Edward O'Callaghan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40482 )
Change subject: mb/google/puff: update USB2 strength ......................................................................
Based on USB SI report to fine tune the strength for USB2 port0.
BRANCH=none BUG=b:153590143 TEST=build and test USB2 port0 function works fine.
Change-Id: I070c9e1c8153a680fb8f827889738a764d7ea9f4 Signed-off-by: Tim Chen tim-chen@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/40482 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Kangheui Won khwon@chromium.org Reviewed-by: Edward O'Callaghan quasisec@chromium.org --- M src/mainboard/google/hatch/variants/duffy/overridetree.cb M src/mainboard/google/hatch/variants/kaisa/overridetree.cb M src/mainboard/google/hatch/variants/puff/overridetree.cb 3 files changed, 24 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Edward O'Callaghan: Looks good to me, approved Kangheui Won: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/hatch/variants/duffy/overridetree.cb b/src/mainboard/google/hatch/variants/duffy/overridetree.cb index ade12c5..d7acbd7 100644 --- a/src/mainboard/google/hatch/variants/duffy/overridetree.cb +++ b/src/mainboard/google/hatch/variants/duffy/overridetree.cb @@ -21,7 +21,14 @@ }"
# USB configuration - register "usb2_ports[0]" = "USB2_PORT_MID(OC2)" # Type-A Port 2 + register "usb2_ports[0]" = "{ + .enable = 1, + .ocpin = OC2, + .tx_bias = USB2_BIAS_0MV, + .tx_emp_enable = USB2_PRE_EMP_ON, + .pre_emp_bias = USB2_BIAS_11P25MV, + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, + }" # Type-A Port 2 register "usb2_ports[1]" = "{ .enable = 1, .ocpin = OC1, diff --git a/src/mainboard/google/hatch/variants/kaisa/overridetree.cb b/src/mainboard/google/hatch/variants/kaisa/overridetree.cb index e2380f4..f5e85bd 100644 --- a/src/mainboard/google/hatch/variants/kaisa/overridetree.cb +++ b/src/mainboard/google/hatch/variants/kaisa/overridetree.cb @@ -21,7 +21,14 @@ }"
# USB configuration - register "usb2_ports[0]" = "USB2_PORT_MID(OC2)" # Type-A Port 2 + register "usb2_ports[0]" = "{ + .enable = 1, + .ocpin = OC2, + .tx_bias = USB2_BIAS_0MV, + .tx_emp_enable = USB2_PRE_EMP_ON, + .pre_emp_bias = USB2_BIAS_11P25MV, + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, + }" # Type-A Port 2 register "usb2_ports[1]" = "{ .enable = 1, .ocpin = OC1, diff --git a/src/mainboard/google/hatch/variants/puff/overridetree.cb b/src/mainboard/google/hatch/variants/puff/overridetree.cb index d869b28..31efc4a 100644 --- a/src/mainboard/google/hatch/variants/puff/overridetree.cb +++ b/src/mainboard/google/hatch/variants/puff/overridetree.cb @@ -24,7 +24,14 @@ # NOTE: This only applies to Puff, # usb2_ports[1] and usb2_ports[3] were swapped on # reference schematics after Puff has been built. - register "usb2_ports[0]" = "USB2_PORT_MID(OC2)" # Type-A Port 2 + register "usb2_ports[0]" = "{ + .enable = 1, + .ocpin = OC2, + .tx_bias = USB2_BIAS_0MV, + .tx_emp_enable = USB2_PRE_EMP_ON, + .pre_emp_bias = USB2_BIAS_11P25MV, + .pre_emp_bit = USB2_HALF_BIT_PRE_EMP, + }" # Type-A Port 2 register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Type-C Port register "usb2_ports[2]" = "{ .enable = 1,
