Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52859 )
Change subject: mb/google/brya: enable DPTF functionality for brya ......................................................................
Enable DPTF functionality for Alder Lake based brya
BRANCH=None BUG=b:188028732 TEST=Built and tested on brya board
Change-Id: I33266c85aa30869466034ccbab04a3c7820ae2b0 Signed-off-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/52859 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/variants/baseboard/devicetree.cb M src/mainboard/google/brya/variants/brya0/overridetree.cb 3 files changed, 88 insertions(+), 0 deletions(-)
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index a910cc7..faa5335 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -5,6 +5,7 @@ select DRIVERS_I2C_HID select DRIVERS_GENERIC_MAX98357A select DRIVERS_I2C_SX9324 + select DRIVERS_INTEL_DPTF select DRIVERS_INTEL_PMC select DRIVERS_SPI_ACPI select DRIVERS_WIFI_GENERIC diff --git a/src/mainboard/google/brya/variants/baseboard/devicetree.cb b/src/mainboard/google/brya/variants/baseboard/devicetree.cb index e7a6ed3..16678cb 100644 --- a/src/mainboard/google/brya/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/brya/variants/baseboard/devicetree.cb @@ -17,6 +17,14 @@ # S0ix enable register "s0ix_enable" = "1"
+ # DPTF enable + register "dptf_enable" = "1" + + register "power_limits_config" = "{ + .tdp_pl1_override = 15, + .tdp_pl2_override = 55, + }" + # This disabled autonomous GPIO power management, otherwise # old cr50 FW only supports short pulses; need to clarify # the minimum PCH IRQ pulse width with Intel, b/180111628 diff --git a/src/mainboard/google/brya/variants/brya0/overridetree.cb b/src/mainboard/google/brya/variants/brya0/overridetree.cb index b5679c8..f56b8d6 100644 --- a/src/mainboard/google/brya/variants/brya0/overridetree.cb +++ b/src/mainboard/google/brya/variants/brya0/overridetree.cb @@ -6,6 +6,85 @@ register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC_SKIP)" # USB3/2 Type A MLB port
device domain 0 on + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""DRAM"" + register "options.tsr[1].desc" = ""Charger"" + + # TODO: below values are initial reference values only + ## Active Policy + register "policies.active" = "{ + [0] = { + .target = DPTF_CPU, + .thresholds = { + TEMP_PCT(85, 90), + TEMP_PCT(80, 80), + TEMP_PCT(75, 70), + } + } + }" + + ## Passive Policy + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 95, 5000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 75, 5000), + [2] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_1, 75, 5000), + }" + + ## Critical Policy + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 105, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 85, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 85, SHUTDOWN), + }" + + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 3000, + .max_power = 15000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 200, + }, + .pl2 = { + .min_power = 55000, + .max_power = 55000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 1700 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + + ## Fan Performance Control (Percent, Speed, Noise, Power) + register "controls.fan_perf" = "{ + [0] = { 90, 6700, 220, 2200, }, + [1] = { 80, 5800, 180, 1800, }, + [2] = { 70, 5000, 145, 1450, }, + [3] = { 60, 4900, 115, 1150, }, + [4] = { 50, 3838, 90, 900, }, + [5] = { 40, 2904, 55, 550, }, + [6] = { 30, 2337, 30, 300, }, + [7] = { 20, 1608, 15, 150, }, + [8] = { 10, 800, 10, 100, }, + [9] = { 0, 0, 0, 50, } + }" + + ## Fan options + register "options.fan.fine_grained_control" = "1" + register "options.fan.step_size" = "2" + + device generic 0 on end + end + end device ref cnvi_wifi on chip drivers/wifi/generic register "wake" = "GPE0_PME_B0"
