Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78307?usp=email )
Change subject: soc/amd/genoa: add root complex support code ......................................................................
This functionality will eventually be used by the common data fabric domain resource reporting code.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ieedd432c144e53e43d8099ec617a15056bb36fd1 Reviewed-on: https://review.coreboot.org/c/coreboot/+/78307 Reviewed-by: Eric Lai ericllai@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/genoa/Makefile.inc A src/soc/amd/genoa/root_complex.c 2 files changed, 63 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Eric Lai: Looks good to me, approved
diff --git a/src/soc/amd/genoa/Makefile.inc b/src/soc/amd/genoa/Makefile.inc index ef8f349..2877fea 100644 --- a/src/soc/amd/genoa/Makefile.inc +++ b/src/soc/amd/genoa/Makefile.inc @@ -14,6 +14,7 @@
ramstage-y += aoac.c ramstage-y += chip.c +ramstage-y += root_complex.c
CPPFLAGS_common += -I$(src)/soc/amd/genoa/include
diff --git a/src/soc/amd/genoa/root_complex.c b/src/soc/amd/genoa/root_complex.c new file mode 100644 index 0000000..7dd1f82 --- /dev/null +++ b/src/soc/amd/genoa/root_complex.c @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <amdblocks/data_fabric.h> +#include <amdblocks/root_complex.h> +#include <console/console.h> +#include <device/device.h> +#include <types.h> + +uint32_t get_iohc_misc_smn_base(struct device *domain) +{ + switch (domain->path.domain.domain) { + case 0: + return SMN_IOHC_MISC_BASE_13C1; + case 1: + return SMN_IOHC_MISC_BASE_13B1; + case 2: + return SMN_IOHC_MISC_BASE_13E1; + case 3: + return SMN_IOHC_MISC_BASE_13D1; + default: + printk(BIOS_ERR, "Invalid domain 0x%x with no corresponding IOHC device.\n", + domain->path.domain.domain); + return 0; + } +} + +static const struct non_pci_mmio_reg non_pci_mmio[] = { + { 0x2d8, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + { 0x2e0, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + { 0x2e8, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + /* The hardware has a 256 byte alignment requirement for the IOAPIC MMIO base, but we + tell the FSP to configure a 4k-aligned base address and this is reported as 4 KiB + resource. */ + { 0x2f0, 0xffffffffff00ull, 4 * KiB, IOMMU_IOAPIC_IDX }, + { 0x2f8, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + { 0x300, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + { 0x308, 0xfffffffff000ull, 4 * KiB, NON_PCI_RES_IDX_AUTO }, + { 0x310, 0xfffffff00000ull, 1 * MiB, NON_PCI_RES_IDX_AUTO }, + { 0x318, 0xfffffff80000ull, 512 * KiB, NON_PCI_RES_IDX_AUTO }, +}; + +const struct non_pci_mmio_reg *get_iohc_non_pci_mmio_regs(size_t *count) +{ + *count = ARRAY_SIZE(non_pci_mmio); + return non_pci_mmio; +} + +signed int get_iohc_fabric_id(struct device *domain) +{ + switch (domain->path.domain.domain) { + case 0: + return 0x22; + case 1: + return 0x23; + case 2: + return 0x21; + case 3: + return 0x20; + default: + return -1; + } +}
