Attention is currently required from: Ashish Kumar Mishra, Karthik Ramasubramanian, Krishna P Bhat D, Shelley Chen, Sowmya Aralguppe.
Hello Ashish Kumar Mishra, Karthik Ramasubramanian, Krishna P Bhat D, Shelley Chen, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81931?usp=email
Change subject: mb/google/brox: Add romstage early graphics ......................................................................
Select MAINBOARD_USE_EARLY_LIBGFXINIT for brox to enable SOL image. This patch enables Sign of Life image during MRC training.
BUG=b:335369811 TEST=Able to boot to ChromeOS with SOL image.
CPU log: [0m[DEBUG] Boot Count incremented to 21[0m [0m[INFO ] CBFS: Found 'fspm.bin' @0x90f80 size 0xd0000 in mcache @0xfef89b10[0m [0m[INFO ] VB2:vb2_digest_init() 851968 bytes, hash algo 2, HW acceleration enabled[0m [0m[DEBUG] FMAP: area RW_MRC_CACHE found @ f10000 (65536 bytes)[0m [1m[NOTE ] MRC: no data in 'RW_MRC_CACHE'[0m [0m[SPEW ] bootmode is set to: 0 (boot with full config)[0m [0.384818] DP PHY mode status not complete [0.388911] DP PHY mode status not complete [0.393197] DP PHY mode status not complete [0.397484] DP PHY mode status not complete [0.401771] DP PHY mode status not complete [0.406057] DP PHY mode status not complete [0.410345] DP PHY mode status not complete [0.414632] DP PHY mode status not complete [0.418916] DP PHY mode status not complete [0.423203] DP PHY mode status not complete [0.427491] DP PHY mode status not complete [0.431777] DP PHY mode status not complete [0m[INFO ] Informing user on-display of memory training.[0m [0m[DEBUG] FMAP: area COREBOOT found @ 1877000 (7901184 bytes)[0m [1;4m[WARN ] CBFS: 'preram_locales' not found.[0m [7m[ERROR] ux_locales_get_text: preram_locales not found.[0m [0m[DEBUG] FMAP: area RW_ELOG found @ f20000 (16384 bytes)[0m [0m[INFO ] ELOG: NV offset 0xf20000 size 0x4000[0m [0m[INFO ] ELOG: area is 4096 bytes, full threshold 3842, shrink size 1024[0m [0m[INFO ] ELOG: Event(B8) added with size 10 at 2024-05-13 01:28:03
Change-Id: I1d4795825960bc58f8f7ef494b01aa975f3bc346 Signed-off-by: Sowmya Aralguppe sowmya.aralguppe@intel.com --- M src/mainboard/google/brox/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/81931/8
