Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36619 )
Change subject: soc/intel/denverton_ns: make use of common cbmem_top_chipset ......................................................................
This replaces denverton_ns's own implementation of cbmem_top_chipset and selects the common code one.
Change-Id: Idae96aabe2807e465bb7ab0f29910757d0346ce9 Signed-off-by: Michael Niewöhner foss@mniewoehner.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/36619 Reviewed-by: Arthur Heymans arthur@aheymans.xyz Reviewed-by: Nico Huber nico.h@gmx.de Reviewed-by: David Guckian Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/denverton_ns/Kconfig M src/soc/intel/denverton_ns/acpi.c M src/soc/intel/denverton_ns/memmap.c M src/soc/intel/denverton_ns/systemagent.c 4 files changed, 7 insertions(+), 27 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved Arthur Heymans: Looks good to me, approved David Guckian: Looks good to me, but someone else must approve
diff --git a/src/soc/intel/denverton_ns/Kconfig b/src/soc/intel/denverton_ns/Kconfig index cb3713d..b7d3d1a 100644 --- a/src/soc/intel/denverton_ns/Kconfig +++ b/src/soc/intel/denverton_ns/Kconfig @@ -47,6 +47,7 @@ select SOC_INTEL_COMMON_BLOCK_PMC select ACPI_INTEL_HARDWARE_SLEEP_VALUES # select SOC_INTEL_COMMON_BLOCK_SA + select SOC_INTEL_COMMON_BLOCK_SA_FSP_TOLUM select SOC_INTEL_COMMON_BLOCK_FAST_SPI select SOC_INTEL_COMMON_BLOCK_GPIO select SOC_INTEL_COMMON_BLOCK_PCR diff --git a/src/soc/intel/denverton_ns/acpi.c b/src/soc/intel/denverton_ns/acpi.c index e969a04..48b67b0 100644 --- a/src/soc/intel/denverton_ns/acpi.c +++ b/src/soc/intel/denverton_ns/acpi.c @@ -81,7 +81,7 @@ gnvs->pcnt = dev_count_cpu();
/* Top of Low Memory (start of resource allocation) */ - gnvs->tolm = top_of_32bit_ram(); + gnvs->tolm = (uintptr_t)cbmem_top();
#if CONFIG(CONSOLE_CBMEM) /* Update the mem console pointer. */ diff --git a/src/soc/intel/denverton_ns/memmap.c b/src/soc/intel/denverton_ns/memmap.c index b4761db..c30f0e9 100644 --- a/src/soc/intel/denverton_ns/memmap.c +++ b/src/soc/intel/denverton_ns/memmap.c @@ -38,30 +38,6 @@ return ALIGN_DOWN(pci_read_config32(dev, reg), 1 * MiB); }
-/* Returns min power of 2 >= size */ -static inline u32 power_of_2(u32 size) -{ - return size ? 1 << (1 + log2(size - 1)) : 0; -} - -u32 top_of_32bit_ram(void) -{ - u32 iqat_region_size = 0; - u32 tseg_region_size = system_agent_region_base(TOLUD) - - system_agent_region_base(TSEGMB); - -/* - * Add IQAT region size if enabled. - */ -#if CONFIG(IQAT_ENABLE) - iqat_region_size = CONFIG_IQAT_MEMORY_REGION_SIZE; -#endif - return system_agent_region_base(TOLUD) - - power_of_2(iqat_region_size + tseg_region_size); -} - -void *cbmem_top_chipset(void) { return (void *)top_of_32bit_ram(); } - static inline uintptr_t smm_region_start(void) { return system_agent_region_base(TSEGMB); diff --git a/src/soc/intel/denverton_ns/systemagent.c b/src/soc/intel/denverton_ns/systemagent.c index cc1d696..00d5228 100644 --- a/src/soc/intel/denverton_ns/systemagent.c +++ b/src/soc/intel/denverton_ns/systemagent.c @@ -15,6 +15,7 @@ * GNU General Public License for more details. */
+#include <cbmem.h> #include <console/console.h> #include <device/mmio.h> #include <device/pci_ops.h> @@ -209,6 +210,7 @@ unsigned long index; struct resource *resource; uint64_t mc_values[NUM_MAP_ENTRIES]; + uintptr_t top_of_ram;
/* Read in the MAP registers and report their values. */ mc_read_map_entries(dev, &mc_values[0]); @@ -246,6 +248,7 @@ * PCI_BASE_ADDRESS_0. */ index = 0; + top_of_ram = (uintptr_t)cbmem_top();
/* 0 - > 0xa0000 */ base_k = 0; @@ -254,12 +257,12 @@
/* 0x100000 -> top_of_ram */ base_k = 0x100000 >> 10; - size_k = (top_of_32bit_ram() >> 10) - base_k; + size_k = (top_of_ram >> 10) - base_k; ram_resource(dev, index++, base_k, size_k);
/* top_of_ram -> TSEG */ resource = new_resource(dev, index++); - resource->base = top_of_32bit_ram(); + resource->base = top_of_ram; resource->size = mc_values[TSEG_REG] - resource->base; resource->flags = IORESOURCE_MEM | IORESOURCE_FIXED | IORESOURCE_STORED | IORESOURCE_RESERVE |
