Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14541
commit 845756a0d27c3b1acc1078332e0e2e6649de8a05 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Fri Apr 29 00:38:29 2016 -0500
nb/amd/mct_ddr3: Fix x4 DIMM receiver enable training on Fam15h
The existing Family 51h receiver enable training code stored temporary delay values in the wrong variables, leading to the requisite averaging of delays across nibbles not being applied. This in turn made x4 DIMMs less stable than they should have been.
Store temporary nibble delay values in a dedicated array.
Change-Id: Ic5da898af7d689db4110211f89b886ccdbb5f78f Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c | 49 ++++++++++++++++------------ 1 file changed, 28 insertions(+), 21 deletions(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c b/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c index c8c75e1..f0ee6af 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c @@ -1194,6 +1194,7 @@ static void dqsTrainRcvrEn_SW_Fam15(struct MCTStatStruc *pMCTstat, uint16_t initial_seed; uint8_t train_both_nibbles; uint16_t current_total_delay[MAX_BYTE_LANES]; + uint16_t nibble0_current_total_delay[MAX_BYTE_LANES]; uint16_t dqs_ret_pass1_total_delay[MAX_BYTE_LANES]; uint16_t rank0_current_total_delay[MAX_BYTE_LANES]; uint16_t phase_recovery_delays[MAX_BYTE_LANES]; @@ -1419,19 +1420,11 @@ static void dqsTrainRcvrEn_SW_Fam15(struct MCTStatStruc *pMCTstat, for (lane = 0; lane < lane_count; lane++) { current_total_delay[lane] = (phase_recovery_delays[lane] & 0x1f); current_total_delay[lane] |= ((seed_gross[lane] + ((phase_recovery_delays[lane] >> 5) & 0x1f) - seed_pre_gross[lane] + 1) << 5); - if (nibble == 0) { - if (lane == 8) - pDCTstat->CH_D_BC_RCVRDLY[Channel][dimm] = current_total_delay[lane]; - else - pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane] = current_total_delay[lane]; - } else { + if (nibble == 1) { /* 2.10.5.8.2 (1) * Average the trained values of both nibbles on x4 DIMMs */ - if (lane == 8) - pDCTstat->CH_D_BC_RCVRDLY[Channel][dimm] = (pDCTstat->CH_D_BC_RCVRDLY[Channel][dimm] + current_total_delay[lane]) / 2; - else - pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane] = (pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane] + current_total_delay[lane]) / 2; + current_total_delay[lane] = (nibble0_current_total_delay[lane] + current_total_delay[lane]) / 2; } }
@@ -1441,26 +1434,40 @@ static void dqsTrainRcvrEn_SW_Fam15(struct MCTStatStruc *pMCTstat, Channel, dimm, nibble, lane, current_total_delay[lane], pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane]); #endif write_dqs_receiver_enable_control_registers(current_total_delay, dev, Channel, dimm, index_reg); - }
- if (rank == 0) { - /* Back up the Rank 0 delays for later use */ - memcpy(rank0_current_total_delay, current_total_delay, sizeof(current_total_delay)); + if (nibble == 0) { + /* Back up the Nibble 0 delays for later use */ + memcpy(nibble0_current_total_delay, current_total_delay, sizeof(current_total_delay)); + } }
- if (rank == 1) { - /* 2.10.5.8.2 (8) - * Compute the average delay across both ranks and program the result into - * the DQS Receiver Enable delay registers - */ + if (_2Ranks) { + if (rank == 0) { + /* Back up the Rank 0 delays for later use */ + memcpy(rank0_current_total_delay, current_total_delay, sizeof(current_total_delay)); + } + if (rank == 1) { + /* 2.10.5.8.2 (8) + * Compute the average delay across both ranks and program the result into + * the DQS Receiver Enable delay registers + */ + for (lane = 0; lane < lane_count; lane++) { + current_total_delay[lane] = (rank0_current_total_delay[lane] + current_total_delay[lane]) / 2; + if (lane == 8) + pDCTstat->CH_D_BC_RCVRDLY[Channel][dimm] = current_total_delay[lane]; + else + pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane] = current_total_delay[lane]; + } + write_dqs_receiver_enable_control_registers(current_total_delay, dev, Channel, dimm, index_reg); + } + } else { + /* Save the current delay for later use by other routines */ for (lane = 0; lane < lane_count; lane++) { - current_total_delay[lane] = (rank0_current_total_delay[lane] + current_total_delay[lane]) / 2; if (lane == 8) pDCTstat->CH_D_BC_RCVRDLY[Channel][dimm] = current_total_delay[lane]; else pDCTstat->CH_D_B_RCVRDLY[Channel][dimm][lane] = current_total_delay[lane]; } - write_dqs_receiver_enable_control_registers(current_total_delay, dev, Channel, dimm, index_reg); } }
