ + PAD_CFG_NF(GPP_H11, NONE, DEEP, NF1), + /* GPP_H13: CPU_C10_GATE_N_R */ + PAD_CFG_NF(GPP_H13, NONE, DEEP, NF1), + /* GPP_H14: NC */ + PAD_NC(GPP_H14, NONE), + /* GPP_H15: NC */ + PAD_NC(GPP_H15, NONE), + /* GPP_H16: WWAN_PWREN */ + PAD_CFG_GPO(GPP_H16, 1, PLTRST), + /* GPP_H17: MIC MUTE LED */ + PAD_CFG_NF(GPP_H17, NONE, DEEP, NF1), + /* GPP_H19: I3C0_SDA_HDR */ + PAD_CFG_NF(GPP_H19, NONE, DEEP, NF2), + /* GPP_H20: I3C0_SCL_HDR */ + PAD_CFG_NF(GPP_H20, NONE, DEEP, NF2), + /* GPP_H21: I2C1_SDA_I3C1_SDA_CAM_FLSH_CVS */ + PAD_CFG_NF(GPP_H21, NONE, DEEP, NF1), + /* GPP_H22: I2C1_SCL_I3C1_SCL_CAM_FLSH_CVS */ + PAD_CFG_NF(GPP_H22, NONE, DEEP, NF1), + + /* GPP_S00: SNDW3_CLK_CODEC */ + PAD_CFG_NF(GPP_S00, NONE, DEEP, NF1), + /* GPP_S01: SNDW3_DATA0_CODEC */ + PAD_CFG_NF(GPP_S01, NONE, DEEP, NF1), + /* GPP_S02: SNDW3_DATA1_CODEC */ + PAD_CFG_NF(GPP_S02, NONE, DEEP, NF1), + /* GPP_S03: SNDW3_DATA2_CODEC */ + PAD_CFG_NF(GPP_S03, NONE, DEEP, NF1), + /* GPP_S04: SNDW2_CLK */ + PAD_CFG_NF(GPP_S04, NONE, DEEP, NF2), + /* GPP_S05: SNDW2_DATA0 */ + PAD_CFG_NF(GPP_S05, NONE, DEEP, NF2), + /* GPP_S06: SNDW1_CLK */ + PAD_CFG_NF(GPP_S06, NONE, DEEP, NF3), + /* GPP_S07: SNDW1_DATA0 */ + PAD_CFG_NF(GPP_S07, NONE, DEEP, NF3), + + /* GPP_V00: PM_BATLOW_N */ + PAD_CFG_NF(GPP_V00, NONE, DEEP, NF1), + /* GPP_V01: BC_ACOK_MCP */ + PAD_CFG_NF(GPP_V01, NONE, DEEP, NF1), + /* GPP_V02: LANWAKE_N_R */ + PAD_CFG_NF(GPP_V02, NONE, DEEP, NF1), + /* GPP_V03: PWRBTN_MCP_N */ + PAD_CFG_NF(GPP_V03, NONE, DEEP, NF1), + /* GPP_V04: PM_SLP_S3_N */ + PAD_CFG_NF(GPP_V04, NONE, DEEP, NF1), + /* GPP_V05: PM_SLP_S4_N */ + PAD_CFG_NF(GPP_V05, NONE, DEEP, NF1), + /* GPP_V06: PM_SLP_A_N */ + PAD_CFG_NF(GPP_V06, NONE, DEEP, NF1), + /* GPP_V07: Not used */ + PAD_NC(GPP_V07, NONE), + /* GPP_V08: SLP_WLAN_N */ + PAD_CFG_NF(GPP_V08, NONE, DEEP, NF1), + /* GPP_V09: PM_SLP_S5_N */ + PAD_CFG_NF(GPP_V09, NONE, DEEP, NF1), + /* GPP_V10: LANPHYPC_R_N */ + PAD_CFG_NF(GPP_V10, NONE, DEEP, NF1), + /* GPP_V11: PM_SLP_LAN_N */ + PAD_CFG_NF(GPP_V11, NONE, DEEP, NF1), + /* GPP_V12: WAKE_N */ + PAD_CFG_NF(GPP_V12, NONE, DEEP, NF1), + /* GPP_V13: GPP_V13_CATERR_N */ + PAD_CFG_NF(GPP_V13, NONE, DEEP, NF1), + /* GPP_V14: GPP_V14_FORCEPR_N */ + PAD_CFG_NF(GPP_V14, NONE, DEEP, NF1), + /* GPP_V15: GPP_V15_THERMTRIP_N */ + PAD_CFG_NF(GPP_V15, NONE, DEEP, NF1), + /* GPP_V16: GPP_V16_VCCST_EN */ + PAD_CFG_NF(GPP_V16, NONE, DEEP, NF1), + /* GPP_V17: TCP_RT_S0IX_ENTRY_EXIT_N */ + PAD_CFG_GPO(GPP_V17, 1, DEEP), +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { + /* GPP_H08: UART0_BUF_RXD */ + PAD_CFG_NF(GPP_H08, NONE, DEEP, NF1), + /* GPP_H09: UART0_BUF_TXD */ + PAD_CFG_NF(GPP_H09, NONE, DEEP, NF1), + + /* GPP_H06: I2C3_SDA_PSS */ + PAD_CFG_NF(GPP_H06, NONE, DEEP, NF1), + /* GPP_H07: I2C3_SCL_PSS */ + PAD_CFG_NF(GPP_H07, NONE, DEEP, NF1), + /* GPP_D15: SPI_TPM_INT_N */ + PAD_CFG_GPI_APIC(GPP_D15, NONE, PLTRST, LEVEL, INVERT), +}; + +/* Pad configuration in romstage */ +static const struct pad_config romstage_gpio_table[] = { + /* GPP_C00: GPP_C0_SMBCLK */ + PAD_CFG_NF(GPP_C00, NONE, DEEP, NF1), + /* GPP_C01: GPP_C1_SMBDATA */ + PAD_CFG_NF(GPP_C01, NONE, DEEP, NF1), +}; + +const struct pad_config *variant_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(gpio_table); + return gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} + +/* Create the stub for romstage gpio, typically use for power sequence */ +const struct pad_config *variant_romstage_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(romstage_gpio_table); + return romstage_gpio_table; +} + +static const struct cros_gpio cros_gpios[] = { + CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE0_NAME), + CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE1_NAME), + CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE2_NAME), + CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE3_NAME), +}; + +DECLARE_CROS_GPIOS(cros_gpios); diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/hda_verb.c b/src/mainboard/intel/ptlrvp/variants/ptlrvp/hda_verb.c new file mode 100644 index 0000000..2f703b7 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/hda_verb.c @@ -0,0 +1,126 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0256, /* Codec Vendor / Device ID: Realtek ALC256 */ + 0x10ec12ac, /* Subsystem