Bora Guvendik (bora.guvendik@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14897
commit 8a53efff8dfe1f3e9b56a4b97b96eed480c60f04 Author: Bora Guvendik bora.guvendik@intel.com Date: Wed May 18 14:56:27 2016 -0700
WIP: intel/amenia: Add changes for image assembly
Insert bootblock Build base images for different variants Generate fmd files for different variants
BUG=chrome-os-partner:51844 BRANCH=none TEST=boots to chrome OS
Change-Id: I0e92858486ecf4720b8bcdf64bae97d9476caabc Signed-off-by: Bora Guvendik bora.guvendik@intel.com --- src/mainboard/intel/amenia/Kconfig | 17 +++++++++++++++-- src/soc/intel/apollolake/Makefile.inc | 5 +++++ 2 files changed, 20 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/intel/amenia/Kconfig b/src/mainboard/intel/amenia/Kconfig index ec76119..bfc4091 100644 --- a/src/mainboard/intel/amenia/Kconfig +++ b/src/mainboard/intel/amenia/Kconfig @@ -35,9 +35,22 @@ config FMAP_FILE string default "amenia"
-config PREBUILT_SPI_IMAGE +config HAVE_IFD_BIN + default y + +config APOLLOLAKE_A0 + bool + default y + +config IFD_BIN_PATH + string "Path and filename of the descriptor.bin file" + default "3rdparty/blobs/baseboard-reef/reef.bin.orig.a0" if APOLLOLAKE_A0 + default "3rdparty/blobs/baseboard-reef/reef.bin.orig.b0" if !APOLLOLAKE_A0 + +config FMDFILE string - default "amenia.bin.orig.a0" + default "3rdparty/blobs/baseboard-reef/reef.bin.orig.a0.fmd" if APOLLOLAKE_A0 + default "3rdparty/blobs/baseboard-reef/reef.bin.orig.b0.fmd" if !APOLLOLAKE_A0
config IFD_BIOS_END hex diff --git a/src/soc/intel/apollolake/Makefile.inc b/src/soc/intel/apollolake/Makefile.inc index 80617a7..db8addf 100644 --- a/src/soc/intel/apollolake/Makefile.inc +++ b/src/soc/intel/apollolake/Makefile.inc @@ -66,4 +66,9 @@ files_added:: $(CBFSTOOL) $(obj)/coreboot.rom write -r $(CONFIG_LBP2_FMAP_NAME) -f $(CONFIG_LBP2_FILE_NAME) --fill-upward endif
+build_complete:: + $(CBFSTOOL) $(obj)/coreboot.rom write \ + -r bootblock \ + -f $(objcbfs)/bootblock.bin + endif
