Attention is currently required from: Ana Carolina Cabral, Felix Held, Martin L Roth, Maximilian Brune, Patrick Rudolph.
Hello Ana Carolina Cabral, Martin L Roth, Maximilian Brune, Patrick Rudolph, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/87277?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Maximilian Brune, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: soc/amd: report I3C controller MMIO to resource allocator ......................................................................
Add minimal common AMD I3C controller code that reports the MMIO region used by the different I3C controllers to the resource allocator. For this to work, select the introduced SOC_AMD_COMMON_BLOCK_I3C Kconfig option and add the 'soc_amd_i3c_mmio_ops' device operations to the I3C device devicetree entries on all SoCs that include I3C controllers.
Change-Id: Iebf709d2548f2535b2a2a03a4f6da9531559c238 Signed-off-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/common/block/i2c/Kconfig M src/soc/amd/common/block/i2c/Makefile.mk A src/soc/amd/common/block/i2c/i3c.c M src/soc/amd/genoa_poc/Kconfig M src/soc/amd/genoa_poc/chipset.cb M src/soc/amd/glinda/Kconfig M src/soc/amd/glinda/chipset.cb M src/soc/amd/mendocino/Kconfig M src/soc/amd/mendocino/chipset_mendocino.cb M src/soc/amd/mendocino/chipset_rembrandt.cb M src/soc/amd/phoenix/Kconfig M src/soc/amd/phoenix/chipset_fsp.cb M src/soc/amd/phoenix/chipset_opensil.cb 13 files changed, 47 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/77/87277/2
