Attention is currently required from: Felix Singer, Martin L Roth.
Hello Felix Singer, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/79067?usp=email
The following approvals got outdated and were removed: Verified-1 by build bot (Jenkins)
Change subject: util/docker: Switch back to root user in jenkins-node ......................................................................
Leaving the user as coreboot caused the entrypoint to run as coreboot, which means we couldn't mount directories or run sshd correctly.
Switching to root at the end of the file fixes this.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: Ie10e1d7ad4def0faafe3bcd580a77e23c3bfe948 --- M util/docker/coreboot-jenkins-node/Dockerfile 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/79067/2