ID */ + 0x00000013, /* Number of jacks (NID entries) */ + + AZALIA_RESET(0x1), + /* NID 0x01, HDA Codec Subsystem ID Verb Table */ + AZALIA_SUBVENDOR(0, 0x10ec12ac), + + /* Pin Widget Verb Table */ + /* + * DMIC + * Requirement is to use PCH DMIC. Hence, + * commented out codec's Internal DMIC. + * AZALIA_PIN_CFG(0, 0x12, 0x90A60130), + * AZALIA_PIN_CFG(0, 0x13, 0x40000000), + */ + /* Pin widget 0x14 - Front (Port-D) */ + AZALIA_PIN_CFG(0, 0x14, 0x90170110), + /* Pin widget 0x18 - NPC */ + AZALIA_PIN_CFG(0, 0x18, 0x411111F0), + /* Pin widget 0x19 - MIC2 (Port-F) */ + AZALIA_PIN_CFG(0, 0x19, 0x04A11040), + /* Pin widget 0x1A - LINE1 (Port-C) */ + AZALIA_PIN_CFG(0, 0x1a, 0x411111F0), + /* Pin widget 0x1B - NPC */ + AZALIA_PIN_CFG(0, 0x1b, 0x411111F0), + /* Pin widget 0x1D - BEEP-IN */ + AZALIA_PIN_CFG(0, 0x1d, 0x40610041), + /* Pin widget 0x1E - NPC */ + AZALIA_PIN_CFG(0, 0x1e, 0x411111F0), + /* Pin widget 0x21 - HP1-OUT (Port-I) */ + AZALIA_PIN_CFG(0, 0x21, 0x04211020), + /* + * Widget node 0x20 - 1 + * Codec hidden reset and speaker power 2W/4ohm + */ + 0x0205001A, + 0x0204C003, + 0x02050038, + 0x02047901, + /* + * Widget node 0x20 - 2 + * Class D power on Reset + */ + 0x0205003C, + 0x02040354, + 0x0205003C, + 0x02040314, + /* + * Widget node 0x20 - 3 + * Disable AGC and set AGC limit to -1.5dB + */ + 0x02050016, + 0x02040C50, + 0x02050012, + 0x0204EBC1, + /* + * Widget node 0x20 - 4 + * Set AGC Post gain +1.5dB then Enable AGC + */ + 0x02050013, + 0x02044023, + 0x02050016, + 0x02040E50, + /* + * Widget node 0x20 - 5 + * Silence detector enabling + Set EAPD to verb control + */ + 0x02050037, + 0x0204FE15, + 0x02050010, + 0x02040020, + /* + * Widget node 0x20 - 6 + * Silence data mode Threshold (-90dB) + */ + 0x02050030, + 0x0204A000, + 0x0205001B, + 0x02040A4B, + /* + * Widget node 0x20 - 7 + * Default setting-1 + */ + 0x05750003, + 0x05740DA3, + 0x02050046, + 0x02040004, + /* + * Widget node 0x20 - 8 + * support 1 pin detect two port + */ + 0x02050009, + 0x0204E003, + 0x0205000A, + 0x02047770, + /* + * Widget node 0x20 - 9 + * To set LDO1/LDO2 as default + */ + 0x02050008, + 0x02046A0C, + 0x02050008, + 0x02046A0C, +}; + +const u32 pc_beep_verbs[] = { + /* Dos beep path - 1 */ + 0x01470C00, + 0x02050036, + 0x02047151, + 0x01470740, + /* Dos beep path - 2 */ + 0x0143b000, + 0x01470C02, + 0x01470C02, + 0x01470C02, +}; + +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/ec.h b/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/ec.h new file mode 100644 index 0000000..4fc0622 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef MAINBOARD_EC_H +#define MAINBOARD_EC_H + +#include <baseboard/ec.h> + +#endif /* MAINBOARD_GPIO_H */ diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/gpio.h b/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/gpio.h new file mode 100644 index 0000000..238a99e --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/include/variant/gpio.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __MAINBOARD_GPIO_H__ +#define __MAINBOARD_GPIO_H__ + +#include <baseboard/gpio.h> + +/* TODO: Add GPIO as per ptlrvp board */ +/* EC wake is LAN_WAKE# which is a special DeepSX wake pin */ +#define GPE_EC_WAKE GPE0_LAN_WAK + +#endif /* __MAINBOARD_GPIO_H__ */ diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory.c b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory.c new file mode 100644 index 0000000..e0908ad --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory.c @@ -0,0 +1,76 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/variants.h> +#include <soc/romstage.h> +#include <soc/meminit.h> + +static const struct mb_cfg lp5_mem_config = { + .type = MEM_TYPE_LP5X, + + .lpx_dq_map = { + .ddr0 = { + .dq0 = { 13, 14, 12, 15, 11, 10, 8, 9, }, + .dq1 = { 7, 5, 4, 6, 0, 3, 1, 2 }, + }, + .ddr1 = { + .dq0 = { 1, 3, 0, 2, 7, 4, 6, 5, }, + .dq1 = { 12, 13, 14, 15, 11, 10, 9, 8 }, + }, + .ddr2 = { + .dq0 = { 0, 2, 1, 3, 6, 4, 7, 5 }, + .dq1 = { 14, 13, 15, 12, 8, 11, 10, 9, }, + }, + .ddr3 = { + .dq0 = { 6, 5, 7, 4, 2, 3, 1, 0, }, + .dq1 = { 10, 8, 11, 9, 12, 15, 13, 14 }, + }, + .ddr4 = { + .dq0 = { 2, 1, 3, 0, 4, 7, 5, 6 }, + .dq1 = { 15, 14, 12, 13, 9, 11, 10, 8, }, + }, + .ddr5 = { + .dq0 = { 6, 5, 7, 4, 3, 1, 0, 2, }, + .dq1 = { 10, 9, 11, 8, 13, 14, 12, 