Leroy P Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15126
commit 88fe4193a543aa662c46b19047dc59a453f07840 Author: Lee Leahy leroy.p.leahy@intel.com Date: Sun Jun 5 18:41:00 2016 -0700
arch/x86: Support "weak" BIST and TSC save routines
Not all x86 architectures support the mm register set. Provide a "weak" routine that saves BIST in mm0 and a "weak" routine that saves the TSC value in mm2:mm1. Use the Kconfig value BOOTBLOCK_SAVE_BIST to specify the "weak" routine to save the BIST value. Use the Kconfig value BOOTBLOCK_SAVE_TIMESTAMP to specify the "weak" routine to get and save the TSC value as the early timestamp.
TEST=Build and run on Amenia and Galileo Gen2.
Change-Id: I8119e74664ac3522c011767d424d441cd62545ce Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/arch/x86/Kconfig | 16 +++++++++++++++ src/arch/x86/bootblock_crt0.S | 19 ++++++++++++------ src/arch/x86/bootblock_save_bist.inc | 27 +++++++++++++++++++++++++ src/arch/x86/bootblock_save_timestamp.inc | 33 +++++++++++++++++++++++++++++++ 4 files changed, 89 insertions(+), 6 deletions(-)
diff --git a/src/arch/x86/Kconfig b/src/arch/x86/Kconfig index 724c4db..cdeb02d 100644 --- a/src/arch/x86/Kconfig +++ b/src/arch/x86/Kconfig @@ -126,6 +126,22 @@ config BOOTBLOCK_NORTHBRIDGE_INIT config BOOTBLOCK_RESETS string
+config BOOTBLOCK_SAVE_BIST + string + default src/arch/x86/bootblock_save_bist.inc + help + Specify the file to use to save the BIST value. The default file + uses register MM0. Another file is necessary when the CPU does not + support the MMx register set. + +config BOOTBLOCK_SAVE_TIMESTAMP + string + default src/arch/x86/bootblock_save_timestamp.inc + help + Specify the file to use to save the timestamp value. The default + file uses registers MM1 and MM2. Another file is necessary when + the CPU does not support the MMx register set. + config HAVE_CMOS_DEFAULT def_bool n
diff --git a/src/arch/x86/bootblock_crt0.S b/src/arch/x86/bootblock_crt0.S index 7292b8b..4e49bce 100644 --- a/src/arch/x86/bootblock_crt0.S +++ b/src/arch/x86/bootblock_crt0.S @@ -34,12 +34,18 @@
bootblock_protected_mode_entry: - /* Save BIST result */ - movd %eax, %mm0 - /* Save an early timestamp */ - rdtsc - movd %eax, %mm1 - movd %edx, %mm2 + + /* Save BIST result: + * eax: BIST result + */ +#ifdef CONFIG_BOOTBLOCK_SAVE_BIST +#include CONFIG_BOOTBLOCK_SAVE_BIST +#endif + + /* Save the timestamp value */ +#ifdef CONFIG_BOOTBLOCK_SAVE_TIMESTAMP +#include CONFIG_BOOTBLOCK_SAVE_TIMESTAMP +#endif
#if !IS_ENABLED(CONFIG_SSE) enable_sse: @@ -53,4 +59,5 @@ enable_sse: #endif /* IS_ENABLED(CONFIG_SSE) */
/* We're done. Now it's up to platform-specific code */ +jump_to_soc_code: jmp bootblock_pre_c_entry diff --git a/src/arch/x86/bootblock_save_bist.inc b/src/arch/x86/bootblock_save_bist.inc new file mode 100644 index 0000000..6474a8c --- /dev/null +++ b/src/arch/x86/bootblock_save_bist.inc @@ -0,0 +1,27 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Alexandru Gagniuc mr.nuke.me@gmail.com + * Copyright (C) 2016, Intel Corporation + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Default BIST save routine. + */ + +.global save_bist + + /* Save BIST result: + * eax: BIST result + */ + +save_bist: + movd %eax, %mm0 diff --git a/src/arch/x86/bootblock_save_timestamp.inc b/src/arch/x86/bootblock_save_timestamp.inc new file mode 100644 index 0000000..d1cbe8a --- /dev/null +++ b/src/arch/x86/bootblock_save_timestamp.inc @@ -0,0 +1,33 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Alexandru Gagniuc mr.nuke.me@gmail.com + * Copyright (C) 2016, Intel Corporation + + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Default timestamp save routine. + */ + +.global save_timestamp + + /* Get an early timestamp */ + rdtsc + + /* Save the timestamp value: + * eax: Low 32-bits of timestamp + * edx: High 32-bits of timestamp + */ + +save_timestamp: + movd %eax, %mm1 + movd %edx, %mm2 +
