Cliff Huang has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/72826 )
Change subject: src/soc/intel/common/block/pcie/rtd3: Fix root port _ON logic ......................................................................
_ON() calls _STA() at the beginning. If _STA() indicates the device is ON, it exits immediately. Before exiting, it needs to check if it was scheduled to be skipped first.
NOTE: RTD3 provides a way to skip _OFF() and _ON() methods following by a device reset such as WWAN device. When such device calls its _RST(), it increments OFSK. When the following _OFF() is called, it was scheduled to skip, it will aslo increments ONSK. Similarly, when the following _ON() is called, it checks if the previous _OFF was skipped or not. If skipped, it needs to do the same. In normal suspend/resume cases, these two variables remains '0'. No _OFF() and _ON() calls are skipped.
BUG=b:241850118 TEST=Use above functions and check the generated SSDT table after OS boot.
Signed-off-by: Cliff Huang cliff.huang@intel.com Change-Id: Id1ea2e78e98d334a90294ee6cdd14ae2de9b9b62 --- M src/soc/intel/common/block/pcie/rtd3/rtd3.c 1 file changed, 33 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/72826/2