15 }, + }, + .ddr6 = { + .dq0 = { 9, 10, 11, 8, 14, 12, 13, 15, }, + .dq1 = { 0, 1, 2, 3, 5, 7, 4, 6 }, + }, + .ddr7 = { + .dq0 = { 0, 1, 2, 3, 7, 5, 6, 4, }, + .dq1 = { 14, 13, 15, 12, 10, 8, 11, 9 }, + }, + }, + + .lpx_dqs_map = { + .ddr0 = { .dqs0 = 1, .dqs1 = 0 }, + .ddr1 = { .dqs0 = 0, .dqs1 = 1 }, + .ddr2 = { .dqs0 = 0, .dqs1 = 1 }, + .ddr3 = { .dqs0 = 0, .dqs1 = 1 }, + .ddr4 = { .dqs0 = 0, .dqs1 = 1 }, + .ddr5 = { .dqs0 = 0, .dqs1 = 1 }, + .ddr6 = { .dqs0 = 1, .dqs1 = 0 }, + .ddr7 = { .dqs0 = 0, .dqs1 = 1 } + }, + + .ect = true, /* Early Command Training */ + + .lp_ddr_dq_dqs_re_training = 1, + + .user_bd = BOARD_TYPE_ULT_ULX, + + .lp5x_config = { + .ccc_config = 0xFF, + }, +}; + +const struct mb_cfg *variant_memory_params(void) +{ + return &lp5_mem_config; +} + +void variant_get_spd_info(struct mem_spd *spd_info) +{ + spd_info->topo = MEM_TOPO_MEMORY_DOWN; + spd_info->cbfs_index = 0; +} diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/Makefile.mk b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/Makefile.mk new file mode 100644 index 0000000..14126ce --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/Makefile.mk @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# ./util/spd_tools/bin/part_id_gen PTL lp5 src/mainboard/intel/ptlrvp/variants/ptlrvp/memory src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt + +SPD_SOURCES = +SPD_SOURCES += spd/lp5/set-0/spd-7.hex # ID = 0(0b0000) Parts = H58G56BK7BX068 diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/dram_id.generated.txt b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/dram_id.generated.txt new file mode 100644 index 0000000..2108211 --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/dram_id.generated.txt @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# ./util/spd_tools/bin/part_id_gen PTL lp5 src/mainboard/intel/ptlrvp/variants/ptlrvp/memory src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt + +DRAM Part Name ID to assign +H58G56BK7BX068 0 (0000) diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt new file mode 100644 index 0000000..17ee7ef --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/memory/mem_parts_used.txt @@ -0,0 +1,12 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.mk and dram_id.generated.txt by running the +# part_id_gen tool from util/spd_tools. +# See util/spd_tools/README.md for more details and instructions. + +# Part Name +H58G56BK7BX068 diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb b/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb new file mode 100644 index 0000000..cb4c21a --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/overridetree.cb @@ -0,0 +1,890 @@ +fw_config + field AUDIO 0 3 + option AUDIO_NONE 0 + option AUDIO_MAX98373_ALC5682_SNDW 1 + option AUDIO_ALC722_SNDW 2 + option AUDIO_ALC256_HDA 3 + option AUDIO_MAX98360_ALC5682I_I2S 4 + option AUDIO_ALC721_SNDW 5 + end + field WIFI 4 5 + option WIFI_CNVI_6 0 + option WIFI_CNVI_7 1 + option WIFI_PCIE_6 2 + option WIFI_PCIE_7 3 + end + field CELLULAR 6 7 + option CELLULAR_ABSENT 0 + option CELLULAR_USB 1 + option CELLULAR_PCIE 2 + end + field TOUCHSCREEN 8 10 + option TOUCHSCREEN_NONE 0 + option TOUCHSCREEN_LPSS_I2C 1 + option TOUCHSCREEN_GSPI 2 + option TOUCHSCREEN_THC_SPI 3 + option TOUCHSCREEN_THC_I2C 4 + end + field TOUCHPAD 11 12 + option TOUCHPAD_NONE 0 + option TOUCHPAD_THC_I2C 1 + option TOUCHPAD_LPSS_I2C 2 + end + field SD 13 14 + option SD_NONE 0 + option SD_GENSYS 1 + option SD_BAYHUB 2 + end + field STORAGE 15 16 + option STORAGE_UNKNOWN 0 + option STORAGE_NVME_GEN4 1 + option STORAGE_NVME_GEN5 2 + option STORAGE_UFS 3 + end + field FP 17 + option FP_ABSENT 0 + option FP_PRESENT 1 + end + field DISPLAY 18 + option DISPLAY_ABSENT 0 + option DISPLAY_PRESENT 1 + end + field KB 19 + option KB_ABSENT 0 + option KB_PRESENT 1 + end + field UFC 20 21 + option UFC_ABSENT 0 + option UFC_MIPI 1 + option UFC_USB 2 + end + field WFC 22 23 + option WFC_ABSENT 0 + option WFC_MIPI 1 + option WFC_USB 2 + end + field ISH 24 + option ISH_DISABLE 0 + option ISH_ENABLE 1 + end +end + +chip soc/intel/pantherlake + + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C0 + register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C1 + register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C2 + register "usb2_ports[3]" = "USB2_PORT_TYPE_C(OC_SKIP)" # USB2_C3 + register "usb2_ports[4]" = "USB2_PORT_MID(OC0)" # Type-A Port A0 + register "usb2_ports[5]" = "USB2_PORT_MID(OC0)" # Type-A Port A1 / WWAN with rework + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # CNVi BT or discrete BT + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC0)" # USB3.2 x1 Type-A Con #1 + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # USB3.2 x1 Type-A Con #2 / M.2 WWAN with rework + + register "tcss_ports[0]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[1]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[2]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + register "tcss_ports[3]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + + register "tcss_cap_policy[0]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[1]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[2]" = "TCSS_TYPE_C_PORT_FULL_FUN" + register "tcss_cap_policy[3]" = "TCSS_TYPE_C_PORT_FULL_FUN" + + # Enable EDP in PortA + register "ddi_port_A_config" = "1" + register "ddi_ports_config" = "{ + [DDI_PORT_A] = DDI_ENABLE_HPD, + }" + + register "serial_io_i2c_mode" = "{ + [PchSerialIoIndexI2C0] = PchSerialIoPci, + [PchSerialIoIndexI2C1] = PchSerialIoPci, + [PchSerialIoIndexI2C2] = PchSerialIoPci, + [PchSerialIoIndexI2C3] = PchSerialIoPci, + [PchSerialIoIndexI2C4] = PchSerialIoPci, + [PchSerialIoIndexI2C5] = PchSerialIoPci, + }" + + register "serial_io_gspi_mode" = "{ + [PchSerialIoIndexGSPI0] = PchSerialIoPci, + [PchSerialIoIndexGSPI1] = PchSerialIoDisabled, + [PchSerialIoIndexGSPI0A] = PchSerialIoDisabled, + }" + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| I2C1 | Camera(CRD1) | + #| I2C2 | Camera(CRD2) | + #| I2C3 | Audio, TPM(cr50) | + #| I2C4 | Touchscreen | + #| I2C5 | Touchpad | + #+-------------------+---------------------------+ + register "common_soc_config" = "{ + .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[3] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + }, + .i2c[4] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[5] = { + .speed = I2C_SPEED_FAST, + }, + }" + + device domain 0 on + device ref igpu on + probe DISPLAY DISPLAY_PRESENT + chip drivers/gfx/generic + register "device_count" = "5" + # DDIA for eDP + register "device[0].name" = ""LCD0"" + register "device[0].type" = "panel" + # DDIB for HDMI + # If HDMI is not enumerated in the kernel, then no GFX device should be added for DDIB + register "device[1].name" = ""DD01"" + # TCP0 (DP-1) for port C0 + register "device[2].name" = ""DD02"" + register "device[2].use_pld" = "true" + register "device[2].pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + # TCP1 (DP-2) for port C1 + register "device[3].name" = ""DD03"" + register "device[3].use_pld" = "true" + register "device[3].pld" = "ACPI_PLD_TYPE_C(LEFT, RIGHT, ACPI_PLD_GROUP(2, 1))" + # TCP2 (DP-3) for port C2 + register "device[4].name" = ""DD04"" + register "device[4].use_pld" = "true" + register "device[4].pld" = "ACPI_PLD_TYPE_C(RIGHT, LEFT, ACPI_PLD_GROUP(3, 1))" + device generic 0 on end + end + end + + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""DDR_SOC"" + register "options.tsr[1].desc" = ""Ambient"" + register "options.tsr[2].desc" = ""Charger"" + register "options.tsr[3].desc" = ""wwan"" + + ## Active Policy + # FIXME: below values are initial reference values only + register "policies.active" = "{ + [0] = { + .target = DPTF_TEMP_SENSOR_0, + .thresholds = { + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), + } + }, + [1] = { + .target = DPTF_TEMP_SENSOR_1, + .thresholds = { + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), + } + }, + [2] = { + .target = DPTF_TEMP_SENSOR_2, + .thresholds = { + TEMP_PCT(75, 90), + TEMP_PCT(70, 80), + TEMP_PCT(65, 70), + TEMP_PCT(60, 50), + } + }, + [3] = { + .target = DPTF_TEMP_SENSOR_3, + .thresholds = { + TEMP_PCT(75, 90), + TEMP_PCT(70, 80), + TEMP_PCT(65, 70), + TEMP_PCT(60, 60), + TEMP_PCT(55, 50), + TEMP_PCT(50, 40), + TEMP_PCT(45, 30), + } + } + }" + + ## Passive Policy + # TODO: below values are initial reference values only + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 95, 5000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 80, 5000), + [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 