Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6114
commit fb57b79b0007ba9f5c8dea0e5182d572f607f32c Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Thu Jun 26 15:02:40 2014 +1000
drivers/spi: Sanitize headers from preprocessor abuse
Continuing on from the rational given in:
a173a62 Remove guarding #includes by CONFIG_FOO combinations
Change-Id: I35c636ee7c0b106323b3e4b90629f7262750f8bd Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/drivers/spi/adesto.c | 1 + src/drivers/spi/amic.c | 1 + src/drivers/spi/eon.c | 1 + src/drivers/spi/gigadevice.c | 1 + src/drivers/spi/macronix.c | 1 + src/drivers/spi/spansion.c | 1 + src/drivers/spi/spi_flash.c | 7 +++---- src/drivers/spi/spi_flash_internal.h | 5 +++++ src/drivers/spi/sst.c | 1 + src/drivers/spi/stmicro.c | 1 + src/drivers/spi/winbond.c | 1 + src/include/cpu/x86/smm.h | 7 ++++--- 12 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/src/drivers/spi/adesto.c b/src/drivers/spi/adesto.c index 83be8b8..669050d 100644 --- a/src/drivers/spi/adesto.c +++ b/src/drivers/spi/adesto.c @@ -12,6 +12,7 @@
#include <stdlib.h> #include <spi_flash.h> + #include "spi_flash_internal.h"
/* at25dfxx-specific commands */ diff --git a/src/drivers/spi/amic.c b/src/drivers/spi/amic.c index fa17036..042efbe 100644 --- a/src/drivers/spi/amic.c +++ b/src/drivers/spi/amic.c @@ -10,6 +10,7 @@
/* A25L-specific commands */ diff --git a/src/drivers/spi/eon.c b/src/drivers/spi/eon.c index 5a74b84..85567eb 100644 --- a/src/drivers/spi/eon.c +++ b/src/drivers/spi/eon.c @@ -6,6 +6,7 @@
/* EN25Q128-specific commands */ diff --git a/src/drivers/spi/gigadevice.c b/src/drivers/spi/gigadevice.c index 5a8f82f..8cac2d4 100644 --- a/src/drivers/spi/gigadevice.c +++ b/src/drivers/spi/gigadevice.c @@ -28,6 +28,7 @@
/* GD25Pxx-specific commands */ diff --git a/src/drivers/spi/macronix.c b/src/drivers/spi/macronix.c index bbc3704..602f7fc 100644 --- a/src/drivers/spi/macronix.c +++ b/src/drivers/spi/macronix.c @@ -31,6 +31,7 @@
/* MX25xx-specific commands */ diff --git a/src/drivers/spi/spansion.c b/src/drivers/spi/spansion.c index 6dd6df9..fc96e40 100644 --- a/src/drivers/spi/spansion.c +++ b/src/drivers/spi/spansion.c @@ -27,6 +27,7 @@
/* S25FLxx-specific commands */ diff --git a/src/drivers/spi/spi_flash.c b/src/drivers/spi/spi_flash.c index f3a5906..626d506 100644 --- a/src/drivers/spi/spi_flash.c +++ b/src/drivers/spi/spi_flash.c @@ -7,14 +7,13 @@ * Licensed under the GPL-2 or later. */
+#include <cpu/x86/smm.h> +#include <delay.h> #include <stdlib.h> #include <string.h> #include <spi-generic.h> #include <spi_flash.h> -#include <delay.h> -#ifdef __SMM__ -#include <cpu/x86/smm.h> -#endif + #include "spi_flash_internal.h" #include <timer.h>
diff --git a/src/drivers/spi/spi_flash_internal.h b/src/drivers/spi/spi_flash_internal.h index e696948..6f18484 100644 --- a/src/drivers/spi/spi_flash_internal.h +++ b/src/drivers/spi/spi_flash_internal.h @@ -4,6 +4,9 @@ * Copyright (C) 2008 Atmel Corporation */
+#ifndef SPI_FLASH_INTERNAL_H +#define SPI_FLASH_INTERNAL_H + /* Common parameters -- kind of high, but they should only occur when there * is a problem (and well your system already is broken), so err on the side * of caution in case we're dealing with slower SPI buses and/or processors. @@ -83,3 +86,5 @@ struct spi_flash *spi_flash_probe_gigadevice(struct spi_slave *spi, u8 *idcode); struct spi_flash *spi_flash_probe_adesto(struct spi_slave *spi, u8 *idcode); struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode); + +#endif /* SPI_FLASH_INTERNAL_H */ diff --git a/src/drivers/spi/sst.c b/src/drivers/spi/sst.c index 3cf6c50..d81888a 100644 --- a/src/drivers/spi/sst.c +++ b/src/drivers/spi/sst.c @@ -14,6 +14,7 @@
#define CMD_SST_WREN 0x06 /* Write Enable */ diff --git a/src/drivers/spi/stmicro.c b/src/drivers/spi/stmicro.c index af23853..b35851f 100644 --- a/src/drivers/spi/stmicro.c +++ b/src/drivers/spi/stmicro.c @@ -29,6 +29,7 @@
/* M25Pxx-specific commands */ diff --git a/src/drivers/spi/winbond.c b/src/drivers/spi/winbond.c index 52c7b61..029248f 100644 --- a/src/drivers/spi/winbond.c +++ b/src/drivers/spi/winbond.c @@ -6,6 +6,7 @@
/* M25Pxx-specific commands */ diff --git a/src/include/cpu/x86/smm.h b/src/include/cpu/x86/smm.h index f63420f..7b529e0 100644 --- a/src/include/cpu/x86/smm.h +++ b/src/include/cpu/x86/smm.h @@ -24,6 +24,9 @@ #ifndef CPU_X86_SMM_H #define CPU_X86_SMM_H
+#include <arch/cpu.h> +#include <types.h> + #define SMM_DEFAULT_BASE 0x30000 #define SMM_DEFAULT_SIZE 0x10000
@@ -33,8 +36,6 @@ #define SMM_ENTRY_OFFSET 0x8000 #define SMM_SAVE_STATE_BEGIN(x) (SMM_ENTRY_OFFSET + (x))
-#include <arch/cpu.h> -#include <types.h> typedef struct { u16 es_selector; u16 es_attributes; @@ -581,4 +582,4 @@ int smm_load_module(void *smram, int size, struct smm_loader_params *params); void *backup_default_smm_area(void); void restore_default_smm_area(void *smm_save_area);
-#endif +#endif /* CPU_X86_SMM_H */
