Attention is currently required from: Kyösti Mälkki, Patrick Rudolph.
Hello Kyösti Mälkki, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/78228?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Kyösti Mälkki, Verified+1 by build bot (Jenkins)
Change subject: sb/intel/bd82x6x: Improve SLCAP ......................................................................
- Use pci_find_capability() and defines from pci_def.h - Set the 'Hotplug Capable' bit and 'Hot Plug Surprise' bit in SLCAP for hotplugable PCIe slots. - Assign unique slot number and set power limit for PCIe root ports that have a slot connected. For integrated devices clear slot number and power limit.
Test: System still boots and all PCIe devices are working.
Change-Id: I03aeb0a1ff0041901acc20fe700d3f7995d22366 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/southbridge/intel/bd82x6x/pcie.c 1 file changed, 27 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/78228/5
