Attention is currently required from: Angel Pons, David Milosevic, Maximilian Brune, Naresh Solanki, Nico Huber, Patrick Rudolph, Paul Menzel.
Hello Angel Pons, David Milosevic, Lean Sheng Tan, Maximilian Brune, Nico Huber, Patrick Rudolph, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/79103?usp=email
Change subject: mb/arm/rdn2: Add support for Arm Neoverse N2 ......................................................................
Add support for Arm Neoverse N2 Reference design.
Based on Arm Neoverse N2 reference design Revision: Release D
TEST=Build Arm Neoverse N2 & make sure there is no error.
Change-Id: I17908d3ce773d4a88924bafb1d0e9e2a043c7fbc Signed-off-by: Naresh Solanki naresh.solanki@9elements.com --- A src/mainboard/arm/Kconfig A src/mainboard/arm/Kconfig.name A src/mainboard/arm/rdn2/Kconfig A src/mainboard/arm/rdn2/Kconfig.name A src/mainboard/arm/rdn2/Makefile.inc A src/mainboard/arm/rdn2/board_info.txt A src/mainboard/arm/rdn2/bootblock.c A src/mainboard/arm/rdn2/cbmem.c A src/mainboard/arm/rdn2/chip.h A src/mainboard/arm/rdn2/devicetree.cb A src/mainboard/arm/rdn2/flash.fmd A src/mainboard/arm/rdn2/include/mainboard/addressmap.h A src/mainboard/arm/rdn2/mainboard.c A src/mainboard/arm/rdn2/media.c A src/mainboard/arm/rdn2/memlayout.ld A src/mainboard/arm/rdn2/mmio.c 16 files changed, 427 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/79103/3
