Keith Hui has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38600 )
Change subject: i82371eb: Drop KB/Mouse/FDC declarations ......................................................................
These are declared by superio.
Change-Id: I1db4aca7d682ec298b8f53cfab6ffe661e8ff6e0 Signed-off-by: Keith Hui buurin@gmail.com --- M src/southbridge/intel/i82371eb/acpi/isabridge.asl 1 file changed, 0 insertions(+), 68 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/38600/1
diff --git a/src/southbridge/intel/i82371eb/acpi/isabridge.asl b/src/southbridge/intel/i82371eb/acpi/isabridge.asl index 2f842d6..6a0cd45 100644 --- a/src/southbridge/intel/i82371eb/acpi/isabridge.asl +++ b/src/southbridge/intel/i82371eb/acpi/isabridge.asl @@ -14,74 +14,6 @@ * GNU General Public License for more details. */
-/* - * ISA portions taken from QEMU acpi-dsdt.dsl. - */ - -// Intel LPC Bus Device - 0:4.0 -Device (LPCB) -{ - Name(_ADR, 0x00040000) - - OperationRegion(PCIC, PCI_Config, 0x00, 0x100) - - /* PS/2 keyboard (seems to be important for WinXP install) */ - Device (KBD) - { - Name (_HID, EisaId ("PNP0303")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - IO (Decode16, 0x0060, 0x0060, 0x01, 0x01) - IO (Decode16, 0x0064, 0x0064, 0x01, 0x01) - IRQNoFlags () {1} - }) - Return (TMP) - } - } - - /* PS/2 mouse */ - Device (MOU) - { - Name (_HID, EisaId ("PNP0F13")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - IRQNoFlags () {12} - }) - Return (TMP) - } - } - - /* PS/2 floppy controller */ - Device (FDC0) - { - Name (_HID, EisaId ("PNP0700")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (BUF0, ResourceTemplate () { - IO (Decode16, 0x03F2, 0x03F2, 0x00, 0x04) - IO (Decode16, 0x03F7, 0x03F7, 0x00, 0x01) - IRQNoFlags () {6} - DMA (Compatibility, NotBusMaster, Transfer8) {2} - }) - Return (BUF0) - } - } -} - Device(MBRS) { Name (_HID, EisaId ("PNP0C02")) Name (_UID, 0x01)
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38600 )
Patch Set 2:
(2 comments)
Did you verify, that `acpidump` still contains that?
https://review.coreboot.org/c/coreboot/+/38600/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38600/2//COMMIT_MSG@7 PS2, Line 7: i82371eb sb/intel/i82371cb:
https://review.coreboot.org/c/coreboot/+/38600/2/src/southbridge/intel/i8237... File src/southbridge/intel/i82371eb/acpi/isabridge.asl:
https://review.coreboot.org/c/coreboot/+/38600/2/src/southbridge/intel/i8237... PS2, Line 83: } I do not see these parts in `src/superio/winbond/w83977tf/acpi/`.
Keith Hui has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38600 )
Patch Set 2:
I checked our dsdt against ones extracted from factory bios images for the entire p2b family.
Oh and this file was not referenced anywhere else until another patch down this train.
It imports a common pnp declaration from superio/common
Patch Set 2:
Did you test a PS/2 mouse? I find KBC definitions(?) in `src/superio/acpi/`, but not MOU and FDC0.
``` $ git grep MOU src/superio/ src/superio/common/ssdt.c: {ACPI_HID_MOUSE, {60, 64, }, {12, } }, src/superio/common/ssdt.c: {ACPI_HID_MOUSE, "PS2 Mouse"}, src/superio/ite/it8783ef/acpi/superio.asl: * 0x6 MOUSE Implemented, untested src/superio/ite/it8786e/acpi/superio.asl: * 0x6 MOUSE Implemented, untested $ git grep FDC0 src/superio/ src/superio/ite/it8772f/acpi/superio.asl:#ifdef SIO_ENABLE_FDC0 src/superio/ite/it8772f/acpi/superio.asl: Device (FDC0) // Floppy controller src/superio/smsc/sio1007/acpi/superio.asl:#ifdef SIO_ENABLE_FDC0 src/superio/smsc/sio1007/acpi/superio.asl: Device (FDC0) // Floppy controller src/superio/winbond/w83627hf/acpi/superio.asl: Device (FDC0) { src/superio/winbond/w83977tf/acpi/superio.asl:Device (FDC0) ```
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38600 )
Patch Set 2: Code-Review+1
Patch Set 2:
Did you test a PS/2 mouse? I find KBC definitions(?) in `src/superio/acpi/`, but not MOU and FDC0. […]
Mouse works. Just tested using gpm.
Hello build bot (Jenkins), Angel Pons, Patrick Rudolph,
Change subject: sb/intel/i82371eb: Drop KB/Mouse/FDC declarations ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/38600/3
Patch Set 3:
(2 comments)
sb/intel/i82371cb:
Done
Ack
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/38600/5
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/38600/6
Patch Set 6: Code-Review+2
(2 comments)
https://review.coreboot.org/c/coreboot/+/38600/6//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38600/6//COMMIT_MSG@7 PS6, Line 7: KB KBD?
https://review.coreboot.org/c/coreboot/+/38600/6//COMMIT_MSG@9 PS6, Line 9: by superio by the Super I/O.
Patch Set 8:
(2 comments)
KBD?
Ack
by the Super I/O.
Ack
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38600 )
Change-Id: I1db4aca7d682ec298b8f53cfab6ffe661e8ff6e0 Signed-off-by: Keith Hui buurin@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/38600 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/southbridge/intel/i82371eb/acpi/isabridge.asl 1 file changed, 0 insertions(+), 68 deletions(-)
diff --git a/src/southbridge/intel/i82371eb/acpi/isabridge.asl b/src/southbridge/intel/i82371eb/acpi/isabridge.asl index 55a0ca5..1298618 100644 --- a/src/southbridge/intel/i82371eb/acpi/isabridge.asl +++ b/src/southbridge/intel/i82371eb/acpi/isabridge.asl @@ -1,74 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */ /* This file is part of the coreboot project. */
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38600 )
Patch Set 9:
Automatic boot test returned (PASS/FAIL/TOTAL): 4/0/4 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/2456 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2455 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2454 EMULATION_QEMU_AARCH64_FIT_SUPPORT_TIMESTAMPS using payload LinuxBoot_u-root_kexec_AARCH64 : SUCCESS : https://lava.9esec.io/r/2453