80, 5000), + [3] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_2, 75, 5000), + [4] = DPTF_PASSIVE(CPU, TEMP_SENSOR_3, 80, 5000), + }" + + ## Critical Policy + # TODO: below values are initial reference values only + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 105, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 85, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 85, SHUTDOWN), + [3] = DPTF_CRITICAL(TEMP_SENSOR_2, 85, SHUTDOWN), + [4] = DPTF_CRITICAL(TEMP_SENSOR_3, 85, SHUTDOWN), + }" + + ## Power Limits Control + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 25000, + .max_power = 25000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 95000, + .max_power = 95000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 3000 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + + ## Fan Performance Control (Percent, Speed, Noise, Power) + register "controls.fan_perf" = "{ + [0] = { 90, 6700, 220, 2200, }, + [1] = { 80, 5800, 180, 1800, }, + [2] = { 70, 5000, 145, 1450, }, + [3] = { 60, 4900, 115, 1150, }, + [4] = { 50, 3838, 90, 900, }, + [5] = { 40, 2904, 55, 550, }, + [6] = { 30, 2337, 30, 300, }, + [7] = { 20, 1608, 15, 150, }, + [8] = { 10, 800, 10, 100, }, + [9] = { 0, 0, 0, 50, } + }" + + ## Fan options + register "options.fan.fine_grained_control" = "true" + register "options.fan.step_size" = "2" + + device generic 0 alias dptf_policy on end + end + end + + device ref ipu on + chip drivers/intel/mipi_camera + register "acpi_uid" = "0x50000" + register "acpi_name" = ""IPU0"" + register "device_type" = "INTEL_ACPI_CAMERA_CIO2" + register "cio2_num_ports" = "2" + register "cio2_lanes_used" = "{4,2}" # 4 and 2 CSI Camera lanes are used + register "cio2_lane_endpoint[0]" = ""^I2C1.CAM0"" + register "cio2_lane_endpoint[1]" = ""^I2C2.CAM1"" + register "cio2_prt[0]" = "0" + register "cio2_prt[1]" = "2" + device generic 0 on + probe UFC UFC_MIPI + probe WFC WFC_MIPI + end + end + end + + device ref iaa off end + + device ref thc0 on + probe TOUCHSCREEN TOUCHSCREEN_THC_SPI + probe TOUCHSCREEN TOUCHSCREEN_THC_I2C + # THC0 is function 0; hence it needs to be enabled when THC1 is to be enabled. + probe TOUCHPAD TOUCHPAD_THC_I2C + end + device ref thc1 on + probe TOUCHPAD TOUCHPAD_THC_I2C + end + + device ref tbt_pcie_rp0 on end + device ref tbt_pcie_rp1 on end + device ref tbt_pcie_rp2 on end + device ref tbt_pcie_rp3 on end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(4, 2)" + device ref tcss_usb3_port0 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C1"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 2)" + device ref tcss_usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C2"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device ref tcss_usb3_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C3"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref tcss_usb3_port3 on end + end + end + end + end + + device ref tcss_dma0 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port0 as dfp[0].typec_port + device generic 0 on end + end + chip drivers/intel/usb4/retimer + register "dfp[1].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port1 as dfp[1].typec_port + device generic 0 on end + end + end + device ref tcss_dma1 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port2 as dfp[0].typec_port + device generic 0 on end + end + chip drivers/intel/usb4/retimer + register "dfp[1].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B21)" + use tcss_usb3_port3 as dfp[1].typec_port + device generic 0 on end + end + end + + device ref ish on + probe ISH ISH_ENABLE + probe FP FP_PRESENT + chip drivers/intel/ish + register "add_acpi_dma_property" = "true" + device generic 0 on end + end + end + + device ref xhci on + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C1"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(2, 1)" + device ref usb2_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C2"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 1)" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C3"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb2_port4 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 1"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(5, 1)" + device ref usb2_port5 