Attention is currently required from: Furquan Shaikh, Tim Wawrzynczak, Amanda Hwang. Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, EricR Lai,
https://review.coreboot.org/c/coreboot/+/55000
Change subject: util/spd_tools: Modify MT53E1G32D2NP-046 WT:B LPDDR4 config ......................................................................
CB:52586 ("util/spd_tools: Add MT53E1G32D2NP-046 WT:B LPDDR4 config") incorrectly set ranks per channel to 1. However, MT53E1G32D2NP-046 WT:B part has 2 channels per die and 2 physical dies. Each channel in each die shares DQ-DQS lines with the channel in other die and uses separate CS lines. Thus, number of ranks per channel is 2.
This change fixes the attribute ranksPerChannel for MT53E1G32D2NP-046 WT:B in LP4x global config by setting it to 2.
BUG=b:186616388
Change-Id: Iba87754ca04c2e026a9cbc8ef07412b467140cba Signed-off-by: Amanda Huang amanda_hwang@compal.corp-partner.google.com --- M util/spd_tools/lp4x/global_lp4x_mem_parts.json.txt 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/55000/4