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 2"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(6, 1)" + device ref usb2_port6 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port 3"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(7, 1)" + device ref usb2_port7 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A16)" + device ref usb2_port8 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port 1"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(1, 2)" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port 2"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device ref usb3_port2 on end + end + end + end + end + + device ref ufs on + probe STORAGE STORAGE_UFS + probe STORAGE STORAGE_UNKNOWN + end + + device ref pcie_rp2 on + probe CELLULAR CELLULAR_PCIE + register "pcie_rp[PCIE_RP(2)]" = "{ + .clk_src = 5, + .clk_req = 5, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D03)" + register "reset_off_delay_ms" = "20" + register "srcclk_pin" = "5" + register "ext_pm_support" = "ACPI_PCIE_RP_EMIT_ALL" + register "skip_on_off_support" = "true" + register "use_rp_mutex" = "true" + device generic 0 alias rp2_rtd3 on end + end + chip drivers/wwan/fm + register "fcpo_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A09)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B20)" + register "perst_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D03)" + register "wake_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E02)" + register "add_acpi_dma_property" = "true" + use rp2_rtd3 as rtd3dev + device generic 0 on end + end + end # WWAN + device ref pcie_rp3 on + probe SD SD_GENSYS + probe SD SD_BAYHUB + # Enable PCH PCIE x1 slot using CLK 3 + register "pcie_rp[PCIE_RP(3)]" = "{ + .clk_src = 2, + .clk_req = 2, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_A08)" + register "enable_delay_ms" = "100" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D19)" + register "reset_delay_ms" = "20" + register "srcclk_pin" = "2" + device generic 0 on end + end + end # PCIE x1 slot + device ref pcie_rp4 on + probe WIFI WIFI_PCIE_6 + probe WIFI WIFI_PCIE_7 + register "pcie_rp[PCH_RP(4)]" = "{ + .clk_src = 4, + .clk_req = 4, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_A11)" + register "srcclk_pin" = "4" + device pci 00.0 on end + end + chip drivers/wifi/generic + register "add_acpi_dma_property" = "true" + register "wake" = "GPE0_DW0_12" # GPP_A12 + use usb2_port7 as bluetooth_companion + device pci 00.0 on end + end + end # discrete WLAN + device ref pcie_rp5 on + probe STORAGE STORAGE_NVME_GEN4 + probe STORAGE STORAGE_UNKNOWN + register "pcie_rp[PCIE_RP(5)]" = "{ + .clk_src = 6, + .clk_req = 6, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "is_storage" = "true" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B10)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B09)" + register "srcclk_pin" = "6" + device generic 0 on end + end + end # Gen4 M.2 SSD + device ref pcie_rp9 on + probe STORAGE STORAGE_NVME_GEN5 + probe STORAGE STORAGE_UNKNOWN + register "pcie_rp[PCIE_RP(9)]" = "{ + .clk_src = 1, + .clk_req = 1, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "is_storage" = "true" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B16)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E03)" + register "srcclk_pin" = "1" + device generic 0 on end + end + end # Gen5 M.2 SSD + device ref cnvi_wifi on + probe WIFI WIFI_CNVI_6 + probe WIFI WIFI_CNVI_7 + chip drivers/wifi/generic + register "wake" = "GPE0_PME_B0" + register "add_acpi_dma_property" = "true" + register "enable_cnvi_ddr_rfim" = "true" + device generic 0 on end + end + end # CNVi + # NOTE: i2c0 is function 0; hence it needs to be enabled when any of i2c1-5 is enabled. + # TPM device is under i2c3. Therefore, i2c0 needs to be enabled anyways. + device ref i2c0 on end + device ref i2c1 on + chip drivers/intel/mipi_camera + register "acpi_hid" = ""OVTIDB10"" + register "acpi_uid" = "0" + register "acpi_name" = ""CAM0"" + register "chip_name" = ""Ov 13b10 Camera"" + register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" + + register "ssdb.vcm_type" = "0x0C" + register "vcm_name" = ""VCM1"" + + register "ssdb.lanes_used" = "4" + register "num_freq_entries" = "1" + register "link_freq[0]" = "560 * MHz" # 560 MHz + register "remote_name" = ""IPU0"" + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D3_COLD" + + register "has_power_resource" = "true" + #Controls + register "clk_panel.clks[0].clknum" = "0" # IMGCLKOUT_0 + register "clk_panel.clks[0].freq" = "1" #19.2 Mhz + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + register "gpio_panel.gpio[1].gpio_num" = "GPP_E10" #reset + + #_ON + register "on_seq.ops_cnt" = "4" + register "on_seq.ops[0]" = "SEQ_OPS_CLK_ENABLE(0, 0)" + register "on_seq.ops[1]" = "SEQ_OPS_GPIO_ENABLE(0, 2)" + register "on_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 1)" + register "on_seq.ops[3]" = "SEQ_OPS_GPIO_ENABLE(1, 1)" + + #_OFF + register "off_seq.ops_cnt" = "3" + register "off_seq.ops[0]" = "SEQ_OPS_CLK_DISABLE(0, 0)" + register "off_seq.ops[1]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" + register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 36 on + probe WFC WFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "3" + register "acpi_name" = ""VCM1"" + register "chip_name" = ""DW AF VCM"" + register "device_type" = "INTEL_ACPI_CAMERA_VCM" + + register "vcm_compat" = ""dongwoon,dw9714"" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 0C on + probe WFC WFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "1" + register "acpi_name" = ""NVM1"" + register "chip_name" = ""BRCA016GWZ"" + register "device_type" = "INTEL_ACPI_CAMERA_NVM" + + register "nvm_compat" = ""atmel,24c16"" + + register "nvm_size" = "0x800" + register "nvm_pagesize" = "0x01" + register "nvm_readonly" = "0x01" + register "nvm_width" = "0x08" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C05" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 50 on + probe WFC WFC_MIPI + end + end + end # I2C1 + device ref i2c2 on + chip drivers/intel/mipi_camera + register "acpi_hid" = ""OVTIDB10"" + register "acpi_uid" = "0" + register "acpi_name" = ""CAM1"" + register "chip_name" = ""Ov 13b10 Camera"" + register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" + + register "ssdb.vcm_type" = "0x0C" + register "vcm_name" = ""VCM1"" + + register "ssdb.lanes_used" = "2" + register "num_freq_entries" = "1" + register "link_freq[0]" = "560 * MHz" # 560 MHz + register "remote_name" = ""IPU0"" + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D3_COLD" + + register "has_power_resource" = "true" + #Controls + register "clk_panel.clks[0].clknum" = "1" # IMGCLKOUT_1 + register "clk_panel.clks[0].freq" = "1" #19.2 Mhz + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + register "gpio_panel.gpio[1].gpio_num" = "GPP_E01" #reset + + #_ON + register "on_seq.ops_cnt" = "4" + register "on_seq.ops[0]" = "SEQ_OPS_CLK_ENABLE(0, 0)" + register "on_seq.ops[1]" = "SEQ_OPS_GPIO_ENABLE(0, 2)" + register "on_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 1)" + register "on_seq.ops[3]" = "SEQ_OPS_GPIO_ENABLE(1, 1)" + + #_OFF + register "off_seq.ops_cnt" = "3" + register "off_seq.ops[0]" = "SEQ_OPS_CLK_DISABLE(0, 0)" + register "off_seq.ops[1]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" + register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 36 on + probe UFC UFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "3" + register "acpi_name" = ""VCM1"" + register "chip_name" = ""DW AF VCM"" + register "device_type" = "INTEL_ACPI_CAMERA_VCM" + + register "vcm_compat" = ""dongwoon,dw9714"" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 0C on + probe UFC UFC_MIPI + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "1" + register "acpi_name" = ""NVM1"" + register "chip_name" = ""BRCA016GWZ"" + register "device_type" = "INTEL_ACPI_CAMERA_NVM" + + register "nvm_compat" = ""atmel,24c16"" + + register "nvm_size" = "0x800" + register "nvm_pagesize" = "0x01" + register "nvm_readonly" = "0x01" + register "nvm_width" = "0x08" + + register "max_dstate_for_probe" = "ACPI_DEVICE_SLEEP_D0" + + register "has_power_resource" = "true" + + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_C08" #power_enable + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 0)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 50 on + probe UFC UFC_MIPI + end + end + end # I2C2 + device ref i2c3 on + chip drivers/i2c/generic + register "hid" = ""RTL5682"" + register "name" = ""RT58"" + register "desc" = ""Headset Codec"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_F17)" + # Set the jd_src to RT5668_JD1 for jack detection + register "property_count" = "1" + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-src"" + register "property_list[0].integer" = "1" + device i2c 1a on + probe AUDIO AUDIO_MAX98360_ALC5682I_I2S + end + end + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D15_IRQ)" + device i2c 50 on end + end + end # I2C3 + device ref i2c4 on + chip drivers/i2c/hid + register "generic.hid" = ""ELAN6918"" + register "generic.desc" = ""ELAN Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_E18_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E16)" + register "generic.reset_delay_ms" = "20" + register "generic.reset_off_delay_ms" = "2" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_F08)" + register "generic.enable_delay_ms" = "1" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 16 on + probe TOUCHSCREEN TOUCHSCREEN_LPSS_I2C + end + end + end # I2C4 + device ref i2c5 on + chip drivers/i2c/hid + register "generic.hid" = ""HFW68H"" + register "generic.desc" = ""Hynitron TOUCHPAD"" + register "generic.irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_A13_IRQ)" + register "generic.wake" = "GPE0_DW0_13" + register "generic.uid" = "5" + register "generic.detect" = "1" + register "hid_desc_reg_offset" = "0x20" + device i2c 2c on + probe TOUCHPAD TOUCHPAD_LPSS_I2C + end + end + end # I2C5 + + device ref gspi0 on + chip drivers/spi/acpi + register "name" = ""CRFP"" + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "uid" = "1" + register "compat_string" = ""google,cros-ec-spi"" + register "irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_D01_IRQ)" + register "wake" = "GPE0_DW1_01" + register "has_power_resource" = "true" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C15)" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E19)" + register "enable_delay_ms" = "3" + device spi 0 on + probe FP FP_PRESENT + end + end # FPMCU + end + + device ref smbus on end + device ref npk on end + device ref hda on + chip drivers/intel/soundwire + device generic 0 on + chip drivers/soundwire/alc711 + register "desc" = ""Headset Codec"" + register "alc711_address.version" = "SOUNDWIRE_VERSION_1_2" + register "alc711_address.class" = "MIPI_CLASS_SDCA" + register "alc711_address.part_id" = "MIPI_DEV_ID_REALTEK_ALC722" + # SoundWire Link 1 ID 1 + device generic 1.1 on + probe AUDIO AUDIO_ALC722_SNDW + end + end + chip drivers/soundwire/alc711 + register "desc" = ""Headset Codec"" + register "alc711_address.version" = "SOUNDWIRE_VERSION_1_2" + register "alc711_address.class" = "MIPI_CLASS_SDCA" + register "alc711_address.part_id" = "MIPI_DEV_ID_REALTEK_ALC721" + # SoundWire Link 3 ID 1 + device generic 3.1 on + probe AUDIO AUDIO_ALC721_SNDW + end + end + end + end + chip drivers/generic/max98357a + register "hid" = ""MX98360A"" + register "sdmode_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E19)" + register "sdmode_delay" = "5" + device generic 0 on + probe AUDIO AUDIO_MAX98360_ALC5682I_I2S + end + end + end + end +end diff --git a/src/mainboard/intel/ptlrvp/variants/ptlrvp/variant.c b/src/mainboard/intel/ptlrvp/variants/ptlrvp/variant.c new file mode 100644 index 0000000..c7aa7aa --- /dev/null +++ b/src/mainboard/intel/ptlrvp/variants/ptlrvp/variant.c @@ -0,0 +1,30 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpigen.h> +#include <baseboard/variants.h> +#include <fw_config.h> +#include <sar.h> + +const char *get_wifi_sar_cbfs_filename(void) +{ + return get_wifi_sar_fw_config_filename(FW_CONFIG_FIELD(WIFI)); +} + +void variant_update_soc_chip_config(struct soc_intel_pantherlake_config *config) +{ + config->cnvi_wifi_core = false; + config->cnvi_bt_core = false; + /* CNVi */ + if (fw_config_probe(FW_CONFIG(WIFI, WIFI_CNVI_6)) || + fw_config_probe(FW_CONFIG(WIFI, WIFI_CNVI_7))) { + config->cnvi_wifi_core = true; + config->cnvi_bt_core = true; + + if (fw_config_probe(FW_CONFIG(AUDIO, AUDIO_MAX98360_ALC5682I_I2S)) || + fw_config_probe(FW_CONFIG(AUDIO, AUDIO_ALC722_SNDW)) || + fw_config_probe(FW_CONFIG(AUDIO, AUDIO_ALC721_SNDW))) { + printk(BIOS_INFO, "BT audio offload configured.\n"); + config->cnvi_bt_audio_offload = true; + } + } +}
